[PATCH v3 5/7] Ported driver usb_ethernet(smsc) to RTEMS. USB DMA related functions commented out, since DMA support for raspberry is underdevelopment.
Deval Shah deval.maker at gmail.com
Wed Aug 31 08:59:51 UTC 2016
 freebsd/sys/dev/usb/net/if_smsc.c               | 32 +++++++++++++++++++++++++
 freebsd/sys/dev/usb/net/if_smscreg.h            |  1 +
 freebsd/sys/dev/usb/net/usb_ethernet.c          | 12 ++++++++++
 freebsd/sys/sys/sysctl.h                        |  1 +
 rtemsbsd/include/machine/rtems-bsd-nexus-bus.h  | 18 ++++++++++++++
 rtemsbsd/include/rtems/bsd/local/opt_platform.h |  0
 6 files changed, 64 insertions(+)
 create mode 100644 rtemsbsd/include/rtems/bsd/local/opt_platform.h
diff --git a/freebsd/sys/dev/usb/net/if_smsc.c b/freebsd/sys/dev/usb/net/if_smsc.c
index 3bdd35a..fa47787 100644
--- a/freebsd/sys/dev/usb/net/if_smsc.c
+++ b/freebsd/sys/dev/usb/net/if_smsc.c
@@ -996,7 +996,9 @@ smsc_bulk_read_callback(struct usb_xfer *xfer, usb_error_t error)
 			/* The frame header is always aligned on a 4 byte boundary */
 			off = ((off + 0x3) & ~0x3);
+#ifndef __rtems__
 			usbd_copy_out(pc, off, &rxhdr, sizeof(rxhdr));
+#endif /* __rtems__ */
 			off += (sizeof(rxhdr) + ETHER_ALIGN);
 			rxhdr = le32toh(rxhdr);
@@ -1008,9 +1010,17 @@ smsc_bulk_read_callback(struct usb_xfer *xfer, usb_error_t error)
 			if (rxhdr & SMSC_RX_STAT_ERROR) {
 				smsc_dbg_printf(sc, "rx error (hdr 0x%08x)\n", rxhdr);
+#ifndef __rtems__
 				if_inc_counter(ifp, IFCOUNTER_IERRORS, 1);
+#else /* __rtems__ */
+				ifp->if_ierrors++;
 				if (rxhdr & SMSC_RX_STAT_COLLISION)
+#ifndef __rtems__
 					if_inc_counter(ifp, IFCOUNTER_COLLISIONS, 1);
+					sc->ifp->if_collisions += 1;
 			} else {
 				/* Check if the ethernet frame is too big or too small */
@@ -1021,12 +1031,18 @@ smsc_bulk_read_callback(struct usb_xfer *xfer, usb_error_t error)
 				m = uether_newbuf();
 				if (m == NULL) {
 					smsc_warn_printf(sc, "failed to create new mbuf\n");
+#ifndef __rtems__
 					if_inc_counter(ifp, IFCOUNTER_IQDROPS, 1);
+					ifp->if_iqdrops++;
 					goto tr_setup;
+#ifndef __rtems__
 				usbd_copy_out(pc, off, mtod(m, uint8_t *), pktlen);
 				/* Check if RX TCP/UDP checksumming is being offloaded */
 				if ((ifp->if_capenable & IFCAP_RXCSUM) != 0) {
@@ -1061,9 +1077,11 @@ smsc_bulk_read_callback(struct usb_xfer *xfer, usb_error_t error)
 							/* Copy the TCP/UDP checksum from the last 2 bytes
 							 * of the transfer and put in the csum_data field.
+#ifndef __rtems__
 							usbd_copy_out(pc, (off + pktlen),
 							              &m->m_pkthdr.csum_data, 2);
 							/* The data is copied in network order, but the
 							 * csum algorithm in the kernel expects it to be
 							 * in host network order.
