[PATCH] Rename is_internal to always_false
Sat Dec 10 22:37:04 UTC 2016
On 9/12/16 8:50 pm, Sebastian Huber wrote:
> diff --git a/cpukit/score/include/rtems/score/userext.h b/cpukit/score/include/rtems/score/userext.h
> index 61de992..e77362a 100644
> --- a/cpukit/score/include/rtems/score/userext.h
> +++ b/cpukit/score/include/rtems/score/userext.h
> @@ -195,14 +195,14 @@ typedef void( *User_extensions_thread_exitted_extension )(
>   * @param[in] source The fatal source indicating the subsystem the fatal
>   * condition originated in.
> - * @param[in] is_internal This parameter is always false and provide only for
> + * @param[in] always_false This parameter is always false and provided only for
>   * backward compatibility reasons.
>   * @param[in] code The fatal error code.  This value must be interpreted with
>   * respect to the source.
>  typedef void( *User_extensions_fatal_extension )(
>    Internal_errors_Source source,
> -  bool                   is_internal,
> +  bool                   always_false,
>    Internal_errors_t      code
Is the parameter to always be set to false, ie always_set_to_false?
