Fwd: rtems interrupt
Ярослав Лещинский midniwalker at gmail.com
Wed Aug 24 18:46:37 UTC 2016
Hi everyone. I need help with interrupt manager for stm32f4. Here is my
test project https://github.com/MiDWalkeR/try_rtems. I took example code
from hello_world_c and modify it: added my own drivers for exti and gpio.
Drivers was checked without rtems and working well.
Board - stm32f446re.
When i flash my device in terminal i see code line number from
exti_event.c, that means that task is working. When i push the button all
breaks down only reset can help. When i enable my own exti interrupt method
without rtems_interrupt_handler_install and push the button in terminal i
get the string "spurious interrupt: 40". - that means interrupt was
detected.
How correct should i config interrupt manager?
It's looks like i'm making some stupid mistake(-s), but don't see them...
Thanks for any advice.
С уважением, Лещинский Ярослав.
+79814031224
+79814031224
URL: <http://lists.rtems.org/pipermail/devel/attachments/20160824/3967c6ec/attachment.html>
