[PATCH] libdl: Add C++ exception support to loaded modules.
Chris Johns
chrisj at rtems.org
Mon Dec 12 00:44:07 UTC 2016
This has been tested on SPARC, i386, PowerPC and ARM.
Closes #2767.
.../sparc/erc32/make/custom/erc32-testsuite.tcfg | 4 -
cpukit/libdl/Makefile.am | 1 +
cpukit/libdl/dlfcn.c | 2 +-
cpukit/libdl/rtl-allocator.c | 26 ++-
cpukit/libdl/rtl-allocator.h | 7 +-
cpukit/libdl/rtl-debugger.c | 14 +-
cpukit/libdl/rtl-elf.c | 94 +++++++----
cpukit/libdl/rtl-elf.h | 26 ++-
cpukit/libdl/rtl-error.c | 17 +-
cpukit/libdl/rtl-mdreloc-arm.c | 147 +++++++++++++++--
cpukit/libdl/rtl-mdreloc-bfin.c | 29 ++++
cpukit/libdl/rtl-mdreloc-h8300.c | 29 ++++
cpukit/libdl/rtl-mdreloc-i386.c | 29 ++++
cpukit/libdl/rtl-mdreloc-lm32.c | 29 ++++
cpukit/libdl/rtl-mdreloc-m68k.c | 29 ++++
cpukit/libdl/rtl-mdreloc-mips.c | 29 ++++
cpukit/libdl/rtl-mdreloc-moxie.c | 29 ++++
cpukit/libdl/rtl-mdreloc-powerpc.c | 43 +++++
cpukit/libdl/rtl-mdreloc-sparc.c | 43 ++++-
cpukit/libdl/rtl-mdreloc-v850.c | 29 ++++
cpukit/libdl/rtl-obj.c | 178 +++++++++++++--------
cpukit/libdl/rtl-obj.h | 169 +++++++++++--------
cpukit/libdl/rtl-rap.c | 55 ++++---
cpukit/libdl/rtl-rap.h | 7 +
cpukit/libdl/rtl-unwind-dw2.c | 71 ++++++++
cpukit/libdl/rtl-unwind-dw2.h | 83 ++++++++++
cpukit/libdl/rtl-unwind.h | 63 ++++++++
cpukit/libdl/rtl.c | 33 +++-
cpukit/libdl/rtl.h | 2 +-
testsuites/libtests/dl01/init.c | 3 +-
testsuites/libtests/dl02/init.c | 2 +
testsuites/libtests/dl03/init.c | 2 +
testsuites/libtests/dl04/init.c | 2 +
testsuites/libtests/dl05/dl-cpp.cpp | 24 ++-
testsuites/libtests/dl05/dl-load.c | 34 ++--
testsuites/libtests/dl05/dl-load.h | 30 +++-
testsuites/libtests/dl05/dl-o5.cpp | 15 +-
testsuites/libtests/dl05/init.c | 8 +-
38 files changed, 1182 insertions(+), 255 deletions(-)
delete mode 100644 c/src/lib/libbsp/sparc/erc32/make/custom/erc32-testsuite.tcfg
create mode 100644 cpukit/libdl/rtl-unwind-dw2.c
create mode 100644 cpukit/libdl/rtl-unwind-dw2.h
create mode 100644 cpukit/libdl/rtl-unwind.h
diff --git a/c/src/lib/libbsp/sparc/erc32/make/custom/erc32-testsuite.tcfg b/c/src/lib/libbsp/sparc/erc32/make/custom/erc32-testsuite.tcfg
deleted file mode 100644
index cee7ce5..0000000
--- a/c/src/lib/libbsp/sparc/erc32/make/custom/erc32-testsuite.tcfg
+++ /dev/null
@@ -1,4 +0,0 @@
-# Excpected failures.
-expected-fail: dl05
diff --git a/cpukit/libdl/Makefile.am b/cpukit/libdl/Makefile.am
index 5c3cd15..b21c167 100644
--- a/cpukit/libdl/Makefile.am
+++ b/cpukit/libdl/Makefile.am
@@ -25,6 +25,7 @@ libdl_a_SOURCES = \
rtl-string.c \
rtl-sym.c \
rtl-trace.c \
+ rtl-unwind-dw2.c \
rtl-unresolved.c
libdl_a_SOURCES += rtl-mdreloc- at RTEMS_CPU@.c
diff --git a/cpukit/libdl/dlfcn.c b/cpukit/libdl/dlfcn.c
index 19feaaf..3b31bb2 100644
--- a/cpukit/libdl/dlfcn.c
+++ b/cpukit/libdl/dlfcn.c
@@ -130,7 +130,7 @@ dlerror (void)
static char msg[64];
rtems_rtl_get_error (msg, sizeof (msg));
- return msg;
+ return msg;
int
diff --git a/cpukit/libdl/rtl-allocator.c b/cpukit/libdl/rtl-allocator.c
index 9880940..39b4bcd 100644
--- a/cpukit/libdl/rtl-allocator.c
+++ b/cpukit/libdl/rtl-allocator.c
@@ -152,6 +152,7 @@ rtems_rtl_alloc_indirect_del (rtems_rtl_alloc_tag_t tag,
bool
rtems_rtl_alloc_module_new (void** text_base, size_t text_size,
void** const_base, size_t const_size,
+ void** eh_base, size_t eh_size,
void** data_base, size_t data_size,
void** bss_base, size_t bss_size)
@@ -173,7 +174,20 @@ rtems_rtl_alloc_module_new (void** text_base, size_t text_size,
const_size, false);
if (!*const_base)
- rtems_rtl_alloc_module_del (text_base, const_base, data_base, bss_base);
+ rtems_rtl_alloc_module_del (text_base, const_base, eh_base,
+ data_base, bss_base);
+ return false;
+ if (eh_size)
+ *eh_base = rtems_rtl_alloc_new (RTEMS_RTL_ALLOC_READ,
+ eh_size, false);
+ if (!*eh_base)
return false;
@@ -184,7 +198,8 @@ rtems_rtl_alloc_module_new (void** text_base, size_t text_size,
data_size, false);
if (!*data_base)
return false;
@@ -195,7 +210,8 @@ rtems_rtl_alloc_module_new (void** text_base, size_t text_size,
bss_size, false);
if (!*bss_base)
return false;
@@ -206,12 +222,14 @@ rtems_rtl_alloc_module_new (void** text_base, size_t text_size,
void
rtems_rtl_alloc_module_del (void** text_base,
void** const_base,
+ void** eh_base,
void** data_base,
void** bss_base)
rtems_rtl_alloc_del (RTEMS_RTL_ALLOC_READ_WRITE, *bss_base);
rtems_rtl_alloc_del (RTEMS_RTL_ALLOC_READ_WRITE, *data_base);
+ rtems_rtl_alloc_del (RTEMS_RTL_ALLOC_READ, *eh_base);
rtems_rtl_alloc_del (RTEMS_RTL_ALLOC_READ, *const_base);
rtems_rtl_alloc_del (RTEMS_RTL_ALLOC_READ_EXEC, *text_base);
- *text_base = *const_base = *data_base = *bss_base = NULL;
+ *text_base = *const_base = *eh_base = *data_base = *bss_base = NULL;
diff --git a/cpukit/libdl/rtl-allocator.h b/cpukit/libdl/rtl-allocator.h
index 4d996d3..e8044ee 100644
--- a/cpukit/libdl/rtl-allocator.h
+++ b/cpukit/libdl/rtl-allocator.h
@@ -146,6 +146,8 @@ void rtems_rtl_alloc_indirect_del (rtems_rtl_alloc_tag_t tag,
* @param text_size The size of the read/exec section.
* @param const_base Pointer to the const base pointer.
* @param const_size The size of the read only section.
+ * @param eh_base Pointer to the eh base pointer.
+ * @param eh_size The size of the eh section.
* @param data_base Pointer to the data base pointer.
* @param data_size The size of the read/write secton.
* @param bss_base Pointer to the bss base pointer.
@@ -155,6 +157,7 @@ void rtems_rtl_alloc_indirect_del (rtems_rtl_alloc_tag_t tag,
bool rtems_rtl_alloc_module_new (void** text_base, size_t text_size,
void** bss_base, size_t bss_size);
@@ -163,11 +166,13 @@ bool rtems_rtl_alloc_module_new (void** text_base, size_t text_size,
* @param text_base Pointer to the text base pointer.
void rtems_rtl_alloc_module_del (void** text_base, void** const_base,
- void** data_base, void** bss_base);
+ void** eh_base, void** data_base,
+ void** bss_base);
#ifdef __cplusplus
diff --git a/cpukit/libdl/rtl-debugger.c b/cpukit/libdl/rtl-debugger.c
index 63add59..afbea8a 100644
--- a/cpukit/libdl/rtl-debugger.c
+++ b/cpukit/libdl/rtl-debugger.c
@@ -45,10 +45,10 @@ _rtld_debug_state (void)
int
_rtld_linkmap_add (rtems_rtl_obj_t* obj)
- struct link_map* l = (struct link_map*)obj->detail;
+ struct link_map* l = obj->linkmap;
struct link_map* prev;
- uint32_t obj_num = obj->obj_num;
- int i;
+ uint32_t obj_num = obj->obj_num;
+ int i;
if (rtems_rtl_trace (RTEMS_RTL_TRACE_DETAIL))
printf ("rtl: linkmap_add\n");
@@ -78,8 +78,10 @@ _rtld_linkmap_add (rtems_rtl_obj_t* obj)
void
_rtld_linkmap_delete (rtems_rtl_obj_t* obj)
- /* link_maps are allocated together if not 1 */
+ * link_maps are allocated together if not 1
struct link_map* e = l + obj->obj_num - 1;
while (e && e->l_next) e = e->l_next;
@@ -90,7 +92,7 @@ _rtld_linkmap_delete (rtems_rtl_obj_t* obj)
e->l_next->l_prev = NULL;
return;
if ((l->l_prev->l_next = e->l_next) != NULL)
e->l_next->l_prev = l->l_prev;
- return;
diff --git a/cpukit/libdl/rtl-elf.c b/cpukit/libdl/rtl-elf.c
index b686a48..37775ff 100644
--- a/cpukit/libdl/rtl-elf.c
+++ b/cpukit/libdl/rtl-elf.c
@@ -30,6 +30,7 @@
#include "rtl-elf.h"
#include "rtl-error.h"
#include "rtl-trace.h"
+#include "rtl-unwind.h"
#include "rtl-unresolved.h"
@@ -169,6 +170,9 @@ rtems_rtl_elf_relocator (rtems_rtl_obj_t* obj,
&relbuf[0], reloc_size))
return false;
+ * Read the symbol details.
