Help with RTEMS
Tanu Hari Dixit tokencolour at gmail.com
Tue Dec 13 18:12:12 UTC 2016
I'm sorry I posted the wrong output: the target should be
sparc-rtems4.12 and not sparc-rtems4.11
Here is the right one:
thd at thd-Inspiron-5537:~/development/rtems/src/b-sis$
../rtems/configure --target=sparc-rtems4.12 --enable-rtemsbsp=sis
--enable-tests=samples --prefix=${HOME}/install_path
checking for gmake... no
checking for make... make
checking for RTEMS Version... 4.11.99.0
checking build system type... x86_64-pc-linux-gnu
checking host system type... x86_64-pc-linux-gnu
checking target system type... sparc-unknown-rtems4.12
checking for a BSD-compatible install... /usr/bin/install -c
checking whether build environment is sane... yes
checking for a thread-safe mkdir -p... /bin/mkdir -p
checking for gawk... gawk
checking whether make sets $(MAKE)... yes
checking whether to enable maintainer-specific portions of Makefiles... no
checking that generated files are newer than configure... done
configure: creating ./config.status
configure: configuring in ./tools/build
configure: running /bin/bash '../../../rtems/tools/build/configure'
'--prefix=/home/thd/install_path' '--host=x86_64-pc-linux-gnu'
'--build=x86_64-pc-linux-gnu'  '--enable-rtemsbsp=sis'
'--enable-tests=samples' '--target=sparc-rtems4.12'
'--cache-file=/dev/null' '--srcdir=../../../rtems/tools/build'
checking for x86_64-pc-linux-gnu-gcc... no
checking for gcc... gcc
checking whether the C compiler works... yes
checking for C compiler default output file name... a.out
checking for suffix of executables...
checking whether we are cross compiling... no
checking for suffix of object files... o
checking whether we are using the GNU C compiler... yes
checking whether gcc accepts -g... yes
checking for gcc option to accept ISO C89... none needed
checking for style of include used by make... GNU
checking dependency style of gcc... gcc3
checking how to run the C preprocessor... gcc -E
checking for grep that handles long lines and -e... /bin/grep
checking for egrep... /bin/grep -E
checking for ANSI C header files... yes
checking for sys/types.h... yes
checking for sys/stat.h... yes
checking for stdlib.h... yes
checking for string.h... yes
checking for memory.h... yes
checking for strings.h... yes
checking for inttypes.h... yes
checking for stdint.h... yes
checking for unistd.h... yes
checking getopt.h usability... yes
checking getopt.h presence... yes
checking for getopt.h... yes
checking libgen.h usability... yes
checking libgen.h presence... yes
checking for libgen.h... yes
checking for strerror... yes
checking for strtol... yes
checking for basename... yes
checking for strnlen... yes
checking for bash... /bin/bash
config.status: creating Makefile
config.status: creating install-if-change
config.status: creating config.h
config.status: config.h is unchanged
config.status: executing depfiles commands
configure: configuring in ./tools/cpu
configure: running /bin/bash '../../../rtems/tools/cpu/configure'
'--cache-file=/dev/null' '--srcdir=../../../rtems/tools/cpu'
checking rtems target cpu... sparc
=== configuring in generic
(/home/thd/development/rtems/src/b-sis/tools/cpu/generic)
../../../../rtems/tools/cpu/generic/configure
--disable-option-checking '--prefix=/home/thd/install_path'
'--host=x86_64-pc-linux-gnu' '--build=x86_64-pc-linux-gnu'
'--enable-rtemsbsp=sis' '--enable-tests=samples'
'--target=sparc-rtems4.12' 'build_alias=x86_64-pc-linux-gnu'
'host_alias=x86_64-pc-linux-gnu' 'target_alias=sparc-rtems4.12'
--cache-file=/dev/null --srcdir=../../../../rtems/tools/cpu/generic
config.status: creating size_rtems
configure: configuring in ./testsuites/tools
'../../../rtems/testsuites/tools/configure'
'--cache-file=/dev/null' '--srcdir=../../../rtems/testsuites/tools'
(/home/thd/development/rtems/src/b-sis/testsuites/tools/generic)
../../../../rtems/testsuites/tools/generic/configure
--srcdir=../../../../rtems/testsuites/tools/generic
config.status: creating difftest
config.status: creating sorttimes
configure: configuring in sparc-rtems4.12/c
configure: running /bin/bash '../../../rtems/c/configure'
'--prefix=/home/thd/install_path' '--host=sparc-rtems4.12'
'--build=x86_64-pc-linux-gnu' '--target=sparc-rtems4.12'
'--with-target-subdir=sparc-rtems4.12'
'--exec-prefix=/home/thd/install_path/sparc-rtems4.12'
'--includedir=/home/thd/install_path/sparc-rtems4.12/include'
'--cache-file=/dev/null' '--srcdir=../../../rtems/c'
checking host system type... sparc-unknown-rtems4.12
checking for sparc-rtems4.12-strip... sparc-rtems4.12-strip
On Tue, Dec 13, 2016 at 11:36 PM, Tanu Hari Dixit <tokencolour at gmail.com> wrote:
> Hey Jennifer,
> Here is the output of the configure command.
