[PATCH 4/9] score: Introduce _Internal_error()
Fri Dec 9 08:45:32 UTC 2016
 cpukit/libcsupport/src/gxx_wrappers.c             |  4 ++--
 cpukit/libcsupport/src/malloc_initialize.c        |  2 +-
 cpukit/posix/src/pthreadinitthreads.c             | 10 ++--------
 cpukit/rtems/src/taskinitusers.c                  | 10 ++--------
 cpukit/score/cpu/powerpc/ppc-isr-vector-install.c |  2 +-
 cpukit/score/include/rtems/score/interr.h         | 10 ++++++++++
 cpukit/score/src/interr.c                         |  5 +++++
 cpukit/score/src/isr.c                            |  5 +----
 cpukit/score/src/mpci.c                           | 11 ++++-------
 cpukit/score/src/objectinitializeinformation.c    |  5 +----
 cpukit/score/src/objectmp.c                       |  6 +++---
 cpukit/score/src/thread.c                         |  2 +-
 cpukit/score/src/threaddispatch.c                 | 10 ++--------
 cpukit/score/src/threadhandler.c                  |  2 +-
 cpukit/score/src/threadmp.c                       |  2 +-
 cpukit/score/src/threadqenqueue.c                 |  5 ++---
 cpukit/score/src/threadrestart.c                  |  2 +-
 cpukit/score/src/wkspace.c                        |  4 ++--
 18 files changed, 42 insertions(+), 55 deletions(-)
diff --git a/cpukit/libcsupport/src/gxx_wrappers.c b/cpukit/libcsupport/src/gxx_wrappers.c
index 545c3af..d30b570 100644
--- a/cpukit/libcsupport/src/gxx_wrappers.c
+++ b/cpukit/libcsupport/src/gxx_wrappers.c
@@ -137,7 +137,7 @@ int rtems_gxx_setspecific(__gthread_key_t key, const void *ptr)
   #endif
   if ( eno != 0 ) {
-    _Terminate( INTERNAL_ERROR_CORE, INTERNAL_ERROR_GXX_KEY_ADD_FAILED );
+    _Internal_error( INTERNAL_ERROR_GXX_KEY_ADD_FAILED );
   return 0;
@@ -171,7 +171,7 @@ void rtems_gxx_mutex_init (__gthread_mutex_t *mutex)
         status
     #endif
-    _Terminate( INTERNAL_ERROR_CORE, INTERNAL_ERROR_GXX_MUTEX_INIT_FAILED );
+    _Internal_error( INTERNAL_ERROR_GXX_MUTEX_INIT_FAILED );
   #ifdef DEBUG_GXX_WRAPPERS
     printk( "gxx_wrappers: mutex init complete =%X\n", *mutex );
diff --git a/cpukit/libcsupport/src/malloc_initialize.c b/cpukit/libcsupport/src/malloc_initialize.c
index e262c0f..dc94b48 100644
--- a/cpukit/libcsupport/src/malloc_initialize.c
+++ b/cpukit/libcsupport/src/malloc_initialize.c
@@ -50,7 +50,7 @@ void RTEMS_Malloc_Initialize(
     if ( init_or_extend == _Heap_Initialize ) {
-      _Terminate( INTERNAL_ERROR_CORE, INTERNAL_ERROR_NO_MEMORY_FOR_HEAP );
+      _Internal_error( INTERNAL_ERROR_NO_MEMORY_FOR_HEAP );
diff --git a/cpukit/posix/src/pthreadinitthreads.c b/cpukit/posix/src/pthreadinitthreads.c
index 2fdfa53..7695879 100644
--- a/cpukit/posix/src/pthreadinitthreads.c
+++ b/cpukit/posix/src/pthreadinitthreads.c
@@ -85,10 +85,7 @@ void _POSIX_Threads_Initialize_user_threads_body(void)
     thread_entry = user_threads[ index ].thread_entry;
     if ( thread_entry == NULL ) {
-      _Terminate(
-        INTERNAL_ERROR_CORE,
-        INTERNAL_ERROR_POSIX_INIT_THREAD_ENTRY_IS_NULL
+      _Internal_error( INTERNAL_ERROR_POSIX_INIT_THREAD_ENTRY_IS_NULL );
     if ( register_global_construction ) {
@@ -103,10 +100,7 @@ void _POSIX_Threads_Initialize_user_threads_body(void)
       NULL
     if ( eno != 0 ) {
-      _Terminate(
-        INTERNAL_ERROR_POSIX_INIT_THREAD_CREATE_FAILED
+      _Internal_error( INTERNAL_ERROR_POSIX_INIT_THREAD_CREATE_FAILED );
diff --git a/cpukit/rtems/src/taskinitusers.c b/cpukit/rtems/src/taskinitusers.c
index 4a851d4..41b7edc 100644
--- a/cpukit/rtems/src/taskinitusers.c
+++ b/cpukit/rtems/src/taskinitusers.c
@@ -89,18 +89,12 @@ void _RTEMS_tasks_Initialize_user_tasks_body( void )
       &id
     if ( !rtems_is_status_successful( return_value ) ) {
-      _Terminate(
-        INTERNAL_ERROR_RTEMS_INIT_TASK_CREATE_FAILED
+      _Internal_error( INTERNAL_ERROR_RTEMS_INIT_TASK_CREATE_FAILED );