if (is_rela)
off = (obj->ooffset + symsect->offset +
(ELF_R_SYM (rela->r_info) * sizeof (sym)));
@@ -246,7 +250,7 @@ rtems_rtl_elf_relocator (rtems_rtl_obj_t* obj,
if (is_rela)
if (rtems_rtl_trace (RTEMS_RTL_TRACE_RELOC))
- printf ("rtl: rela: sym:%s(%-2d)=%08lx type:%-2d off:%08lx addend:%d\n",
+ printf ("rtl: rela: sym:%s(%d)=%08lx type:%d off:%08lx addend:%d\n",
symname, (int) ELF_R_SYM (rela->r_info), symvalue,
(int) ELF_R_TYPE (rela->r_info), rela->r_offset, (int) rela->r_addend);
if (!rtems_rtl_elf_relocate_rela (obj, rela, targetsect,
@@ -256,7 +260,7 @@ rtems_rtl_elf_relocator (rtems_rtl_obj_t* obj,
else
- printf ("rtl: rel: sym:%s(%-2d)=%08lx type:%-2d off:%08lx\n",
+ printf ("rtl: rel: sym:%s(%d)=%08lx type:%d off:%08lx\n",
symname, (int) ELF_R_SYM (rel->r_info), symvalue,
(int) ELF_R_TYPE (rel->r_info), rel->r_offset);
if (!rtems_rtl_elf_relocate_rel (obj, rel, targetsect,
@@ -300,7 +304,7 @@ rtems_rtl_obj_relocate_unresolved (rtems_rtl_unresolv_reloc_t* reloc,
rela.r_info = reloc->rel[REL_R_INFO];
rela.r_addend = reloc->rel[REL_R_ADDEND];
- printf ("rtl: rela: sym:%-2d type:%-2d off:%08lx addend:%d\n",
+ printf ("rtl: rela: sym:%d type:%d off:%08lx addend:%d\n",
(int) ELF_R_SYM (rela.r_info), (int) ELF_R_TYPE (rela.r_info),
rela.r_offset, (int) rela.r_addend);
if (!rtems_rtl_elf_relocate_rela (reloc->obj, &rela, sect,
@@ -313,7 +317,7 @@ rtems_rtl_obj_relocate_unresolved (rtems_rtl_unresolv_reloc_t* reloc,
rel.r_offset = reloc->rel[REL_R_OFFSET];
rel.r_info = reloc->rel[REL_R_INFO];
- printf ("rtl: rel: sym:%-2d type:%-2d off:%08lx\n",
+ printf ("rtl: rel: sym:%d type:%d off:%08lx\n",
(int) ELF_R_SYM (rel.r_info), (int) ELF_R_TYPE (rel.r_info),
rel.r_offset);
if (!rtems_rtl_elf_relocate_rel (reloc->obj, &rel, sect,
@@ -707,9 +711,16 @@ rtems_rtl_elf_parse_sections (rtems_rtl_obj_t* obj, int fd, Elf_Ehdr* ehdr)
break;
default:
- if (rtems_rtl_trace (RTEMS_RTL_TRACE_WARNING))
- printf ("rtl: unsupported section: %2d: type=%02d flags=%02x\n",
- section, (int) shdr.sh_type, (int) shdr.sh_flags);
+ * See there are architecture specific flags?
+ flags = rtems_rtl_elf_section_flags (obj, &shdr);
+ if (flags == 0)
+ if (rtems_rtl_trace (RTEMS_RTL_TRACE_WARNING))
+ printf ("rtl: unsupported section: %2d: type=%02d flags=%02x\n",
+ section, (int) shdr.sh_type, (int) shdr.sh_flags);
break;
@@ -729,6 +740,12 @@ rtems_rtl_elf_parse_sections (rtems_rtl_obj_t* obj, int fd, Elf_Ehdr* ehdr)
if (strcmp (".dtors", name) == 0)
flags |= RTEMS_RTL_OBJ_SECT_DTOR;
+ if (rtems_rtl_elf_unwind_parse (obj, name, flags))
+ flags &= ~(RTEMS_RTL_OBJ_SECT_TEXT | RTEMS_RTL_OBJ_SECT_CONST);
+ flags |= RTEMS_RTL_OBJ_SECT_EH;
if (!rtems_rtl_obj_add_section (obj, section, name,
shdr.sh_size, shdr.sh_offset,
shdr.sh_addralign, shdr.sh_link,
@@ -771,16 +788,19 @@ rtems_rtl_elf_file_check (rtems_rtl_obj_t* obj, int fd)
return true;
-bool rtems_rtl_elf_load_details (rtems_rtl_obj_t* obj)
+static bool
+rtems_rtl_elf_load_linkmap (rtems_rtl_obj_t* obj)
rtems_chain_control* sections = NULL;
rtems_chain_node* node = NULL;
size_t mask = 0;
- struct link_map* l = NULL;
int sec_num = 0;
+ section_detail* sd;
int i = 0;
- /* caculate the size of sections' name. */
+ * Caculate the size of sections' name.
for (mask = RTEMS_RTL_OBJ_SECT_TEXT;
mask <= RTEMS_RTL_OBJ_SECT_BSS;
@@ -791,7 +811,6 @@ bool rtems_rtl_elf_load_details (rtems_rtl_obj_t* obj)
while (!rtems_chain_is_tail (sections, node))
rtems_rtl_obj_sect_t* sect = (rtems_rtl_obj_sect_t*) node;
if ((sect->size != 0) && ((sect->flags & mask) != 0))
++sec_num;
@@ -801,32 +820,31 @@ bool rtems_rtl_elf_load_details (rtems_rtl_obj_t* obj)
obj->obj_num = 1;
- obj->detail = rtems_rtl_alloc_new (RTEMS_RTL_ALLOC_OBJECT,
- sizeof(struct link_map) +
- sec_num * sizeof (section_detail), true);
- if (!obj->detail)
+ obj->linkmap = rtems_rtl_alloc_new (RTEMS_RTL_ALLOC_OBJECT,
+ sizeof(struct link_map) +
+ sec_num * sizeof (section_detail), true);
+ if (!obj->linkmap)
- rtems_rtl_set_error (ENOMEM, "no memory for obj global syms");
+ rtems_rtl_set_error (ENOMEM, "no memory for obj linkmap");
return false;
- l = (struct link_map*) obj->detail;
- l->name = obj->oname;
- l->sec_num = sec_num;
- l->sec_detail = (section_detail*) (l + 1);
- l->rpathlen = 0;
- l->rpath = NULL;
- l->l_next = NULL;
- l->l_prev = NULL;
- l->sec_addr[rap_text] = obj->text_base;
- l->sec_addr[rap_const] = obj->const_base;
- l->sec_addr[rap_data] = obj->data_base;
- l->sec_addr[rap_bss] = obj->bss_base;
- section_detail* sd = l->sec_detail;
+ obj->linkmap->name = obj->oname;
+ obj->linkmap->sec_num = sec_num;
+ obj->linkmap->sec_detail = (section_detail*) (obj->linkmap + 1);
+ obj->linkmap->rpathlen = 0;
+ obj->linkmap->rpath = NULL;
+ obj->linkmap->l_next = NULL;
+ obj->linkmap->l_prev = NULL;
+ obj->linkmap->sec_addr[rap_text] = obj->text_base;
+ obj->linkmap->sec_addr[rap_const] = obj->const_base;
+ obj->linkmap->sec_addr[rap_data] = obj->data_base;
+ obj->linkmap->sec_addr[rap_bss] = obj->bss_base;
+ sd = obj->linkmap->sec_detail;
sections = &obj->sections;
node = rtems_chain_first (sections);
mask <<= 1)
@@ -948,7 +966,12 @@ rtems_rtl_elf_file_load (rtems_rtl_obj_t* obj, int fd)
rtems_rtl_symbol_obj_erase_local (obj);
- if (!rtems_rtl_elf_load_details (obj))
+ if (!rtems_rtl_elf_load_linkmap (obj))
+ return false;
+ if (!rtems_rtl_elf_unwind_register (obj))
return false;
@@ -956,6 +979,13 @@ rtems_rtl_elf_file_load (rtems_rtl_obj_t* obj, int fd)
return true;
+bool
+rtems_rtl_elf_file_unload (rtems_rtl_obj_t* obj)
+ rtems_rtl_elf_unwind_deregister (obj);
+ return true;
rtems_rtl_loader_format_t*
rtems_rtl_elf_file_sig (void)
diff --git a/cpukit/libdl/rtl-elf.h b/cpukit/libdl/rtl-elf.h
index 7f6ea30..e3ac07f 100644
--- a/cpukit/libdl/rtl-elf.h
+++ b/cpukit/libdl/rtl-elf.h
@@ -55,6 +55,18 @@ extern "C" {
#define RTEMS_RTL_ELF_STRING_MAX (256)
+ * Architecture specific handler to translate unknown section flags to RTL
+ * section flags.
+ * @param obj The object file being relocated.
+ * @param shdr The ELF section header.
+ * @retval 0 Unknown or unsupported flags.
+ * @retval uint32_t RTL object file flags.
+uint32_t rtems_rtl_elf_section_flags (const rtems_rtl_obj_t* obj,
+ const Elf_Shdr* shdr);
* Architecture specific handler to check is a relocation record's type is
* required to resolve a symbol.
@@ -137,13 +149,6 @@ bool rtems_rtl_elf_find_symbol (rtems_rtl_obj_t* obj,
bool rtems_rtl_elf_file_check (rtems_rtl_obj_t* obj, int fd);
- * The ELF file details handler.
- * @param obj Load the details of the obj.
-bool rtems_rtl_elf_load_details (rtems_rtl_obj_t* obj);
* The ELF format load handler.
* @param obj The object to load.
@@ -152,6 +157,13 @@ bool rtems_rtl_elf_load_details (rtems_rtl_obj_t* obj);
bool rtems_rtl_elf_file_load (rtems_rtl_obj_t* obj, int fd);
+ * The ELF format unload handler.
+ * @param obj The object to unload.
+bool rtems_rtl_elf_file_unload (rtems_rtl_obj_t* obj);
* The ELF format signature handler.
* @return rtems_rtl_loader_format_t* The format's signature.
diff --git a/cpukit/libdl/rtl-error.c b/cpukit/libdl/rtl-error.c
index 3251fa5..5ec4b26 100644
--- a/cpukit/libdl/rtl-error.c
+++ b/cpukit/libdl/rtl-error.c
@@ -17,6 +17,7 @@
#include "config.h"
#endif
+#include <errno.h>
#include <stdarg.h>
@@ -39,9 +40,15 @@ int
rtems_rtl_get_error (char* message, size_t max_message)
rtems_rtl_data_t* rtl = rtems_rtl_lock ();
- int last_errno = rtl->last_errno;
- strncpy (message, rtl->last_error, sizeof (rtl->last_error));
- rtems_rtl_unlock ();
- return last_errno;
+ if (rtl != NULL)
+ int last_errno = rtl->last_errno;
+ strncpy (message, rtl->last_error, sizeof (rtl->last_error));
+ rtems_rtl_unlock ();
+ return last_errno;
+ strncpy(message, "RTL init error", max_message);
+ return EIO;
diff --git a/cpukit/libdl/rtl-mdreloc-arm.c b/cpukit/libdl/rtl-mdreloc-arm.c
index 84d58e3..4c55cae 100644
--- a/cpukit/libdl/rtl-mdreloc-arm.c
+++ b/cpukit/libdl/rtl-mdreloc-arm.c
@@ -10,11 +10,14 @@
#include <sys/types.h>
#include <sys/stat.h>
+#include <unwind.h>
+#include <unwind-arm-common.h>
#include <rtems/rtl/rtl.h>
* It is possible for the compiler to emit relocations for unaligned data.
