[PATCH 1/9] score: Remove fatal is internal indicator
Fri Dec 9 08:45:29 UTC 2016
The fatal is internal indicator is redundant since the fatal source and
error code uniquely identify a fatal error.  Keep the fatal user
extension is internal parameter for backward compatibility and set it to
false always.
Update #2825.
 c/src/lib/libbsp/powerpc/shared/startup/panic.c   |  2 --
 cpukit/libcsupport/src/gxx_wrappers.c             | 12 ++------
 cpukit/libcsupport/src/malloc_initialize.c        |  6 +---
 cpukit/posix/src/pthreadinitthreads.c             |  1 -
 cpukit/rtems/src/taskinitusers.c                  |  3 +-
 cpukit/sapi/Makefile.am                           |  2 +-
 cpukit/sapi/include/rtems/fatal.h                 | 17 ++++++-----
 cpukit/sapi/src/exshutdown.c                      |  2 +-
 cpukit/sapi/src/fatal.c                           |  2 +-
 cpukit/sapi/src/fatal2.c                          | 35 -----------------------
 cpukit/sapi/src/posixapi.c                        |  2 +-
 cpukit/score/cpu/nios2/nios2-context-initialize.c |  2 +-
 cpukit/score/cpu/nios2/nios2-isr-get-level.c      |  2 +-
 cpukit/score/cpu/nios2/nios2-isr-set-level.c      |  2 +-
 cpukit/score/cpu/powerpc/ppc-isr-vector-install.c |  6 +---
 cpukit/score/include/rtems/score/interr.h         |  7 +----
 cpukit/score/include/rtems/score/smpimpl.h        |  2 +-
 cpukit/score/include/rtems/score/userext.h        |  4 +--
 cpukit/score/include/rtems/score/userextimpl.h    |  4 +--
 cpukit/score/src/heap.c                           |  2 +-
 cpukit/score/src/interr.c                         | 12 ++++----
 cpukit/score/src/isr.c                            |  1 -
 cpukit/score/src/mpci.c                           | 19 ++----------
 cpukit/score/src/objectinitializeinformation.c    |  1 -
 cpukit/score/src/objectmp.c                       | 19 ++----------
 cpukit/score/src/thread.c                         |  6 +---
 cpukit/score/src/threaddispatch.c                 |  2 --
 cpukit/score/src/threadhandler.c                  |  6 +---
 cpukit/score/src/threadmp.c                       |  6 +---
 cpukit/score/src/threadqenqueue.c                 |  7 +----
 cpukit/score/src/threadrestart.c                  |  6 +---
 cpukit/score/src/userextiterate.c                 |  2 +-
 cpukit/score/src/wkspace.c                        | 12 ++------
 testsuites/libtests/devnullfatal01/testcase.h     |  1 -
 testsuites/psxtests/psxfatal01/testcase.h         |  1 -
 testsuites/psxtests/psxfatal02/testcase.h         |  1 -
 testsuites/psxtests/psxfatal_support/init.c       | 11 ++-----
 testsuites/sptests/spfatal01/testcase.h           |  1 -
 testsuites/sptests/spfatal02/testcase.h           |  1 -
 testsuites/sptests/spfatal03/testcase.h           |  1 -
 testsuites/sptests/spfatal04/testcase.h           |  1 -
 testsuites/sptests/spfatal05/testcase.h           |  1 -
 testsuites/sptests/spfatal06/testcase.h           |  1 -
 testsuites/sptests/spfatal07/testcase.h           |  1 -
 testsuites/sptests/spfatal08/testcase.h           |  1 -
 testsuites/sptests/spfatal09/testcase.h           |  1 -
 testsuites/sptests/spfatal10/testcase.h           |  1 -
 testsuites/sptests/spfatal11/testcase.h           |  1 -
 testsuites/sptests/spfatal12/testcase.h           |  1 -
 testsuites/sptests/spfatal13/testcase.h           |  1 -
 testsuites/sptests/spfatal14/testcase.h           |  1 -
 testsuites/sptests/spfatal15/testcase.h           |  1 -
 testsuites/sptests/spfatal16/testcase.h           |  1 -
 testsuites/sptests/spfatal17/testcase.h           |  1 -
 testsuites/sptests/spfatal18/testcase.h           |  1 -
 testsuites/sptests/spfatal19/testcase.h           |  1 -
 testsuites/sptests/spfatal20/testcase.h           |  1 -
 testsuites/sptests/spfatal24/testcase.h           |  1 -
 testsuites/sptests/spfatal25/testcase.h           |  1 -
 testsuites/sptests/spfatal27/testcase.h           |  1 -
 testsuites/sptests/spfatal28/testcase.h           |  3 +-
 testsuites/sptests/spfatal29/testcase.h           |  1 -
 testsuites/sptests/spfatal_support/init.c         | 17 ++++-------
 testsuites/sptests/spinternalerror01/init.c       | 10 ++-----
 testsuites/sptests/sptimecounter01/init.c         |  2 +-
 65 files changed, 59 insertions(+), 225 deletions(-)
 delete mode 100644 cpukit/sapi/src/fatal2.c
diff --git a/c/src/lib/libbsp/powerpc/shared/startup/panic.c b/c/src/lib/libbsp/powerpc/shared/startup/panic.c
index bff7aeb..9b0aa75 100644
--- a/c/src/lib/libbsp/powerpc/shared/startup/panic.c
+++ b/c/src/lib/libbsp/powerpc/shared/startup/panic.c
@@ -23,7 +23,6 @@ void BSP_panic(char *s)
 #define THESRC _Internal_errors_What_happened.the_source
-#define ISITNL _Internal_errors_What_happened.is_internal
 #define THEERR _Internal_errors_What_happened.the_error
 void _BSP_Fatal_error(unsigned int v)
@@ -36,7 +35,6 @@ void _BSP_Fatal_error(unsigned int v)
   printk("%s\n",_RTEMS_version);
   printk("FATAL ERROR:\n");
-  printk("Internal error: %s\n", ISITNL? "Yes":"No");
   printk("Environment:");
   switch (THESRC) {
     case INTERNAL_ERROR_CORE:
