[PATCH] Added interrupt handler for DMA channel 0, 1 & 2
Mudit Jain
muditjain18011995 at gmail.com
Tue Aug 23 15:19:02 UTC 2016
Hi Pavel,
I have the latest GIT master synced and have cherry-picked my changes on
top of that.
Regarding the change you have suggested :
DMA : https://github.com/spark1729/rtems/commits/DMA_RPI
Mailbox : https://github.com/spark1729/rtems/commits/MAILBOX_RPI
Is this what you suggested right ?
I have updated the blog with the information regarding the patches
submitted : Blog <http://rtemsgsoc2016-mudit.blogspot.in/>
This also has information on the status as well as the plan of action in
the future.
Blog Posts :
Regarding DMA : Link
<http://rtemsgsoc2016-mudit.blogspot.in/2016/08/dma-direct-memory-access-for-rpi.html?view=flipcard>
Regarding SD card Driver : Link
<http://rtemsgsoc2016-mudit.blogspot.in/2016/08/porting-sd-card-driver-from-freebsd-to.html?view=flipcard>
Regarding Mailbox : Link
<http://rtemsgsoc2016-mudit.blogspot.in/2016/08/mailbox-interface-for-rpi.html?view=flipcard>
Thanks
Mudit Jain
On Mon, Aug 22, 2016 at 3:47 AM, Pavel Pisa <ppisa4lists at pikron.com> wrote:
> Hello Mudit,
> please, send information what is RTEMS GIT revision are
> your changes based on. See comment below
> On Saturday 20 of August 2016 17:04:19 Mudit Jain wrote:
> > Added macros for DMA channels 0-12
> > Added interrupt handlers for DMA 0, 1 & 2
> > The added IRQs are in accordance with the
> > BCM Peripherals Datasheet and also have been verified
> > with the linux source code for RPi
> > c/src/lib/libbsp/arm/raspberrypi/include/irq.h | 17 ++++++++++
> > c/src/lib/libbsp/arm/raspberrypi/irq/irq.c | 45
> > ++++++++++++++++++++++++++ 2 files changed, 62 insertions(+)
> > diff --git a/c/src/lib/libbsp/arm/raspberrypi/include/irq.h
> > b/c/src/lib/libbsp/arm/raspberrypi/include/irq.h index 8436c2d..50616e1
> > 100644
> > --- a/c/src/lib/libbsp/arm/raspberrypi/include/irq.h
> > +++ b/c/src/lib/libbsp/arm/raspberrypi/include/irq.h
> > @@ -35,6 +35,23 @@
> > #define BCM2835_INTC_TOTAL_IRQ 64 + 8
> > +/* DMA Interrupt is routed to IRQ 16 for DMA Channel 0,
> > + IRQ 17 for Channel 1, and so on till IRQ 28 for Channel 12.
> > +#define BCM2835_IRQ_ID_DMA_CH0 16
> > +#define BCM2835_IRQ_ID_DMA_CH1 17
> > +#define BCM2835_IRQ_ID_DMA_CH2 18
> > +#define BCM2835_IRQ_ID_DMA_CH3 19
> > +#define BCM2835_IRQ_ID_DMA_CH4 20
> > +#define BCM2835_IRQ_ID_DMA_CH5 21
> > +#define BCM2835_IRQ_ID_DMA_CH6 22
> > +#define BCM2835_IRQ_ID_DMA_CH7 23
> > +#define BCM2835_IRQ_ID_DMA_CH8 24
> > +#define BCM2835_IRQ_ID_DMA_CH9 25
> > +#define BCM2835_IRQ_ID_DMA_CH10 26
> > +#define BCM2835_IRQ_ID_DMA_CH11 27
> > +#define BCM2835_IRQ_ID_DMA_CH12 28
> > #define BCM2835_IRQ_ID_AUX 29
> > #define BCM2835_IRQ_ID_SPI_SLAVE 43
> > diff --git a/c/src/lib/libbsp/arm/raspberrypi/irq/irq.c
> > b/c/src/lib/libbsp/arm/raspberrypi/irq/irq.c index 7b3b2be..3279b35
> 100644
> > --- a/c/src/lib/libbsp/arm/raspberrypi/irq/irq.c
> > +++ b/c/src/lib/libbsp/arm/raspberrypi/irq/irq.c
> > @@ -64,6 +64,21 @@ void bsp_interrupt_dispatch(void)
> > vector = BCM2835_IRQ_ID_UART;
> > + /* DMA 0 */
> > + else if ( BCM2835_REG(BCM2835_IRQ_PENDING1) & BCM2835_BIT(16) )
> > + vector = BCM2835_IRQ_ID_DMA_CH0;
> > + /* DMA 1 */
> > + else if ( BCM2835_REG(BCM2835_IRQ_PENDING1) & BCM2835_BIT(17) )
> > + vector = BCM2835_IRQ_ID_DMA_CH1;
> > + /* DMA 2 */
> > + else if ( BCM2835_REG(BCM2835_IRQ_PENDING1) & BCM2835_BIT(18) )
> > + vector = BCM2835_IRQ_ID_DMA_CH2;
> I hope, I have eliminated need for all these individual peripherals
> specific code in raspberrypi/irq/irq.c .
