[PATCH 01/02] USB driver bcm283x_dwcotg added.
Thomas Kim thomas73.kim at gmail.com
Wed Aug 10 14:23:37 UTC 2016
Dear Deval Shah,
Thank you very much for finding my fault.
I changed BSP from rasberrypi to rasberrypi2. also, I changed base address
and irq number accroding to your guide.
I will test this tomorrow.
Additionally, I modifed usb-sysinit.h in below;
#ifdef USB_SYSINIT_INIT
#if defined(LIBBSP_ARM_LPC24XX_BSP_H) || defined(LIBBSP_ARM_LPC32XX_BSP_H)
 #define NEED_USB_OHCI
#elif defined(__GEN83xx_BSP_h) || defined(LIBBSP_POWERPC_QORIQ_BSP_H)
 #define NEED_USB_EHCI
#elif defined(LIBBSP_ARM_RASPBERRYPI_BSP_H)
 #define NEED_USB_OTG
#endif
SYSINIT_NEED_USB_CORE;
#ifdef NEED_USB_OHCI
 SYSINIT_NEED_USB_OHCI;
#endif
#ifdef NEED_USB_EHCI
 SYSINIT_NEED_USB_EHCI;
#endif
#ifdef NEED_USB_OTG
 SYSINIT_NEED_USB_OTG;
#endif
also, I added below definition in rtems-bsd-sysinit.h
#define SYSINIT_NEED_USB_OTG \
 SYSINIT_DRIVER_REFERENCE(dwcotg, nexus); \
 SYSINIT_DRIVER_REFERENCE(usbus, dwcotg)
Is this correct modification ?
Or, Because DEFINE_CLASS_1 is defined in bcm2835_dwc_fdt.c, Is this
modification non-effective code ?
Best Regards,
Thomas Kim
2016-08-10 22:06 GMT+09:00 Deval Shah <deval.maker at gmail.com>:
> I saw the files which you have attached. I found one quick mistake.
> In your nexus-devices.h file "RTEMS_BSD_DRIVER_BCM283X_DWCOTG(0x20980000,
> 17);", base and irq used are wrong. I had corrected the irq in my other
> commit. They will be 0x3F980000 (since you are using Raspberry pi 2) and 9.
> It would be easier to use the macros. i.e.
> RTEMS_BSD_DRIVER_BCM283X_DWCOTG(BCM2835_USB_BASE, BCM2835_IRQ_ID_USB);
> ᐧ
> On Wed, Aug 10, 2016 at 1:11 PM, Thomas Kim <thomas73.kim at gmail.com>
> wrote:
>> Dear Deval Shah,
>> Thank you very much for your reply.
>> I checked this again.
>> Because there is not your code in currrent git system, I patched your
>> code in current libbsd code.
>> As I know in current libbsd source tree, your nexus_devices.h should be
>> sperated into rtems-bsd-nexus-bus.h. I attached this.
>> First of all, I completed to test RTEMS testsuites/sample/ticker.exe on
>> RPI2 B+ board.
>> I am tring to test rtems-libbsd/rtemsbsd/testsuite/usb01.
>> also, I try to test two cases in usb01/init.c
>> case 1 does not include NEED_USB_EHCI. case 2 include NEED_USB_EHCI.
>> _H)
>> (CASE1) #elif defined(__GEN83xx_BSP_h) || defined(LIBBSP_POWERPC_QORIQ_B
>> SP_H)
>> (CASE2) #elif defined(__GEN83xx_BSP_h) || defined(LIBBSP_ARM_RASPBERRYPI
>> _BSP_H)
>> #endif
>> #endif
>> #endif
>> also, I added "#define VERBOSE_SYSINIT 1" in init_main.c for checking
>> SYS_INIT functional call.
>> At this time, usb_quirk_init() only is called when I test two cases.
>> I attached serial log file, too.
>> Please let me know my missing point.
>> Best Regards,
>> JunBeom
>> 2016-08-10 5:31 GMT+09:00 Deval Shah <deval.maker at gmail.com>:
>>> Hello Thomas Kim,
>>> It is the same code which you downloaded will work for the raspberry pi.
>>> You can test the libbsd version of raspberry pi by configuring waf with the
>>> following arguments.
>>> waf configure --prefix=/opt/rtems/4.12/bsps \
>>> --rtems=/opt/rtems/4.12/bsps \
>>> --rtems-tools=/opt/rtems/4.12/tools \
>>> --rtems-bsps=arm/raspberrypi
>>> You can find more at this link. https://git.rtems.org/rt
>>> ems-libbsd/tree/README.waf
>>> Deval Shah
>>> ᐧ
>>> On Tue, Aug 9, 2016 at 11:48 AM, Thomas Kim <thomas73.kim at gmail.com>
>>> wrote:
>>>> Dear Sir,
>>>> I am sorry.
>>>> I want to test this libbsd version for Rasberry Pi.
>>>> When I check "git://git.rtems.org/rtems-libbsd.git", there is not any
>>>> code for Rasberry pi.
>>>> Please could you let me know git URL for downloading this libbsd
>>>> version ?
>>>> Best Regards,
>>>> Thomas Kim
>>>> 2016-08-09 14:52 GMT+09:00 Sebastian Huber <
>>>> sebastian.huber at embedded-brains.de>:
>>>>> From which FreeBSD version are these files?
>>>>> On 05/08/16 18:32, Deval Shah wrote:
>>>>>>   freebsd/sys/arm/broadcom/bcm2835/bcm283x_dwc_fdt.c | 127
>>>>>>   freebsd/sys/dev/usb/controller/dwc_otg_fdt.c       | 228
>>>>>>   freebsd/sys/dev/usb/controller/dwc_otg_fdt.h       |  39 ++++
>>>>>>   libbsd.py                                          |   3 +
>>>>>>   libbsd_waf.py                                      |   4 +-
>>>>>>   rtemsbsd/include/bsp/nexus-devices.h               |  21 ++
>>>>>>   6 files changed, 421 insertions(+), 1 deletion(-)
>>>>>>   create mode 100644 freebsd/sys/arm/broadcom/bcm28
>>>>>>   create mode 100644 freebsd/sys/dev/usb/controller/dwc_otg_fdt.c
>>>>>>   create mode 100644 freebsd/sys/dev/usb/controller/dwc_otg_fdt.h
>>>>> Sebastian Huber, embedded brains GmbH
>>>>> Address : Dornierstr. 4, D-82178 Puchheim, Germany
>>>>> Phone   : +49 89 189 47 41-16
>>>>> Fax     : +49 89 189 47 41-09
>>>>> E-Mail  : sebastian.huber at embedded-brains.de
>>>>> PGP     : Public key available on request.
>>>>> Diese Nachricht ist keine geschäftliche Mitteilung im Sinne des EHUG.
>>>>> _______________________________________________
>>>>> devel mailing list
>>>>> devel at rtems.org
>>>>> http://lists.rtems.org/mailman/listinfo/devel
>>> Deval Shah
>>> Graduate Student,
>>> B.E. (Hons.) Electrical and Electronics Engineering
>>> BITS Pilani Hyderabad Campus <http://www.bits-pilani.ac.in/hyderabad/>
>>> Github Profile <https://github.com/deval-maker>
> Deval Shah
> Graduate Student,
URL: <http://lists.rtems.org/pipermail/devel/attachments/20160810/8d86045e/attachment-0002.html>
