[PATCH 2/9] Add INTERNAL_ERROR_RTEMS_INIT_TASK_CREATE_FAILED
Fri Dec 9 08:45:30 UTC 2016
Update #2825.
 cpukit/rtems/src/taskinitusers.c            | 8 ++++++--
 cpukit/sapi/src/interrtext.c                | 3 ++-
 cpukit/score/include/rtems/score/interr.h   | 3 ++-
 testsuites/sptests/spfatal01/testcase.h     | 4 ++--
 testsuites/sptests/spinternalerror02/init.c | 2 +-
 5 files changed, 13 insertions(+), 7 deletions(-)
diff --git a/cpukit/rtems/src/taskinitusers.c b/cpukit/rtems/src/taskinitusers.c
index 5104639..4a851d4 100644
--- a/cpukit/rtems/src/taskinitusers.c
+++ b/cpukit/rtems/src/taskinitusers.c
@@ -88,8 +88,12 @@ void _RTEMS_tasks_Initialize_user_tasks_body( void )
       user_tasks[ index ].attribute_set,
       &id
-    if ( !rtems_is_status_successful( return_value ) )
-      _Terminate( INTERNAL_ERROR_RTEMS_API, return_value );
+    if ( !rtems_is_status_successful( return_value ) ) {
+      _Terminate(
+        INTERNAL_ERROR_CORE,
+        INTERNAL_ERROR_RTEMS_INIT_TASK_CREATE_FAILED
     entry_point = user_tasks[ index ].entry_point;
     if ( entry_point == NULL ) {
diff --git a/cpukit/sapi/src/interrtext.c b/cpukit/sapi/src/interrtext.c
index 860513b..55b79d1 100644
--- a/cpukit/sapi/src/interrtext.c
+++ b/cpukit/sapi/src/interrtext.c
@@ -58,7 +58,8 @@ static const char *const internal_error_text[] = {
   "INTERNAL_ERROR_THREAD_QUEUE_DEADLOCK",
   "INTERNAL_ERROR_THREAD_QUEUE_ENQUEUE_STICKY_FROM_BAD_STATE",
   "INTERNAL_ERROR_BAD_THREAD_DISPATCH_DISABLE_LEVEL",
-  "INTERNAL_ERROR_BAD_THREAD_DISPATCH_ENVIRONMENT"
+  "INTERNAL_ERROR_BAD_THREAD_DISPATCH_ENVIRONMENT",
+  "INTERNAL_ERROR_RTEMS_INIT_TASK_CREATE_FAILED"
 const char *rtems_internal_error_text( rtems_fatal_code error )
diff --git a/cpukit/score/include/rtems/score/interr.h b/cpukit/score/include/rtems/score/interr.h
index b030a22..cd72dea 100644
--- a/cpukit/score/include/rtems/score/interr.h
+++ b/cpukit/score/include/rtems/score/interr.h
@@ -171,7 +171,8 @@ typedef enum {
   INTERNAL_ERROR_THREAD_QUEUE_DEADLOCK = 28,
   INTERNAL_ERROR_THREAD_QUEUE_ENQUEUE_STICKY_FROM_BAD_STATE = 29,
   INTERNAL_ERROR_BAD_THREAD_DISPATCH_DISABLE_LEVEL = 30,
-  INTERNAL_ERROR_BAD_THREAD_DISPATCH_ENVIRONMENT = 31
+  INTERNAL_ERROR_BAD_THREAD_DISPATCH_ENVIRONMENT = 31,
+  INTERNAL_ERROR_RTEMS_INIT_TASK_CREATE_FAILED = 32
 } Internal_errors_Core_list;
 typedef CPU_Uint32ptr Internal_errors_t;
diff --git a/testsuites/sptests/spfatal01/testcase.h b/testsuites/sptests/spfatal01/testcase.h
index 01710dc..19cd16e 100644
--- a/testsuites/sptests/spfatal01/testcase.h
+++ b/testsuites/sptests/spfatal01/testcase.h
@@ -24,8 +24,8 @@ rtems_initialization_tasks_table Initialization_tasks[] = {
 #define FATAL_ERROR_TEST_NAME            "1"
 #define FATAL_ERROR_DESCRIPTION          "Classic API Init task create failure"
-#define FATAL_ERROR_EXPECTED_SOURCE      INTERNAL_ERROR_RTEMS_API
-#define FATAL_ERROR_EXPECTED_ERROR       RTEMS_UNSATISFIED
+#define FATAL_ERROR_EXPECTED_SOURCE      INTERNAL_ERROR_CORE
+#define FATAL_ERROR_EXPECTED_ERROR       INTERNAL_ERROR_RTEMS_INIT_TASK_CREATE_FAILED
 void force_error()
diff --git a/testsuites/sptests/spinternalerror02/init.c b/testsuites/sptests/spinternalerror02/init.c
index 8c1ab36..5bea4f1 100644
--- a/testsuites/sptests/spinternalerror02/init.c
+++ b/testsuites/sptests/spinternalerror02/init.c
@@ -36,7 +36,7 @@ static void test_internal_error_text(void)
   } while ( text != text_last );
   rtems_test_assert(
-    error - 3 == INTERNAL_ERROR_BAD_THREAD_DISPATCH_ENVIRONMENT
+    error - 3 == INTERNAL_ERROR_RTEMS_INIT_TASK_CREATE_FAILED
1.8.4.5
