[PATCH 2/2] libmisc/capture: Removal all use of the reserved _t in types.
Tue Aug 30 08:07:07 UTC 2016
 cpukit/libmisc/capture/capture-cli.c            |  82 ++++++-------
 cpukit/libmisc/capture/capture.c                | 148 +++++++++++-------------
 cpukit/libmisc/capture/capture.h                | 139 +++++++++++-----------
 cpukit/libmisc/capture/capture_buffer.c         |  10 +-
 cpukit/libmisc/capture/capture_buffer.h         |  22 ++--
 cpukit/libmisc/capture/capture_support.c        |  62 +++++-----
 cpukit/libmisc/capture/capture_user_extension.c |  46 ++++----
 cpukit/libmisc/capture/captureimpl.h            |  22 ++--
 8 files changed, 256 insertions(+), 275 deletions(-)
diff --git a/cpukit/libmisc/capture/capture-cli.c b/cpukit/libmisc/capture/capture-cli.c
index d2ee383..05c922b 100644
--- a/cpukit/libmisc/capture/capture-cli.c
+++ b/cpukit/libmisc/capture/capture-cli.c
@@ -111,7 +111,7 @@ rtems_capture_cli_open (int                                argc,
   if (!enable)
     return;
-  sc = rtems_capture_control (enable);
+  sc = rtems_capture_set_control (enable);
   if (sc != RTEMS_SUCCESSFUL)
@@ -161,7 +161,7 @@ rtems_capture_cli_enable (int                                argc RC_UNUSED,
   rtems_status_code sc;
-  sc = rtems_capture_control (true);
+  sc = rtems_capture_set_control (true);
@@ -186,7 +186,7 @@ rtems_capture_cli_disable (int                                argc RC_UNUSED,
-  sc = rtems_capture_control (false);
+  sc = rtems_capture_set_control (false);
@@ -270,9 +270,9 @@ rtems_capture_cli_task_list (int                                argc RC_UNUSED,
                              const rtems_monitor_command_arg_t* command_arg RC_UNUSED,
                              bool                               verbose RC_UNUSED)
-  rtems_capture_time_t  uptime;
+  rtems_capture_time uptime;
-  rtems_capture_time (&uptime);
+  rtems_capture_get_time (&uptime);
   rtems_capture_cli_task_count = 0;
   rtems_iterate_over_all_threads (rtems_capture_cli_count_tasks);
@@ -710,14 +710,14 @@ static char const *trigger_set_types =
  * Structure to handle the parsing of the trigger command line.
-typedef struct rtems_capture_cli_triggers_s
+typedef struct rtems_capture_cli_triggers
-  char const *            name;
-  rtems_capture_trigger_t type;
-  int                     to_only;
-} rtems_capture_cli_triggers_t;
+  char const *          name;
+  rtems_capture_trigger type;
+  int                   to_only;
+} rtems_capture_cli_triggers;
-static rtems_capture_cli_triggers_t rtems_capture_cli_triggers[] =
+static const rtems_capture_cli_triggers rtems_capture_cli_trigger[] =
   { "switch",  rtems_capture_switch,  0 }, /* must be first */
   { "create",  rtems_capture_create,  0 },
@@ -728,39 +728,39 @@ static rtems_capture_cli_triggers_t rtems_capture_cli_triggers[] =
   { "exitted", rtems_capture_exitted, 1 }
-typedef enum rtems_capture_cli_trig_state_e
+typedef enum rtems_capture_cli_trig_state
   trig_type,
   trig_to,
   trig_from_from,
   trig_from
-} rtems_capture_cli_trig_state_t;
+} rtems_capture_cli_trig_state;
 #define RTEMS_CAPTURE_CLI_TRIGGERS_NUM \
-  (sizeof (rtems_capture_cli_triggers) / sizeof (rtems_capture_cli_triggers_t))
+  (sizeof (rtems_capture_cli_trigger) / sizeof (rtems_capture_cli_triggers))
 static void
 rtems_capture_cli_trigger_worker (int set, int argc, char** argv)
-  rtems_status_code            sc;
-  int                          arg;
-  int                          trigger = 0; /* switch */
-  rtems_capture_trigger_mode_t trigger_mode = rtems_capture_from_any;
-  bool                         trigger_set = false;
-  bool                         is_from = false;
-  bool                         is_to = false;
-  rtems_name                   name = 0;
-  rtems_id                     id = 0;
-  bool                         valid_name = false;
-  bool                         valid_id = false;
-  rtems_name                   from_name = 0;
-  rtems_id                     from_id = 0;
-  bool                         from_valid_name = false;
-  bool                         from_valid_id = false;
-  rtems_name                   to_name = 0;
-  rtems_id                     to_id = 0;
-  bool                         to_valid_name = false;
-  bool                         to_valid_id = false;
+  rtems_status_code          sc;
+  int                        arg;
+  int                        trigger = 0; /* switch */
+  rtems_capture_trigger_mode trigger_mode = rtems_capture_from_any;
+  bool                       trigger_set = false;
+  bool                       is_from = false;
+  bool                       is_to = false;
+  rtems_name                 name = 0;
+  rtems_id                   id = 0;
+  bool                       valid_name = false;
+  bool                       valid_id = false;
+  rtems_name                 from_name = 0;
+  rtems_id                   from_id = 0;
+  bool                       from_valid_name = false;
+  bool                       from_valid_id = false;
+  rtems_name                 to_name = 0;
+  rtems_id                   to_id = 0;
+  bool                       to_valid_name = false;
+  bool                       to_valid_id = false;
   for (arg = 1; arg < argc; arg++)
@@ -785,7 +785,7 @@ rtems_capture_cli_trigger_worker (int set, int argc, char** argv)
         int  t;
         for (t = 0; t < RTEMS_CAPTURE_CLI_TRIGGERS_NUM; t++)
-          if (strcmp (argv[arg], rtems_capture_cli_triggers[t].name) == 0)
+          if (strcmp (argv[arg], rtems_capture_cli_trigger[t].name) == 0)
             trigger = t;
             found = true;
@@ -874,10 +874,10 @@ rtems_capture_cli_trigger_worker (int set, int argc, char** argv)
-  if (is_from && rtems_capture_cli_triggers[trigger].to_only)
+  if (is_from && rtems_capture_cli_trigger[trigger].to_only)
     fprintf (stdout, "error: a %s trigger can be a TO trigger\n",
-             rtems_capture_cli_triggers[trigger].name);