diff --git a/cpukit/libcsupport/src/gxx_wrappers.c b/cpukit/libcsupport/src/gxx_wrappers.c
index 82f4bdb..545c3af 100644
--- a/cpukit/libcsupport/src/gxx_wrappers.c
+++ b/cpukit/libcsupport/src/gxx_wrappers.c
@@ -137,11 +137,7 @@ int rtems_gxx_setspecific(__gthread_key_t key, const void *ptr)
   #endif
   if ( eno != 0 ) {
-    _Terminate(
-      INTERNAL_ERROR_CORE,
-      true,
-      INTERNAL_ERROR_GXX_KEY_ADD_FAILED
+    _Terminate( INTERNAL_ERROR_CORE, INTERNAL_ERROR_GXX_KEY_ADD_FAILED );
   return 0;
@@ -175,11 +171,7 @@ void rtems_gxx_mutex_init (__gthread_mutex_t *mutex)
         status
     #endif
-    _Terminate(
-      true,
-      INTERNAL_ERROR_GXX_MUTEX_INIT_FAILED
+    _Terminate( INTERNAL_ERROR_CORE, INTERNAL_ERROR_GXX_MUTEX_INIT_FAILED );
   #ifdef DEBUG_GXX_WRAPPERS
     printk( "gxx_wrappers: mutex init complete =%X\n", *mutex );
diff --git a/cpukit/libcsupport/src/malloc_initialize.c b/cpukit/libcsupport/src/malloc_initialize.c
index 60fe2d9..e262c0f 100644
--- a/cpukit/libcsupport/src/malloc_initialize.c
+++ b/cpukit/libcsupport/src/malloc_initialize.c
@@ -50,11 +50,7 @@ void RTEMS_Malloc_Initialize(
     if ( init_or_extend == _Heap_Initialize ) {
-      _Terminate(
-        true,
-        INTERNAL_ERROR_NO_MEMORY_FOR_HEAP
+      _Terminate( INTERNAL_ERROR_CORE, INTERNAL_ERROR_NO_MEMORY_FOR_HEAP );
diff --git a/cpukit/posix/src/pthreadinitthreads.c b/cpukit/posix/src/pthreadinitthreads.c
index ff11e8a..3cfb92d 100644
--- a/cpukit/posix/src/pthreadinitthreads.c
+++ b/cpukit/posix/src/pthreadinitthreads.c
@@ -87,7 +87,6 @@ void _POSIX_Threads_Initialize_user_threads_body(void)
     if ( thread_entry == NULL ) {
       _Terminate(
-        false,
         INTERNAL_ERROR_POSIX_INIT_THREAD_ENTRY_IS_NULL
diff --git a/cpukit/rtems/src/taskinitusers.c b/cpukit/rtems/src/taskinitusers.c
index 81b6c04..5104639 100644
--- a/cpukit/rtems/src/taskinitusers.c
+++ b/cpukit/rtems/src/taskinitusers.c
@@ -89,13 +89,12 @@ void _RTEMS_tasks_Initialize_user_tasks_body( void )
       &id
     if ( !rtems_is_status_successful( return_value ) )
-      _Terminate( INTERNAL_ERROR_RTEMS_API, true, return_value );
+      _Terminate( INTERNAL_ERROR_RTEMS_API, return_value );
     entry_point = user_tasks[ index ].entry_point;
     if ( entry_point == NULL ) {
       _Terminate(
-        false,
         INTERNAL_ERROR_RTEMS_INIT_TASK_ENTRY_IS_NULL
diff --git a/cpukit/sapi/Makefile.am b/cpukit/sapi/Makefile.am
index 4e85062..50d065b 100644
--- a/cpukit/sapi/Makefile.am
+++ b/cpukit/sapi/Makefile.am
@@ -34,7 +34,7 @@ libsapi_a_SOURCES = src/extension.c src/extensioncreate.c \
     src/getversionstring.c \
     src/chainappendnotify.c src/chaingetnotify.c src/chaingetwait.c \
     src/chainprependnotify.c src/rbheap.c src/interrtext.c \
-    src/fatal2.c src/fatalsrctext.c
+    src/fatalsrctext.c
 libsapi_a_SOURCES += src/chainprotected.c
 libsapi_a_SOURCES += src/cpucounterconverter.c
 libsapi_a_SOURCES += src/delayticks.c
diff --git a/cpukit/sapi/include/rtems/fatal.h b/cpukit/sapi/include/rtems/fatal.h
index b4b3b0f..03cfafa 100644
--- a/cpukit/sapi/include/rtems/fatal.h
+++ b/cpukit/sapi/include/rtems/fatal.h
@@ -73,17 +73,20 @@ void rtems_fatal_error_occurred(
 ) RTEMS_NO_RETURN;
- * @brief Invokes the internal error handler with is internal set to false.
+ * @brief Terminates the system.
- * @param[in] source is the fatal source.
- * @param[in] error is the fatal code.
+ * @param[in] fatal_source The fatal source.
+ * @param[in] error_code The error code.
  * @see _Terminate().
-void rtems_fatal(
-  rtems_fatal_source source,
-  rtems_fatal_code error
-) RTEMS_NO_RETURN;
+RTEMS_INLINE_ROUTINE void rtems_fatal(
+  rtems_fatal_source fatal_source,
+  rtems_fatal_code   error_code
+  _Terminate( fatal_source, error_code );
  * @brief Returns a text for a fatal source.
diff --git a/cpukit/sapi/src/exshutdown.c b/cpukit/sapi/src/exshutdown.c
index 9306eaf..4f70091 100644
--- a/cpukit/sapi/src/exshutdown.c
+++ b/cpukit/sapi/src/exshutdown.c
@@ -18,7 +18,7 @@
 void rtems_shutdown_executive( uint32_t result )
-  _Terminate( RTEMS_FATAL_SOURCE_EXIT, false, result );
+  _Terminate( RTEMS_FATAL_SOURCE_EXIT, result );
diff --git a/cpukit/sapi/src/fatal.c b/cpukit/sapi/src/fatal.c
index 684e878..4a0314a 100644
--- a/cpukit/sapi/src/fatal.c
+++ b/cpukit/sapi/src/fatal.c
@@ -30,7 +30,7 @@ void rtems_fatal_error_occurred(
   uint32_t   the_error
-  _Terminate( INTERNAL_ERROR_RTEMS_API, FALSE, the_error );
+  _Terminate( INTERNAL_ERROR_RTEMS_API, the_error );
 /* will not return from this routine */
diff --git a/cpukit/sapi/src/fatal2.c b/cpukit/sapi/src/fatal2.c
deleted file mode 100644
index faa9cdb..0000000
--- a/cpukit/sapi/src/fatal2.c
+++ /dev/null
@@ -1,35 +0,0 @@
- * @file
- * @ingroup ClassicFatal
- * Copyright (c) 2012 embedded brains GmbH.  All rights reserved.
- *  embedded brains GmbH
- *  Obere Lagerstr. 30
- *  82178 Puchheim
- *  Germany
- *  <rtems at embedded-brains.de>
- * The license and distribution terms for this file may be
- * found in the file LICENSE in this distribution or at
- * http://www.rtems.org/license/LICENSE.