> ../rtems/configure --target=sparc-rtems4.11 --enable-rtemsbsp=sis
> checking target system type... sparc-unknown-rtems4.11
> '--enable-tests=samples' '--target=sparc-rtems4.11'
> '--target=sparc-rtems4.11' 'build_alias=x86_64-pc-linux-gnu'
> 'host_alias=x86_64-pc-linux-gnu' 'target_alias=sparc-rtems4.11'
> configure: configuring in sparc-rtems4.11/c
> '--prefix=/home/thd/install_path' '--host=sparc-rtems4.11'
> '--build=x86_64-pc-linux-gnu' '--target=sparc-rtems4.11'
> '--with-target-subdir=sparc-rtems4.11'
> '--exec-prefix=/home/thd/install_path/sparc-rtems4.11'
> '--includedir=/home/thd/install_path/sparc-rtems4.11/include'
> checking host system type... sparc-unknown-rtems4.11
> checking for sparc-rtems4.11-strip... no
> checking for strip... strip
> configure: WARNING: using cross tools not prefixed with host triplet
> On Tue, Dec 13, 2016 at 10:17 PM, Jennifer Averett
> <Jennifer.Averett at oarcorp.com> wrote:
>> Sorry, if  I'm remembering correctly the exe's will be in the
>> build tree which is the directory you were at when you ran the
>> configure command.  Can you capture the configure output
>> and post it?
>> Jennifer Averett
>> On-Line Applications Research
>> ________________________________________
>> From: Tanu Hari Dixit [tokencolour at gmail.com]
>> Sent: Tuesday, December 13, 2016 10:18 AM
>> To: Jennifer Averett
>> Cc: devel-request at rtems.org; users at rtems.org
>> Subject: Re: Help with RTEMS
>> Hey Jennifer,
>> Thank you for your reply. I did look into /install_path.
>> Here is what the folder install_path holds, after configuring.
>> thd at thd-Inspiron-5537:~/install_path$ tree  ./
>> |-- bin
>> |   |-- cklength
>> |   |-- eolstrip
>> |   |-- install-if-change
>> |   |-- packhex
>> |   |-- rtems-bin2c
>> |   |-- sparc-rtems4.12-difftest
>> |   |-- sparc-rtems4.12-sorttimes
>> |   `-- unhex
>> |-- make
>> |   |-- custom
>> |   |   `-- default.cfg
>> |   |-- leaf.cfg
>> |   `-- main.cfg
>> `-- share
>>     `-- rtems4.12
>>         `-- make
>>             `-- Templates
>>                 |-- Makefile.dir
>>                 |-- Makefile.leaf
>>                 `-- Makefile.lib
>> 7 directories, 14 files
>> It does not have the sample executables.
>> Tanu Hari Dixit.
>> On Tue, Dec 13, 2016 at 9:20 PM, Jennifer Averett
>>> This may not be the issue but if you used  exactly "--prefix=${HOME}/install_path" in the configure
>>> did you look in the directory "${HOME}/install_path"?
