[PATCH v3 7/7] USB and ethernet controller: Update to FreeBSD trunk 2016-08-23 FreeBSD trunk, 2016-08-23, 9fe7c416e6abb28b1398fd3e5687099846800cfd.
Deval Shah deval.maker at gmail.com
Wed Aug 31 08:59:53 UTC 2016
 freebsd/sys/dev/usb/net/usb_ethernet.c | 6 +++++-
 libbsd.txt                             | 6 +++---
 2 files changed, 8 insertions(+), 4 deletions(-)
diff --git a/freebsd/sys/dev/usb/net/usb_ethernet.c b/freebsd/sys/dev/usb/net/usb_ethernet.c
index de923e9..6497385 100644
--- a/freebsd/sys/dev/usb/net/usb_ethernet.c
+++ b/freebsd/sys/dev/usb/net/usb_ethernet.c
@@ -655,5 +655,9 @@ uether_rxflush(struct usb_ether *ue)
-DECLARE_MODULE(uether, uether_mod, SI_SUB_PSEUDO, SI_ORDER_ANY);
+ * USB net drivers are run by DRIVER_MODULE() thus SI_SUB_DRIVERS,
+ * SI_ORDER_MIDDLE.  Run uether after that.
+DECLARE_MODULE(uether, uether_mod, SI_SUB_DRIVERS, SI_ORDER_ANY);
 MODULE_VERSION(uether, 1);
diff --git a/libbsd.txt b/libbsd.txt
index 121acfa..fc3fa5e 100644
--- a/libbsd.txt
+++ b/libbsd.txt
@@ -768,9 +768,9 @@ detail and debug level information from the command.
 . sys/dev/dwc/*, trunk, 2015-03-26, cfc3df2b8f708ce8494d9d556e3472a5c8c21b8a
 . sys/dev/usb/*, trunk, 2015-10-30, 968dafb4fcf133cb8beb6fa3c558fecd7dc00ef0
 . *, stable/9, 2015-04-08, 99a648a912e81e29d9c4c159cbbe263462f2d719
-. sys/arm/broadcom/bcm2835/bcm283x_dwc_fdt.c, trunk, 2016-05-26, a7019c8505c0592f2e80ac63be139075d8977c4e
-. sys/dev/usb/controller/dwc_otg_fdt.*, trunk, 2016-05-26, a7019c8505c0592f2e80ac63be139075d8977c4e
-. sys/dev/usb/net/*, trunk, 2016-05-26, a7019c8505c0592f2e80ac63be139075d8977c4e
+. sys/arm/broadcom/bcm2835/bcm283x_dwc_fdt.c, trunk, 2016-08-23, 9fe7c416e6abb28b1398fd3e5687099846800cfd
+. sys/dev/usb/controller/dwc_otg_fdt.*, trunk, 2016-08-23, 9fe7c416e6abb28b1398fd3e5687099846800cfd
+. sys/dev/usb/net/*, trunk, 2016-08-23, 9fe7c416e6abb28b1398fd3e5687099846800cfd
 == How to import code from FreeBSD
2.7.4