@@ -23,6 +26,8 @@
#define RELOC_ALIGNED_P(x) \
(((uintptr_t)(x) & (sizeof(void *) - 1)) == 0)
+#define SHT_ARM_EXIDX 0x70000001 /* Section holds ARM unwind info. */
static inline Elf_Addr
load_ptr(void *where)
@@ -56,9 +61,18 @@ static inline Elf_SOff
sign_extend31(Elf_Addr val)
if (0x40000000 & val)
- return ~((Elf_Addr)0x7fffffff) | (0x7fffffff & val);
- else
- return 0x7fffffff & val;
+ val = ~((Elf_Addr)0x7fffffff) | (0x7fffffff & val);
+ return 0x7fffffff & val;
+uint32_t
+rtems_rtl_elf_section_flags (const rtems_rtl_obj_t* obj,
+ uint32_t flags = 0;
+ if (shdr->sh_type == SHT_ARM_EXIDX)
+ flags = RTEMS_RTL_OBJ_SECT_EH | RTEMS_RTL_OBJ_SECT_LOAD;
+ return flags;
bool
@@ -96,8 +110,11 @@ rtems_rtl_elf_relocate_rel (const rtems_rtl_obj_t* obj,
where = (Elf_Addr *)(sect->base + rel->r_offset);
switch (ELF_R_TYPE(rel->r_info)) {
- case R_TYPE(NONE):
- break;
+ case R_TYPE(NONE):
+ if (rtems_rtl_trace (RTEMS_RTL_TRACE_RELOC)) {
+ printf ("rtl: NONE %p in %s\n", where, rtems_rtl_obj_oname (obj));
+ break;
case R_TYPE(CALL): /* BL/BLX */
case R_TYPE(JUMP24): /* B/BL<cond> */
@@ -175,29 +192,31 @@ rtems_rtl_elf_relocate_rel (const rtems_rtl_obj_t* obj,
case R_TYPE(ABS32): /* word32 (S + A) | T */
case R_TYPE(GLOB_DAT): /* word32 (S + A) | T */
case R_TYPE(PREL31): /* word32 (S + A) | T - P */
- case R_TYPE(TARGET2): /* Equivalent to ABS32 */
+ case R_TYPE(TARGET2): /* Equivalent to REL32 */
if (__predict_true(RELOC_ALIGNED_P(where))) {
tmp = *where + symvalue;
if (isThumb(symvalue))
tmp |= 1;
- if (ELF_R_TYPE(rel->r_info) == R_TYPE(REL32))
+ if (ELF_R_TYPE(rel->r_info) == R_TYPE(REL32) ||
+ ELF_R_TYPE(rel->r_info) == R_TYPE(TARGET2))
tmp -= (Elf_Addr)where;
else if (ELF_R_TYPE(rel->r_info) == R_TYPE(PREL31))
- tmp -= sign_extend31((Elf_Addr)where);
+ tmp = sign_extend31(tmp - (Elf_Addr)where);
*where = tmp;
} else {
tmp = load_ptr(where) + symvalue;
tmp |= 1;
store_ptr(where, tmp);
- printf ("rtl: REL32/ABS32/GLOB_DAT/PREL31/TARGET2 %p @ %p in %s",
+ printf ("rtl: REL32/ABS32/GLOB_DAT/PREL31/TARGET2 %p @ %p in %s\n",
(void *)tmp, where, rtems_rtl_obj_oname (obj));
break;
@@ -321,7 +340,7 @@ rtems_rtl_elf_relocate_rel (const rtems_rtl_obj_t* obj,
(void *)*where, where, rtems_rtl_obj_oname (obj));
break;
- default:
+ default:
printf ("rtl: reloc unknown: sym = %lu, type = %lu, offset = %p, "
"contents = %p\n",
ELF_R_SYM(rel->r_info), (uint32_t) ELF_R_TYPE(rel->r_info),
@@ -330,9 +349,109 @@ rtems_rtl_elf_relocate_rel (const rtems_rtl_obj_t* obj,
"%s: Unsupported relocation type %ld "
"in non-PLT relocations",
sect->name, (uint32_t) ELF_R_TYPE(rel->r_info));
- return false;
+ return false;
- return true;
+ return true;
+bool
+rtems_rtl_elf_unwind_parse (const rtems_rtl_obj_t* obj,
+ const char* name,
+ uint32_t flags)
+ * We location the EH sections in section flags.
+ return false;
+bool
+rtems_rtl_elf_unwind_register (rtems_rtl_obj_t* obj)
+ rtems_chain_control* sections = &obj->sections;
+ rtems_chain_node* node = rtems_chain_first (sections);
+ while (!rtems_chain_is_tail (sections, node))
+ rtems_rtl_obj_sect_t* sect = (rtems_rtl_obj_sect_t*) node;
+ if ((sect->flags & RTEMS_RTL_OBJ_SECT_EH) != 0)
+ break;
+ node = rtems_chain_next (node);
+ return true;
+bool
+rtems_rtl_elf_unwind_deregister (rtems_rtl_obj_t* obj)
+ obj->loader = NULL;
+ return true;
+/* An exception index table entry. */
+typedef struct __EIT_entry
+ _uw fnoffset;
+ _uw content;
+} __EIT_entry;
+/* The exception index table location in the base module */
+extern __EIT_entry __exidx_start;
+extern __EIT_entry __exidx_end;
+static inline _uw
+selfrel_offset31 (const _uw *p)
+ _uw offset;
+ offset = *p;
+ /* Sign extend to 32 bits. */
+ if (offset & (1 << 30))
+ offset |= 1u << 31;
+ else
+ offset &= ~(1u << 31);
+ return offset + (_uw) p;
+ * A weak reference is in libgcc, provide a real version and provide a way to
+ * manage loaded modules.
+ * Passed in the return address and a reference to the number of records
+ * found. We set the start of the exidx data and the number of records.
+_Unwind_Ptr __gnu_Unwind_Find_exidx (_Unwind_Ptr return_address,
+ int* nrec) __attribute__ ((__noinline__,
+ __used__,
+ __noclone__));
+ int* nrec)
+ rtems_rtl_data_t* rtl;
+ rtems_chain_node* node;
+ __EIT_entry* exidx_start = &__exidx_start;
+ __EIT_entry* exidx_end = &__exidx_end;
+ rtl = rtems_rtl_lock ();
+ node = rtems_chain_first (&rtl->objects);
+ while (!rtems_chain_is_tail (&rtl->objects, node)) {
+ rtems_rtl_obj_t* obj = (rtems_rtl_obj_t*) node;
+ if (rtems_rtl_obj_text_inside (obj, (void*) return_address)) {
+ exidx_start = (__EIT_entry*) obj->eh_base;
+ exidx_end = (__EIT_entry*) (obj->eh_base + obj->eh_size);
+ break;
+ *nrec = exidx_end - exidx_start;
+ return (_Unwind_Ptr) exidx_start;
diff --git a/cpukit/libdl/rtl-mdreloc-bfin.c b/cpukit/libdl/rtl-mdreloc-bfin.c
index d855d30..5a1fd26 100644
--- a/cpukit/libdl/rtl-mdreloc-bfin.c
+++ b/cpukit/libdl/rtl-mdreloc-bfin.c
@@ -6,6 +6,15 @@
+#include "rtl-unwind-dw2.h"
+uint32_t
+ return 0;
bool
rtems_rtl_elf_rel_resolve_sym (Elf_Word type)
@@ -113,3 +122,23 @@ rtems_rtl_elf_relocate_rel (const rtems_rtl_obj_t* obj,
rtems_rtl_set_error (EINVAL, "rel type record not supported");
return false;
+bool
+ const char* name,
+ uint32_t flags)
+ return rtems_rtl_elf_unwind_dw2_parse (obj, name, flags);
+bool
+ return rtems_rtl_elf_unwind_dw2_register (obj);
+bool
+ return rtems_rtl_elf_unwind_dw2_deregister (obj);
diff --git a/cpukit/libdl/rtl-mdreloc-h8300.c b/cpukit/libdl/rtl-mdreloc-h8300.c
index 925601b..0ef717b 100644
--- a/cpukit/libdl/rtl-mdreloc-h8300.c
+++ b/cpukit/libdl/rtl-mdreloc-h8300.c
@@ -9,6 +9,15 @@
+uint32_t
+ return 0;
bool
@@ -99,3 +108,23 @@ rtems_rtl_elf_relocate_rel (const rtems_rtl_obj_t* obj,
return false;
+bool
+ const char* name,
+ uint32_t flags)
+bool
+bool
diff --git a/cpukit/libdl/rtl-mdreloc-i386.c b/cpukit/libdl/rtl-mdreloc-i386.c
index b6dd9b7..c8f1e11 100644
--- a/cpukit/libdl/rtl-mdreloc-i386.c
+++ b/cpukit/libdl/rtl-mdreloc-i386.c
@@ -15,6 +15,15 @@
+uint32_t
+ return 0;
bool
@@ -101,3 +110,23 @@ rtems_rtl_elf_relocate_rel (const rtems_rtl_obj_t* obj,
return true;
+bool
+ const char* name,
+ uint32_t flags)
+bool
+bool
diff --git a/cpukit/libdl/rtl-mdreloc-lm32.c b/cpukit/libdl/rtl-mdreloc-lm32.c
index 057d6ce..e7e2a4c 100644
--- a/cpukit/libdl/rtl-mdreloc-lm32.c
+++ b/cpukit/libdl/rtl-mdreloc-lm32.c
@@ -9,6 +9,15 @@
+uint32_t
+ return 0;
bool
@@ -118,3 +127,23 @@ rtems_rtl_elf_relocate_rel (const rtems_rtl_obj_t* obj,
rtems_rtl_set_error (EINVAL, "rela type record not supported");
return false;
+bool
+ const char* name,
+ uint32_t flags)
+bool
+bool
diff --git a/cpukit/libdl/rtl-mdreloc-m68k.c b/cpukit/libdl/rtl-mdreloc-m68k.c
index 36692eb..8a91ebc 100644
--- a/cpukit/libdl/rtl-mdreloc-m68k.c
+++ b/cpukit/libdl/rtl-mdreloc-m68k.c
@@ -15,6 +15,8 @@
static inline int overflow_8_check(int value)
@@ -30,6 +32,13 @@ static inline int overflow_16_check(int value)
return false;
+uint32_t
+ return 0;
bool
@@ -146,3 +155,23 @@ rtems_rtl_elf_relocate_rel (const rtems_rtl_obj_t* obj,
return false;
+bool
+ const char* name,
+ uint32_t flags)
+bool
+bool
diff --git a/cpukit/libdl/rtl-mdreloc-mips.c b/cpukit/libdl/rtl-mdreloc-mips.c
index c17dbc2..7ceac54 100644
--- a/cpukit/libdl/rtl-mdreloc-mips.c
+++ b/cpukit/libdl/rtl-mdreloc-mips.c
@@ -9,6 +9,15 @@
+uint32_t
+ return 0;
bool
@@ -188,3 +197,23 @@ rtems_rtl_elf_relocate_rel (const rtems_rtl_obj_t* obj,
return true;
+bool
+ const char* name,
+ uint32_t flags)
+bool
+bool
diff --git a/cpukit/libdl/rtl-mdreloc-moxie.c b/cpukit/libdl/rtl-mdreloc-moxie.c
index 1fb05e6..27b0cf6 100644
--- a/cpukit/libdl/rtl-mdreloc-moxie.c
+++ b/cpukit/libdl/rtl-mdreloc-moxie.c
@@ -10,6 +10,15 @@
+uint32_t
+ return 0;
bool
@@ -86,3 +95,23 @@ rtems_rtl_elf_relocate_rel (const rtems_rtl_obj_t* obj,
return false;
+bool
+ const char* name,
+ uint32_t flags)
+bool
+bool
diff --git a/cpukit/libdl/rtl-mdreloc-powerpc.c b/cpukit/libdl/rtl-mdreloc-powerpc.c
index 6909167..43c0b83 100644
--- a/cpukit/libdl/rtl-mdreloc-powerpc.c
+++ b/cpukit/libdl/rtl-mdreloc-powerpc.c
@@ -15,11 +15,19 @@
#define ha(x) ((((u_int32_t)(x) & 0x8000) ? \
((u_int32_t)(x) + 0x10000) : (u_int32_t)(x)) >> 16)
#define l(x) ((u_int32_t)(x) & 0xffff)
+uint32_t
+ return 0;
bool
@@ -158,6 +166,21 @@ rtems_rtl_elf_relocate_rela (const rtems_rtl_obj_t* obj,
break;
+ case R_TYPE(SDAREL16):
+ * A sign-extended 16 bit value relative to _SDA_BASE_, for use with
+ * small data items.