+             rtems_capture_cli_trigger[trigger].name);
     return;
@@ -890,14 +890,14 @@ rtems_capture_cli_trigger_worker (int set, int argc, char** argv)
   if (!is_from && !to_valid_name && !to_valid_id)
     fprintf (stdout, "error: a %s trigger needs a TO name or id\n",
     return;
   if (is_from && !from_valid_name && !from_valid_id)
     fprintf (stdout, "error: a %s trigger needs a FROM name or id\n",
     return;
@@ -911,11 +911,11 @@ rtems_capture_cli_trigger_worker (int set, int argc, char** argv)
   if (set)
     sc = rtems_capture_set_trigger (from_name, from_id, to_name, to_id,
                                     trigger_mode,
-                                    rtems_capture_cli_triggers[trigger].type);
+                                    rtems_capture_cli_trigger[trigger].type);
   else
     sc = rtems_capture_clear_trigger (from_name, from_id, to_name, to_id,
                                       trigger_mode,
@@ -1192,7 +1192,7 @@ rtems_capture_cli_init (rtems_capture_timestamp timestamp)
   for (cmd = 0;
        cmd < sizeof (rtems_capture_cli_cmds) / sizeof (rtems_monitor_command_entry_t);
        cmd++)
-      rtems_monitor_insert_cmd (&rtems_capture_cli_cmds[cmd]);
+    rtems_monitor_insert_cmd (&rtems_capture_cli_cmds[cmd]);
   return RTEMS_SUCCESSFUL;
diff --git a/cpukit/libmisc/capture/capture.c b/cpukit/libmisc/capture/capture.c
index 6cec8a5..6fc2f09 100644
--- a/cpukit/libmisc/capture/capture.c
+++ b/cpukit/libmisc/capture/capture.c
@@ -56,21 +56,21 @@
 #endif
 typedef struct {
-  rtems_capture_buffer_t   records;
-  uint32_t                 count;
-  rtems_id                 reader;
-  rtems_interrupt_lock     lock;
-  uint32_t                 flags;
+  rtems_capture_buffer records;
+  uint32_t             count;
+  rtems_id             reader;
+  rtems_interrupt_lock lock;
+  uint32_t             flags;
 } rtems_capture_per_cpu_data;
 typedef struct {
-  uint32_t                 flags;
-  rtems_capture_control_t* controls;
-  int                      extension_index;
-  rtems_capture_timestamp  timestamp;
-  rtems_task_priority      ceiling;
-  rtems_task_priority      floor;
+  uint32_t                flags;
+  rtems_capture_control*  controls;
+  int                     extension_index;
+  rtems_capture_timestamp timestamp;
+  rtems_task_priority     ceiling;
+  rtems_task_priority     floor;
 } rtems_capture_global_data;
 static rtems_capture_per_cpu_data  *capture_per_cpu = NULL;
@@ -145,7 +145,7 @@ void rtems_capture_set_flags(uint32_t mask)
  * by the user get the time from that.
 void
-rtems_capture_get_time (rtems_capture_time_t* time)
+rtems_capture_get_time (rtems_capture_time* time)
   if (capture_timestamp)
     capture_timestamp (time);
@@ -221,9 +221,9 @@ rtems_capture_dup_name (rtems_name* dst, rtems_name src)
  * tasks is the number of bits in uint32_t.
 static inline bool
-rtems_capture_by_in_to (uint32_t                 events,
-                        rtems_tcb*               by,
-                        rtems_capture_control_t* to)
+rtems_capture_by_in_to (uint32_t               events,
+                        rtems_tcb*             by,
+                        rtems_capture_control* to)
   uint32_t valid_mask = RTEMS_CAPTURE_CONTROL_FROM_MASK (0);
   uint32_t valid_remainder = 0xffffffff;
@@ -265,10 +265,10 @@ rtems_capture_by_in_to (uint32_t                 events,
  * This function searches for a trigger given a name.
-static inline rtems_capture_control_t*
+static inline rtems_capture_control*
 rtems_capture_find_control (rtems_name name, rtems_id id)
-  rtems_capture_control_t* control;
+  rtems_capture_control* control;
   for (control = capture_controls; control != NULL; control = control->next)
     if (rtems_capture_match_name_id (name, id, control->name, control->id))
       break;
@@ -284,9 +284,9 @@ rtems_capture_initialize_control (rtems_tcb *tcb)
   if (tcb->Capture.control == NULL)
-    rtems_name               name = rtems_build_name(0, 0, 0, 0);
-    rtems_id                 id;
+    rtems_name             name = rtems_build_name(0, 0, 0, 0);
+    rtems_id               id;
      * We need to scan the default control list to initialise
@@ -307,11 +307,11 @@ rtems_capture_initialize_control (rtems_tcb *tcb)
-static rtems_capture_control_t*
+static rtems_capture_control*
 rtems_capture_create_control (rtems_name name, rtems_id id)
   rtems_interrupt_lock_context lock_context;
   if ((name == 0) && (id == 0))
     return NULL;
@@ -375,7 +375,7 @@ rtems_capture_record_open (rtems_tcb*                         tcb,
   rtems_capture_per_cpu_data* cpu;
   uint8_t*                    ptr;
-  size += sizeof (rtems_capture_record_t);
+  size += sizeof (rtems_capture_record);
   cpu = capture_per_cpu_get (rtems_get_current_processor ());
@@ -384,7 +384,7 @@ rtems_capture_record_open (rtems_tcb*                         tcb,
   ptr = rtems_capture_buffer_allocate (&cpu->records, size);
   if (ptr != NULL)
-    rtems_capture_record_t in;
+    rtems_capture_record in;
     ++cpu->count;
@@ -419,7 +419,7 @@ rtems_capture_record_close (rtems_capture_record_lock_context* context)
 void
 rtems_capture_initialize_task( rtems_tcb* tcb )
   rtems_id                     id = rtems_capture_task_id (tcb);
@@ -449,7 +449,7 @@ void rtems_capture_record_task (rtems_tcb* tcb)
   rtems_name                        name = rtems_build_name (0, 0, 0, 0);
-  rtems_capture_task_record_t       rec;
+  rtems_capture_task_record         rec;
   void*                             ptr;
   rtems_capture_record_lock_context rec_context;
@@ -486,7 +486,7 @@ bool rtems_capture_filter (rtems_tcb*  tcb, uint32_t events)
         (RTEMS_CAPTURE_TRIGGERED | RTEMS_CAPTURE_ONLY_MONITOR)) ==
        RTEMS_CAPTURE_TRIGGERED))
     control = tcb->Capture.control;
@@ -513,18 +513,18 @@ bool rtems_capture_filter (rtems_tcb*  tcb, uint32_t events)
  * cause of a trigger.
