[PATCH v2 2/2] libbsp/arm: Fix the local interrupt mask disable/enable calls.
Pavel Pisa ppisa4lists at pikron.com
Thu Aug 25 17:47:03 UTC 2016
Hello Gedare,
On Thursday 25 of August 2016 17:32:09 Gedare Bloom wrote:
> On Thu, Aug 25, 2016 at 6:56 AM, Pavel Pisa <ppisa4lists at pikron.com> wrote:
> >   Is there some defined function/way to check if RTEMS executive
> >   reached switch to multitasking mode?
> _System_state_Is_before_multitasking()
Thanks, great that is what I have been looking for.
> > This has impact to think about correct locking in functions
> > which are required to be used during startup when there is
> > no concurrent execution but mutexes support and memory initialization
> > is not finished yet but the same functions can be used later
> > when scheduler is running for further update of system state.
> > More complete analysis and context in previous communication.
> I read prior discussion and had no problems, but Sebastian's concern
> should be addressed whether other ARM targets are correct or not.
His (correct) concern has been about SMP.
But I think that need of locking has been eliminated by my previous commit.
There is another reason against locking by IRQ disable or spinlock.
If we consider update of pagetables at runtime where some real time tasks
run then if scheduler is blocked but change in large part of address space
then we can consider this as almost unbound latency source.
So I vote for no locking at this level at all and mutex based locking
(skipped if part of initialization and _System_state_Is_before_multitasking)
at higher level when concurrent use need arises - for example allocation
of virtual address space for mmap or something similar.
Best wishes,
             Pavel
