Help with RTEMS
Tue Dec 13 22:44:47 UTC 2016
On 14/12/2016 09:32, Martin Werner wrote:
> This seems to be because the sparc/sis BSP is removed in the latest
> master (as of a month ago: de7b174).
Yes the sis BSP has been removed from master (4.12).
> For sparc you need to pick one of the other available BSPs, currently
> erc32 leon2 leon3 or ngmp.
I am testing with erc32 and after a build with --enable-tests I use the
following:
$ /opt/work/rtems/4.12/bin/rtems-test --rtems-bsp=erc32 \
     --report-mode=all `find . -name dl05.exe`
If I wish to run a number of tests I can:
    `find sparc-rtems4.12/c/erc32/testsuites/libtests -name \dl*.exe`
RTEMS Testing - Tester, 4.12.not_released
  Command Line: /opt/work/rtems/4.12/bin/rtems-test --rtems-bsp=erc32
sparc-rtems4.12/c/erc32/testsuites/libtests/dl02/dl02.exe
sparc-rtems4.12/c/erc32/testsuites/libtests/dl05/dl05.exe
sparc-rtems4.12/c/erc32/testsuites/libtests/dl01/dl01.exe
sparc-rtems4.12/c/erc32/testsuites/libtests/dl04/dl04.exe
sparc-rtems4.12/c/erc32/testsuites/libtests/dl03/dl03.exe
  Python: 2.7.12 (default, Sep 27 2016, 01:49:05) [GCC 4.2.1 Compatible
FreeBSD Clang 3.4.1 (tags/RELEASE_34/dot1-final 208032)]
[1/5] p:0 f:0 t:0 i:0 | sparc/erc32: dl01.exe
[2/5] p:0 f:0 t:0 i:0 | sparc/erc32: dl02.exe
[4/5] p:0 f:0 t:0 i:0 | sparc/erc32: dl04.exe
[3/5] p:0 f:0 t:0 i:0 | sparc/erc32: dl03.exe
[5/5] p:0 f:0 t:0 i:0 | sparc/erc32: dl05.exe
Passed:   5
Failed:   0
Timeouts: 0
Invalid:  0
Total:    5
Average test time: 0:00:00.521724
Testing time     : 0:00:02.608620
Note, all tests have passed.
This approach lets you use the same mechanism for all bsps, for example
if you are using the PowerPC Simulator (psim) you can run:
$ /opt/work/rtems/4.12/bin/rtems-test --rtems-bsp=psim \
> The examples in the getting started guide should probably be updated.
The doco is being slowly moved to the User Manual.