 bool
-rtems_capture_trigger (rtems_tcb* ft, rtems_tcb* tt, uint32_t events)
+rtems_capture_trigger_fired (rtems_tcb* ft, rtems_tcb* tt, uint32_t events)
    * If we have not triggered then see if this is a trigger condition.
   if (!(capture_flags_global & RTEMS_CAPTURE_TRIGGERED))
-    rtems_capture_control_t* fc = NULL;
-    rtems_capture_control_t* tc = NULL;
-    uint32_t                 from_events = 0;
-    uint32_t                 to_events = 0;
-    uint32_t                 from_to_events = 0;
+    rtems_capture_control* fc = NULL;
+    rtems_capture_control* tc = NULL;
+    uint32_t               from_events = 0;
+    uint32_t               to_events = 0;
+    uint32_t               from_to_events = 0;
     if (ft)
@@ -582,10 +582,10 @@ rtems_capture_trigger (rtems_tcb* ft, rtems_tcb* tt, uint32_t events)
 rtems_status_code
 rtems_capture_open (uint32_t   size, rtems_capture_timestamp timestamp RTEMS_UNUSED)
-  rtems_status_code       sc = RTEMS_SUCCESSFUL;
-  size_t                  count;
-  uint32_t                i;
-  rtems_capture_buffer_t* buff;
+  rtems_status_code     sc = RTEMS_SUCCESSFUL;
+  size_t                count;
+  uint32_t              i;
+  rtems_capture_buffer* buff;
    * See if the capture engine is already open.
@@ -639,7 +639,7 @@ rtems_status_code
 rtems_capture_close (void)
   uint32_t                     cpu;
@@ -676,7 +676,7 @@ rtems_capture_close (void)
   while (control)
-    rtems_capture_control_t* delete = control;
+    rtems_capture_control* delete = control;
     control = control->next;
     free (delete);
@@ -696,7 +696,7 @@ rtems_capture_close (void)
 rtems_status_code
-rtems_capture_control (bool enable)
+rtems_capture_set_control (bool enable)
@@ -724,7 +724,7 @@ rtems_capture_control (bool enable)
  * to profile the load on a system.
 rtems_status_code
-rtems_capture_monitor (bool enable)
+rtems_capture_set_monitor (bool enable)
@@ -811,7 +811,7 @@ rtems_capture_flush (bool prime)
 rtems_status_code
 rtems_capture_watch_add (rtems_name name, rtems_id id)
   if ( (capture_flags_global & RTEMS_CAPTURE_ON) != 0 )
     return RTEMS_UNSATISFIED;
@@ -843,8 +843,8 @@ rtems_status_code
 rtems_capture_watch_del (rtems_name name, rtems_id id)
-  rtems_capture_control_t**    prev_control;
+  rtems_capture_control**      prev_control;
   bool                         found = false;
@@ -892,7 +892,7 @@ rtems_status_code
 rtems_capture_watch_ctrl (rtems_name name, rtems_id id, bool enable)
   bool                         found = false;
@@ -1008,7 +1008,7 @@ rtems_capture_watch_get_floor (void)
  * Map the trigger to a bit mask.
 static uint32_t
-rtems_capture_map_trigger (rtems_capture_trigger_t trigger)
+rtems_capture_map_trigger (rtems_capture_trigger trigger)
    * Transform the mode and trigger to a bit map.
@@ -1049,15 +1049,15 @@ rtems_capture_map_trigger (rtems_capture_trigger_t trigger)
  * linked to single control.
 rtems_status_code
-rtems_capture_set_trigger (rtems_name                   from_name,
-                           rtems_id                     from_id,
-                           rtems_name                   to_name,
-                           rtems_id                     to_id,
-                           rtems_capture_trigger_mode_t mode,
-                           rtems_capture_trigger_t      trigger)
+rtems_capture_set_trigger (rtems_name                 from_name,
+                           rtems_id                   from_id,
+                           rtems_name                 to_name,
+                           rtems_id                   to_id,
+                           rtems_capture_trigger_mode mode,
+                           rtems_capture_trigger      trigger)
-  uint32_t                 flags;
+  uint32_t               flags;
   flags = rtems_capture_map_trigger (trigger);
@@ -1127,15 +1127,15 @@ rtems_capture_set_trigger (rtems_name                   from_name,
  * This function clear a trigger.
 rtems_status_code
-rtems_capture_clear_trigger (rtems_name                   from_name,
-                             rtems_id                     from_id,
-                             rtems_id                     to_id,
+rtems_capture_clear_trigger (rtems_name                 from_name,
+                             rtems_id                   from_id,
+                             rtems_id                   to_id,
-  uint32_t                 flags;
+  uint32_t               flags;
@@ -1202,7 +1202,7 @@ rtems_capture_count_records (const void* records, size_t size)
   while (bytes < size)
-    const rtems_capture_record_t* rec = (const rtems_capture_record_t*) ptr;
+    const rtems_capture_record* rec = (const rtems_capture_record*) ptr;
     recs++;
     ptr += rec->size;
     bytes += rec->size;
@@ -1234,7 +1234,7 @@ rtems_capture_read (uint32_t cpu, size_t* read, const void** recs)
     RTEMS_INTERRUPT_LOCK_REFERENCE (lock, &(capture_lock_on_cpu (cpu)))
     size_t                       recs_size = 0;
-    rtems_capture_buffer_t*      records;
+    rtems_capture_buffer*        records;
     uint32_t*                    flags;
     *read = 0;
@@ -1287,12 +1287,12 @@ rtems_capture_release (uint32_t cpu, uint32_t count)
     uint8_t*                     ptr;
-    rtems_capture_record_t*      rec;
+    rtems_capture_record*        rec;
     uint32_t                     counted;
     size_t                       ptr_size = 0;
     size_t                       rel_size = 0;
     RTEMS_INTERRUPT_LOCK_REFERENCE( lock, &(capture_lock_on_cpu( cpu )) )
-    rtems_capture_buffer_t*      records = &(capture_records_on_cpu( cpu ));
+    rtems_capture_buffer*        records = &(capture_records_on_cpu( cpu ));
     uint32_t*                    flags = &(capture_flags_on_cpu( cpu ));
     uint32_t*                    total = &(capture_count_on_cpu( cpu ));
@@ -1316,7 +1316,7 @@ rtems_capture_release (uint32_t cpu, uint32_t count)
     rel_size = 0;
     while (counted--) {
-      rec = (rtems_capture_record_t*) ptr;
+      rec = (rtems_capture_record*) ptr;
       rel_size += rec->size;
       _Assert( rel_size <= ptr_size );
       ptr += rec->size;
@@ -1342,16 +1342,6 @@ rtems_capture_release (uint32_t cpu, uint32_t count)
- * This function returns the current time. If a handler is provided
- * by the user get the time from that.
