dl05 does not print END OF TEST message
Chris Johns
chrisj at rtems.org
Thu Dec 1 19:38:49 UTC 2016
> On 2 Dec. 2016, at 3:44 am, Joel Sherrill <joel at rtems.org> wrote:
> dl05 appears to work since it catches the exception but
> so it is recognized as a pass, there needs to be an
> "END OF" test message like the others.
It is a known failure:
https://devel.rtems.org/ticket/2767
The loaded object's exception data is not registered with the base module. I am working on it.
URL: <http://lists.rtems.org/pipermail/devel/attachments/20161202/4d0825a4/attachment.html>
