[PATCH] arm/cortex-a: Fix cache flush/invalidate after u-boot.
    Chris Johns
    chrisj at rtems.org
    Tue Aug 16 01:49:27 UTC 2016
On 15/08/2016 16:54, Pavel Pisa wrote:
> If you test that chage is OK for Zynq with SMP then I reintroduce
> change to RPi code (it would worth to have RPi2 SMP working for that
> testing but that is near to bottom of my own TODO list).
My debug server app does not link when SMP is enabled. I am getting:
[13/13] Linking build/arm-rtems4.12-xilinx_zynq_zedboard/net-app.exe
/opt/work/chris/rtems/kernel/4.12/arm-rtems4.12/xilinx_zynq_zedboard/lib/librtemsbsp.a(libbsp_a-arm-cp15-set-ttb-entries.o):
In function `arm_cp15_set_translation_table_entries':
/opt/work/chris/rtems/kernel/rtems.master/c/src/lib/libbsp/arm/xilinx-zynq/../shared/arm-cp15-set-ttb-entries.c:91:
undefined reference to `rtems_interrupt_disable'
/opt/work/chris/rtems/kernel/rtems.master/c/src/lib/libbsp/arm/xilinx-zynq/../shared/arm-cp15-set-ttb-entries.c:94:
undefined reference to `rtems_interrupt_enable'
It seems these functions are not available for SMP however these calls
map to _ISR_level, _ISR_Local_disable and _ISR_Local_enable and these
calls are used in the SMP test
testsuites/smptests/smpthreadlife01/init.c. I am confused.
Sebastian?