-void
-rtems_capture_time (rtems_capture_time_t* uptime)
-  rtems_capture_get_time(uptime);
  * This function returns a string for an event based on the bit in the
  * event. The functions takes the bit offset as a number not the bit
  * set in a bit map.
@@ -1368,7 +1358,7 @@ rtems_capture_event_text (int event)
  * This function returns the head of the list of control in the
  * capture engine.
-rtems_capture_control_t*
+rtems_capture_control*
 rtems_capture_get_control_list (void)
   return capture_controls;
diff --git a/cpukit/libmisc/capture/capture.h b/cpukit/libmisc/capture/capture.h
index b35d262..546926a 100644
--- a/cpukit/libmisc/capture/capture.h
+++ b/cpukit/libmisc/capture/capture.h
@@ -75,7 +75,7 @@ extern "C" {
  * This is a nanosecond capture timestamp
-typedef uint64_t rtems_capture_time_t;
+typedef uint64_t rtems_capture_time;
  * @brief Task id and mask for the from trigger.
@@ -86,12 +86,12 @@ typedef uint64_t rtems_capture_time_t;
  * will only be a from type trigger if the flags in the control
  * structure has the specific *_BY bit set.
-typedef struct rtems_capture_from_s
+typedef struct rtems_capture_from
   rtems_name name;
   rtems_id   id;
   uint32_t   trigger;
-} rtems_capture_from_t;
+} rtems_capture_from;
  * @brief Capture control structure for a group of tasks.
@@ -104,18 +104,18 @@ typedef struct rtems_capture_from_s
  * caused BY the task listed TO this task. The by_valid flag which entries
  * in by are valid.
-typedef struct rtems_capture_control_s
+typedef struct rtems_capture_control
-  rtems_name                      name;
-  rtems_id                        id;
-  uint32_t                        flags;
-  uint32_t                        to_triggers;
-  uint32_t                        from_triggers;
-  uint32_t                        by_triggers;
-  uint32_t                        by_valid;
-  rtems_capture_from_t            by[RTEMS_CAPTURE_TRIGGER_TASKS];
-  struct rtems_capture_control_s* next;
-} rtems_capture_control_t;
+  rtems_name                    name;
+  rtems_id                      id;
+  uint32_t                      flags;
+  uint32_t                      to_triggers;
+  uint32_t                      from_triggers;
+  uint32_t                      by_triggers;
+  uint32_t                      by_valid;
+  rtems_capture_from            by[RTEMS_CAPTURE_TRIGGER_TASKS];
+  struct rtems_capture_control* next;
+} rtems_capture_control;
  * The from_valid mask.
@@ -168,13 +168,13 @@ typedef struct rtems_capture_control_s
  * the buffer. The events includes the priority of the task
  * at the time of the context switch.
-typedef struct rtems_capture_record_s
+typedef struct rtems_capture_record
-  size_t                size;
-  uint32_t              events;
-  rtems_capture_time_t  time;
-  rtems_id              task_id;
-} RTEMS_PACKED rtems_capture_record_t;
+  size_t             size;
+  uint32_t           events;
+  rtems_capture_time time;
+  rtems_id           task_id;
+} RTEMS_PACKED rtems_capture_record;
  * @brief Capture task record.
@@ -183,12 +183,12 @@ typedef struct rtems_capture_record_s
-typedef struct rtems_capture_task_record_s
+typedef struct rtems_capture_task_record
   rtems_name          name;
   rtems_task_priority start_priority;
   uint32_t            stack_size;
-} RTEMS_PACKED rtems_capture_task_record_t;
+} RTEMS_PACKED rtems_capture_task_record;
  * The capture record event flags.
@@ -219,19 +219,19 @@ typedef struct rtems_capture_task_record_s
  * The types of trigger modes that exist.
-typedef enum rtems_capture_trigger_mode_e
+typedef enum rtems_capture_trigger_mode
   rtems_capture_to_any,
   rtems_capture_from_any,
   rtems_capture_from_to
-} rtems_capture_trigger_mode_t;
+} rtems_capture_trigger_mode;
  * @brief Capture trigger.
  * The types of triggers that exist.
-typedef enum rtems_capture_trigger_e
@@ -241,7 +241,7 @@ typedef enum rtems_capture_trigger_e
   rtems_capture_begin,
   rtems_capture_terminated
-} rtems_capture_trigger_t;
+} rtems_capture_trigger;
  * @brief Capture timestamp callout handler.
@@ -251,7 +251,7 @@ typedef enum rtems_capture_trigger_e
-typedef void (*rtems_capture_timestamp)(rtems_capture_time_t* time);
+typedef void (*rtems_capture_timestamp)(rtems_capture_time* time);
  * @brief Capture record lock context.
@@ -313,7 +313,7 @@ rtems_status_code rtems_capture_close (void);
  *         error. Otherwise, a status code is returned indicating the
  *         source of the error.
-rtems_status_code rtems_capture_control (bool enable);
+rtems_status_code rtems_capture_set_control (bool enable);
  * @brief Capture monitor enable/disable.
@@ -328,7 +328,7 @@ rtems_status_code rtems_capture_control (bool enable);
-rtems_status_code rtems_capture_monitor (bool enable);
+rtems_status_code rtems_capture_set_monitor (bool enable);
  * @brief Capture flush trace buffer.
@@ -503,12 +503,12 @@ rtems_task_priority rtems_capture_watch_get_floor (void);
 rtems_status_code
-                           rtems_id                     from_id,
-                           rtems_id                     to_id,
-                           rtems_capture_trigger_t      trigger);
+                           rtems_id                   from_id,
+                           rtems_id                   to_id,
+                           rtems_capture_trigger      trigger);
  * @brief Capture clear trigger.