-#if HAVE_CONFIG_H
-  #include "config.h"
-#endif
-#include <rtems/fatal.h>
-void rtems_fatal(
-  _Terminate( source, false, error );
diff --git a/cpukit/sapi/src/posixapi.c b/cpukit/sapi/src/posixapi.c
index d1de103..e7d34fd 100644
--- a/cpukit/sapi/src/posixapi.c
+++ b/cpukit/sapi/src/posixapi.c
@@ -25,5 +25,5 @@ void _POSIX_Fatal_error( POSIX_Fatal_domain domain, int eno )
   uint32_t code = ( domain << 8 ) | ( ( uint32_t ) eno & 0xffU );
-  _Terminate( INTERNAL_ERROR_POSIX_API, false, code );
+  _Terminate( INTERNAL_ERROR_POSIX_API, code );
diff --git a/cpukit/score/cpu/nios2/nios2-context-initialize.c b/cpukit/score/cpu/nios2/nios2-context-initialize.c
index 5313327..7468bec 100644
--- a/cpukit/score/cpu/nios2/nios2-context-initialize.c
+++ b/cpukit/score/cpu/nios2/nios2-context-initialize.c
@@ -62,7 +62,7 @@ void _CPU_Context_Initialize(
     if ( !ok ) {
       /* The task stack allocator must ensure that the stack area is valid */
-      _Terminate( INTERNAL_ERROR_CORE, false, 0xdeadbeef );
+      _Terminate( INTERNAL_ERROR_CORE, 0xdeadbeef );
diff --git a/cpukit/score/cpu/nios2/nios2-isr-get-level.c b/cpukit/score/cpu/nios2/nios2-isr-get-level.c
index dad4053..9380437 100644
--- a/cpukit/score/cpu/nios2/nios2-isr-get-level.c
+++ b/cpukit/score/cpu/nios2/nios2-isr-get-level.c
@@ -48,7 +48,7 @@ uint32_t _CPU_ISR_Get_level( void )
       break;
     default:
       /* FIXME */
       break;
diff --git a/cpukit/score/cpu/nios2/nios2-isr-set-level.c b/cpukit/score/cpu/nios2/nios2-isr-set-level.c
index 422f990..9eb8dec 100644
--- a/cpukit/score/cpu/nios2/nios2-isr-set-level.c
+++ b/cpukit/score/cpu/nios2/nios2-isr-set-level.c
@@ -48,7 +48,7 @@ uint32_t _Nios2_ISR_Set_level( uint32_t new_level, uint32_t status )
       break;
     default:
       /* FIXME */
       break;
diff --git a/cpukit/score/cpu/powerpc/ppc-isr-vector-install.c b/cpukit/score/cpu/powerpc/ppc-isr-vector-install.c
index eab211f..7d75fd8 100644
--- a/cpukit/score/cpu/powerpc/ppc-isr-vector-install.c
+++ b/cpukit/score/cpu/powerpc/ppc-isr-vector-install.c
@@ -31,9 +31,5 @@ void _CPU_ISR_install_vector(
   proc_ptr *old_handler
-  _Terminate(
-    false,
-    INTERNAL_ERROR_CPU_ISR_INSTALL_VECTOR
+  _Terminate( INTERNAL_ERROR_CORE, INTERNAL_ERROR_CPU_ISR_INSTALL_VECTOR );
diff --git a/cpukit/score/include/rtems/score/interr.h b/cpukit/score/include/rtems/score/interr.h
index 0bd1eec..b030a22 100644
--- a/cpukit/score/include/rtems/score/interr.h
+++ b/cpukit/score/include/rtems/score/interr.h
@@ -182,8 +182,6 @@ typedef CPU_Uint32ptr Internal_errors_t;
 typedef struct {
   /** This is the source of the error. */
   Internal_errors_Source  the_source;
-  /** This indicates if the error is internal of external. */
-  bool                    is_internal;
   /** This is the error code. */
   Internal_errors_t       the_error;
 } Internal_errors_Information;
@@ -225,16 +223,13 @@ extern Internal_errors_Information _Internal_errors_What_happened;
  * @param[in] the_source The fatal source indicating the subsystem the fatal
  * condition originated in.
- * @param[in] is_internal Indicates if the fatal condition was generated
- * internally to the executive.
  * @param[in] the_error The fatal error code.  This value must be interpreted
  * with respect to the source.
- * @see rtems_fatal_error_occurred() and rtems_fatal().
+ * @see rtems_fatal() and _Internal_error().
 void _Terminate(
   Internal_errors_Source  the_source,
-  bool                    is_internal,
 ) RTEMS_NO_RETURN;
diff --git a/cpukit/score/include/rtems/score/smpimpl.h b/cpukit/score/include/rtems/score/smpimpl.h
index 7f2de5f..1651a5e 100644
--- a/cpukit/score/include/rtems/score/smpimpl.h
+++ b/cpukit/score/include/rtems/score/smpimpl.h
@@ -84,7 +84,7 @@ typedef enum {
 static inline void _SMP_Fatal( SMP_Fatal_code code )
-  _Terminate( RTEMS_FATAL_SOURCE_SMP, false, code );
+  _Terminate( RTEMS_FATAL_SOURCE_SMP, code );
diff --git a/cpukit/score/include/rtems/score/userext.h b/cpukit/score/include/rtems/score/userext.h
index e626f2f..61de992 100644
--- a/cpukit/score/include/rtems/score/userext.h
+++ b/cpukit/score/include/rtems/score/userext.h
@@ -195,8 +195,8 @@ typedef void( *User_extensions_thread_exitted_extension )(
  * @param[in] source The fatal source indicating the subsystem the fatal
+ * @param[in] is_internal This parameter is always false and provide only for
+ * backward compatibility reasons.
  * @param[in] code The fatal error code.  This value must be interpreted with
  * respect to the source.
