[PATCH v2] Mailbox : Extending functionality
Mudit Jain
muditjain18011995 at gmail.com
Sat Aug 27 06:15:04 UTC 2016
Adding functionality to get board serial,
power state & clock rate
c/src/lib/libbsp/arm/raspberrypi/include/vc.h | 17 +++++
c/src/lib/libbsp/arm/raspberrypi/misc/vc.c | 78 ++++++++++++++++++++++
c/src/lib/libbsp/arm/raspberrypi/misc/vc_defines.h | 35 ++++++++++
3 files changed, 130 insertions(+)
diff --git a/c/src/lib/libbsp/arm/raspberrypi/include/vc.h b/c/src/lib/libbsp/arm/raspberrypi/include/vc.h
index 00414ff..e863732 100644
--- a/c/src/lib/libbsp/arm/raspberrypi/include/vc.h
+++ b/c/src/lib/libbsp/arm/raspberrypi/include/vc.h
@@ -106,6 +106,8 @@ typedef struct {
#define BCM2835_MAILBOX_POWER_STATE_NODEV ( 1 << 1 )
int bcm2835_mailbox_set_power_state( bcm2835_set_power_state_entries *_entries );
+int bcm2835_mailbox_get_power_state( bcm2835_set_power_state_entries *_entries );
typedef struct {
uint32_t base;
size_t size;
@@ -135,6 +137,21 @@ int bcm2835_mailbox_get_board_model( bcm2835_get_board_spec_entries *_entries );
int bcm2835_mailbox_get_board_revision(
+typedef struct {
+ uint64_t board_serial;
+} bcm2835_get_board_serial_entries;
+int bcm2835_mailbox_get_board_serial(
+ bcm2835_get_board_serial_entries *_entries );
+typedef struct {
+ uint32_t clock_id;
+ uint32_t clock_rate;
+} bcm2835_get_clock_rate_entries;
+int bcm2835_mailbox_get_clock_rate(
+ bcm2835_get_clock_rate_entries *_entries );
#endif /* LIBBSP_ARM_RASPBERRYPI_VC_H */
diff --git a/c/src/lib/libbsp/arm/raspberrypi/misc/vc.c b/c/src/lib/libbsp/arm/raspberrypi/misc/vc.c
index 2fff70b..249ea1e 100644
--- a/c/src/lib/libbsp/arm/raspberrypi/misc/vc.c
+++ b/c/src/lib/libbsp/arm/raspberrypi/misc/vc.c
@@ -242,6 +242,32 @@ int bcm2835_mailbox_get_cmdline( bcm2835_get_cmdline_entries *_entries )
return 0;
+ struct BCM2835_MBOX_BUF_ALIGN_ATTRIBUTE {
+ bcm2835_mbox_buf_hdr hdr;
+ bcm2835_mbox_tag_get_power_state get_power_state;
+ uint32_t end_tag;
+ uint32_t padding_reserve[16];
+ } buffer;
+ BCM2835_MBOX_INIT_BUF( &buffer );
+ BCM2835_MBOX_INIT_TAG( &buffer.get_power_state,
+ BCM2835_MAILBOX_TAG_GET_POWER_STATE );
+ buffer.get_power_state.body.req.dev_id = _entries->dev_id;
+ bcm2835_mailbox_buffer_flush_and_invalidate( &buffer, sizeof( &buffer ) );
+ if ( bcm2835_mailbox_send_read_buffer( &buffer ) )
+ return -1;
+ _entries->dev_id = buffer.get_power_state.body.resp.dev_id;
+ _entries->state = buffer.get_power_state.body.resp.state;
+ if ( !bcm2835_mailbox_buffer_suceeded( &buffer.hdr ) )
+ return -2;
+ return 0;
@@ -407,3 +433,55 @@ int bcm2835_mailbox_get_board_revision(
return 0;
+ bcm2835_mbox_tag_get_board_serial get_board_serial;
+ uint32_t end_tag;
+ } buffer;
+ BCM2835_MBOX_INIT_TAG_NO_REQ( &buffer.get_board_serial,
+ BCM2835_MAILBOX_TAG_GET_BOARD_SERIAL );
+ return -1;
+ _entries->board_serial = buffer.get_board_serial.body.resp.board_serial;
+ return -2;
+ return 0;
+ bcm2835_mbox_tag_get_clock_rate get_clock_rate;
+ uint32_t end_tag;
+ } buffer;
+ BCM2835_MBOX_INIT_TAG_NO_REQ( &buffer.get_clock_rate,
+ BCM2835_MAILBOX_TAG_GET_CLOCK_RATE );
+ buffer.get_clock_rate.body.req.clock_id = _entries->clock_id;
+ return -1;
+ _entries->clock_id = buffer.get_clock_rate.body.resp.clock_id;
+ _entries->clock_rate = buffer.get_clock_rate.body.resp.clock_rate;
+ return -2;
+ return 0;
diff --git a/c/src/lib/libbsp/arm/raspberrypi/misc/vc_defines.h b/c/src/lib/libbsp/arm/raspberrypi/misc/vc_defines.h
index bc901b4..9725445 100644
--- a/c/src/lib/libbsp/arm/raspberrypi/misc/vc_defines.h
+++ b/c/src/lib/libbsp/arm/raspberrypi/misc/vc_defines.h
@@ -182,6 +182,17 @@ typedef struct {
#define BCM2835_MAILBOX_TAG_GET_BOARD_MAC 0x00010003
#define BCM2835_MAILBOX_TAG_GET_BOARD_SERIAL 0x00010004
+typedef struct {
+ bcm2835_mbox_tag_hdr tag_hdr;
+ union {
+ struct {
+ } req;
+ struct {
+ } resp;
+ } body;
+} bcm2835_mbox_tag_get_board_serial;
#define BCM2835_MAILBOX_TAG_GET_ARM_MEMORY 0x00010005
typedef struct {
@@ -209,6 +220,18 @@ typedef struct {
} bcm2835_mbox_tag_get_vc_memory;
#define BCM2835_MAILBOX_TAG_GET_CLOCKS 0x00010007
+typedef struct {
+ union {
+ struct {
+ } req;
+ struct {
+ } resp;
+ } body;
+} bcm2835_mbox_tag_get_clock_rate;
/* Config */
#define BCM2835_MAILBOX_TAG_GET_CMD_LINE 0x00050001
@@ -238,6 +261,18 @@ typedef struct {
#define BCM2835_MAILBOX_POWER_UDID_CCP2TX 0x00000008
#define BCM2835_MAILBOX_TAG_GET_POWER_STATE 0x00020001
+typedef struct {
+ union {
+ struct {
+ uint32_t dev_id;
+ } req;
+ struct {
+ uint32_t dev_id;
+ uint32_t state;
+ } resp;
+ } body;
+} bcm2835_mbox_tag_get_power_state;
#define BCM2835_MAILBOX_POWER_STATE_RESP_ON (1 << 0)
#define BCM2835_MAILBOX_POWER_STATE_RESP_NODEV (1 << 1)
2.1.4
