[PATCH v2 1/6] Imported files for driver: bcm283x_dwcotg
Deval Shah
deval.maker at gmail.com
Sat Aug 27 11:16:50 UTC 2016
On Tue, Aug 23, 2016 at 7:08 PM, Sebastian Huber <
> I updated the MMC support to use the FreeBSD trunk, 2016-08-23,
> 9fe7c416e6abb28b1398fd3e5687099846800cfd. It would be great if you can
> use this version as well as a baseline for your work.
Is it okay if I provide a new patch (not resend in the previous ones)
updating the code ?
> On 22/08/16 10:37, Deval Shah wrote:
>> On Mon, Aug 22, 2016 at 11:25 AM, Sebastian Huber <
>> sebastian.huber at embedded-brains.de <mailto:sebastian.huber at embedd
>> ed-brains.de>> wrote:
>> If you think the guidelines could be more clear, need an
>> explanation or examples, then we should address this first.
>> I could use some examples on the last rule " Do not disable option header
>> includes via guards. Instead, add an empty option header, e.g.
>> `rtemsbsd/include/rtems/bsd/local/opt_xyz.h`. In general, provide empty
>> header files and do not guard includes. "
> Ok, I updated the libbsd.txt.
> I have a small doubt here.
https://git.rtems.org/rtems-libbsd/tree/libbsd.txt#n654
Do I have to provide all the headers which I want to ignore, with an empty
file as mentioned or only the ones which are transformed by the import
script ?
For example includes like these. "#include <dev/ofw/ofw_bus_subr.h>"
> Phone : +49 89 189 47 41-16
> Fax : +49 89 189 47 41-09
Deval Shah
Graduate Student,
B.E. (Hons.) Electrical and Electronics Engineering
BITS Pilani Hyderabad Campus <http://www.bits-pilani.ac.in/hyderabad/>
Github Profile <https://github.com/deval-maker>
ᐧ
URL: <http://lists.rtems.org/pipermail/devel/attachments/20160827/12b3fb3b/attachment.html>