diff --git a/cpukit/score/include/rtems/score/userextimpl.h b/cpukit/score/include/rtems/score/userextimpl.h
index e6692c8..6684c4a 100644
--- a/cpukit/score/include/rtems/score/userextimpl.h
+++ b/cpukit/score/include/rtems/score/userextimpl.h
@@ -166,7 +166,6 @@ void _User_extensions_Thread_exitted_visitor(
 typedef struct {
   Internal_errors_Source source;
-  bool                   is_internal;
   Internal_errors_t      error;
 } User_extensions_Fatal_context;
@@ -300,11 +299,10 @@ static inline void _User_extensions_Thread_exitted( Thread_Control *executing )
 static inline void _User_extensions_Fatal(
   Internal_errors_Source source,
-  bool                   is_internal,
-  User_extensions_Fatal_context ctx = { source, is_internal, error };
+  User_extensions_Fatal_context ctx = { source, error };
   _User_extensions_Iterate(
     &ctx,
diff --git a/cpukit/score/src/heap.c b/cpukit/score/src/heap.c
index 3fddb1a..402f631 100644
--- a/cpukit/score/src/heap.c
+++ b/cpukit/score/src/heap.c
@@ -157,7 +157,7 @@
     /* FIXME */
 #endif
diff --git a/cpukit/score/src/interr.c b/cpukit/score/src/interr.c
index 8740027..5993eb9 100644
--- a/cpukit/score/src/interr.c
+++ b/cpukit/score/src/interr.c
@@ -28,16 +28,14 @@ System_state_Codes _System_state_Current;
 void _Terminate(
-  Internal_errors_Source  the_source,
-  bool                    is_internal,
-  Internal_errors_t       the_error
+  Internal_errors_Source the_source,
+  Internal_errors_t      the_error
-  _User_extensions_Fatal( the_source, is_internal, the_error );
+  _User_extensions_Fatal( the_source, the_error );
-  _Internal_errors_What_happened.the_source  = the_source;
-  _Internal_errors_What_happened.is_internal = is_internal;
-  _Internal_errors_What_happened.the_error   = the_error;
+  _Internal_errors_What_happened.the_source = the_source;
+  _Internal_errors_What_happened.the_error  = the_error;
   _System_state_Set( SYSTEM_STATE_TERMINATED );
diff --git a/cpukit/score/src/isr.c b/cpukit/score/src/isr.c
index 1ae6e59..aaa0513 100644
--- a/cpukit/score/src/isr.c
+++ b/cpukit/score/src/isr.c
@@ -51,7 +51,6 @@ void _ISR_Handler_initialization( void )
     if ( !_Stack_Is_enough( stack_size ) )
       _Terminate(
-        true,
         INTERNAL_ERROR_INTERRUPT_STACK_TOO_SMALL
diff --git a/cpukit/score/src/mpci.c b/cpukit/score/src/mpci.c
index 2f0a2de..e495eb4 100644
--- a/cpukit/score/src/mpci.c
+++ b/cpukit/score/src/mpci.c
@@ -95,11 +95,7 @@ static void _MPCI_Handler_initialization( void )
   users_mpci_table = _Configuration_MP_table->User_mpci_table;
   if ( _System_state_Is_multiprocessing && !users_mpci_table )
-    _Terminate(
-      true,
-      INTERNAL_ERROR_NO_MPCI
+    _Terminate( INTERNAL_ERROR_CORE, INTERNAL_ERROR_NO_MPCI );
   _MPCI_table = users_mpci_table;
@@ -191,11 +187,7 @@ MP_packet_Prefix *_MPCI_Get_packet ( void )
   (*_MPCI_table->get_packet)( &the_packet );
   if ( the_packet == NULL )
-    _Terminate(
-      true,
-      INTERNAL_ERROR_OUT_OF_PACKETS
+    _Terminate( INTERNAL_ERROR_CORE, INTERNAL_ERROR_OUT_OF_PACKETS );
    *  Put in a default timeout that will be used for
@@ -375,11 +367,7 @@ void _MPCI_Receive_server(
       the_function = _MPCI_Packet_processors[ the_packet->the_class ];
       if ( !the_function )
-        _Terminate(
-          true,
-          INTERNAL_ERROR_BAD_PACKET
+        _Terminate( INTERNAL_ERROR_CORE, INTERNAL_ERROR_BAD_PACKET );
        (*the_function)( the_packet );
@@ -463,7 +451,6 @@ void _MPCI_Internal_packets_Process_packet (
         _Terminate(
-          true,
           INTERNAL_ERROR_INCONSISTENT_MP_INFORMATION
diff --git a/cpukit/score/src/objectinitializeinformation.c b/cpukit/score/src/objectinitializeinformation.c
index dc8a106..92a561a 100644
--- a/cpukit/score/src/objectinitializeinformation.c
+++ b/cpukit/score/src/objectinitializeinformation.c
@@ -76,7 +76,6 @@ void _Objects_Do_initialize_information(
   if ( information->auto_extend && maximum_per_allocation == 0) {
     _Terminate(
-      true,
       INTERNAL_ERROR_UNLIMITED_AND_MAXIMUM_IS_0
diff --git a/cpukit/score/src/objectmp.c b/cpukit/score/src/objectmp.c
index b97a9d5..4e6a838 100644
--- a/cpukit/score/src/objectmp.c
+++ b/cpukit/score/src/objectmp.c
@@ -165,11 +165,7 @@ void _Objects_MP_Handler_early_initialization(void)
   maximum_nodes          = _Configuration_MP_table->maximum_nodes;
   if ( node < 1 || node > maximum_nodes )
-    _Terminate(
-      true,
-      INTERNAL_ERROR_INVALID_NODE
+    _Terminate( INTERNAL_ERROR_CORE, INTERNAL_ERROR_INVALID_NODE );
   _Objects_Local_node    = node;
   _Objects_Maximum_nodes = maximum_nodes;
@@ -246,12 +242,7 @@ bool _Objects_MP_Allocate_and_open (
     if ( is_fatal_error == false )
       return false;
-    _Terminate(
-      true,
-      INTERNAL_ERROR_OUT_OF_GLOBAL_OBJECTS
+    _Terminate( INTERNAL_ERROR_CORE, INTERNAL_ERROR_OUT_OF_GLOBAL_OBJECTS );
   _Objects_MP_Open( information, the_global_object, the_name, the_id );
@@ -291,11 +282,7 @@ void _Objects_MP_Close (
   } else {
     _Objects_MP_Global_release( &lock_context );
-    _Terminate(
-      true,
-      INTERNAL_ERROR_INVALID_GLOBAL_ID
+    _Terminate( INTERNAL_ERROR_CORE, INTERNAL_ERROR_INVALID_GLOBAL_ID );
diff --git a/cpukit/score/src/thread.c b/cpukit/score/src/thread.c
index a0ba61d..1fcc639 100644
--- a/cpukit/score/src/thread.c
+++ b/cpukit/score/src/thread.c
@@ -84,11 +84,7 @@ void _Thread_Handler_initialization(void)
   if ( rtems_configuration_get_stack_allocate_hook() == NULL ||