@@ -529,12 +529,12 @@ rtems_capture_set_trigger (rtems_name                   from_name,
 rtems_status_code
-                             rtems_id                     from_id,
-                             rtems_id                     to_id,
+                             rtems_id                   from_id,
+                             rtems_id                   to_id,
  * @brief Capture read records from capture buffer
@@ -578,15 +578,6 @@ rtems_status_code rtems_capture_read (uint32_t     cpu,
 rtems_status_code rtems_capture_release (uint32_t cpu, uint32_t count);
- * @brief Capture nano-second time period.
- * This function returns the time period in nano-seconds.
- * @param[out] uptime The nano-second time period.
-void rtems_capture_time (rtems_capture_time_t* uptime);
  * @brief Capture filter
@@ -612,7 +603,7 @@ bool rtems_capture_filter (rtems_tcb* task, uint32_t events);
  * @retval This method returns a nano-second time if no user handler
  * is provided.  Otherwise, it returns a resolution defined by the handler.
-void rtems_capture_get_time (rtems_capture_time_t* time);
+void rtems_capture_get_time (rtems_capture_time* time);
  * @brief Capture get event text.
@@ -634,7 +625,7 @@ const char* rtems_capture_event_text (int event);
  * @param[in] tcb is the task control block for the task
-void rtems_capture_initialize_task( rtems_tcb* tcb );
+void rtems_capture_initialize_task (rtems_tcb* tcb);
  * @brief Capture record task.
@@ -643,7 +634,7 @@ void rtems_capture_initialize_task( rtems_tcb* tcb );
-void rtems_capture_record_task( rtems_tcb* tcb );
+void rtems_capture_record_task (rtems_tcb* tcb);
  * @brief Capture record lock.
@@ -739,8 +730,8 @@ rtems_capture_record_extract (void* data, const void* rec, size_t size)
-static inline bool rtems_capture_task_recorded( rtems_tcb* tcb ) {
-  return ( (tcb->Capture.flags & RTEMS_CAPTURE_RECORD_TASK) != 0 );
+static inline bool rtems_capture_task_recorded (rtems_tcb* tcb) {
+  return ((tcb->Capture.flags & RTEMS_CAPTURE_RECORD_TASK) != 0);
@@ -751,8 +742,8 @@ static inline bool rtems_capture_task_recorded( rtems_tcb* tcb ) {
-static inline bool rtems_capture_task_initialized( rtems_tcb* tcb ) {
-  return ( (tcb->Capture.flags & RTEMS_CAPTURE_INIT_TASK) != 0 );
+static inline bool rtems_capture_task_initialized (rtems_tcb* tcb) {
+  return ((tcb->Capture.flags & RTEMS_CAPTURE_INIT_TASK) != 0);
@@ -843,7 +834,7 @@ rtems_capture_task_flags (rtems_tcb* tcb)
  * @retval This function returns the task control if present.
 rtems_capture_task_control (rtems_tcb* tcb)
   return tcb->Capture.control;
@@ -861,7 +852,7 @@ rtems_capture_task_control (rtems_tcb* tcb)
 static inline uint32_t
 rtems_capture_task_control_flags (rtems_tcb* tcb)
-  rtems_capture_control_t*  control = tcb->Capture.control;
+  rtems_capture_control*  control = tcb->Capture.control;
   if (!control)
     return 0;
   return control->flags;
@@ -924,7 +915,7 @@ rtems_capture_task_curr_priority (rtems_tcb* tcb)
  * @retval This function returns the head of the list of controls in the
  * capture engine.
 rtems_capture_get_control_list (void);
@@ -938,8 +929,8 @@ rtems_capture_get_control_list (void);
  * @retval This function returns the pointer to the next control in the list. The
  * pointer NULL terminates the list.
-rtems_capture_next_control (rtems_capture_control_t* control)
+rtems_capture_next_control (rtems_capture_control* control)
   return control->next;
@@ -954,7 +945,7 @@ rtems_capture_next_control (rtems_capture_control_t* control)
  * @retval This function returns the control id.
 static inline rtems_id
-rtems_capture_control_id (rtems_capture_control_t* control)
+rtems_capture_control_id (rtems_capture_control* control)
   return control->id;
@@ -969,7 +960,7 @@ rtems_capture_control_id (rtems_capture_control_t* control)
  * @retval This function returns the control name.
 static inline rtems_name
-rtems_capture_control_name (rtems_capture_control_t* control)
+rtems_capture_control_name (rtems_capture_control* control)
   return control->name;
@@ -984,7 +975,7 @@ rtems_capture_control_name (rtems_capture_control_t* control)
  * @retval This function returns the control flags.
-rtems_capture_control_flags (rtems_capture_control_t* control)
+rtems_capture_control_flags (rtems_capture_control* control)
@@ -999,7 +990,7 @@ rtems_capture_control_flags (rtems_capture_control_t* control)
  * @retval This function returns the task control to triggers.
-rtems_capture_control_to_triggers (rtems_capture_control_t* control)
+rtems_capture_control_to_triggers (rtems_capture_control* control)
   return control->to_triggers;
@@ -1014,7 +1005,7 @@ rtems_capture_control_to_triggers (rtems_capture_control_t* control)
  * @retval This function returns the task control from triggers.
-rtems_capture_control_from_triggers (rtems_capture_control_t* control)
+rtems_capture_control_from_triggers (rtems_capture_control* control)
   return control->from_triggers;
@@ -1029,7 +1020,7 @@ rtems_capture_control_from_triggers (rtems_capture_control_t* control)
  * @retval This function returns the task control by triggers.
-rtems_capture_control_all_by_triggers (rtems_capture_control_t* control)
+rtems_capture_control_all_by_triggers (rtems_capture_control* control)
   return control->by_triggers;
@@ -1045,7 +1036,7 @@ rtems_capture_control_all_by_triggers (rtems_capture_control_t* control)
  * @retval This function returns the control valid BY flags.
 static inline int
-rtems_capture_control_by_valid (rtems_capture_control_t* control, int slot)
+rtems_capture_control_by_valid (rtems_capture_control* control, int slot)
   return control->by_valid & RTEMS_CAPTURE_CONTROL_FROM_MASK (slot);
@@ -1061,7 +1052,7 @@ rtems_capture_control_by_valid (rtems_capture_control_t* control, int slot)
  * @retval This function returns the control @a by task name.
-rtems_capture_control_by_name (rtems_capture_control_t* control, int by)
+rtems_capture_control_by_name (rtems_capture_control* control, int by)
   if (by < RTEMS_CAPTURE_TRIGGER_TASKS)
     return control->by[by].name;
@@ -1076,7 +1067,7 @@ rtems_capture_control_by_name (rtems_capture_control_t* control, int by)
  * @retval This function returns the control @a by task id.
