[PATCH v2 1/6] Imported files for driver: bcm283x_dwcotg
Deval Shah
deval.maker at gmail.com
Wed Aug 31 07:21:52 UTC 2016
Okay. Understood. I will update and prepare a patch.
ᐧ
On Mon, Aug 29, 2016 at 12:26 PM, Christian Mauderer <
christian.mauderer at embedded-brains.de> wrote:
> Am 27.08.2016 um 13:16 schrieb Deval Shah:
> > On Tue, Aug 23, 2016 at 7:08 PM, Sebastian Huber
> > <sebastian.huber at embedded-brains.de
> > <mailto:sebastian.huber at embedded-brains.de>> wrote:
> > I updated the MMC support to use the FreeBSD trunk, 2016-08-23,
> > 9fe7c416e6abb28b1398fd3e5687099846800cfd. It would be great if you
> > can use this version as well as a baseline for your work.
> > Is it okay if I provide a new patch (not resend in the previous ones)
> > updating the code ?
> > On 22/08/16 10:37, Deval Shah wrote:
> > On Mon, Aug 22, 2016 at 11:25 AM, Sebastian Huber
> > <mailto:sebastian.huber at embedded-brains.de>>> wrote:
> > If you think the guidelines could be more clear, need an
> > explanation or examples, then we should address this first.
> > I could use some examples on the last rule " Do not disable
> > option header includes via guards. Instead, add an empty option
> > header, e.g. `rtemsbsd/include/rtems/bsd/local/opt_xyz.h`. In
> > general, provide empty header files and do not guard includes. "
> > Ok, I updated the libbsd.txt.
> > I have a small doubt
> > here. https://git.rtems.org/rtems-libbsd/tree/libbsd.txt#n654
> > Do I have to provide all the headers which I want to ignore, with an
> > empty file as mentioned or only the ones which are transformed by the
> > import script ?
> > For example includes like these. "#include <dev/ofw/ofw_bus_subr.h>"
> Hello Deval,
> Sebastian is currently on vacation so he might need some time to answer.
> I'll try to give some hints but I'm far from being as familiar with
> libbsd as Sebastian is, so he (or some others) might have another opinion.
> Regarding the header: Currently mainly the option headers are empty. If
> you do a
> find -size 0 -name "*.h"
> (or some other search for empty files) in the libbsd directory, the
> empty headers are option headers and some machine dependent files.
> So if you ask me, it should be OK to disable the mentioned
> ofw_bus_subr.h especially because you disabled ofw in the whole file.
> On the other hand an option header that you should add as an empty file
> would be opt_platform.h in your patch 5/6.
> Kind regards
> Christian
> embedded brains GmbH
> Christian Mauderer
> Dornierstr. 4
> D-82178 Puchheim
> Germany
> email: christian.mauderer at embedded-brains.de
> Phone: +49-89-18 94 741 - 18
> Fax: +49-89-18 94 741 - 08
> PGP: Public key available on request.
Deval Shah
Graduate Student,
B.E. (Hons.) Electrical and Electronics Engineering
BITS Pilani Hyderabad Campus <http://www.bits-pilani.ac.in/hyderabad/>
Github Profile <https://github.com/deval-maker>
URL: <http://lists.rtems.org/pipermail/devel/attachments/20160831/84914611/attachment-0001.html>