        rtems_configuration_get_stack_free_hook() == NULL)
-    _Terminate(
-      true,
-      INTERNAL_ERROR_BAD_STACK_HOOK
+    _Terminate( INTERNAL_ERROR_CORE, INTERNAL_ERROR_BAD_STACK_HOOK );
   if ( stack_allocate_init_hook != NULL )
     (*stack_allocate_init_hook)( rtems_configuration_get_stack_space_size() );
diff --git a/cpukit/score/src/threaddispatch.c b/cpukit/score/src/threaddispatch.c
index 4f89475..6bce046 100644
--- a/cpukit/score/src/threaddispatch.c
+++ b/cpukit/score/src/threaddispatch.c
@@ -156,7 +156,6 @@ void _Thread_Do_dispatch( Per_CPU_Control *cpu_self, ISR_Level level )
     _Terminate(
-      false,
       INTERNAL_ERROR_BAD_THREAD_DISPATCH_ENVIRONMENT
@@ -241,7 +240,6 @@ void _Thread_Dispatch_direct( Per_CPU_Control *cpu_self )
   if ( cpu_self->thread_dispatch_disable_level != 1 ) {
     _Terminate(
-      0,
       INTERNAL_ERROR_BAD_THREAD_DISPATCH_DISABLE_LEVEL
diff --git a/cpukit/score/src/threadhandler.c b/cpukit/score/src/threadhandler.c
index a8d6580..721dcf4 100644
--- a/cpukit/score/src/threadhandler.c
+++ b/cpukit/score/src/threadhandler.c
@@ -96,9 +96,5 @@ void _Thread_Handler( void )
   _User_extensions_Thread_exitted( executing );
-  _Terminate(
-    true,
-    INTERNAL_ERROR_THREAD_EXITTED
+  _Terminate( INTERNAL_ERROR_CORE, INTERNAL_ERROR_THREAD_EXITTED );
diff --git a/cpukit/score/src/threadmp.c b/cpukit/score/src/threadmp.c
index 22078a7..59f393f 100644
--- a/cpukit/score/src/threadmp.c
+++ b/cpukit/score/src/threadmp.c
@@ -173,11 +173,7 @@ Thread_Control *_Thread_MP_Allocate_proxy (
   _Thread_MP_Proxies_release( &lock_context );
-  _Terminate(
-    true,
-    INTERNAL_ERROR_OUT_OF_PROXIES
+  _Terminate( INTERNAL_ERROR_CORE, INTERNAL_ERROR_OUT_OF_PROXIES );
    *  NOTE: The following return ensures that the compiler will
diff --git a/cpukit/score/src/threadqenqueue.c b/cpukit/score/src/threadqenqueue.c
index cea1886..a96fbfc 100644
--- a/cpukit/score/src/threadqenqueue.c
+++ b/cpukit/score/src/threadqenqueue.c
@@ -372,11 +372,7 @@ void _Thread_queue_Deadlock_status( Thread_Control *the_thread )
 void _Thread_queue_Deadlock_fatal( Thread_Control *the_thread )
-  _Terminate(
-    false,
-    INTERNAL_ERROR_THREAD_QUEUE_DEADLOCK
+  _Terminate( INTERNAL_ERROR_CORE, INTERNAL_ERROR_THREAD_QUEUE_DEADLOCK );
 static void _Thread_queue_Timeout(
@@ -525,7 +521,6 @@ Status_Control _Thread_queue_Enqueue_sticky(
     _Terminate(
-      false,
       INTERNAL_ERROR_THREAD_QUEUE_ENQUEUE_STICKY_FROM_BAD_STATE
diff --git a/cpukit/score/src/threadrestart.c b/cpukit/score/src/threadrestart.c
index 54491d8..4295bc4 100644
--- a/cpukit/score/src/threadrestart.c
+++ b/cpukit/score/src/threadrestart.c
@@ -136,11 +136,7 @@ static void _Thread_Make_zombie( Thread_Control *the_thread )
 #if defined(RTEMS_SCORE_THREAD_ENABLE_RESOURCE_COUNT)
   if ( _Thread_Owns_resources( the_thread ) ) {
-    _Terminate(
-      false,
-      INTERNAL_ERROR_RESOURCE_IN_USE
+    _Terminate( INTERNAL_ERROR_CORE, INTERNAL_ERROR_RESOURCE_IN_USE );
 #endif
diff --git a/cpukit/score/src/userextiterate.c b/cpukit/score/src/userextiterate.c
index 6cb8774..6e14376 100644
--- a/cpukit/score/src/userextiterate.c
+++ b/cpukit/score/src/userextiterate.c
@@ -129,7 +129,7 @@ void _User_extensions_Fatal_visitor(
   if ( callout != NULL ) {
     const User_extensions_Fatal_context *ctx = arg;
-    (*callout)( ctx->source, ctx->is_internal, ctx->error );
+    (*callout)( ctx->source, false, ctx->error );
diff --git a/cpukit/score/src/wkspace.c b/cpukit/score/src/wkspace.c
index b53138d..ae48e44 100644
--- a/cpukit/score/src/wkspace.c
+++ b/cpukit/score/src/wkspace.c
@@ -134,11 +134,7 @@ void _Workspace_Handler_initialization(
   if ( remaining > 0 ) {
-    _Terminate(
-      true,
-      INTERNAL_ERROR_TOO_LITTLE_WORKSPACE
+    _Terminate( INTERNAL_ERROR_CORE, INTERNAL_ERROR_TOO_LITTLE_WORKSPACE );
   _Heap_Protection_set_delayed_free_fraction( &_Workspace_Area, 1 );
@@ -204,11 +200,7 @@ void *_Workspace_Allocate_or_fatal_error(
   #endif
   if ( memory == NULL )
-    _Terminate(
-      true,
-      INTERNAL_ERROR_WORKSPACE_ALLOCATION
+    _Terminate( INTERNAL_ERROR_CORE, INTERNAL_ERROR_WORKSPACE_ALLOCATION );
   return memory;
diff --git a/testsuites/libtests/devnullfatal01/testcase.h b/testsuites/libtests/devnullfatal01/testcase.h
index 14675da..1060d50 100644
--- a/testsuites/libtests/devnullfatal01/testcase.h
+++ b/testsuites/libtests/devnullfatal01/testcase.h
@@ -10,7 +10,6 @@
 #define FATAL_ERROR_TEST_NAME            "/DEV/NULL 1"
 #define FATAL_ERROR_DESCRIPTION          "/dev/null already registered"
 #define FATAL_ERROR_EXPECTED_SOURCE      INTERNAL_ERROR_RTEMS_API
-#define FATAL_ERROR_EXPECTED_IS_INTERNAL FALSE
 #define FATAL_ERROR_EXPECTED_ERROR       RTEMS_TOO_MANY
 #define TESTS_USE_PRINTK
diff --git a/testsuites/psxtests/psxfatal01/testcase.h b/testsuites/psxtests/psxfatal01/testcase.h
index b400fa6..a88ef48 100644
--- a/testsuites/psxtests/psxfatal01/testcase.h
+++ b/testsuites/psxtests/psxfatal01/testcase.h
@@ -28,7 +28,6 @@ posix_initialization_threads_table POSIX_Initialization_threads[] = {
 #define FATAL_ERROR_DESCRIPTION \
         "POSIX API Init thread create failure - NULL entry"
 #define FATAL_ERROR_EXPECTED_SOURCE      INTERNAL_ERROR_CORE
 #define FATAL_ERROR_EXPECTED_ERROR \
diff --git a/testsuites/psxtests/psxfatal02/testcase.h b/testsuites/psxtests/psxfatal02/testcase.h
index 7c10715..facf731 100644
--- a/testsuites/psxtests/psxfatal02/testcase.h
+++ b/testsuites/psxtests/psxfatal02/testcase.h
