[PATCH 9/9] Add INTERNAL_ERROR_LIBIO_STDERR_FD_OPEN_FAILED
Fri Dec 9 08:45:37 UTC 2016
Update #2825.
 cpukit/libcsupport/src/open_dev_console.c   | 2 +-
 cpukit/sapi/src/interrtext.c                | 3 ++-
 cpukit/score/include/rtems/score/interr.h   | 3 ++-
 testsuites/sptests/spfatal15/testcase.h     | 4 ++--
 testsuites/sptests/spinternalerror02/init.c | 2 +-
 5 files changed, 8 insertions(+), 6 deletions(-)
diff --git a/cpukit/libcsupport/src/open_dev_console.c b/cpukit/libcsupport/src/open_dev_console.c
index 50c1e08..5bba0fb 100644
--- a/cpukit/libcsupport/src/open_dev_console.c
+++ b/cpukit/libcsupport/src/open_dev_console.c
@@ -43,7 +43,7 @@ void rtems_libio_post_driver(void)
   if (open("/dev/console", O_WRONLY, 0) != STDERR_FILENO) {
-    rtems_fatal_error_occurred( 0x55544432 );
+    _Internal_error( INTERNAL_ERROR_LIBIO_STDERR_FD_OPEN_FAILED );
   atexit(rtems_libio_exit);
diff --git a/cpukit/sapi/src/interrtext.c b/cpukit/sapi/src/interrtext.c
index f15c82b..c92f922 100644
--- a/cpukit/sapi/src/interrtext.c
+++ b/cpukit/sapi/src/interrtext.c
@@ -63,7 +63,8 @@ static const char *const internal_error_text[] = {
   "INTERNAL_ERROR_POSIX_INIT_THREAD_CREATE_FAILED",
   "INTERNAL_ERROR_LIBIO_USER_ENV_KEY_CREATE_FAILED",
   "INTERNAL_ERROR_LIBIO_SEM_CREATE_FAILED",
-  "INTERNAL_ERROR_LIBIO_STDOUT_FD_OPEN_FAILED"
+  "INTERNAL_ERROR_LIBIO_STDOUT_FD_OPEN_FAILED",
+  "INTERNAL_ERROR_LIBIO_STDERR_FD_OPEN_FAILED"
 const char *rtems_internal_error_text( rtems_fatal_code error )
diff --git a/cpukit/score/include/rtems/score/interr.h b/cpukit/score/include/rtems/score/interr.h
index 61a4153..7dd6168 100644
--- a/cpukit/score/include/rtems/score/interr.h
+++ b/cpukit/score/include/rtems/score/interr.h
@@ -176,7 +176,8 @@ typedef enum {
   INTERNAL_ERROR_POSIX_INIT_THREAD_CREATE_FAILED = 33,
   INTERNAL_ERROR_LIBIO_USER_ENV_KEY_CREATE_FAILED = 34,
   INTERNAL_ERROR_LIBIO_SEM_CREATE_FAILED = 35,
-  INTERNAL_ERROR_LIBIO_STDOUT_FD_OPEN_FAILED = 36
+  INTERNAL_ERROR_LIBIO_STDOUT_FD_OPEN_FAILED = 36,
+  INTERNAL_ERROR_LIBIO_STDERR_FD_OPEN_FAILED = 37
 } Internal_errors_Core_list;
 typedef CPU_Uint32ptr Internal_errors_t;
diff --git a/testsuites/sptests/spfatal15/testcase.h b/testsuites/sptests/spfatal15/testcase.h
index 742b5b9..fc3d25f 100644
--- a/testsuites/sptests/spfatal15/testcase.h
+++ b/testsuites/sptests/spfatal15/testcase.h
@@ -10,8 +10,8 @@
 /* generate fatal errors in open_dev_console.c */
 #define FATAL_ERROR_TEST_NAME            "15"
 #define FATAL_ERROR_DESCRIPTION          "fail to open stderr"
-#define FATAL_ERROR_EXPECTED_SOURCE      INTERNAL_ERROR_RTEMS_API
-#define FATAL_ERROR_EXPECTED_ERROR       0x55544432
+#define FATAL_ERROR_EXPECTED_SOURCE      INTERNAL_ERROR_CORE
+#define FATAL_ERROR_EXPECTED_ERROR       INTERNAL_ERROR_LIBIO_STDERR_FD_OPEN_FAILED
 #define CONFIGURE_LIBIO_MAXIMUM_FILE_DESCRIPTORS 2
diff --git a/testsuites/sptests/spinternalerror02/init.c b/testsuites/sptests/spinternalerror02/init.c
index aa5f12e..4126755 100644
--- a/testsuites/sptests/spinternalerror02/init.c
+++ b/testsuites/sptests/spinternalerror02/init.c
@@ -36,7 +36,7 @@ static void test_internal_error_text(void)
   } while ( text != text_last );
   rtems_test_assert(
-    error - 3 == INTERNAL_ERROR_LIBIO_STDOUT_FD_OPEN_FAILED
+    error - 3 == INTERNAL_ERROR_LIBIO_STDERR_FD_OPEN_FAILED
1.8.4.5