     entry_point = user_tasks[ index ].entry_point;
     if ( entry_point == NULL ) {
-      _Terminate(
-        INTERNAL_ERROR_RTEMS_INIT_TASK_ENTRY_IS_NULL
+      _Internal_error( INTERNAL_ERROR_RTEMS_INIT_TASK_ENTRY_IS_NULL );
diff --git a/cpukit/score/cpu/powerpc/ppc-isr-vector-install.c b/cpukit/score/cpu/powerpc/ppc-isr-vector-install.c
index 7d75fd8..c42c2e2 100644
--- a/cpukit/score/cpu/powerpc/ppc-isr-vector-install.c
+++ b/cpukit/score/cpu/powerpc/ppc-isr-vector-install.c
@@ -31,5 +31,5 @@ void _CPU_ISR_install_vector(
   proc_ptr *old_handler
-  _Terminate( INTERNAL_ERROR_CORE, INTERNAL_ERROR_CPU_ISR_INSTALL_VECTOR );
+  _Internal_error( INTERNAL_ERROR_CPU_ISR_INSTALL_VECTOR );
diff --git a/cpukit/score/include/rtems/score/interr.h b/cpukit/score/include/rtems/score/interr.h
index aaaacf5..254d1f5 100644
--- a/cpukit/score/include/rtems/score/interr.h
+++ b/cpukit/score/include/rtems/score/interr.h
@@ -235,6 +235,16 @@ void _Terminate(
   Internal_errors_t       the_error
 ) RTEMS_NO_RETURN;
+ * @brief Terminates the system with an INTERNAL_ERROR_CORE fatal source and
+ * the specified core error code.
+ * @param[in] core_error The core error code.
+ * @see _Terminate().
+void _Internal_error( Internal_errors_Core_list core_error ) RTEMS_NO_RETURN;
 #ifdef __cplusplus
 #endif
diff --git a/cpukit/score/src/interr.c b/cpukit/score/src/interr.c
index 5993eb9..3a74f95 100644
--- a/cpukit/score/src/interr.c
+++ b/cpukit/score/src/interr.c
@@ -46,3 +46,8 @@ void _Terminate(
   /* will not return from this routine */
   while (true);
+  _Terminate( INTERNAL_ERROR_CORE, core_error );
diff --git a/cpukit/score/src/isr.c b/cpukit/score/src/isr.c
index aaa0513..1078ef6 100644
--- a/cpukit/score/src/isr.c
+++ b/cpukit/score/src/isr.c
@@ -49,10 +49,7 @@ void _ISR_Handler_initialization( void )
     uint32_t cpu_index;
     if ( !_Stack_Is_enough( stack_size ) )
-      _Terminate(
-        INTERNAL_ERROR_INTERRUPT_STACK_TOO_SMALL
+      _Internal_error( INTERNAL_ERROR_INTERRUPT_STACK_TOO_SMALL );
     for ( cpu_index = 0 ; cpu_index < cpu_max; ++cpu_index ) {
       Per_CPU_Control *cpu = _Per_CPU_Get_by_index( cpu_index );
diff --git a/cpukit/score/src/mpci.c b/cpukit/score/src/mpci.c
index e495eb4..89651b9 100644
--- a/cpukit/score/src/mpci.c
+++ b/cpukit/score/src/mpci.c
@@ -95,7 +95,7 @@ static void _MPCI_Handler_initialization( void )
   users_mpci_table = _Configuration_MP_table->User_mpci_table;
   if ( _System_state_Is_multiprocessing && !users_mpci_table )
-    _Terminate( INTERNAL_ERROR_CORE, INTERNAL_ERROR_NO_MPCI );
+    _Internal_error( INTERNAL_ERROR_NO_MPCI );
   _MPCI_table = users_mpci_table;
@@ -187,7 +187,7 @@ MP_packet_Prefix *_MPCI_Get_packet ( void )
   (*_MPCI_table->get_packet)( &the_packet );
   if ( the_packet == NULL )
-    _Terminate( INTERNAL_ERROR_CORE, INTERNAL_ERROR_OUT_OF_PACKETS );
+    _Internal_error( INTERNAL_ERROR_OUT_OF_PACKETS );
    *  Put in a default timeout that will be used for
@@ -367,7 +367,7 @@ void _MPCI_Receive_server(
       the_function = _MPCI_Packet_processors[ the_packet->the_class ];
       if ( !the_function )
-        _Terminate( INTERNAL_ERROR_CORE, INTERNAL_ERROR_BAD_PACKET );
+        _Internal_error( INTERNAL_ERROR_BAD_PACKET );
        (*the_function)( the_packet );
@@ -449,10 +449,7 @@ void _MPCI_Internal_packets_Process_packet (
         _MPCI_Return_packet( the_packet_prefix );
-        _Terminate(
-          INTERNAL_ERROR_INCONSISTENT_MP_INFORMATION
+        _Internal_error( INTERNAL_ERROR_INCONSISTENT_MP_INFORMATION );
diff --git a/cpukit/score/src/objectinitializeinformation.c b/cpukit/score/src/objectinitializeinformation.c
index 92a561a..8b1b88d 100644
--- a/cpukit/score/src/objectinitializeinformation.c
+++ b/cpukit/score/src/objectinitializeinformation.c
@@ -74,10 +74,7 @@ void _Objects_Do_initialize_information(
    *  Unlimited and maximum of zero is illogical.
