[PATCH v2 2/6] SD card : DMA Driver : Changes over initial commit
    Mudit Jain
    muditjain18011995 at gmail.com
    Mon Aug 22 04:04:14 UTC 2016
Changes required for using the DMA controller for SD card.
 freebsd/sys/arm/broadcom/bcm2835/bcm2835_dma.c | 13 +++++++++++++
 rtemsbsd/include/bsp/nexus-devices.h           | 20 ++++++++++++++++++++
 2 files changed, 33 insertions(+)
diff --git a/freebsd/sys/arm/broadcom/bcm2835/bcm2835_dma.c b/freebsd/sys/arm/broadcom/bcm2835/bcm2835_dma.c
index 98dd2cf..8687207 100644
--- a/freebsd/sys/arm/broadcom/bcm2835/bcm2835_dma.c
+++ b/freebsd/sys/arm/broadcom/bcm2835/bcm2835_dma.c
@@ -42,10 +42,12 @@ __FBSDID("$FreeBSD$");
 #include <rtems/bsd/sys/resource.h>
 #include <sys/rman.h>
+#ifndef __rtems__
 #include <dev/fdt/fdt_common.h>
 #include <dev/ofw/openfirm.h>
 #include <dev/ofw/ofw_bus.h>
 #include <dev/ofw/ofw_bus_subr.h>
+#endif /* __rtems__ */
 #include <vm/vm.h>
 #include <vm/pmap.h>
@@ -657,11 +659,13 @@ static int
 bcm_dma_probe(device_t dev)
+#ifndef __rtems__
 	if (!ofw_bus_status_okay(dev))
 		return (ENXIO);
 	if (!ofw_bus_is_compatible(dev, "broadcom,bcm2835-dma"))
 		return (ENXIO);
 	device_set_desc(dev, "BCM2835 DMA Controller");
 	return (BUS_PROBE_DEFAULT);
@@ -671,7 +675,9 @@ static int
 bcm_dma_attach(device_t dev)
 	struct bcm_dma_softc *sc = device_get_softc(dev);
+#ifndef __rtems__
 	phandle_t node;
 	int rid, err = 0;
 	int i;
@@ -685,6 +691,7 @@ bcm_dma_attach(device_t dev)
 		sc->sc_intrhand[i] = NULL;
+#ifndef __rtems__
 	/* Get DMA channel mask. */
 	node = ofw_bus_get_node(sc->sc_dev);
 	if (OF_getencprop(node, "brcm,dma-channel-mask", &bcm_dma_channel_mask,
@@ -694,6 +701,7 @@ bcm_dma_attach(device_t dev)
 		device_printf(dev, "could not get channel mask property\n");
 		return (ENXIO);
 	/* Mask out channels used by GPU. */
 	bcm_dma_channel_mask &= ~BCM_DMA_CH_GPU_MASK;
@@ -764,5 +772,10 @@ static driver_t bcm_dma_driver = {
 static devclass_t bcm_dma_devclass;
+#ifndef __rtems__
 DRIVER_MODULE(bcm_dma, simplebus, bcm_dma_driver, bcm_dma_devclass, 0, 0);
 MODULE_VERSION(bcm_dma, 1);
+#else /* __rtems__ */
+DRIVER_MODULE(bcm_dma, nexus, bcm_dma_driver, bcm_dma_devclass, 0, 0);
+MODULE_VERSION(bcm_dma, 1);
+#endif
\ No newline at end of file
diff --git a/rtemsbsd/include/bsp/nexus-devices.h b/rtemsbsd/include/bsp/nexus-devices.h
index 3ca21f0..decd042 100644
--- a/rtemsbsd/include/bsp/nexus-devices.h
+++ b/rtemsbsd/include/bsp/nexus-devices.h
@@ -178,4 +178,24 @@ RTEMS_BSD_DEFINE_NEXUS_DEVICE(tsec, 0, RTEMS_ARRAY_SIZE(tsec0_res),
 #endif /* !QORIQ_CHIP_IS_T_VARIANT(QORIQ_CHIP_VARIANT) */
+#elif defined(LIBBSP_ARM_RASPBERRYPI_BSP_H)
+#include <bsp/raspberrypi.h>
+#include <bsp/irq.h>
+static const rtems_bsd_device_resource rpi_dma_res[] = {
+		.type = RTEMS_BSD_RES_MEMORY,
+		.start_request = 0,
+		.start_actual = 0x20007000
+		.type = RTEMS_BSD_RES_IRQ,
+		.start_actual = 16
+RTEMS_BSD_DEFINE_NEXUS_DEVICE(bcm_dma, 0, RTEMS_ARRAY_SIZE(rpi_dma_res),
+&rpi_dma_res[0]);
 #endif
1.9.1