@@ -1165,19 +1183,29 @@ tr_setup:
 			txhdr = SMSC_TX_CTRL_0_BUF_SIZE(m->m_pkthdr.len) |
 					SMSC_TX_CTRL_0_FIRST_SEG | SMSC_TX_CTRL_0_LAST_SEG;
 			txhdr = htole32(txhdr);
+#ifndef __rtems__
 			usbd_copy_in(pc, 0, &txhdr, sizeof(txhdr));
 			txhdr = SMSC_TX_CTRL_1_PKT_LENGTH(m->m_pkthdr.len);
+#ifndef __rtems__
 			usbd_copy_in(pc, 4, &txhdr, sizeof(txhdr));
 			frm_len += 8;
 			/* Next copy in the actual packet */
+#ifndef __rtems__
 			usbd_m_copy_in(pc, frm_len, m, 0, m->m_pkthdr.len);
 			frm_len += m->m_pkthdr.len;
+#ifndef __rtems__
 			if_inc_counter(ifp, IFCOUNTER_OPACKETS, 1);
+			sc->ifp->if_opackets++;
 			/* If there's a BPF listener, bounce a copy of this frame to him */
 			BPF_MTAP(ifp, m);
@@ -1195,7 +1223,11 @@ tr_setup:
 		return;
 	default:
+#ifndef __rtems__
 		if_inc_counter(ifp, IFCOUNTER_OERRORS, 1);
+		sc->ifp->if_oerrors++;
 		ifp->if_drv_flags &= ~IFF_DRV_OACTIVE;
 		if (error != USB_ERR_CANCELLED) {
diff --git a/freebsd/sys/dev/usb/net/if_smscreg.h b/freebsd/sys/dev/usb/net/if_smscreg.h
index 31a6382..cce37ec 100644
--- a/freebsd/sys/dev/usb/net/if_smscreg.h
+++ b/freebsd/sys/dev/usb/net/if_smscreg.h
@@ -256,6 +256,7 @@ enum {
 struct smsc_softc {
+	struct ifnet		*ifp;
 	struct usb_ether  sc_ue;
 	struct mtx        sc_mtx;
 	struct usb_xfer  *sc_xfer[SMSC_N_TRANSFER];
diff --git a/freebsd/sys/dev/usb/net/usb_ethernet.c b/freebsd/sys/dev/usb/net/usb_ethernet.c
index 0d9185d..de923e9 100644
--- a/freebsd/sys/dev/usb/net/usb_ethernet.c
+++ b/freebsd/sys/dev/usb/net/usb_ethernet.c
@@ -582,7 +582,11 @@ uether_rxmbuf(struct usb_ether *ue, struct mbuf *m,
 	UE_LOCK_ASSERT(ue, MA_OWNED);
 	/* finalize mbuf */
+#ifndef __rtems__
 	if_inc_counter(ifp, IFCOUNTER_IPACKETS, 1);
+	ifp->if_ipackets++;
 	m->m_pkthdr.rcvif = ifp;
 	m->m_pkthdr.len = m->m_len = len;
@@ -605,14 +609,22 @@ uether_rxbuf(struct usb_ether *ue, struct usb_page_cache *pc,
 	if (m == NULL) {
+#ifndef __rtems__
 		return (ENOMEM);
 	usbd_copy_out(pc, offset, mtod(m, uint8_t *), len);
 	/* finalize mbuf */
+#ifndef __rtems__
diff --git a/freebsd/sys/sys/sysctl.h b/freebsd/sys/sys/sysctl.h
index cfbbc7f..b7283e2 100644
--- a/freebsd/sys/sys/sysctl.h
+++ b/freebsd/sys/sys/sysctl.h
@@ -186,6 +186,7 @@ struct sysctl_oid {
 #define SYSCTL_IN(r, p, l) (r->newfunc)(r, p, l)
 #define SYSCTL_OUT(r, p, l) (r->oldfunc)(r, p, l)
+#define SYSCTL_OUT_STR(r, p) (r->oldfunc)(r, p, strlen(p) + 1)
 int sysctl_handle_int(SYSCTL_HANDLER_ARGS);
 int sysctl_msec_to_ticks(SYSCTL_HANDLER_ARGS);
diff --git a/rtemsbsd/include/machine/rtems-bsd-nexus-bus.h b/rtemsbsd/include/machine/rtems-bsd-nexus-bus.h
index 467ea7b..d0591ec 100644
--- a/rtemsbsd/include/machine/rtems-bsd-nexus-bus.h
+++ b/rtemsbsd/include/machine/rtems-bsd-nexus-bus.h
@@ -71,10 +71,12 @@
  *   RTEMS_BSD_DRIVER_PCI_IGB
  *   RTEMS_BSD_DRIVER_PCI_EM
  *   RTEMS_BSD_DRIVER_PCI_RE
+ *   RTEMS_BSD_DRIVER_SMSC
  *  MMI PHY:
  *   RTEMS_BSD_DRIVER_E1000PHY
  *   RTEMS_BSD_DRIVER_REPHY
+ *   RTEMS_BSD_DRIVER_UKPHY
  *   RTEMS_BSD_DRIVER_MIPHY
@@ -354,6 +356,14 @@ extern "C" {
     SYSINIT_DRIVER_REFERENCE(re, pci);
 #endif /* RTEMS_BSD_DRIVER_PCI_RE */
+ * SMSC USB-Ethernet Driver
+#if !defined(RTEMS_BSD_DRIVER_SMSC)
+  #define RTEMS_BSD_DRIVER_SMSC                 \
+    SYSINIT_DRIVER_REFERENCE(miibus, smsc);
+#endif /* RTEMS_BSD_DRIVER_SMSC */
  ** MMI Physical Layer Support.
@@ -375,6 +385,14 @@ extern "C" {
 #endif /* RTEMS_BSD_DRIVER_REPHY */
+ * Synopsis(uk) PHY
+#if !defined(RTEMS_BSD_DRIVER_UKPHY)
+  #define RTEMS_BSD_DRIVER_UKPHY                  \
+    SYSINIT_DRIVER_REFERENCE(ukphy, miibus);
+#endif /* RTEMS_BSD_DRIVER_UKPHY */
  * MI PHY.
 #if !defined(RTEMS_BSD_DRIVER_MIPHY)
diff --git a/rtemsbsd/include/rtems/bsd/local/opt_platform.h b/rtemsbsd/include/rtems/bsd/local/opt_platform.h
new file mode 100644
index 0000000..e69de29
2.7.4