   if ( information->auto_extend && maximum_per_allocation == 0) {
-    _Terminate(
-      INTERNAL_ERROR_UNLIMITED_AND_MAXIMUM_IS_0
+    _Internal_error( INTERNAL_ERROR_UNLIMITED_AND_MAXIMUM_IS_0 );
diff --git a/cpukit/score/src/objectmp.c b/cpukit/score/src/objectmp.c
index 4e6a838..75a0fdb 100644
--- a/cpukit/score/src/objectmp.c
+++ b/cpukit/score/src/objectmp.c
@@ -165,7 +165,7 @@ void _Objects_MP_Handler_early_initialization(void)
   maximum_nodes          = _Configuration_MP_table->maximum_nodes;
   if ( node < 1 || node > maximum_nodes )
-    _Terminate( INTERNAL_ERROR_CORE, INTERNAL_ERROR_INVALID_NODE );
+    _Internal_error( INTERNAL_ERROR_INVALID_NODE );
   _Objects_Local_node    = node;
   _Objects_Maximum_nodes = maximum_nodes;
@@ -242,7 +242,7 @@ bool _Objects_MP_Allocate_and_open (
     if ( is_fatal_error == false )
       return false;
-    _Terminate( INTERNAL_ERROR_CORE, INTERNAL_ERROR_OUT_OF_GLOBAL_OBJECTS );
+    _Internal_error( INTERNAL_ERROR_OUT_OF_GLOBAL_OBJECTS );
   _Objects_MP_Open( information, the_global_object, the_name, the_id );
@@ -282,7 +282,7 @@ void _Objects_MP_Close (
   } else {
     _Objects_MP_Global_release( &lock_context );
-    _Terminate( INTERNAL_ERROR_CORE, INTERNAL_ERROR_INVALID_GLOBAL_ID );
+    _Internal_error( INTERNAL_ERROR_INVALID_GLOBAL_ID );
diff --git a/cpukit/score/src/thread.c b/cpukit/score/src/thread.c
index 1fcc639..70bcccf 100644
--- a/cpukit/score/src/thread.c
+++ b/cpukit/score/src/thread.c
@@ -84,7 +84,7 @@ void _Thread_Handler_initialization(void)
   if ( rtems_configuration_get_stack_allocate_hook() == NULL ||
        rtems_configuration_get_stack_free_hook() == NULL)
-    _Terminate( INTERNAL_ERROR_CORE, INTERNAL_ERROR_BAD_STACK_HOOK );
+    _Internal_error( INTERNAL_ERROR_BAD_STACK_HOOK );
   if ( stack_allocate_init_hook != NULL )
     (*stack_allocate_init_hook)( rtems_configuration_get_stack_space_size() );
diff --git a/cpukit/score/src/threaddispatch.c b/cpukit/score/src/threaddispatch.c
index 6bce046..5fe0843 100644
--- a/cpukit/score/src/threaddispatch.c
+++ b/cpukit/score/src/threaddispatch.c
@@ -154,10 +154,7 @@ void _Thread_Do_dispatch( Per_CPU_Control *cpu_self, ISR_Level level )
       && rtems_configuration_is_smp_enabled()
 #endif
-    _Terminate(
-      INTERNAL_ERROR_BAD_THREAD_DISPATCH_ENVIRONMENT
+    _Internal_error( INTERNAL_ERROR_BAD_THREAD_DISPATCH_ENVIRONMENT );
 #endif
@@ -238,10 +235,7 @@ void _Thread_Dispatch_direct( Per_CPU_Control *cpu_self )
   ISR_Level level;
   if ( cpu_self->thread_dispatch_disable_level != 1 ) {
-    _Terminate(
-      INTERNAL_ERROR_BAD_THREAD_DISPATCH_DISABLE_LEVEL
+    _Internal_error( INTERNAL_ERROR_BAD_THREAD_DISPATCH_DISABLE_LEVEL );
   _ISR_Local_disable( level );
diff --git a/cpukit/score/src/threadhandler.c b/cpukit/score/src/threadhandler.c