@@ -33,7 +33,6 @@ posix_initialization_threads_table POSIX_Initialization_threads[] = {
         "POSIX API Init thread create failure -- no memory for stack"
 #define FATAL_ERROR_EXPECTED_SOURCE      INTERNAL_ERROR_POSIX_API
 #define FATAL_ERROR_EXPECTED_ERROR       ((POSIX_FD_PTHREAD << 8) | EAGAIN)
 void force_error(void)
diff --git a/testsuites/psxtests/psxfatal_support/init.c b/testsuites/psxtests/psxfatal_support/init.c
index 0f995dc..bc48b95 100644
--- a/testsuites/psxtests/psxfatal_support/init.c
+++ b/testsuites/psxtests/psxfatal_support/init.c
@@ -77,13 +77,8 @@ void Fatal_extension(
     printk( ")\n" );
-  if ( is_internal !=  FATAL_ERROR_EXPECTED_IS_INTERNAL )
-    if ( is_internal == TRUE )
-      printk( "ERROR==> Fatal Extension is internal set to TRUE expected FALSE\n" );
-    else
-      printk( "ERROR==> Fatal Extension is internal set to FALSE expected TRUE\n" );
+  if ( is_internal )
+    printk( "ERROR==> Fatal Extension is internal set to true expected false\n" );
   if ( error !=  FATAL_ERROR_EXPECTED_ERROR ) {
     printk( "ERROR==> Fatal Error Expected (");
@@ -95,7 +90,7 @@ void Fatal_extension(
   if (
     source == FATAL_ERROR_EXPECTED_SOURCE
-      && is_internal == FATAL_ERROR_EXPECTED_IS_INTERNAL
+      && !is_internal
       && error == FATAL_ERROR_EXPECTED_ERROR
     TEST_END();
diff --git a/testsuites/sptests/spfatal01/testcase.h b/testsuites/sptests/spfatal01/testcase.h
index 9ac322a..01710dc 100644
--- a/testsuites/sptests/spfatal01/testcase.h
+++ b/testsuites/sptests/spfatal01/testcase.h
@@ -25,7 +25,6 @@ rtems_initialization_tasks_table Initialization_tasks[] = {
 #define FATAL_ERROR_TEST_NAME            "1"
 #define FATAL_ERROR_DESCRIPTION          "Classic API Init task create failure"
-#define FATAL_ERROR_EXPECTED_IS_INTERNAL TRUE
 #define FATAL_ERROR_EXPECTED_ERROR       RTEMS_UNSATISFIED
 void force_error()
diff --git a/testsuites/sptests/spfatal02/testcase.h b/testsuites/sptests/spfatal02/testcase.h
index bd9ac67..8ed2f44 100644
--- a/testsuites/sptests/spfatal02/testcase.h
+++ b/testsuites/sptests/spfatal02/testcase.h
 #define FATAL_ERROR_TEST_NAME            "2"
 #define FATAL_ERROR_DESCRIPTION          "Classic API Init task start failure"
diff --git a/testsuites/sptests/spfatal03/testcase.h b/testsuites/sptests/spfatal03/testcase.h
index 7b98cc3..90ed053 100644
--- a/testsuites/sptests/spfatal03/testcase.h
+++ b/testsuites/sptests/spfatal03/testcase.h
@@ -14,7 +14,6 @@
 #define FATAL_ERROR_TEST_NAME            "3"
 #define FATAL_ERROR_DESCRIPTION          "Core Mutex obtain in critical section"
diff --git a/testsuites/sptests/spfatal04/testcase.h b/testsuites/sptests/spfatal04/testcase.h
index 98429b4..323a777 100644
--- a/testsuites/sptests/spfatal04/testcase.h
+++ b/testsuites/sptests/spfatal04/testcase.h
@@ -26,7 +26,6 @@ rtems_initialization_tasks_table Initialization_tasks[] = {
         "Classic API call rtems_fatal_error_occurred"
 #define FATAL_ERROR_EXPECTED_ERROR       0xdead
 void force_error()
diff --git a/testsuites/sptests/spfatal05/testcase.h b/testsuites/sptests/spfatal05/testcase.h
index 8900aef..933b7a5 100644
--- a/testsuites/sptests/spfatal05/testcase.h
+++ b/testsuites/sptests/spfatal05/testcase.h
@@ -34,7 +34,6 @@ rtems_initialization_tasks_table Initialization_tasks[] = {
 #define FATAL_ERROR_TEST_NAME            "5"
 #define FATAL_ERROR_DESCRIPTION          "Core fall out of a task"
 #define FATAL_ERROR_EXPECTED_ERROR       INTERNAL_ERROR_THREAD_EXITTED
 rtems_task EmptyTask( rtems_task_argument unused );
diff --git a/testsuites/sptests/spfatal06/testcase.h b/testsuites/sptests/spfatal06/testcase.h
index db823da..8ec1627 100644
--- a/testsuites/sptests/spfatal06/testcase.h
+++ b/testsuites/sptests/spfatal06/testcase.h
@@ -33,7 +33,6 @@ rtems_initialization_tasks_table Initialization_tasks[] = {
         "Core initialize with invalid stack hook"
 #define FATAL_ERROR_EXPECTED_ERROR       INTERNAL_ERROR_BAD_STACK_HOOK
 void *New_stack_allocate_hook(size_t unused);
diff --git a/testsuites/sptests/spfatal07/testcase.h b/testsuites/sptests/spfatal07/testcase.h
index 7cc9a5f..4db2cf1 100644
--- a/testsuites/sptests/spfatal07/testcase.h
+++ b/testsuites/sptests/spfatal07/testcase.h
         "Core Configuration Invalid ISR stack size"
diff --git a/testsuites/sptests/spfatal08/testcase.h b/testsuites/sptests/spfatal08/testcase.h
index 12c8d4e..03e7ca5 100644
--- a/testsuites/sptests/spfatal08/testcase.h
+++ b/testsuites/sptests/spfatal08/testcase.h
@@ -14,7 +14,6 @@
 #define FATAL_ERROR_TEST_NAME            "8"
 #define FATAL_ERROR_DESCRIPTION          "Core workspace too small"
 #define FATAL_ERROR_EXPECTED_ERROR       INTERNAL_ERROR_WORKSPACE_ALLOCATION
 void force_error()
diff --git a/testsuites/sptests/spfatal09/testcase.h b/testsuites/sptests/spfatal09/testcase.h
index 7e9b10f..07b03af 100644
--- a/testsuites/sptests/spfatal09/testcase.h
+++ b/testsuites/sptests/spfatal09/testcase.h
@@ -15,7 +15,6 @@
 #define FATAL_ERROR_TEST_NAME            "9"
 #define FATAL_ERROR_DESCRIPTION          "Bad heap address to malloc"
 #define FATAL_ERROR_EXPECTED_ERROR       INTERNAL_ERROR_NO_MEMORY_FOR_HEAP
 void force_error()
diff --git a/testsuites/sptests/spfatal10/testcase.h b/testsuites/sptests/spfatal10/testcase.h
index ae1e99e..df4125e 100644
--- a/testsuites/sptests/spfatal10/testcase.h
+++ b/testsuites/sptests/spfatal10/testcase.h
@@ -14,7 +14,6 @@
 #define FATAL_ERROR_TEST_NAME            "10"
 #define FATAL_ERROR_DESCRIPTION          "asserting with non-NULL strings..."
