[PATCH 6/9] Add INTERNAL_ERROR_LIBIO_SEM_CREATE_FAILED
Fri Dec 9 08:45:34 UTC 2016
Update #2825.
 cpukit/libcsupport/src/libio_init.c         | 5 +++--
 cpukit/sapi/src/interrtext.c                | 3 ++-
 cpukit/score/include/rtems/score/interr.h   | 3 ++-
 testsuites/sptests/spinternalerror02/init.c | 2 +-
 4 files changed, 8 insertions(+), 5 deletions(-)
diff --git a/cpukit/libcsupport/src/libio_init.c b/cpukit/libcsupport/src/libio_init.c
index a265290..3fa9e09 100644
--- a/cpukit/libcsupport/src/libio_init.c
+++ b/cpukit/libcsupport/src/libio_init.c
@@ -79,8 +79,9 @@ static void rtems_libio_init( void )
     RTEMS_NO_PRIORITY,
     &rtems_libio_semaphore
-  if ( rc != RTEMS_SUCCESSFUL )
-    rtems_fatal_error_occurred( rc );
+  if ( rc != RTEMS_SUCCESSFUL ) {
+    _Internal_error( INTERNAL_ERROR_LIBIO_SEM_CREATE_FAILED );
 RTEMS_SYSINIT_ITEM(
diff --git a/cpukit/sapi/src/interrtext.c b/cpukit/sapi/src/interrtext.c
index 916d582..2285cd3 100644
--- a/cpukit/sapi/src/interrtext.c
+++ b/cpukit/sapi/src/interrtext.c
@@ -61,7 +61,8 @@ static const char *const internal_error_text[] = {
   "INTERNAL_ERROR_BAD_THREAD_DISPATCH_ENVIRONMENT",
   "INTERNAL_ERROR_RTEMS_INIT_TASK_CREATE_FAILED",
   "INTERNAL_ERROR_POSIX_INIT_THREAD_CREATE_FAILED",
-  "INTERNAL_ERROR_LIBIO_USER_ENV_KEY_CREATE_FAILED"
+  "INTERNAL_ERROR_LIBIO_USER_ENV_KEY_CREATE_FAILED",
+  "INTERNAL_ERROR_LIBIO_SEM_CREATE_FAILED"
 const char *rtems_internal_error_text( rtems_fatal_code error )
diff --git a/cpukit/score/include/rtems/score/interr.h b/cpukit/score/include/rtems/score/interr.h
index 3bcece0..d6a961e 100644
--- a/cpukit/score/include/rtems/score/interr.h
+++ b/cpukit/score/include/rtems/score/interr.h
@@ -174,7 +174,8 @@ typedef enum {
   INTERNAL_ERROR_BAD_THREAD_DISPATCH_ENVIRONMENT = 31,
   INTERNAL_ERROR_RTEMS_INIT_TASK_CREATE_FAILED = 32,
   INTERNAL_ERROR_POSIX_INIT_THREAD_CREATE_FAILED = 33,
-  INTERNAL_ERROR_LIBIO_USER_ENV_KEY_CREATE_FAILED = 34
+  INTERNAL_ERROR_LIBIO_USER_ENV_KEY_CREATE_FAILED = 34,
+  INTERNAL_ERROR_LIBIO_SEM_CREATE_FAILED = 35
 } Internal_errors_Core_list;
 typedef CPU_Uint32ptr Internal_errors_t;
diff --git a/testsuites/sptests/spinternalerror02/init.c b/testsuites/sptests/spinternalerror02/init.c
index 1d24863..69bc89f 100644
--- a/testsuites/sptests/spinternalerror02/init.c
+++ b/testsuites/sptests/spinternalerror02/init.c
@@ -36,7 +36,7 @@ static void test_internal_error_text(void)
   } while ( text != text_last );
   rtems_test_assert(
-    error - 3 == INTERNAL_ERROR_LIBIO_USER_ENV_KEY_CREATE_FAILED
+    error - 3 == INTERNAL_ERROR_LIBIO_SEM_CREATE_FAILED
1.8.4.5
