Regarding modified hello world example
Tanu Hari Dixit tokencolour at gmail.com
Sun Dec 18 04:40:56 UTC 2016
I forgot to ask another important question-
Which of the above projects would require me to have actual hardware?
Thank you,
Tanu Hari Dixit.
On Sun, Dec 18, 2016 at 5:52 AM, Tanu Hari Dixit <tokencolour at gmail.com> wrote:
> Hello Joel,
> Thank you for your reply.
>> Congratulations on getting it working. Please post your diff to hello world
>> and a screenshot.
> I'll post the diff and the screenshot ASAP.
>> What host OS are you using?
> I'm working on Linux Ubuntu 14.04 LTS.
>> What type of project are you interested in doing? Depending on the project,
>> you may have to move to another BSP which has a simulator with same
>> networking or graphics support. Or you may need to be on actual hardware.
>> We can guide you through BSP selection after we know what you want to do.
> I went through https://devel.rtems.org/wiki/Developer/OpenProjects and
> I am interested in contributing to the following projects in
> decreasing order of preference :
> # Implementing MMU low-level support code for more BSPs.
>     *Work Package flow as given at
> https://devel.rtems.org/wiki/Projects/MMU_Support#TheWorkpackageFlow
>     *Mid Level APIs as given at
> https://devel.rtems.org/wiki/Projects/MMU_Support#MidLevelAPIs
>     *Are these already implemented? Can you please provide me pointers
> on the current status?
> # Testing by Fault injection
>     * I found http://rtems-fi.blogspot.in/ and I browsed through
> https://github.com/salpha2004/slingshot
>     * I guess these
> (https://devel.rtems.org/wiki/SOCIS/2016#FutureWorks) are the things
> left to be done.
> # RISC-V related work
>     *I did not find it listed on the Open Projects page. Is there some
> work already done on this front?
> # RTEMS Scikit
>     *The project page says it is uninitiated. Is this still true?
>     *Is this exactly about scientific applications that will run on
> RTEMS? What exactly has to be done?
> # Python GDB Support
>     *The page (https://devel.rtems.org/wiki/Projects/GDB_Python) says
> that this project is under heavy development.  Is this still true?
> Which of these projects will be best suitable for me? Could you please
> provide me with some beginner friendly tasks in relation to these
> projects? My plan is to get comfortable with RTEMS and perhaps its
> software architecture (whenever required) and contribute something to
> it. This will help me make a decent GSoC effort, when the time comes.
>> Disclaimer: No organizations have applied to GSOC and there is no guarantee
>> we will be accepted. :)
> I understand.
>> --joel
> Tanu Hari Dixit.