+ mask = 0xffff;
+ tmp = *((Elf32_Half*) where);
+ tmp &= ~mask;
+ tmp |= (symvalue + rela->r_addend - (Elf_Addr)where) & mask;
+ *((Elf32_Half*) where) = tmp;
+ printf ("rtl: SDAREL16 %p @ %p in %s\n",
+ (void *) *((Elf32_Half*) where), where, rtems_rtl_obj_oname (obj));
+ break;
default:
"contents = %p\n",
@@ -183,3 +206,23 @@ rtems_rtl_elf_relocate_rel (const rtems_rtl_obj_t* obj,
printf ("rtl: rel type record not supported; please report\n");
return false;
+bool
+ const char* name,
+ uint32_t flags)
+bool
+bool
diff --git a/cpukit/libdl/rtl-mdreloc-sparc.c b/cpukit/libdl/rtl-mdreloc-sparc.c
index 509b62f..38b3850 100644
--- a/cpukit/libdl/rtl-mdreloc-sparc.c
+++ b/cpukit/libdl/rtl-mdreloc-sparc.c
@@ -41,6 +41,8 @@
* The following table holds for each relocation type:
@@ -128,6 +130,13 @@ static const int reloc_target_bitmask[] = {
#define RELOC_VALUE_BITMASK(t) (reloc_target_bitmask[t])
+uint32_t
+ return 0;
bool
@@ -220,21 +229,22 @@ rtems_rtl_elf_relocate_rela (const rtems_rtl_obj_t* obj,
value &= mask;
if (RELOC_UNALIGNED(type)) {
- /* Handle unaligned relocations. */
- char *ptr = (char *)where;
+ * Handle unaligned relocations.
+ char *ptr = (char*) where;
int i, size = RELOC_TARGET_SIZE (type) / 8;
/* Read it in one byte at a time. */
- for (i=0; i<size; i++)
+ for (i = size - 1; i >= 0; i--)
tmp = (tmp << 8) | ptr[i];
tmp &= ~mask;
tmp |= value;
/* Write it back out. */
- ptr[i] = ((tmp >> (8*i)) & 0xff);
+ for (i = size - 1; i >= 0; i--, tmp >>= 8)
+ ptr[i] = tmp & 0xff;
} else {
*where &= ~mask;
*where |= value;
@@ -245,7 +255,6 @@ rtems_rtl_elf_relocate_rela (const rtems_rtl_obj_t* obj,
printf ("rtl: %s %p @ %p in %s\n",
reloc_names[type], (void *)tmp, where, rtems_rtl_obj_oname (obj));
return true;
@@ -260,3 +269,23 @@ rtems_rtl_elf_relocate_rel (const rtems_rtl_obj_t* obj,
return false;
+bool
+ const char* name,
+ uint32_t flags)
+bool
+bool
diff --git a/cpukit/libdl/rtl-mdreloc-v850.c b/cpukit/libdl/rtl-mdreloc-v850.c
index 5372e81..7f958a5 100644
--- a/cpukit/libdl/rtl-mdreloc-v850.c
+++ b/cpukit/libdl/rtl-mdreloc-v850.c
@@ -10,6 +10,15 @@
+uint32_t
+ return 0;
bool
@@ -95,3 +104,23 @@ rtems_rtl_elf_relocate_rel (const rtems_rtl_obj_t* obj,
return false;
+bool
+ const char* name,
+ uint32_t flags)
+bool
+bool
diff --git a/cpukit/libdl/rtl-obj.c b/cpukit/libdl/rtl-obj.c
index bdcebce..b27f28b 100644
--- a/cpukit/libdl/rtl-obj.c
+++ b/cpukit/libdl/rtl-obj.c
@@ -49,14 +49,21 @@
* The table of supported loader formats.
-static rtems_rtl_loader_table_t loaders[RTEMS_RTL_ELF_LOADER_COUNT +
- RTEMS_RTL_RAP_LOADER_COUNT] =
+#define RTEMS_RTL_LOADERS (RTEMS_RTL_ELF_LOADER_COUNT + RTEMS_RTL_RAP_LOADER_COUNT)
+static const rtems_rtl_loader_table_t loaders[RTEMS_RTL_LOADERS] =
#if RTEMS_RTL_RAP_LOADER
- { rtems_rtl_rap_file_check, rtems_rtl_rap_file_load, rtems_rtl_rap_file_sig },
+ { .check = rtems_rtl_rap_file_check,
+ .load = rtems_rtl_rap_file_load,
+ .unload = rtems_rtl_rap_file_unload,
+ .signature = rtems_rtl_rap_file_sig },
#endif
#if RTEMS_RTL_ELF_LOADER
- { rtems_rtl_elf_file_check, rtems_rtl_elf_file_load, rtems_rtl_elf_file_sig },
+ { .check = rtems_rtl_elf_file_check,
+ .load = rtems_rtl_elf_file_load,
+ .unload = rtems_rtl_elf_file_unload,
+ .signature = rtems_rtl_elf_file_sig },
#endif
@@ -72,6 +79,10 @@ rtems_rtl_obj_alloc (void)
* Initialise the chains.
rtems_chain_initialize_empty (&obj->sections);
+ * No valid format.
+ obj->format = -1;
return obj;
@@ -97,14 +108,14 @@ rtems_rtl_obj_free (rtems_rtl_obj_t* obj)
if (!rtems_chain_is_node_off_chain (&obj->link))
rtems_chain_extract (&obj->link);
- rtems_rtl_alloc_module_del (&obj->text_base, &obj->const_base,
+ rtems_rtl_alloc_module_del (&obj->text_base, &obj->const_base, &obj->eh_base,
&obj->data_base, &obj->bss_base);
rtems_rtl_symbol_obj_erase (obj);
rtems_rtl_obj_free_names (obj);
if (obj->sec_num)
free (obj->sec_num);
- if (obj->detail)
- rtems_rtl_alloc_del (RTEMS_RTL_ALLOC_OBJECT, (void*)obj->detail);
+ if (obj->linkmap)
+ rtems_rtl_alloc_del (RTEMS_RTL_ALLOC_OBJECT, (void*) obj->linkmap);
rtems_rtl_alloc_del (RTEMS_RTL_ALLOC_OBJECT, obj);
return true;
@@ -238,7 +249,7 @@ rtems_rtl_scan_decimal (const uint8_t* string, size_t len)
static size_t
rtems_rtl_sect_align (size_t offset, uint32_t alignment)
- if ((alignment > 1) && ((offset & ~alignment) != 0))
+ if ((alignment > 1) && ((offset & (alignment - 1)) != 0))
offset = (offset + alignment) & ~(alignment - 1);
return offset;
@@ -264,12 +275,12 @@ rtems_rtl_obj_sect_summer (rtems_chain_node* node, void* data)
static size_t
-rtems_rtl_obj_section_size (rtems_rtl_obj_t* obj, uint32_t mask)
+rtems_rtl_obj_section_size (const rtems_rtl_obj_t* obj, uint32_t mask)
rtems_rtl_obj_sect_summer_t summer;
summer.mask = mask;
summer.size = 0;
- rtems_rtl_chain_iterate (&obj->sections,
+ rtems_rtl_chain_iterate ((rtems_chain_control*) &obj->sections,
rtems_rtl_obj_sect_summer,
&summer);
return summer.size;
@@ -302,12 +313,12 @@ rtems_rtl_obj_sect_aligner (rtems_chain_node* node, void* data)
static size_t
-rtems_rtl_obj_section_alignment (rtems_rtl_obj_t* obj, uint32_t mask)
+rtems_rtl_obj_section_alignment (const rtems_rtl_obj_t* obj, uint32_t mask)
rtems_rtl_obj_sect_aligner_t aligner;
aligner.mask = mask;
aligner.alignment = 0;
rtems_rtl_obj_sect_aligner,
&aligner);
return aligner.alignment;
@@ -401,26 +412,30 @@ rtems_rtl_obj_add_section (rtems_rtl_obj_t* obj,
int info,
uint32_t flags)
- rtems_rtl_obj_sect_t* sect = rtems_rtl_alloc_new (RTEMS_RTL_ALLOC_OBJECT,
- sizeof (rtems_rtl_obj_sect_t), true);
- if (!sect)
+ if (size > 0)
- rtems_rtl_set_error (ENOMEM, "adding allocated section");
- return false;
+ rtems_rtl_obj_sect_t* sect = rtems_rtl_alloc_new (RTEMS_RTL_ALLOC_OBJECT,
+ sizeof (rtems_rtl_obj_sect_t),
+ true);
+ if (!sect)
+ rtems_rtl_set_error (ENOMEM, "adding allocated section");
+ return false;
+ sect->section = section;
+ sect->name = rtems_rtl_strdup (name);
+ sect->size = size;
+ sect->offset = offset;
+ sect->alignment = alignment;
+ sect->link = link;
+ sect->info = info;
+ sect->flags = flags;
+ sect->base = NULL;
+ rtems_chain_append (&obj->sections, §->node);
+ if (rtems_rtl_trace (RTEMS_RTL_TRACE_SECTION))
+ printf ("rtl: sect: %-2d: %s (%zu)\n", section, name, size);
- sect->section = section;
- sect->name = rtems_rtl_strdup (name);
- sect->size = size;
- sect->offset = offset;
- sect->alignment = alignment;
- sect->link = link;
- sect->info = info;
- sect->flags = flags;
- sect->base = NULL;
- rtems_chain_append (&obj->sections, §->node);
- if (rtems_rtl_trace (RTEMS_RTL_TRACE_SECTION))
- printf ("rtl: sect: %-2d: %s\n", section, name);
return true;
@@ -464,12 +479,13 @@ rtems_rtl_obj_sect_match_name (rtems_chain_node* node, void* data)
-rtems_rtl_obj_find_section (rtems_rtl_obj_t* obj, const char* name)
+rtems_rtl_obj_find_section (const rtems_rtl_obj_t* obj,
+ const char* name)
rtems_rtl_obj_sect_finder_t match;
match.sect = NULL;
match.name = name;
rtems_rtl_obj_sect_match_name,
&match);
return match.sect;
@@ -489,61 +505,74 @@ rtems_rtl_obj_sect_match_index (rtems_chain_node* node, void* data)
-rtems_rtl_obj_find_section_by_index (rtems_rtl_obj_t* obj, int index)
+rtems_rtl_obj_find_section_by_index (const rtems_rtl_obj_t* obj,
+ int index)
match.sect = NULL;
match.index = index;
rtems_rtl_obj_sect_match_index,
&match);
return match.sect;
size_t
-rtems_rtl_obj_text_size (rtems_rtl_obj_t* obj)
+rtems_rtl_obj_text_size (const rtems_rtl_obj_t* obj)
return rtems_rtl_obj_section_size (obj, RTEMS_RTL_OBJ_SECT_TEXT);
uint32_t