 #define FATAL_ERROR_EXPECTED_SOURCE      RTEMS_FATAL_SOURCE_ASSERT
 #define FATAL_ERROR_EXPECTED_ERROR_CHECK spfatal10_is_expected_error
 #define ASSERT_FILE "testcase.h"
diff --git a/testsuites/sptests/spfatal11/testcase.h b/testsuites/sptests/spfatal11/testcase.h
index 3efa7e5..ddd37a6 100644
--- a/testsuites/sptests/spfatal11/testcase.h
+++ b/testsuites/sptests/spfatal11/testcase.h
@@ -14,7 +14,6 @@
 #define FATAL_ERROR_TEST_NAME            "11"
 #define FATAL_ERROR_DESCRIPTION          "asserting with NULL strings..."
 #define FATAL_ERROR_EXPECTED_ERROR_CHECK spfatal11_is_expected_error
diff --git a/testsuites/sptests/spfatal12/testcase.h b/testsuites/sptests/spfatal12/testcase.h
index 0aac3b1..8b3d409 100644
--- a/testsuites/sptests/spfatal12/testcase.h
+++ b/testsuites/sptests/spfatal12/testcase.h
@@ -14,7 +14,6 @@
         "_Heap_Initialize fails during RTEMS initialization"
 #define FATAL_ERROR_EXPECTED_ERROR       INTERNAL_ERROR_TOO_LITTLE_WORKSPACE
 void force_error()
diff --git a/testsuites/sptests/spfatal13/testcase.h b/testsuites/sptests/spfatal13/testcase.h
index b99ff4d..6f82689 100644
--- a/testsuites/sptests/spfatal13/testcase.h
+++ b/testsuites/sptests/spfatal13/testcase.h
@@ -12,7 +12,6 @@
         "Configuration of unlimited and maximum of 0"
 #define FATAL_ERROR_EXPECTED_ERROR     INTERNAL_ERROR_UNLIMITED_AND_MAXIMUM_IS_0
diff --git a/testsuites/sptests/spfatal14/testcase.h b/testsuites/sptests/spfatal14/testcase.h
index 4aded0a..3dcd030 100644
--- a/testsuites/sptests/spfatal14/testcase.h
+++ b/testsuites/sptests/spfatal14/testcase.h
@@ -12,7 +12,6 @@
 #define FATAL_ERROR_TEST_NAME            "14"
 #define FATAL_ERROR_DESCRIPTION          "fail to open stdout"
 #define FATAL_ERROR_EXPECTED_ERROR       0x55544431
 #define CONFIGURE_LIBIO_MAXIMUM_FILE_DESCRIPTORS 1
diff --git a/testsuites/sptests/spfatal15/testcase.h b/testsuites/sptests/spfatal15/testcase.h
index d1527fd..742b5b9 100644
--- a/testsuites/sptests/spfatal15/testcase.h
+++ b/testsuites/sptests/spfatal15/testcase.h
@@ -11,7 +11,6 @@
 #define FATAL_ERROR_TEST_NAME            "15"
 #define FATAL_ERROR_DESCRIPTION          "fail to open stderr"
 #define FATAL_ERROR_EXPECTED_ERROR       0x55544432
 #define CONFIGURE_LIBIO_MAXIMUM_FILE_DESCRIPTORS 2
diff --git a/testsuites/sptests/spfatal16/testcase.h b/testsuites/sptests/spfatal16/testcase.h
index 743b2be..412f20e 100644
--- a/testsuites/sptests/spfatal16/testcase.h
+++ b/testsuites/sptests/spfatal16/testcase.h
@@ -16,7 +16,6 @@
 #define FATAL_ERROR_TEST_NAME            "16"
 #define FATAL_ERROR_DESCRIPTION          "termios sem create #1"
 #define CONFIGURE_APPLICATION_PREREQUISITE_DRIVERS \
diff --git a/testsuites/sptests/spfatal17/testcase.h b/testsuites/sptests/spfatal17/testcase.h
index 78f1b40..2f1046a 100644
--- a/testsuites/sptests/spfatal17/testcase.h
+++ b/testsuites/sptests/spfatal17/testcase.h
@@ -14,7 +14,6 @@
 #define FATAL_ERROR_TEST_NAME            "17"
 #define FATAL_ERROR_DESCRIPTION          "termios sem create #2"
diff --git a/testsuites/sptests/spfatal18/testcase.h b/testsuites/sptests/spfatal18/testcase.h
index cb42543..eab617c 100644
--- a/testsuites/sptests/spfatal18/testcase.h
+++ b/testsuites/sptests/spfatal18/testcase.h
@@ -14,7 +14,6 @@
 #define FATAL_ERROR_TEST_NAME            "18"
 #define FATAL_ERROR_DESCRIPTION          "termios sem create #3"
diff --git a/testsuites/sptests/spfatal19/testcase.h b/testsuites/sptests/spfatal19/testcase.h
index daa53b9..16ef09d 100644
--- a/testsuites/sptests/spfatal19/testcase.h
+++ b/testsuites/sptests/spfatal19/testcase.h
@@ -14,7 +14,6 @@
 #define FATAL_ERROR_TEST_NAME            "19"
 #define FATAL_ERROR_DESCRIPTION          "termios sem create #4"
diff --git a/testsuites/sptests/spfatal20/testcase.h b/testsuites/sptests/spfatal20/testcase.h
index 1000f8f..863982a 100644
--- a/testsuites/sptests/spfatal20/testcase.h
+++ b/testsuites/sptests/spfatal20/testcase.h
@@ -11,7 +11,6 @@
   "rtems_termios_initialize cannot create semaphore"
diff --git a/testsuites/sptests/spfatal24/testcase.h b/testsuites/sptests/spfatal24/testcase.h
index 87cbe53..19a7547 100644
--- a/testsuites/sptests/spfatal24/testcase.h
+++ b/testsuites/sptests/spfatal24/testcase.h
@@ -13,7 +13,6 @@