index 721dcf4..7267577 100644
--- a/cpukit/score/src/threadhandler.c
+++ b/cpukit/score/src/threadhandler.c
@@ -96,5 +96,5 @@ void _Thread_Handler( void )
   _User_extensions_Thread_exitted( executing );
-  _Terminate( INTERNAL_ERROR_CORE, INTERNAL_ERROR_THREAD_EXITTED );
+  _Internal_error( INTERNAL_ERROR_THREAD_EXITTED );
diff --git a/cpukit/score/src/threadmp.c b/cpukit/score/src/threadmp.c
index 59f393f..4868e8f 100644
--- a/cpukit/score/src/threadmp.c
+++ b/cpukit/score/src/threadmp.c
@@ -173,7 +173,7 @@ Thread_Control *_Thread_MP_Allocate_proxy (
   _Thread_MP_Proxies_release( &lock_context );
-  _Terminate( INTERNAL_ERROR_CORE, INTERNAL_ERROR_OUT_OF_PROXIES );
+  _Internal_error( INTERNAL_ERROR_OUT_OF_PROXIES );
    *  NOTE: The following return ensures that the compiler will
diff --git a/cpukit/score/src/threadqenqueue.c b/cpukit/score/src/threadqenqueue.c
index a96fbfc..bf08d78 100644
--- a/cpukit/score/src/threadqenqueue.c
+++ b/cpukit/score/src/threadqenqueue.c
@@ -372,7 +372,7 @@ void _Thread_queue_Deadlock_status( Thread_Control *the_thread )
 void _Thread_queue_Deadlock_fatal( Thread_Control *the_thread )
-  _Terminate( INTERNAL_ERROR_CORE, INTERNAL_ERROR_THREAD_QUEUE_DEADLOCK );
+  _Internal_error( INTERNAL_ERROR_THREAD_QUEUE_DEADLOCK );
 static void _Thread_queue_Timeout(
@@ -519,8 +519,7 @@ Status_Control _Thread_queue_Enqueue_sticky(
   _Thread_queue_Queue_release( queue, &queue_context->Lock_context.Lock_context );
-    _Terminate(
+    _Internal_error(
       INTERNAL_ERROR_THREAD_QUEUE_ENQUEUE_STICKY_FROM_BAD_STATE
diff --git a/cpukit/score/src/threadrestart.c b/cpukit/score/src/threadrestart.c
index 4295bc4..5938dcf 100644
--- a/cpukit/score/src/threadrestart.c
+++ b/cpukit/score/src/threadrestart.c
@@ -136,7 +136,7 @@ static void _Thread_Make_zombie( Thread_Control *the_thread )
 #if defined(RTEMS_SCORE_THREAD_ENABLE_RESOURCE_COUNT)
   if ( _Thread_Owns_resources( the_thread ) ) {
-    _Terminate( INTERNAL_ERROR_CORE, INTERNAL_ERROR_RESOURCE_IN_USE );
+    _Internal_error( INTERNAL_ERROR_RESOURCE_IN_USE );
 #endif
diff --git a/cpukit/score/src/wkspace.c b/cpukit/score/src/wkspace.c
index ae48e44..13dfc03 100644
--- a/cpukit/score/src/wkspace.c
+++ b/cpukit/score/src/wkspace.c
@@ -134,7 +134,7 @@ void _Workspace_Handler_initialization(
   if ( remaining > 0 ) {
-    _Terminate( INTERNAL_ERROR_CORE, INTERNAL_ERROR_TOO_LITTLE_WORKSPACE );
+    _Internal_error( INTERNAL_ERROR_TOO_LITTLE_WORKSPACE );
   _Heap_Protection_set_delayed_free_fraction( &_Workspace_Area, 1 );
@@ -200,7 +200,7 @@ void *_Workspace_Allocate_or_fatal_error(
   #endif
   if ( memory == NULL )
-    _Terminate( INTERNAL_ERROR_CORE, INTERNAL_ERROR_WORKSPACE_ALLOCATION );
+    _Internal_error( INTERNAL_ERROR_WORKSPACE_ALLOCATION );
   return memory;
1.8.4.5
