[PATCH v2 1/6] Imported files for driver: bcm283x_dwcotg
Tue Aug 23 13:38:22 UTC 2016
I updated the MMC support to use the FreeBSD trunk, 2016-08-23,
9fe7c416e6abb28b1398fd3e5687099846800cfd. It would be great if you can
use this version as well as a baseline for your work.
On 22/08/16 10:37, Deval Shah wrote:
> On Mon, Aug 22, 2016 at 11:25 AM, Sebastian Huber
> <sebastian.huber at embedded-brains.de
> <mailto:sebastian.huber at embedded-brains.de>> wrote:
>     If you think the guidelines could be more clear, need an
>     explanation or examples, then we should address this first.
> I could use some examples on the last rule " Do not disable option
> header includes via guards.  Instead, add an empty option header, e.g.
> `rtemsbsd/include/rtems/bsd/local/opt_xyz.h`.  In general, provide
> empty header files and do not guard includes. "
Ok, I updated the libbsd.txt.
Phone   : +49 89 189 47 41-16
Fax     : +49 89 189 47 41-09
