[PATCH 1/7] Adding pipe support
Kirspel, Kevin Kevin-Kirspel at idexx.com
Thu Dec 15 13:28:20 UTC 2016
Let me take a look when running it with QEMU.  I ran it against my custom LPC3250 BSP on real hardware.  Perhaps there is something else that needs to be done to support pipe than just the patches I submitted.
Kevin Kirspel
Electrical Engineer - Sr. Staff
Idexx Roswell
235 Hembree Park Drive
Roswell GA 30076
Tel: (770)-510-4444 ext. 81642
Direct: (770)-688-1642
Fax: (770)-510-4445
-----Original Message-----
From: Sebastian Huber [mailto:sebastian.huber at embedded-brains.de]
Sent: Thursday, December 15, 2016 3:52 AM
To: Kirspel, Kevin <Kevin-Kirspel at idexx.com>; devel at rtems.org
Subject: Re: [PATCH 1/7] Adding pipe support
Hello Kevin,
looks good so far (except one white space change, which I will fix for you, white space changes may lead to merge conflicts during a FreeBSD update). However, the "LIBBSD SELECT AND POLL AND KQUEUE AND PIPE 1 TEST" fails:
qemu-system-arm -no-reboot -serial null -serial mon:stdio -net none -nographic -M xilinx-zynq-a9 -m 256M -kernel build/arm-rtems4.12-xilinx_zynq_a9_qemu/selectpollkqueue01.exe
Warning: nic cadence_gem.0 has no peer
Warning: nic cadence_gem.1 has no peer
*** LIBBSD SELECT AND POLL AND KQUEUE AND PIPE 1 TEST ***
nexus0: <RTEMS Nexus device>
test select timeout
test select connect
worker: create new connect socket
worker: connect
test select read
worker: write
test select write
worker: read
test select close
worker: close
test poll timeout
test poll connect
worker: connect
test poll read
worker: write
test poll write
worker: read
test poll close
worker: close
test kqueue timer
test kqueue timer
test kqueue connect
worker: connect
test kqueue read
worker: write
test kqueue write
worker: read
test kqueue close
worker: shutdown
test kqueue user
test pipe timeout
assertion "rv == 0" failed: file
"../../testsuite/selectpollkqueue01/test_main.c", line 1057, function:
test_pipe_timeout
Phone   : +49 89 189 47 41-16
Fax     : +49 89 189 47 41-09