-rtems_rtl_obj_text_alignment (rtems_rtl_obj_t* obj)
+rtems_rtl_obj_text_alignment (const rtems_rtl_obj_t* obj)
return rtems_rtl_obj_section_alignment (obj, RTEMS_RTL_OBJ_SECT_TEXT);
size_t
-rtems_rtl_obj_const_size (rtems_rtl_obj_t* obj)
+rtems_rtl_obj_const_size (const rtems_rtl_obj_t* obj)
return rtems_rtl_obj_section_size (obj, RTEMS_RTL_OBJ_SECT_CONST);
uint32_t
-rtems_rtl_obj_const_alignment (rtems_rtl_obj_t* obj)
+rtems_rtl_obj_eh_alignment (const rtems_rtl_obj_t* obj)
+ return rtems_rtl_obj_section_alignment (obj, RTEMS_RTL_OBJ_SECT_EH);
+size_t
+rtems_rtl_obj_eh_size (const rtems_rtl_obj_t* obj)
+ return rtems_rtl_obj_section_size (obj, RTEMS_RTL_OBJ_SECT_EH);
+uint32_t
+rtems_rtl_obj_const_alignment (const rtems_rtl_obj_t* obj)
return rtems_rtl_obj_section_alignment (obj, RTEMS_RTL_OBJ_SECT_CONST);
size_t
-rtems_rtl_obj_data_size (rtems_rtl_obj_t* obj)
+rtems_rtl_obj_data_size (const rtems_rtl_obj_t* obj)
return rtems_rtl_obj_section_size (obj, RTEMS_RTL_OBJ_SECT_DATA);
uint32_t
-rtems_rtl_obj_data_alignment (rtems_rtl_obj_t* obj)
+rtems_rtl_obj_data_alignment (const rtems_rtl_obj_t* obj)
return rtems_rtl_obj_section_alignment (obj, RTEMS_RTL_OBJ_SECT_DATA);
size_t
-rtems_rtl_obj_bss_size (rtems_rtl_obj_t* obj)
+rtems_rtl_obj_bss_size (const rtems_rtl_obj_t* obj)
return rtems_rtl_obj_section_size (obj, RTEMS_RTL_OBJ_SECT_BSS);
uint32_t
-rtems_rtl_obj_bss_alignment (rtems_rtl_obj_t* obj)
+rtems_rtl_obj_bss_alignment (const rtems_rtl_obj_t* obj)
return rtems_rtl_obj_section_alignment (obj, RTEMS_RTL_OBJ_SECT_BSS);
@@ -580,13 +609,17 @@ rtems_rtl_obj_sect_sync_handler (rtems_chain_node* node, void* data)
if ( !(sect->flags & sync_ctx->mask) || !sect->size)
return true;
- if (sync_ctx->end_va == sync_ctx->start_va) {
+ if (sync_ctx->end_va == sync_ctx->start_va)
sync_ctx->start_va = sect->base;
- } else {
- old_end = (uintptr_t)sync_ctx->end_va & ~(sync_ctx->cache_line_size - 1);
- new_start = (uintptr_t)sect->base & ~(sync_ctx->cache_line_size - 1);
- if ( (sect->base < sync_ctx->start_va) ||
- (new_start - old_end > sync_ctx->cache_line_size) ) {
+ else
+ old_end = (uintptr_t) sync_ctx->end_va & ~(sync_ctx->cache_line_size - 1);
+ new_start = (uintptr_t) sect->base & ~(sync_ctx->cache_line_size - 1);
+ if ((sect->base < sync_ctx->start_va) ||
+ (new_start - old_end > sync_ctx->cache_line_size))
rtems_cache_instruction_sync_after_code_change(sync_ctx->start_va,
sync_ctx->end_va - sync_ctx->start_va + 1);
@@ -658,8 +691,8 @@ rtems_rtl_obj_sections_loader (uint32_t mask,
sect->base = base + base_offset;
if (rtems_rtl_trace (RTEMS_RTL_TRACE_LOAD_SECT))
- printf ("rtl: loading: %s -> %8p (%zi)\n",
- sect->name, sect->base, sect->size);
+ printf ("rtl: loading: %s -> %8p (l:%zi m:%04lx)\n",
+ sect->name, sect->base, sect->size, sect->flags);
if ((sect->flags & RTEMS_RTL_OBJ_SECT_LOAD) == RTEMS_RTL_OBJ_SECT_LOAD)
@@ -698,20 +731,30 @@ rtems_rtl_obj_load_sections (rtems_rtl_obj_t* obj,
size_t text_size;
size_t const_size;
+ size_t eh_size;
size_t data_size;
size_t bss_size;
text_size = rtems_rtl_obj_text_size (obj) + rtems_rtl_obj_const_alignment (obj);
- const_size = rtems_rtl_obj_const_size (obj) + rtems_rtl_obj_data_alignment (obj);
+ const_size = rtems_rtl_obj_const_size (obj) + rtems_rtl_obj_eh_alignment (obj);
+ eh_size = rtems_rtl_obj_eh_size (obj) + rtems_rtl_obj_data_alignment (obj);
data_size = rtems_rtl_obj_data_size (obj) + rtems_rtl_obj_bss_alignment (obj);
bss_size = rtems_rtl_obj_bss_size (obj);
+ * Set the sizes held in the object data. We need this for a fast reference.
+ obj->text_size = text_size;
+ obj->eh_size = eh_size;
+ obj->bss_size = bss_size;
* Let the allocator manage the actual allocation. The user can use the
* standard heap or provide a specific allocator with memory protection.
if (!rtems_rtl_alloc_module_new (&obj->text_base, text_size,
&obj->const_base, const_size,
+ &obj->eh_base, eh_size,
&obj->data_base, data_size,
&obj->bss_base, bss_size))
@@ -728,6 +771,8 @@ rtems_rtl_obj_load_sections (rtems_rtl_obj_t* obj,
obj->text_base, text_size, rtems_rtl_obj_text_alignment (obj));
printf ("rtl: load sect: const - b:%p s:%zi a:%" PRIu32 "\n",
obj->const_base, const_size, rtems_rtl_obj_const_alignment (obj));
+ printf ("rtl: load sect: eh - b:%p s:%zi a:%" PRIu32 "\n",
+ obj->eh_base, eh_size, rtems_rtl_obj_eh_alignment (obj));
printf ("rtl: load sect: data - b:%p s:%zi a:%" PRIu32 "\n",
obj->data_base, data_size, rtems_rtl_obj_data_alignment (obj));
printf ("rtl: load sect: bss - b:%p s:%zi a:%" PRIu32 "\n",
@@ -742,12 +787,14 @@ rtems_rtl_obj_load_sections (rtems_rtl_obj_t* obj,
obj, fd, obj->text_base, handler, data) ||
!rtems_rtl_obj_sections_loader (RTEMS_RTL_OBJ_SECT_CONST,
obj, fd, obj->const_base, handler, data) ||
+ !rtems_rtl_obj_sections_loader (RTEMS_RTL_OBJ_SECT_EH,
+ obj, fd, obj->eh_base, handler, data) ||
!rtems_rtl_obj_sections_loader (RTEMS_RTL_OBJ_SECT_DATA,
obj, fd, obj->data_base, handler, data) ||
!rtems_rtl_obj_sections_loader (RTEMS_RTL_OBJ_SECT_BSS,
obj, fd, obj->bss_base, handler, data))
obj->exec_size = 0;
return false;
@@ -972,7 +1019,7 @@ rtems_rtl_obj_archive_find (rtems_rtl_obj_t* obj, int fd)
* name from the table and compare with the name we are after.
#define RTEMS_RTL_MAX_FILE_SIZE (256)
- char name[RTEMS_RTL_MAX_FILE_SIZE];
+ char name[RTEMS_RTL_MAX_FILE_SIZE];
if (!rtems_rtl_seek_read (fd, extended_file_names + extended_off,
RTEMS_RTL_MAX_FILE_SIZE, (uint8_t*) &name[0]))
@@ -1016,7 +1063,7 @@ rtems_rtl_obj_archive_find (rtems_rtl_obj_t* obj, int fd)
return false;
-bool
+static bool
rtems_rtl_obj_file_load (rtems_rtl_obj_t* obj, int fd)
int l;
@@ -1024,13 +1071,24 @@ rtems_rtl_obj_file_load (rtems_rtl_obj_t* obj, int fd)
for (l = 0; l < (sizeof (loaders) / sizeof (rtems_rtl_loader_table_t)); ++l)
if (loaders[l].check (obj, fd))
+ obj->format = l;
return loaders[l].load (obj, fd);
rtems_rtl_set_error (ENOENT, "no format loader found");
return false;
+static bool
+rtems_rtl_obj_file_unload (rtems_rtl_obj_t* obj)
+ if (obj->format >= 0 && obj->format < RTEMS_RTL_LOADERS)
+ return loaders[obj->format].unload (obj);
+ return false;
bool
rtems_rtl_obj_load (rtems_rtl_obj_t* obj)
@@ -1057,20 +1115,16 @@ rtems_rtl_obj_load (rtems_rtl_obj_t* obj)
if (!rtems_rtl_obj_archive_find (obj, fd))
- rtems_rtl_obj_caches_flush ();
close (fd);
return false;
- * Call the format specific loader. Currently this is a call to the ELF
- * loader. This call could be changed to allow probes then calls if more than
- * one format is supported.
+ * Call the format specific loader.
if (!rtems_rtl_obj_file_load (obj, fd))
close (fd);
return false;
@@ -1081,8 +1135,6 @@ rtems_rtl_obj_load (rtems_rtl_obj_t* obj)
return false;
close (fd);
return true;
@@ -1092,6 +1144,6 @@ bool
rtems_rtl_obj_unload (rtems_rtl_obj_t* obj)
_rtld_linkmap_delete(obj);
- rtems_rtl_symbol_obj_erase (obj);
- return rtems_rtl_obj_free (obj);
+ rtems_rtl_obj_file_unload (obj);
+ return true;
diff --git a/cpukit/libdl/rtl-obj.h b/cpukit/libdl/rtl-obj.h
index 80fc60f..9ec184b 100644
--- a/cpukit/libdl/rtl-obj.h
+++ b/cpukit/libdl/rtl-obj.h
@@ -56,14 +56,20 @@ typedef struct rtems_rtl_loader_format_s
typedef bool (*rtems_rtl_loader_check) (rtems_rtl_obj_t* obj, int fd);
- * The type of the format loader handler. This handler loads the specific
+ * The type of the format loader load handler. This handler loads the specific
* format.
typedef bool (*rtems_rtl_loader_load) (rtems_rtl_obj_t* obj, int fd);
- * format.
+ * The type of the format loader unload handler. This handler unloads the
+ * specific format.