> See the commit
> https://git.rtems.org/rtems/commit/c/src/lib/libbsp/arm/
> raspberrypi/irq/irq.c?id=d216c5d6a2325551accb836429a6ac9cc2b2f4b7
> Try rebase your changes for other files to actual RTEMS GIT master.
> If there is some problem which prevents to your code to run
> with master then it is necessary to find what is broken
> on master. I try to help with it.
> May it be that there is some problem with irq.c code, I have
> tested it only by timer IRQ because other are not used by mater yet.
> But code written the way that it should be fully generic by now.
> It should support all 72 interrupt sources.
> > /* GPIO 0*/
> > else if ( BCM2835_REG(BCM2835_IRQ_PENDING2) & BCM2835_BIT(17) )
> > @@ -114,6 +129,21 @@ rtems_status_code
> > bsp_interrupt_vector_enable(rtems_vector_number vector) {
> > BCM2835_REG(BCM2835_IRQ_ENABLE2) = BCM2835_BIT(25);
> > + /* DMA 0 */
> > + else if ( vector == BCM2835_IRQ_ID_DMA_CH0 )
> > + BCM2835_REG(BCM2835_IRQ_ENABLE1) = BCM2835_BIT(16);
> > + /* DMA 1 */
> > + else if ( vector == BCM2835_IRQ_ID_DMA_CH1 )
> > + BCM2835_REG(BCM2835_IRQ_ENABLE1) = BCM2835_BIT(17);
> > + /* DMA 2 */
> > + else if ( vector == BCM2835_IRQ_ID_DMA_CH2 )
> > + BCM2835_REG(BCM2835_IRQ_ENABLE1) = BCM2835_BIT(18);
> Should be solved by master already.
> > /* GPIO 0 */
> > else if ( vector == BCM2835_IRQ_ID_GPIO_0 )
> > @@ -164,6 +194,21 @@ rtems_status_code
> > bsp_interrupt_vector_disable(rtems_vector_number vector) {
> > BCM2835_REG(BCM2835_IRQ_DISABLE2) = BCM2835_BIT(25);
> > + /* DMA 0 */
> > + BCM2835_REG(BCM2835_IRQ_DISABLE1) = BCM2835_BIT(16);
> > + /* DMA 1 */
> > + BCM2835_REG(BCM2835_IRQ_DISABLE1) = BCM2835_BIT(17);
> > + /* DMA 2 */
> > + BCM2835_REG(BCM2835_IRQ_DISABLE1) = BCM2835_BIT(18);
> > /* GPIO 0 */
> If you have problem with rebase then you can format patch,
> use editor to delete parts concerning files which should
> be untouched, then reset some branch back before patch series
> or to master and then apply modified patches.
> Again, I can help.
> I would be happy if you write some summary about testing, which
> attempts has been done, what worked, what failed and what has
> not been tested. Ideally, it should be done for work
> on your branch before rebase and after rebase to master.
> Best wishes,
> Pavel
URL: <http://lists.rtems.org/pipermail/devel/attachments/20160823/fa28ada2/attachment-0001.html>
