Test Failures on erc32 (sis)
Fri Dec 2 09:25:05 UTC 2016
On 01/12/16 17:43, Joel Sherrill wrote:
> Hi
> erc32 has a couple of test failures on master:
> *** BEGIN OF TEST PSXSPIN 1 ***
> pthread_spin_init( &spinlock, PTHREAD_PROCESS_PRIVATE ) -- OK
> pthread_spin_destroy( &spinlock ) -- OK
> pthread_spin_init( &spinlock, PTHREAD_PROCESS_SHARED ) -- OK
> pthread_spin_init( &spinlock, 0x1234 ) -- OK
> pthread_spin_init( &spinlock2, 0 ) -- OK
> pthread_spin_lock( &spinlock ) -- OK
> Unexpected trap ( 9) at address 0x02008758
> data access exception at 0x00000008
Sorry, I fixed this.
> *** BEGIN OF TEST SPCONTEXT 1 ***
> Test configuration N N N... done
> Test configuration N N F...
> ../../../../../../../rtems/c/src/../../testsuites/sptests/spcontext01/init.c:
> 44 0
This is:
https://lists.rtems.org/pipermail/devel/2015-October/012729.html
Should we add some warning message for non-SMP SPARC that this test
intentionally fails?
> I have not had a chance to check other BSPs yet.
> Thanks.
> --joel
> devel mailing list
> devel at rtems.org
Phone   : +49 89 189 47 41-16
Fax     : +49 89 189 47 41-09