 #define FATAL_ERROR_TEST_NAME            "GXX KEY ADD FAILURE"
 #define FATAL_ERROR_DESCRIPTION          "GXX KEY ADD FAILURE"
 #define FATAL_ERROR_EXPECTED_ERROR       INTERNAL_ERROR_GXX_KEY_ADD_FAILED
 void force_error()
diff --git a/testsuites/sptests/spfatal25/testcase.h b/testsuites/sptests/spfatal25/testcase.h
index fb800bf..c2c97e4 100644
--- a/testsuites/sptests/spfatal25/testcase.h
+++ b/testsuites/sptests/spfatal25/testcase.h
@@ -12,7 +12,6 @@
 #define FATAL_ERROR_TEST_NAME            "GXX MUTEX INIT FAILED"
 #define FATAL_ERROR_DESCRIPTION          "GXX MUTEX INIT FAILED"
 #define FATAL_ERROR_EXPECTED_ERROR       INTERNAL_ERROR_GXX_MUTEX_INIT_FAILED
 void force_error()
diff --git a/testsuites/sptests/spfatal27/testcase.h b/testsuites/sptests/spfatal27/testcase.h
index 29ef327..a7b26bd 100644
--- a/testsuites/sptests/spfatal27/testcase.h
+++ b/testsuites/sptests/spfatal27/testcase.h
@@ -15,7 +15,6 @@
 #define FATAL_ERROR_TEST_NAME            "27"
 #define FATAL_ERROR_DESCRIPTION          "libio init no posix key left"
 #define CONFIGURE_MAXIMUM_POSIX_KEYS (-1)
diff --git a/testsuites/sptests/spfatal28/testcase.h b/testsuites/sptests/spfatal28/testcase.h
index 9741760..fda4122 100644
--- a/testsuites/sptests/spfatal28/testcase.h
+++ b/testsuites/sptests/spfatal28/testcase.h
@@ -15,7 +15,6 @@
 #define FATAL_ERROR_TEST_NAME            "28"
 #define FATAL_ERROR_DESCRIPTION          "delete a task with a semaphore in use"
 #define FATAL_ERROR_EXPECTED_ERROR       INTERNAL_ERROR_RESOURCE_IN_USE
 #define CONFIGURE_MAXIMUM_SEMAPHORES 1
@@ -38,6 +37,6 @@ void force_error()
   sc = rtems_task_delete(RTEMS_SELF);
   rtems_test_assert(sc == RTEMS_SUCCESSFUL);
 #else
-  _Terminate( INTERNAL_ERROR_CORE, false, INTERNAL_ERROR_RESOURCE_IN_USE );
 #endif
diff --git a/testsuites/sptests/spfatal29/testcase.h b/testsuites/sptests/spfatal29/testcase.h
index 096a66a..63f74f8 100644
--- a/testsuites/sptests/spfatal29/testcase.h
+++ b/testsuites/sptests/spfatal29/testcase.h
@@ -15,7 +15,6 @@
 #define FATAL_ERROR_TEST_NAME            "29"
 #define FATAL_ERROR_DESCRIPTION          "yield in interrupt context"
 #define FATAL_ERROR_EXPECTED_ERROR       INTERNAL_ERROR_BAD_THREAD_DISPATCH_DISABLE_LEVEL
 #define CONFIGURE_MAXIMUM_TIMERS 1
diff --git a/testsuites/sptests/spfatal_support/init.c b/testsuites/sptests/spfatal_support/init.c
index 319dbd2..aa49a30 100644
--- a/testsuites/sptests/spfatal_support/init.c
+++ b/testsuites/sptests/spfatal_support/init.c
@@ -80,17 +80,10 @@ void Fatal_extension(
     printk( ")\n" );
-      printk(
-        "ERROR==> Fatal Extension is internal set to TRUE expected FALSE\n"
-    else
-      printk(
-        "ERROR==> Fatal Extension is internal set to FALSE expected TRUE\n"
+    printk(
+      "ERROR==> Fatal Extension is internal set to true expected false\n"
 #ifdef FATAL_ERROR_EXPECTED_ERROR
@@ -104,7 +97,7 @@ void Fatal_extension(
   if (
+      && !is_internal
       && is_expected_error( error )
     TEST_END();
diff --git a/testsuites/sptests/spinternalerror01/init.c b/testsuites/sptests/spinternalerror01/init.c
index e864db1..6201aff 100644
--- a/testsuites/sptests/spinternalerror01/init.c
+++ b/testsuites/sptests/spinternalerror01/init.c
@@ -26,13 +26,11 @@ const char rtems_test_name[] = "SPINTERNALERROR 1";
 #define FATAL_SOURCE 0xdeadbeef
-#define FATAL_IS_INTERNAL false
 #define FATAL_ERROR 0x600df00d
 void boot_card( const char *cmdline )
-  _Terminate( FATAL_SOURCE, FATAL_IS_INTERNAL, FATAL_ERROR );
+  _Terminate( FATAL_SOURCE, FATAL_ERROR );
 static void fatal_extension(
@@ -43,11 +41,7 @@ static void fatal_extension(
   TEST_BEGIN();
-  if (
-    source == FATAL_SOURCE
-      && is_internal == FATAL_IS_INTERNAL
-      && error == FATAL_ERROR
+  if ( source == FATAL_SOURCE && !is_internal && error == FATAL_ERROR ) {
     TEST_END();
diff --git a/testsuites/sptests/sptimecounter01/init.c b/testsuites/sptests/sptimecounter01/init.c
index 9e396de..179590d 100644
--- a/testsuites/sptests/sptimecounter01/init.c
+++ b/testsuites/sptests/sptimecounter01/init.c
@@ -151,7 +151,7 @@ void boot_card(const char *cmdline)
   TEST_END();
-  _Terminate(RTEMS_FATAL_SOURCE_EXIT, false, 0);
+  _Terminate(RTEMS_FATAL_SOURCE_EXIT, 0);
 #define CONFIGURE_APPLICATION_DOES_NOT_NEED_CLOCK_DRIVER
1.8.4.5