-rtems_capture_control_by_id (rtems_capture_control_t* control, int by)
+rtems_capture_control_by_id (rtems_capture_control* control, int by)
     return control->by[by].id;
@@ -1091,7 +1082,7 @@ rtems_capture_control_by_id (rtems_capture_control_t* control, int by)
  * @retval This function returns the control @a by task triggers.
-rtems_capture_control_by_triggers (rtems_capture_control_t* control,
+rtems_capture_control_by_triggers (rtems_capture_control* control,
                                    int                      by)
@@ -1111,8 +1102,8 @@ rtems_capture_control_by_triggers (rtems_capture_control_t* control,
 rtems_capture_control_count (void)
-  rtems_capture_control_t* control = rtems_capture_get_control_list ();
-  uint32_t                 count = 0;
+  rtems_capture_control* control = rtems_capture_get_control_list ();
+  uint32_t               count = 0;
   while (control)
diff --git a/cpukit/libmisc/capture/capture_buffer.c b/cpukit/libmisc/capture/capture_buffer.c
index be812b0..9678420 100644
--- a/cpukit/libmisc/capture/capture_buffer.c
+++ b/cpukit/libmisc/capture/capture_buffer.c
@@ -27,7 +27,7 @@
 #include "capture_buffer.h"
 void*
-rtems_capture_buffer_allocate (rtems_capture_buffer_t* buffer, size_t size)
+rtems_capture_buffer_allocate (rtems_capture_buffer* buffer, size_t size)
   void* ptr = NULL;
@@ -95,11 +95,11 @@ rtems_capture_buffer_allocate (rtems_capture_buffer_t* buffer, size_t size)
 void*
-rtems_capture_buffer_free (rtems_capture_buffer_t* buffer, size_t size)
+rtems_capture_buffer_free (rtems_capture_buffer* buffer, size_t size)
-  void   *ptr;
-  size_t  next;
-  size_t  buff_size;
+  void*  ptr;
+  size_t next;
+  size_t buff_size;
   if (size == 0)
     return NULL;
diff --git a/cpukit/libmisc/capture/capture_buffer.h b/cpukit/libmisc/capture/capture_buffer.h
index 7f21f47..5a437bb 100644
--- a/cpukit/libmisc/capture/capture_buffer.h
+++ b/cpukit/libmisc/capture/capture_buffer.h
@@ -36,7 +36,7 @@ extern "C" {
  * Capture buffer. There is one per CPU.
-typedef struct {
+typedef struct rtems_capture_buffer {
   uint8_t* buffer;       /**< The per cpu buffer. */
   size_t   size;         /**< The size of the buffer in bytes. */
   size_t   count;        /**< The number of used bytes in the buffer. */
@@ -44,10 +44,10 @@ typedef struct {
   size_t   tail;         /**< Head == Tail for empty. */
   size_t   end;          /**< Buffer current end, it may move in. */
   size_t   max_rec;      /**< The largest record in the buffer. */
-} rtems_capture_buffer_t;
+} rtems_capture_buffer;
 static inline void
-rtems_capture_buffer_flush (rtems_capture_buffer_t* buffer)
+rtems_capture_buffer_flush (rtems_capture_buffer* buffer)
   buffer->end = buffer->size;
   buffer->head = buffer->tail =  0;
@@ -56,7 +56,7 @@ rtems_capture_buffer_flush (rtems_capture_buffer_t* buffer)
 static inline void
-rtems_capture_buffer_create (rtems_capture_buffer_t* buffer, size_t size)
+rtems_capture_buffer_create (rtems_capture_buffer* buffer, size_t size)
   buffer->buffer = malloc(size);
   buffer->size = size;
@@ -64,7 +64,7 @@ rtems_capture_buffer_create (rtems_capture_buffer_t* buffer, size_t size)
 static inline void
-rtems_capture_buffer_destroy (rtems_capture_buffer_t*  buffer)
+rtems_capture_buffer_destroy (rtems_capture_buffer*  buffer)
   rtems_capture_buffer_flush (buffer);
   free (buffer->buffer);
@@ -72,19 +72,19 @@ rtems_capture_buffer_destroy (rtems_capture_buffer_t*  buffer)
 static inline bool
-rtems_capture_buffer_is_empty (rtems_capture_buffer_t* buffer)
+rtems_capture_buffer_is_empty (rtems_capture_buffer* buffer)
    return buffer->count == 0;
 static inline bool
-rtems_capture_buffer_is_full (rtems_capture_buffer_t* buffer)
+rtems_capture_buffer_is_full (rtems_capture_buffer* buffer)
    return buffer->count == buffer->size;
 static inline bool
-rtems_capture_buffer_has_wrapped (rtems_capture_buffer_t* buffer)
+rtems_capture_buffer_has_wrapped (rtems_capture_buffer* buffer)
   if (buffer->tail > buffer->head)
     return true;
@@ -93,7 +93,7 @@ rtems_capture_buffer_has_wrapped (rtems_capture_buffer_t* buffer)
 static inline void*
-rtems_capture_buffer_peek (rtems_capture_buffer_t* buffer, size_t* size)
+rtems_capture_buffer_peek (rtems_capture_buffer* buffer, size_t* size)
   if (rtems_capture_buffer_is_empty (buffer))
@@ -109,9 +109,9 @@ rtems_capture_buffer_peek (rtems_capture_buffer_t* buffer, size_t* size)
   return &buffer->buffer[buffer->tail];
-void* rtems_capture_buffer_allocate (rtems_capture_buffer_t* buffer, size_t size);
+void* rtems_capture_buffer_allocate (rtems_capture_buffer* buffer, size_t size);
-void* rtems_capture_buffer_free (rtems_capture_buffer_t* buffer, size_t size);
+void* rtems_capture_buffer_free (rtems_capture_buffer* buffer, size_t size);
 #ifdef __cplusplus
diff --git a/cpukit/libmisc/capture/capture_support.c b/cpukit/libmisc/capture/capture_support.c
index f9091ae..ddae3e1 100644
--- a/cpukit/libmisc/capture/capture_support.c
+++ b/cpukit/libmisc/capture/capture_support.c
@@ -41,12 +41,12 @@
 typedef struct
-  const void*            recs;      /**< Next record to be read. */
-  size_t                 read;      /**< Number of records read. */
-  size_t                 printed;   /**< Records been printed. */
-  bool                   rec_valid; /**< The record is valid. */
-  rtems_capture_record_t rec;       /**< The record, copied out. */
-} ctrace_per_cpu_t;
+  const void*          recs;      /**< Next record to be read. */
+  size_t               read;      /**< Number of records read. */
+  size_t               printed;   /**< Records been printed. */
+  bool                 rec_valid; /**< The record is valid. */
+  rtems_capture_record rec;       /**< The record, copied out. */
+} ctrace_per_cpu;
  * Task block size.