+typedef bool (*rtems_rtl_loader_unload) (rtems_rtl_obj_t* obj);
+ * The type of the format loader signature handler. This handler checks the
+ * format signature.
typedef rtems_rtl_loader_format_t* (*rtems_rtl_loader_sig) (void);
@@ -72,9 +78,10 @@ typedef rtems_rtl_loader_format_t* (*rtems_rtl_loader_sig) (void);
typedef struct rtems_rtl_loader_table_s
- rtems_rtl_loader_check check; /**< The check handler. */
- rtems_rtl_loader_load load; /**< The loader. */
- rtems_rtl_loader_sig signature; /**< The loader's signature. */
+ rtems_rtl_loader_check check; /**< The check handler. */
+ rtems_rtl_loader_load load; /**< The loader. */
+ rtems_rtl_loader_unload unload; /**< The unloader. */
+ rtems_rtl_loader_sig signature; /**< The loader's signature. */
} rtems_rtl_loader_table_t;
@@ -84,18 +91,19 @@ typedef struct rtems_rtl_loader_table_s
#define RTEMS_RTL_OBJ_SECT_CONST (1 << 1) /**< Section holds program text. */
#define RTEMS_RTL_OBJ_SECT_DATA (1 << 2) /**< Section holds program data. */
#define RTEMS_RTL_OBJ_SECT_BSS (1 << 3) /**< Section holds program bss. */
-#define RTEMS_RTL_OBJ_SECT_REL (1 << 4) /**< Section holds relocation records. */
-#define RTEMS_RTL_OBJ_SECT_RELA (1 << 5) /**< Section holds relocation addend
+#define RTEMS_RTL_OBJ_SECT_EH (1 << 4) /**< Section holds exception data. */
+#define RTEMS_RTL_OBJ_SECT_REL (1 << 5) /**< Section holds relocation records. */
+#define RTEMS_RTL_OBJ_SECT_RELA (1 << 6) /**< Section holds relocation addend
* records. */
-#define RTEMS_RTL_OBJ_SECT_SYM (1 << 6) /**< Section holds symbols. */
-#define RTEMS_RTL_OBJ_SECT_STR (1 << 7) /**< Section holds strings. */
-#define RTEMS_RTL_OBJ_SECT_ALLOC (1 << 8) /**< Section allocates runtime memory. */
-#define RTEMS_RTL_OBJ_SECT_LOAD (1 << 9) /**< Section is loaded from object file. */
-#define RTEMS_RTL_OBJ_SECT_WRITE (1 << 10) /**< Section is writable, ie data. */
-#define RTEMS_RTL_OBJ_SECT_EXEC (1 << 11) /**< Section is executable. */
-#define RTEMS_RTL_OBJ_SECT_ZERO (1 << 12) /**< Section is preset to zero. */
-#define RTEMS_RTL_OBJ_SECT_CTOR (1 << 13) /**< Section contains constructors. */
-#define RTEMS_RTL_OBJ_SECT_DTOR (1 << 14) /**< Section contains destructors. */
+#define RTEMS_RTL_OBJ_SECT_SYM (1 << 7) /**< Section holds symbols. */
+#define RTEMS_RTL_OBJ_SECT_STR (1 << 8) /**< Section holds strings. */
+#define RTEMS_RTL_OBJ_SECT_ALLOC (1 << 9) /**< Section allocates runtime memory. */
+#define RTEMS_RTL_OBJ_SECT_LOAD (1 << 10) /**< Section is loaded from object file. */
+#define RTEMS_RTL_OBJ_SECT_WRITE (1 << 11) /**< Section is writable, ie data. */
+#define RTEMS_RTL_OBJ_SECT_EXEC (1 << 12) /**< Section is executable. */
+#define RTEMS_RTL_OBJ_SECT_ZERO (1 << 13) /**< Section is preset to zero. */
+#define RTEMS_RTL_OBJ_SECT_CTOR (1 << 14) /**< Section contains constructors. */
+#define RTEMS_RTL_OBJ_SECT_DTOR (1 << 15) /**< Section contains destructors. */
* An object file is made up of sections and the can be more than
@@ -109,7 +117,7 @@ struct rtems_rtl_obj_sect_s
const char* name; /**< The section's name. */
size_t size; /**< The size of the section in memory. */
off_t offset; /**< Offset into the object file. Relative to
- * the start of the object file. */
+ * the start of the object file. */
uint32_t alignment; /**< Alignment of this section. */
int link; /**< Section link field. */
int info; /**< Secfion info field. */
@@ -135,6 +143,7 @@ struct rtems_rtl_obj_s
rtems_chain_node link; /**< The node's link in the chain. */
uint32_t flags; /**< The status of the object file. */
uint32_t users; /**< References to the object file. */
+ int format; /**< The format of the object file. */
const char* fname; /**< The file name for the object. */
const char* oname; /**< The object file name. Can be
* relative. */
@@ -153,26 +162,27 @@ struct rtems_rtl_obj_s
size_t global_size; /**< Global symbol memory usage. */
uint32_t unresolved; /**< The number of unresolved relocations. */
void* text_base; /**< The base address of the text section
- * in memory. */
+ * in memory. */
+ size_t text_size; /**< The size of the text section. */
void* const_base; /**< The base address of the const section
- * in memory. */
+ * in memory. */
+ void* eh_base; /**< The base address of the eh section
+ * in memory. */
+ size_t eh_size; /**< The size of the eh section. */
void* data_base; /**< The base address of the data section
- * in memory. */
+ * in memory. */
void* bss_base; /**< The base address of the bss section
- * in memory. */
+ * in memory. */
size_t bss_size; /**< The size of the bss section. */
size_t exec_size; /**< The amount of executable memory
- * allocated */
+ * allocated */
void* entry; /**< The entry point of the module. */
uint32_t checksum; /**< The checksum of the text sections. A
- * zero means do not checksum. */
- void* detail; /**< The file details. It contains the elf file
- * detail, mainly including elf file name,
- * section offset, section size, which
- * elf this section belongs to.*/
+ * zero means do not checksum. */
uint32_t* sec_num; /**< The sec nums of each obj. */
uint32_t obj_num; /**< The count of elf files in an rtl obj. */
struct link_map* linkmap; /**< For GDB. */
+ void* loader; /**< The file details specific to a loader. */
@@ -258,6 +268,20 @@ static inline bool rtems_rtl_obj_aname_valid (const rtems_rtl_obj_t* obj)
+ * Is the address inside the text section?
+ * @param obj The object file.
+ * @return bool There is an archive name
+static inline bool rtems_rtl_obj_text_inside (const rtems_rtl_obj_t* obj,
+ const void* address)
+ return
+ (address >= obj->text_base) &&
+ (address < (obj->text_base + obj->text_size));
* Allocate an object structure on the heap.
* @retval NULL No memory for the object.
@@ -300,18 +324,6 @@ bool rtems_rtl_parse_name (const char* name,
off_t* ooffset);
- * Load the object file.
- * @param obj The object file's descriptor.
- * @param fd The file descriptor.
- * @param load_syms Load symbols.
- * @param load_dep Load dependent object files.
- * @retval true The load was successful.
- * @retval false The load failed. The RTL error has been set.
-bool rtems_rtl_obj_file_load (rtems_rtl_obj_t* obj, int fd);
* Check of the name matches the object file's object name.
@@ -371,8 +383,8 @@ void rtems_rtl_obj_erase_sections (rtems_rtl_obj_t* obj);
* @retval NULL The section was not found.
* @return rtems_rtl_obj_sect_t* The named section.
-rtems_rtl_obj_sect_t* rtems_rtl_obj_find_section (rtems_rtl_obj_t* obj,
- const char* name);
+rtems_rtl_obj_sect_t* rtems_rtl_obj_find_section (const rtems_rtl_obj_t* obj,
+ const char* name);
* Find a section given a section's index number.
@@ -382,21 +394,21 @@ rtems_rtl_obj_sect_t* rtems_rtl_obj_find_section (rtems_rtl_obj_t* obj,
* @return rtems_rtl_obj_sect_t* The found section.
-rtems_rtl_obj_sect_t* rtems_rtl_obj_find_section_by_index (rtems_rtl_obj_t* obj,
- int index);
+rtems_rtl_obj_sect_t* rtems_rtl_obj_find_section_by_index (const rtems_rtl_obj_t* obj,
+ int index);
- * The text size of the object file. Only use once all the sections has been
- * added. It includes alignments between sections that are part of the object's
- * text area. The consts sections are included in this section.
+ * The text section size. Only use once all the sections has been added. It
+ * includes alignments between sections that are part of the object's text
+ * area. The consts sections are included in this section.
* @return size_t The size of the text area of the object file.
-size_t rtems_rtl_obj_text_size (rtems_rtl_obj_t* obj);
+size_t rtems_rtl_obj_text_size (const rtems_rtl_obj_t* obj);
- * The text section alignment of the object file. Only use once all the
+ * The text section alignment for the object file. Only use once all the
* sections has been added. The section alignment is the alignment of the first
* text type section loaded the text section.
@@ -406,20 +418,20 @@ size_t rtems_rtl_obj_text_size (rtems_rtl_obj_t* obj);
* @return uint32_t The alignment. Can be 0 or 1 for not aligned or the alignment.
-uint32_t rtems_rtl_obj_text_alignment (rtems_rtl_obj_t* obj);
+uint32_t rtems_rtl_obj_text_alignment (const rtems_rtl_obj_t* obj);
- * The const size of the object file. Only use once all the sections has been
- * const area. The consts sections are included in this section.
+ * The const section size. Only use once all the sections has been added. It
+ * includes alignments between sections that are part of the object's const
* @return size_t The size of the const area of the object file.
-size_t rtems_rtl_obj_const_size (rtems_rtl_obj_t* obj);
+size_t rtems_rtl_obj_const_size (const rtems_rtl_obj_t* obj);
- * The const section alignment of the object file. Only use once all the
+ * The const section alignment for the object file. Only use once all the
* const type section loaded the const section.
@@ -429,20 +441,42 @@ size_t rtems_rtl_obj_const_size (rtems_rtl_obj_t* obj);
-uint32_t rtems_rtl_obj_const_alignment (rtems_rtl_obj_t* obj);
+uint32_t rtems_rtl_obj_const_alignment (const rtems_rtl_obj_t* obj);
+ * The eh section size. Only use once all the sections has been added. It
+ * includes alignments between sections that are part of the object's bss area.
+ * @param obj The object file's descriptor.
+ * @return size_t The size of the bss area of the object file.
+size_t rtems_rtl_obj_eh_size (const rtems_rtl_obj_t* obj);
+ * The eh section alignment for the object file. Only use once all the sections
+ * has been added. The section alignment is the alignment of the first bss type
+ * section loaded the bss section.
+ * You can assume the alignment is a positive integral power of 2 if not 0 or
+ * 1. If 0 or 1 then there is no alignment.
+ * @return uint32_t The alignment. Can be 0 or 1 for not aligned or the alignment.
+uint32_t rtems_rtl_obj_eh_alignment (const rtems_rtl_obj_t* obj);
- * The data size of the object file. Only use once all the sections has been
- * data area.
+ * The data section size. Only use once all the sections has been added. It
+ * includes alignments between sections that are part of the object's data
+ * area.
* @return size_t The size of the data area of the object file.
-size_t rtems_rtl_obj_data_size (rtems_rtl_obj_t* obj);
+size_t rtems_rtl_obj_data_size (const rtems_rtl_obj_t* obj);
- * The data section alignment of the object file. Only use once all the
+ * The data section alignment for the object file. Only use once all the
* data type section loaded the data section.
