Help with RTEMS
Tanu Hari Dixit tokencolour at gmail.com
Tue Dec 13 15:47:57 UTC 2016
Hey Punit,
Thank you for your reply and pointing to the open projects.
The problem is I don't have "testsuites" folder in
/development/rtems/src/b-sis/sparc-rtems4.12/c. I'm still unable to
find the executables. I can't seem to figure out where the "samples"
folder is located. As I had mentioned in my previous mail, there are
samples in the rtems source directory
(/development/rtems/src/rtems/testsuites/samples/ticker) but I don't
know as to how to specify to test those samples with the configure
command.
Thank you,
Tanu Hari Dixit.
On Tue, Dec 13, 2016 at 7:32 PM, punit vara <punitvara at gmail.com> wrote:
> Hi Tanu,
> https://github.com/RTEMS/rtems
> You can follow any of following open ideas to get contribute :
> https://devel.rtems.org/wiki/Developer/OpenProjects
> On Tue, Dec 13, 2016 at 11:40 AM, Tanu Hari Dixit <tokencolour at gmail.com> wrote:
> > Hey Punit,
> > I am Tanu, here. I am an undergraduate student from IIT BHU studying
> > electronics engineering. I wanted to contribute to RTEMS, and in a useful
> > way so that the devs consider me for GSoC '17. I wanted to know how did you
> > fill the gaps when you started with RTOS. I've not even done my bachelor
> > yet, am I too early to start with any real time implementation of an OS? I'm
> There is always something we can contribute to open source project.
> > facing trouble while finding exe files in the prefix and have mailed on the
> > users list. (I did that yesterday). Can you please help me with it?
> > I have included the mail I sent on the users list:
> Its better you ask question on dev list rather than user list.
> > Hello Devs!
> > I followed the instructions given in the Getting started guide
> > (https://devel.rtems.org/wiki/GSoC/GettingStarted) and
> > (https://devel.rtems.org/wiki/TBR/UserManual/Quick_Start). The latter
> > says that when I bootstrap and then make and make install, I should
> > find sample executables in a path similar to:
> > "/home2/work/joel/rtems-4.11-work/build/build-sparc-sis-rtems/
> > sparc-rtems4.11/c/sis/testsuites/samples/ticker/ticker.exe"
> That's Joel's directory structure. But I would say you must have
> created directory named b-sis right ?
> You can see .exe file in path something like
> b-sis/sparc-rtems4.12/c/../testsuites/samples/hello
> > I am unable to find exe files in my working directory (not even in the
> > prefix).
> > My tree is the following:
> > |-- sparc-rtems4.12
> > |   `-- c
> > |-- testsuites
> > |   `-- tools
> > |       `-- generic
> > `-- tools
> >     |-- build
> >     `-- cpu
> >         `-- generic
> > and sparc-rtems4.12/c/ has 3 files config.log,  config.status,  Makefile
> > and the directory testsuites(shown in the above tree) has no samples.
> > There are samples in the rtems source directory, though
> > (/development/rtems/src/rtems/testsuites/samples/ticker) but I'm
> > clueless as to how to specify to test those samples. The configure
> > command :
> > /rtems/configure --target=sparc-rtems4.12 --enable-rtemsbsp=sis \
> >   --enable-tests=samples --prefix=${HOME}/install_path
> > specifies to enable tests on "samples" which I'm unable to find. How
> > do I successfully run a test? Is there a mistake I did while building
> > RTEMS or the RSB? Kindly help me figure this out.
> > Thank you so much!
> > Tanu Hari Dixit,
> > Senior Undergraduate,
> > Department of Electronics Engineering,
> > IIT BHU.