@@ -88,9 +88,9 @@ rtems_capture_print_timestamp (uint64_t uptime)
 void
-rtems_capture_print_record_task (int                                cpu,
-                                 const rtems_capture_record_t*      rec,
-                                 const rtems_capture_task_record_t* task_rec)
+rtems_capture_print_record_task (int                              cpu,
+                                 const rtems_capture_record*      rec,
+                                 const rtems_capture_task_record* task_rec)
   fprintf(stdout,"%2i ", cpu);
   rtems_capture_print_timestamp (rec->time);
@@ -117,10 +117,10 @@ rtems_capture_print_record_task (int                                cpu,
 void
-rtems_capture_print_record_capture(int                           cpu,
-                                   uint64_t                      diff,
-                                   const rtems_name*             name)
+rtems_capture_print_record_capture(int                         cpu,
+                                   uint64_t                    diff,
+                                   const rtems_name*           name)
   uint32_t event;
   int      e;
@@ -164,14 +164,14 @@ rtems_capture_print_record_capture(int                           cpu,
 void
 rtems_capture_print_trace_records (int total, bool csv)
-  ctrace_per_cpu_t*    per_cpu;
-  ctrace_per_cpu_t*    cpu;
-  int                  cpus;
-  rtems_capture_time_t last_time = 0;
-  ctrace_task_name*    tasks = NULL;
-  size_t               tasks_size = CTRACE_TASK_BLOCK_SIZE;
-  size_t               task_count = 0;
-  int                  i;
+  ctrace_per_cpu*    per_cpu;
+  ctrace_per_cpu*    cpu;
+  int                cpus;
+  rtems_capture_time last_time = 0;
+  ctrace_task_name*  tasks = NULL;
+  size_t             tasks_size = CTRACE_TASK_BLOCK_SIZE;
+  size_t             task_count = 0;
+  int                i;
   cpus = rtems_get_processor_count ();
@@ -192,9 +192,9 @@ rtems_capture_print_trace_records (int total, bool csv)
   while (total)
-    const rtems_capture_record_t* rec_out = NULL;
-    int                           cpu_out = -1;
-    rtems_capture_time_t          this_time = 0;
+    const rtems_capture_record* rec_out = NULL;
+    int                         cpu_out = -1;
+    rtems_capture_time          this_time = 0;
     /* Prime the per_cpu data */
     for (i = 0; i < cpus; i++) {
@@ -254,7 +254,7 @@ rtems_capture_print_trace_records (int total, bool csv)
               (uint64_t) rec_out->time);
     } else {
       if ((rec_out->events >> RTEMS_CAPTURE_EVENT_START) == 0) {
-        rtems_capture_task_record_t task_rec;
+        rtems_capture_task_record task_rec;
         cpu->recs = rtems_capture_record_extract (&task_rec,
                                                   cpu->recs,
                                                   sizeof (task_rec));
@@ -293,9 +293,9 @@ rtems_capture_print_trace_records (int total, bool csv)
         rtems_capture_print_record_task (cpu_out, rec_out, &task_rec);
       else {
-        rtems_capture_time_t diff;
-        const rtems_name*    name = NULL;
-        size_t               t;
+        rtems_capture_time diff;
+        const rtems_name*  name = NULL;
+        size_t             t;
         for (t = 0; t < task_count; ++t)
           if (tasks[t].id == rec_out->task_id)
@@ -343,9 +343,9 @@ rtems_capture_print_trace_records (int total, bool csv)
 void
 rtems_capture_print_watch_list ()
-  rtems_task_priority      ceiling = rtems_capture_watch_get_ceiling ();
-  rtems_task_priority      floor = rtems_capture_watch_get_floor ();
+  rtems_task_priority    ceiling = rtems_capture_watch_get_ceiling ();
+  rtems_task_priority    floor = rtems_capture_watch_get_floor ();
   fprintf (stdout, "watch priority ceiling is %" PRId32 "\n", ceiling);
   fprintf (stdout, "watch priority floor is %" PRId32 "\n", floor);
diff --git a/cpukit/libmisc/capture/capture_user_extension.c b/cpukit/libmisc/capture/capture_user_extension.c
index 6e42fd7..ea8d55d 100644
--- a/cpukit/libmisc/capture/capture_user_extension.c
+++ b/cpukit/libmisc/capture/capture_user_extension.c
@@ -78,7 +78,7 @@ static const rtems_extensions_table capture_extensions = {
   .thread_terminate = rtems_capture_terminated_task
-static inline void rtems_capture_record (rtems_tcb* tcb, uint32_t events)
+static inline void capture_record (rtems_tcb* tcb, uint32_t events)
@@ -140,10 +140,10 @@ rtems_capture_create_task (rtems_tcb* ct,
   rtems_capture_initialize_task (nt);
-  if (rtems_capture_trigger (ct, nt, RTEMS_CAPTURE_CREATE))
+  if (rtems_capture_trigger_fired (ct, nt, RTEMS_CAPTURE_CREATE))
-    rtems_capture_record (ct, RTEMS_CAPTURE_CREATED_BY_EVENT);
-    rtems_capture_record (nt, RTEMS_CAPTURE_CREATED_EVENT);
+    capture_record (ct, RTEMS_CAPTURE_CREATED_BY_EVENT);
+    capture_record (nt, RTEMS_CAPTURE_CREATED_EVENT);
   return 1 == 1;
@@ -167,10 +167,10 @@ rtems_capture_start_task (rtems_tcb* ct,
   if (st != NULL)
     rtems_capture_initialize_task (st);
-  if (rtems_capture_trigger (ct, st, RTEMS_CAPTURE_START))
+  if (rtems_capture_trigger_fired (ct, st, RTEMS_CAPTURE_START))
-    rtems_capture_record (ct, RTEMS_CAPTURE_STARTED_BY_EVENT);
-    rtems_capture_record (st, RTEMS_CAPTURE_STARTED_EVENT);