@@ -452,20 +486,19 @@ size_t rtems_rtl_obj_data_size (rtems_rtl_obj_t* obj);
-uint32_t rtems_rtl_obj_data_alignment (rtems_rtl_obj_t* obj);
+uint32_t rtems_rtl_obj_data_alignment (const rtems_rtl_obj_t* obj);
- * The bss size of the object file. Only use once all the sections has been
- * bss area.
+ * The bss section size. Only use once all the sections has been added. It
-size_t rtems_rtl_obj_bss_size (rtems_rtl_obj_t* obj);
+size_t rtems_rtl_obj_bss_size (const rtems_rtl_obj_t* obj);
- * The bss section alignment of the object file. Only use once all the
+ * The bss section alignment for the object file. Only use once all the
* bss type section loaded the bss section.
@@ -475,7 +508,7 @@ size_t rtems_rtl_obj_bss_size (rtems_rtl_obj_t* obj);
-uint32_t rtems_rtl_obj_bss_alignment (rtems_rtl_obj_t* obj);
+uint32_t rtems_rtl_obj_bss_alignment (const rtems_rtl_obj_t* obj);
* Relocate the object file. The object file's section are parsed for any
diff --git a/cpukit/libdl/rtl-rap.c b/cpukit/libdl/rtl-rap.c
index a7fcb9f..cb7b751 100644
--- a/cpukit/libdl/rtl-rap.c
+++ b/cpukit/libdl/rtl-rap.c
@@ -427,20 +427,22 @@ rtems_rtl_rap_relocate (rtems_rtl_rap_t* rap, rtems_rtl_obj_t* obj)
- * The structure of obj->detail is
+ * The structure of obj->linkmap is:
* |object_detail(0..obj_num)|section_detail(0..sec_num[0..obj_num])|
* obj_name(0..obj_num)|section_name(0..sec_num[0..obj_num])
static bool
-rtems_rtl_rap_load_details (rtems_rtl_rap_t* rap, rtems_rtl_obj_t* obj)
+rtems_rtl_rap_load_linkmap (rtems_rtl_rap_t* rap, rtems_rtl_obj_t* obj)
+ void* detail;
struct link_map* tmp1;
- section_detail* tmp2;
- uint32_t obj_detail_size;
- uint32_t pos = 0;
- int i,j;
+ section_detail* tmp2;
+ uint32_t obj_detail_size;
+ uint32_t pos = 0;
+ int i;
+ int j;
obj_detail_size = sizeof (struct link_map) * obj->obj_num;
@@ -449,26 +451,31 @@ rtems_rtl_rap_load_details (rtems_rtl_rap_t* rap, rtems_rtl_obj_t* obj)
obj_detail_size += (obj->sec_num[i] * sizeof (section_detail));
- obj_detail_size + rap->strtable_size, true);
+ detail = rtems_rtl_alloc_new (RTEMS_RTL_ALLOC_OBJECT,
+ obj_detail_size + rap->strtable_size, true);
- if (!obj->detail)
+ if (!detail)
rap->strtable_size = 0;
return false;
- rap->strtable = obj->detail + obj_detail_size;
+ rap->strtable = detail + obj_detail_size;
- /* Read the obj names and section names */
- if (!rtems_rtl_obj_comp_read (rap->decomp, rap->strtable,
+ * Read the obj names and section names
+ if (!rtems_rtl_obj_comp_read (rap->decomp,
+ rap->strtable,
rap->strtable_size))
- rtems_rtl_alloc_del (RTEMS_RTL_ALLOC_OBJECT, obj->detail);
+ rtems_rtl_alloc_del (RTEMS_RTL_ALLOC_OBJECT, detail);
return false;
+ obj->linkmap = (struct link_map*) detail;
if (rap->rpathlen > 0)
@@ -489,7 +496,7 @@ rtems_rtl_rap_load_details (rtems_rtl_rap_t* rap, rtems_rtl_obj_t* obj)
for (i = 0; i < obj->obj_num; ++i)
- tmp1 = (struct link_map*) (obj->detail) + i;
+ tmp1 = obj->linkmap + i;
tmp1->name = rap->strtable + pos;
tmp1->sec_num = obj->sec_num[i];
tmp1->rpathlen = rap->rpathlen;
@@ -509,17 +516,17 @@ rtems_rtl_rap_load_details (rtems_rtl_rap_t* rap, rtems_rtl_obj_t* obj)
- tmp2 =(section_detail*) ((struct link_map*) (obj->detail) + obj->obj_num);
+ tmp2 = (section_detail*) (obj->linkmap + obj->obj_num);
- printf ("File %d: %s\n", i, ((struct link_map*) obj->detail + i)->name);
- printf ("Section: %d sections\n",(unsigned int) obj->sec_num[i]);
+ printf ("File %d: %s\n", i, (obj->linkmap + i)->name);
+ printf ("Section: %d sections\n", (unsigned int) obj->sec_num[i]);
- ((struct link_map*)obj->detail + i)->sec_detail = tmp2;
+ obj->linkmap[i].sec_detail = tmp2;
for (j = 0; j < obj->sec_num[i]; ++j)
@@ -532,7 +539,8 @@ rtems_rtl_rap_load_details (rtems_rtl_rap_t* rap, rtems_rtl_obj_t* obj)
!rtems_rtl_rap_read_uint32 (rap->decomp, &offset) ||
!rtems_rtl_rap_read_uint32 (rap->decomp, &size))
- rtems_rtl_alloc_del (RTEMS_RTL_ALLOC_SYMBOL, obj->detail);
+ rtems_rtl_alloc_del (RTEMS_RTL_ALLOC_SYMBOL, obj->linkmap);
+ obj->linkmap = NULL;
return false;
@@ -907,7 +915,7 @@ rtems_rtl_rap_file_load (rtems_rtl_obj_t* obj, int fd)
printf ("rtl: rap: details: obj_num=%lu\n", obj->obj_num);
- if (!rtems_rtl_rap_load_details (&rap, obj))
+ if (!rtems_rtl_rap_load_linkmap (&rap, obj))
return false;
@@ -975,6 +983,13 @@ rtems_rtl_rap_file_load (rtems_rtl_obj_t* obj, int fd)
return true;
+bool
+rtems_rtl_rap_file_unload (rtems_rtl_obj_t* obj)
+ (void) obj;
+ return true;
rtems_rtl_rap_file_sig (void)
diff --git a/cpukit/libdl/rtl-rap.h b/cpukit/libdl/rtl-rap.h
index f828b1f..eca6e9e 100644
--- a/cpukit/libdl/rtl-rap.h
+++ b/cpukit/libdl/rtl-rap.h
@@ -41,6 +41,13 @@ bool rtems_rtl_rap_file_check (rtems_rtl_obj_t* obj, int fd);
bool rtems_rtl_rap_file_load (rtems_rtl_obj_t* obj, int fd);
+ * The RAP format unload handler.
+bool rtems_rtl_rap_file_unload (rtems_rtl_obj_t* obj);
* The RAP format signature handler.
diff --git a/cpukit/libdl/rtl-unwind-dw2.c b/cpukit/libdl/rtl-unwind-dw2.c
new file mode 100644
index 0000000..d9237c5
--- /dev/null
+++ b/cpukit/libdl/rtl-unwind-dw2.c
@@ -0,0 +1,71 @@
+ * COPYRIGHT (c) 2012-2016 Chris Johns <chrisj at rtems.org>
+ * @file
+ * @ingroup rtems_rtld
+ * @brief RTEMS Run-Time Link Editor
+ * This is the RTL implementation.
+#if HAVE_CONFIG_H
+#include "config.h"
+#endif
+#include <string.h>
+#include <stdio.h>
+#include <rtems/rtl/rtl.h>
+#include "rtl-elf.h"
+#include "rtl-error.h"
+ * These interfaces are not exported outside the GCC source.
+void __register_frame (void *begin);
+void __deregister_frame (void *begin);
+bool
+rtems_rtl_elf_unwind_dw2_parse (const rtems_rtl_obj_t* obj,
+ const char* name,
+ uint32_t flags)
+ return
+ ((flags & RTEMS_RTL_OBJ_SECT_CONST) != 0) &&
+ ((strcmp(name, ".eh_frame") == 0) ||
+ (strncmp(name, ".gcc_except_table.", sizeof (".gcc_except_table.") - 1) == 0));
+bool
+rtems_rtl_elf_unwind_dw2_register (const rtems_rtl_obj_t* obj)
+ rtems_rtl_obj_sect_t* sect = rtems_rtl_obj_find_section (obj, ".eh_frame");
+ if (sect != NULL && sect->size > 0 && sect->base != NULL)
+ __register_frame (sect->base);
+ return true;
+bool rtems_rtl_elf_unwind_dw2_deregister (const rtems_rtl_obj_t* obj)
+ __deregister_frame (sect->base);
+ return true;
diff --git a/cpukit/libdl/rtl-unwind-dw2.h b/cpukit/libdl/rtl-unwind-dw2.h
index 0000000..55b9797
--- /dev/null
+++ b/cpukit/libdl/rtl-unwind-dw2.h
@@ -0,0 +1,83 @@
+ * COPYRIGHT (c) 2016 Chris Johns <chrisj at rtems.org>
+ * @file
+ * @brief RTEMS Run-Time Linker Unwind DWARF Support.
+#if !defined (_RTEMS_RTL_UNWIND_DW2_H_)
+#define _RTEMS_RTL_UNWIND_DW2_H_
+#ifdef __cplusplus
+extern "C" {
+#endif /* __cplusplus */
+#if __SIZEOF_LONG__ >= __SIZEOF_POINTER__
+ typedef long rtems_rtl_elf_unwind_dw2_sleb128;
+ typedef unsigned long rtems_rtl_elf_unwind_dw2_uleb128;
+#elif __SIZEOF_LONG_LONG__ >= __SIZEOF_POINTER__
+ typedef long long rtems_rtl_elf_unwind_dw2_sleb128;
+ typedef unsigned long long rtems_rtl_elf_unwind_dw2_uleb128;
+#else
+ #error No DW2 type available.
+#endif
+ * Architecture specific handler to check if a section contains exception
+ * handler data..
+ * @param name The section's name.
+ * @param uint32 flags The object file's flags.
+ * @retval true The section contains unwind information.
+ * @retval false The section does not contain unwind information.
+bool rtems_rtl_elf_unwind_dw2_parse (const rtems_rtl_obj_t* obj,
+ const char* name,
+ uint32_t flags);
+ * Architecture specific handler to add an object file's unwind information to
+ * the base image.
+ * @retval true The unwind information has been registered.
+ * @retval false The unwind information could not be registered.
+bool rtems_rtl_elf_unwind_dw2_register (const rtems_rtl_obj_t* obj);
+ * Architecture specific handler to remove an object file's unwind information
+ * from the base image.
+ * @retval true The unwind information has been deregistered.
+ * @retval false The unwind information could not be deregistered.
+bool rtems_rtl_elf_unwind_dw2_deregister (const rtems_rtl_obj_t* obj);
+ * Read signed and unsigned LEB128 values.
+const uint8_t* rtems_rtl_elf_unwind_dw2_read_uleb128 (const uint8_t* data,
+ rtems_rtl_elf_unwind_dw2_uleb128* val);
+const uint8_t* rtems_rtl_elf_unwind_dw2_read_sleb128 (const uint8_t* data,
+ rtems_rtl_elf_unwind_dw2_sleb128* val);
+bool rtems_rtl_elf_unwind_dw2_relocate (const Elf_Addr* where, Elf_Word value, Elf_Word mask);
+#ifdef __cplusplus
+#endif
diff --git a/cpukit/libdl/rtl-unwind.h b/cpukit/libdl/rtl-unwind.h
index 0000000..f88787e
--- /dev/null
+++ b/cpukit/libdl/rtl-unwind.h
@@ -0,0 +1,63 @@
+ * @file
+ * @brief RTEMS Run-Time Linker Unwind Support.