>>> Jennifer Averett
>>> From: devel [devel-bounces at rtems.org] On Behalf Of Tanu Hari Dixit [tokencolour at gmail.com]
>>> Sent: Tuesday, December 13, 2016 9:47 AM
>>> To: punit vara
>>> Cc: users at rtems.org; devel at rtems.org
>>> Hey Punit,
>>> Thank you for your reply and pointing to the open projects.
>>> The problem is I don't have "testsuites" folder in
>>> /development/rtems/src/b-sis/sparc-rtems4.12/c. I'm still unable to
>>> find the executables. I can't seem to figure out where the "samples"
>>> folder is located. As I had mentioned in my previous mail, there are
>>> samples in the rtems source directory
>>> (/development/rtems/src/rtems/testsuites/samples/ticker) but I don't
>>> know as to how to specify to test those samples with the configure
>>> command.
>>> Thank you,
>>> Tanu Hari Dixit.
>>> On Tue, Dec 13, 2016 at 7:32 PM, punit vara <punitvara at gmail.com> wrote:
>>>> Hi Tanu,
>>>> https://github.com/RTEMS/rtems
>>>> You can follow any of following open ideas to get contribute :
>>>> https://devel.rtems.org/wiki/Developer/OpenProjects
>>>> On Tue, Dec 13, 2016 at 11:40 AM, Tanu Hari Dixit <tokencolour at gmail.com> wrote:
>>>> > Hey Punit,
>>>> > I am Tanu, here. I am an undergraduate student from IIT BHU studying
>>>> > electronics engineering. I wanted to contribute to RTEMS, and in a useful
>>>> > way so that the devs consider me for GSoC '17. I wanted to know how did you
>>>> > fill the gaps when you started with RTOS. I've not even done my bachelor
>>>> > yet, am I too early to start with any real time implementation of an OS? I'm
>>>> There is always something we can contribute to open source project.
>>>> > facing trouble while finding exe files in the prefix and have mailed on the
>>>> > users list. (I did that yesterday). Can you please help me with it?
>>>> > I have included the mail I sent on the users list:
>>>> Its better you ask question on dev list rather than user list.
>>>> > Hello Devs!
>>>> > I followed the instructions given in the Getting started guide
>>>> > (https://devel.rtems.org/wiki/GSoC/GettingStarted) and
>>>> > (https://devel.rtems.org/wiki/TBR/UserManual/Quick_Start). The latter
>>>> > says that when I bootstrap and then make and make install, I should
>>>> > find sample executables in a path similar to:
>>>> > "/home2/work/joel/rtems-4.11-work/build/build-sparc-sis-rtems/
>>>> > sparc-rtems4.11/c/sis/testsuites/samples/ticker/ticker.exe"
>>>> That's Joel's directory structure. But I would say you must have
>>>> created directory named b-sis right ?
>>>> You can see .exe file in path something like
>>>> b-sis/sparc-rtems4.12/c/../testsuites/samples/hello
>>>> > I am unable to find exe files in my working directory (not even in the
>>>> > prefix).
>>>> > My tree is the following:
>>>> > |-- sparc-rtems4.12
>>>> > |   `-- c
>>>> > |-- testsuites
>>>> > |   `-- tools
>>>> > |       `-- generic
>>>> > `-- tools
>>>> >     |-- build
>>>> >     `-- cpu
>>>> >         `-- generic
>>>> > and sparc-rtems4.12/c/ has 3 files config.log,  config.status,  Makefile
>>>> > and the directory testsuites(shown in the above tree) has no samples.
>>>> > There are samples in the rtems source directory, though
>>>> > (/development/rtems/src/rtems/testsuites/samples/ticker) but I'm
>>>> > clueless as to how to specify to test those samples. The configure
>>>> > command :
>>>> > /rtems/configure --target=sparc-rtems4.12 --enable-rtemsbsp=sis \
>>>> > specifies to enable tests on "samples" which I'm unable to find. How
>>>> > do I successfully run a test? Is there a mistake I did while building
>>>> > RTEMS or the RSB? Kindly help me figure this out.
>>>> > Thank you so much!
>>>> > Tanu Hari Dixit,
>>>> > Senior Undergraduate,
>>>> > Department of Electronics Engineering,
>>>> > IIT BHU.
>>> devel mailing list
>>> devel at rtems.org
>>> http://lists.rtems.org/mailman/listinfo/devel