+    capture_record (ct, RTEMS_CAPTURE_STARTED_BY_EVENT);
+    capture_record (st, RTEMS_CAPTURE_STARTED_EVENT);
@@ -191,10 +191,10 @@ rtems_capture_restart_task (rtems_tcb* ct,
   if (!rtems_capture_task_initialized (rt))
     rtems_capture_initialize_task (rt);
-  if (rtems_capture_trigger (ct, rt, RTEMS_CAPTURE_RESTART))
+  if (rtems_capture_trigger_fired (ct, rt, RTEMS_CAPTURE_RESTART))
-    rtems_capture_record (ct, RTEMS_CAPTURE_RESTARTED_BY_EVENT);
-    rtems_capture_record (rt, RTEMS_CAPTURE_RESTARTED_EVENT);
+    capture_record (ct, RTEMS_CAPTURE_RESTARTED_BY_EVENT);
+    capture_record (rt, RTEMS_CAPTURE_RESTARTED_EVENT);
@@ -211,10 +211,10 @@ rtems_capture_delete_task (rtems_tcb* ct,
   if (!rtems_capture_task_initialized (dt))
     rtems_capture_initialize_task (dt);
-  if (rtems_capture_trigger (ct, dt, RTEMS_CAPTURE_DELETE))
+  if (rtems_capture_trigger_fired (ct, dt, RTEMS_CAPTURE_DELETE))
-    rtems_capture_record (ct, RTEMS_CAPTURE_DELETED_BY_EVENT);
-    rtems_capture_record (dt, RTEMS_CAPTURE_DELETED_EVENT);
+    capture_record (ct, RTEMS_CAPTURE_DELETED_BY_EVENT);
+    capture_record (dt, RTEMS_CAPTURE_DELETED_EVENT);
@@ -232,8 +232,8 @@ rtems_capture_begin_task (rtems_tcb* bt)
   if (!rtems_capture_task_initialized (bt))
     rtems_capture_initialize_task (bt);
-  if (rtems_capture_trigger (NULL, bt, RTEMS_CAPTURE_BEGIN))
-    rtems_capture_record (bt, RTEMS_CAPTURE_BEGIN_EVENT);
+  if (rtems_capture_trigger_fired (NULL, bt, RTEMS_CAPTURE_BEGIN))
+    capture_record (bt, RTEMS_CAPTURE_BEGIN_EVENT);
@@ -251,8 +251,8 @@ rtems_capture_exitted_task (rtems_tcb* et)
   if (!rtems_capture_task_initialized (et))
     rtems_capture_initialize_task (et);
-  if (rtems_capture_trigger (NULL, et, RTEMS_CAPTURE_EXITTED))
-    rtems_capture_record (et, RTEMS_CAPTURE_EXITTED_EVENT);
+  if (rtems_capture_trigger_fired (NULL, et, RTEMS_CAPTURE_EXITTED))
+    capture_record (et, RTEMS_CAPTURE_EXITTED_EVENT);
@@ -269,8 +269,8 @@ rtems_capture_terminated_task (rtems_tcb* tt)
   if (!rtems_capture_task_initialized (tt))
     rtems_capture_initialize_task (tt);
-  if (rtems_capture_trigger (NULL, tt, RTEMS_CAPTURE_TERMINATED))
-    rtems_capture_record (tt, RTEMS_CAPTURE_TERMINATED_EVENT);
+  if (rtems_capture_trigger_fired (NULL, tt, RTEMS_CAPTURE_TERMINATED))
+    capture_record (tt, RTEMS_CAPTURE_TERMINATED_EVENT);
@@ -288,7 +288,7 @@ rtems_capture_switch_task (rtems_tcb* ct,
   if (flags & RTEMS_CAPTURE_ON)
     if (!rtems_capture_task_initialized (ct))
       rtems_capture_initialize_task (ct);
@@ -301,10 +301,10 @@ rtems_capture_switch_task (rtems_tcb* ct,
     rtems_capture_get_time (&time);
-    if (rtems_capture_trigger (ct, ht, RTEMS_CAPTURE_SWITCH))
+    if (rtems_capture_trigger_fired (ct, ht, RTEMS_CAPTURE_SWITCH))
-      rtems_capture_record (ct, RTEMS_CAPTURE_SWITCHED_OUT_EVENT);
-      rtems_capture_record (ht, RTEMS_CAPTURE_SWITCHED_IN_EVENT);
+      capture_record (ct, RTEMS_CAPTURE_SWITCHED_OUT_EVENT);
+      capture_record (ht, RTEMS_CAPTURE_SWITCHED_IN_EVENT);
diff --git a/cpukit/libmisc/capture/captureimpl.h b/cpukit/libmisc/capture/captureimpl.h
index 7d545e7..4c86482 100644
--- a/cpukit/libmisc/capture/captureimpl.h
+++ b/cpukit/libmisc/capture/captureimpl.h
@@ -102,7 +102,7 @@ rtems_status_code rtems_capture_user_extension_open(void);
 rtems_status_code rtems_capture_user_extension_close(void);
- * @brief Capture trigger.
+ * @brief Capture check trigger.
  * This function checks if we have triggered or if this event is a
@@ -114,9 +114,9 @@ rtems_status_code rtems_capture_user_extension_close(void);
  * @retval This method returns true if we have triggered or
  * if the event is a cause of a trigger.
-bool rtems_capture_trigger (rtems_tcb* ft,
-                            rtems_tcb* tt,
-                            uint32_t   events);
+bool rtems_capture_trigger_fired (rtems_tcb* ft,
+                                  rtems_tcb* tt,
+                                  uint32_t   events);
  * @brief Capture print trace records.
@@ -149,9 +149,9 @@ void rtems_capture_print_timestamp (uint64_t uptime);
  * @param[in] cpu specifies the cpu the cpu the record was logged on.
  * @param[in] rec specifies the task record.
-void rtems_capture_print_record_task(int                                cpu,
-                                     const rtems_capture_task_record_t* task_rec);
+void rtems_capture_print_record_task(int                              cpu,
+                                     const rtems_capture_task_record* task_rec);
  * @brief Capture print capture record.
@@ -165,10 +165,10 @@ void rtems_capture_print_record_task(int                                cpu,
  * @param[in] name specifies the name of the task, NULL if none.
  * @param[in] task_count number of tasks to search for.
-void rtems_capture_print_record_capture(int                           cpu,
-                                        uint64_t                      diff,
-                                        const rtems_name*             name);
+void rtems_capture_print_record_capture(int                         cpu,
+                                        uint64_t                    diff,
+                                        const rtems_name*           name);
  * @brief Capture print watch list
2.3.0