+#if !defined (_RTEMS_RTL_UNWIND_H_)
+#define _RTEMS_RTL_UNWIND_H_
+#ifdef __cplusplus
+extern "C" {
+ * handler data..
+bool rtems_rtl_elf_unwind_parse (const rtems_rtl_obj_t* obj,
+ const char* name,
+ uint32_t flags);
+ * the base image.
+bool rtems_rtl_elf_unwind_register (rtems_rtl_obj_t* obj);
+bool rtems_rtl_elf_unwind_deregister (rtems_rtl_obj_t* obj);
+#ifdef __cplusplus
+#endif
diff --git a/cpukit/libdl/rtl.c b/cpukit/libdl/rtl.c
index abfcf25..5052251 100644
--- a/cpukit/libdl/rtl.c
+++ b/cpukit/libdl/rtl.c
@@ -62,6 +62,7 @@
* Static RTL data is returned to the user when the linker is locked.
static rtems_rtl_data_t* rtl;
+static bool rtl_data_init;
* Define a default base global symbol loader function that is weak
@@ -95,11 +96,25 @@ rtems_rtl_data_init (void)
rtems_id lock;
+ * We cannot set an error in this code because there is no RTL data to
+ * hold it.
+ if (rtl_data_init)
+ rtems_libio_unlock ();
+ return false;
+ rtl_data_init = true;
* Always in the heap.
rtl = malloc (sizeof (rtems_rtl_data_t));
if (!rtl)
errno = ENOMEM;
return false;
@@ -120,6 +135,7 @@ rtems_rtl_data_init (void)
if (sc != RTEMS_SUCCESSFUL)
free (rtl);
return false;
@@ -128,6 +144,7 @@ rtems_rtl_data_init (void)
rtems_semaphore_delete (lock);
free (rtl);
return false;
@@ -143,6 +160,7 @@ rtems_rtl_data_init (void)
free (rtl);
return false;
@@ -152,6 +170,7 @@ rtems_rtl_data_init (void)
rtems_rtl_symbol_table_close (&rtl->globals);
free (rtl);
return false;
@@ -162,6 +181,7 @@ rtems_rtl_data_init (void)
rtems_rtl_unresolved_table_close (&rtl->unresolved);
free (rtl);
return false;
@@ -173,6 +193,7 @@ rtems_rtl_data_init (void)
free (rtl);
return false;
@@ -185,6 +206,7 @@ rtems_rtl_data_init (void)
free (rtl);
return false;
@@ -198,6 +220,7 @@ rtems_rtl_data_init (void)
free (rtl);
return false;
@@ -212,6 +235,7 @@ rtems_rtl_data_init (void)
free (rtl);
return false;
@@ -288,7 +312,7 @@ rtems_rtl_obj_caches (rtems_rtl_obj_cache_t** symbols,
void
-rtems_rtl_obj_caches_flush ()
+rtems_rtl_obj_caches_flush (void)
if (rtl)
@@ -438,6 +462,7 @@ rtems_rtl_load_object (const char* name, int mode)
if (!rtems_rtl_obj_find_file (obj, name))
+ rtems_rtl_obj_caches_flush ();
return NULL;
@@ -446,9 +471,12 @@ rtems_rtl_load_object (const char* name, int mode)
if (!rtems_rtl_obj_load (obj))
return NULL;
rtems_rtl_unresolved_resolve ();
@@ -514,6 +542,9 @@ rtems_rtl_unload_object (rtems_rtl_obj_t* obj)
obj->flags &= ~RTEMS_RTL_OBJ_LOCKED;
ok = rtems_rtl_obj_unload (obj);
+ rtems_rtl_obj_free (obj);
return ok;
diff --git a/cpukit/libdl/rtl.h b/cpukit/libdl/rtl.h
index 234fc32..fe9a7df 100644
--- a/cpukit/libdl/rtl.h
+++ b/cpukit/libdl/rtl.h
@@ -112,7 +112,7 @@ struct rtems_rtl_data_s
- * Get the RTL data with out locking. This call assmes the RTL is locked.
+ * Get the RTL data with out locking. This call assumes the RTL is locked.
* @return rtems_rtl_data_t* The RTL data after being locked.
* @retval NULL The RTL data is not initialised.
diff --git a/testsuites/libtests/dl01/init.c b/testsuites/libtests/dl01/init.c
index 9fbdaa5..e9c7a1a 100644
--- a/testsuites/libtests/dl01/init.c
+++ b/testsuites/libtests/dl01/init.c
@@ -73,6 +73,8 @@ static void Init(rtems_task_argument arg)
#define CONFIGURE_EXTRA_TASK_STACKS (8 * 1024)
+#define CONFIGURE_MAXIMUM_SEMAPHORES 1
#define CONFIGURE_INITIAL_EXTENSIONS RTEMS_TEST_INITIAL_EXTENSION
#define CONFIGURE_RTEMS_INIT_TASKS_TABLE
@@ -80,4 +82,3 @@ static void Init(rtems_task_argument arg)
#include <rtems/confdefs.h>
diff --git a/testsuites/libtests/dl02/init.c b/testsuites/libtests/dl02/init.c
index f761b46..bf2d1a9 100644
--- a/testsuites/libtests/dl02/init.c
+++ b/testsuites/libtests/dl02/init.c
diff --git a/testsuites/libtests/dl03/init.c b/testsuites/libtests/dl03/init.c
index 68f8150..ae82722 100644
--- a/testsuites/libtests/dl03/init.c
+++ b/testsuites/libtests/dl03/init.c
@@ -55,6 +55,8 @@ static void Init(rtems_task_argument arg)
diff --git a/testsuites/libtests/dl04/init.c b/testsuites/libtests/dl04/init.c
index 566752b..6e48864 100644
--- a/testsuites/libtests/dl04/init.c
+++ b/testsuites/libtests/dl04/init.c
diff --git a/testsuites/libtests/dl05/dl-cpp.cpp b/testsuites/libtests/dl05/dl-cpp.cpp
index fcb9e0a..0e20057 100644
--- a/testsuites/libtests/dl05/dl-cpp.cpp
+++ b/testsuites/libtests/dl05/dl-cpp.cpp
@@ -4,11 +4,27 @@
#include <cstdio>
#include <stdexcept>
#include "dl-load.h"
-void exception_base(bool istrue)
+void exception_base(bool throw_runtime)
- printf("exception_base called\n");
- if (istrue)
+ printf("%s: begin\n", __func__);
+ try
- throw std::runtime_error("dummy call to link in symbols");
+ if (throw_runtime)
+ throw std::runtime_error("eb: throw std::runtime_error");
+ else
+ throw dl_test_throw_me("eb: throw me");
+ catch (std::exception const& e)
+ printf("%s: caught: %s\n", __func__, e.what());
+ catch (dl_test_throw_me const& e)
+ catch (...)
+ printf("%s: caught: unknown\n", __func__);
+ printf("%s: end\n", __func__);
diff --git a/testsuites/libtests/dl05/dl-load.c b/testsuites/libtests/dl05/dl-load.c
index f94317d..c7d5698 100644
--- a/testsuites/libtests/dl05/dl-load.c
+++ b/testsuites/libtests/dl05/dl-load.c
@@ -24,22 +24,38 @@ int dl_load_test(void)
void* handle;
const char* err;
- void (*func)(void);
+ void (*func)(bool );
+#if __i386__
+ * std::runtime_error destructor locks up in atomics.
+ bool throw_runtime = false;
+#else
+ bool throw_runtime = true;
+#endif
rtems_rtl_trace_set_mask(RTEMS_RTL_TRACE_ALL);
handle = dlopen("/dl-o5.o", RTLD_GLOBAL | RTLD_NOW);
- err = dlerror();
- if (err != NULL)
- printf("dlopen: %s\n", err);
+ if (handle == NULL)
+ err = dlerror();
+ if (err != NULL)
+ printf("dlopen: %s\n", err);
rtems_test_assert(handle != NULL);
func = dlsym(handle, "exception_dl");
- err = dlerror ();
- if (err)
- printf ("dlsym: %s\n", err);
+ if (func == NULL) {
+ err = dlerror ();
+ if (err)
+ printf ("dlsym: %s\n", err);
rtems_test_assert(func != NULL);
- exception_base(false);
- func();
+ exception_base(throw_runtime);
+ func(throw_runtime);
rtems_test_assert(dlclose(handle) == 0);
diff --git a/testsuites/libtests/dl05/dl-load.h b/testsuites/libtests/dl05/dl-load.h
index 98f4154..7a9e138 100644
--- a/testsuites/libtests/dl05/dl-load.h
+++ b/testsuites/libtests/dl05/dl-load.h
@@ -13,12 +13,38 @@
extern "C" {
#endif
-void exception_base(bool istrue);
-void exception_dl(void);
+void exception_base(bool throw_runtime);
+void exception_dl(bool throw_runtime);
int dl_load_test(void);
#ifdef __cplusplus
+ class dl_test_throw_me
+ public:
+ dl_test_throw_me(const char* message) :
+ message (message) {
+ dl_test_throw_me(const dl_test_throw_me& orig) :
+ message (orig.message) {
+ dl_test_throw_me() :
+ message (0) {
+ ~dl_test_throw_me() {
+ const char* what() const {
+ return message;
+ private:
+ const char* message;
+#endif
+#ifdef __cplusplus
#endif
diff --git a/testsuites/libtests/dl05/dl-o5.cpp b/testsuites/libtests/dl05/dl-o5.cpp
index 6e8476d..5918e8f 100644
--- a/testsuites/libtests/dl05/dl-o5.cpp
+++ b/testsuites/libtests/dl05/dl-o5.cpp
@@ -1,12 +1,20 @@
#include <cstdio>
#include "dl-load.h" /* make the symbol a C linkage */
+ printf("exception_dl: begin\n");
try
- printf("exception_dl: throwing\n");
- throw std::runtime_error("exception_dl throw");
+ printf("exception_dl: throwing...\n");
+ throw std::runtime_error("throw std::runtime_error object");
+ else
+ throw dl_test_throw_me("throw dl_test_throw_me object");
@@ -16,4 +24,5 @@ void exception_dl(void)
+ printf("exception_dl: end\n");
diff --git a/testsuites/libtests/dl05/init.c b/testsuites/libtests/dl05/init.c
index f6e0c20..9c7f006 100644
--- a/testsuites/libtests/dl05/init.c
+++ b/testsuites/libtests/dl05/init.c
@@ -69,9 +69,13 @@ static void Init(rtems_task_argument arg)
#define CONFIGURE_MAXIMUM_TASKS 1
-#define CONFIGURE_MINIMUM_TASK_STACK_SIZE (8U * 1024U)
+#define CONFIGURE_MINIMUM_TASK_STACK_SIZE (32U * 1024U)
-#define CONFIGURE_EXTRA_TASK_STACKS (8 * 1024)
+#define CONFIGURE_EXTRA_TASK_STACKS (64 * 1024)
+#define CONFIGURE_MAXIMUM_POSIX_KEYS 2
2.9.0
