[PATCH 1/5] SD Card : Initial Port of DMA Controller
Mudit Jain
muditjain18011995 at gmail.com
Tue Aug 23 13:39:26 UTC 2016
Hi Sebastian,
Yes sure, This would be a cleaner approach. Will be doing as you suggested
and uploading the patches.
Thanks
Mudit
On Tue, Aug 23, 2016 at 6:54 PM, Sebastian Huber <
> Hello,
> I updated the MMC stack to use the FreeBSD trunk, 2016-08-23,
> 9fe7c416e6abb28b1398fd3e5687099846800cfd.
> https://git.rtems.org/rtems-libbsd/commit/?id=0c24e06130bd03
> 4474a33a191c6da095f4f59a5e
> Please use exactly this version for your stuff as well.
> For the SDHCI support, please try the following.
> 1. Delete the existing SDHCI support with one commit.
> 2. Do a fresh import of the SDHCI support.
> 3. Do the port to RTEMS.
> On 22/08/16 05:57, Mudit Jain wrote:
>> This is the initial port of the DMA controller
>> from the libbsd using freebsd-to-rtems.py
>> This change is dependent on the interrupt handler
>> in the Mainline.
> Phone : +49 89 189 47 41-16
> Fax : +49 89 189 47 41-09
URL: <http://lists.rtems.org/pipermail/devel/attachments/20160823/6b7b7bfd/attachment-0002.html>
