[PATCH 04/10] Remove Discrete Driver chapter
Tue Dec 20 13:45:21 UTC 2016
There exists no standard Discrete Driver in the RTEMS code base.
Close #2851.
 bsp-howto/discrete.rst | 190 -------------------------------------------------
 bsp-howto/index.rst    |   1 -
 2 files changed, 191 deletions(-)
 delete mode 100644 bsp-howto/discrete.rst
diff --git a/bsp-howto/discrete.rst b/bsp-howto/discrete.rst
deleted file mode 100644
index 6607882..0000000
--- a/bsp-howto/discrete.rst
+++ /dev/null
@@ -1,190 +0,0 @@
-.. comment SPDX-License-Identifier: CC-BY-SA-4.0
-Discrete Driver
-The Discrete driver is responsible for providing an interface to Discrete
-Input/Outputs.  The capabilities provided by this class of device driver are:
-- Initialize a Discrete I/O Board
-- Open a Particular Discrete Bitfield
-- Close a Particular Discrete Bitfield
-- Read from a Particular Discrete Bitfield
-- Write to a Particular Discrete Bitfield
-- Reset DACs
-- Reinitialize DACS
-Most discrete I/O devices are found on I/O cards that support many bits of
-discrete I/O on a single card.  This driver model is centered on the notion of
-reading bitfields from the card.
-There are currently no discrete I/O device drivers included in the RTEMS source
-tree.  The information provided in this chapter is based on drivers developed
-for applications using RTEMS.  It is hoped that this driver model information
-can form the discrete I/O driver model that can be supported in future RTEMS
-distribution.
-Major and Minor Numbers
-The ``major`` number of a device driver is its index in the RTEMS Device
-Address Table.
-A ``minor`` number is associated with each device instance managed by a
-particular device driver.  An RTEMS minor number is an ``unsigned32`` entity.
-Convention calls for dividing the bits in the minor number down into categories
-that specify a particular bitfield.  This results in categories like the
-following:
-- ``board`` - indicates the board a particular bitfield is located on
-- ``word`` - indicates the particular word of discrete bits the bitfield is
-  located within
-- ``start`` - indicates the starting bit of the bitfield
-- ``width`` - indicates the width of the bitfield
-From the above, it should be clear that a single device driver can support
-multiple copies of the same board in a single system.  The minor number is used
-to distinguish the devices.
-By providing a way to easily access a particular bitfield from the device
-driver, the application is insulated with knowing how to mask fields in and out
-of a discrete I/O.
-Discrete I/O Driver Configuration
-There is not a standard discrete I/O driver configuration table but some fields
-are common across different drivers.  The discrete I/O driver configuration
-table is typically an array of structures with each structure containing the
-information for a particular board.  The following is a list of the type of
-information normally required to configure an discrete I/O board:
-``board_offset``
-    is the base address of a board.
-``relay_initial_values``
-    is an array of the values that should be written to each output word on the
-    board during initialization.  This allows the driver to start with the
-    board's output in a known state.
-Initialize a Discrete I/O Board
-At system initialization, the discrete I/O driver's initialization entry point
-will be invoked.  As part of initialization, the driver will perform whatever
-board initializatin is required and then set all outputs to their configured
-initial state.
-The discrete I/O driver may register a device name for bitfields of particular
-interest to the system.  Normally this will be restricted to the names of each
-word and, if the driver supports it, an "all words".
-Open a Particular Discrete Bitfield
-This is the driver open call.  Usually this call does nothing other than
-validate the minor number.
-With some drivers, it may be necessary to allocate memory when a particular
-device is opened.  If that is the case, then this is often the place to do this
-operation.
-Close a Particular Discrete Bitfield
-This is the driver close call.  Usually this call does nothing.
-device is opened.  If that is the case, then this is the place where that
-memory should be deallocated.
-Read from a Particular Discrete Bitfield
-This corresponds to the driver read call.  After validating the minor number
-and arguments, this call reads the indicated bitfield.  A discrete I/O devices
-may have to store the last value written to a discrete output.  If the bitfield
-is output only, saving the last written value gives the appearance that it can
-be read from also.  If the bitfield is input, then it is sampled.
-.. note::
-   Many discrete inputs have a tendency to bounce.  The application may have to
-   take account for bounces.
-The value returned is an ``unsigned32`` number representing the bitfield read.
-This value is stored in the ``argument_block`` passed in to the call.
-.. note::
-   Some discrete I/O drivers have a special minor number used to access all
-   discrete I/O bits on the board.  If this special minor is used, then the
-   area pointed to by ``argument_block`` must be the correct size.
-Write to a Particular Discrete Bitfield
-This corresponds to the driver write call.  After validating the minor number
-and arguments, this call writes the indicated device.  If the specified device
-is an ADC, then an error is usually returned.
-The value written is an ``unsigned32`` number representing the value to be
-written to the specified bitfield.  This value is stored in the
-``argument_block`` passed in to the call.
-.. note::
-Disable Discrete Outputs
-This is one of the IOCTL functions supported by the I/O control device driver
-entry point.  When this IOCTL function is invoked, the discrete outputs are
-disabled.
-.. note::
-   It may not be possible to disable/enable discrete output on all discrete I/O
-   boards.
-Enable Discrete Outputs
-enabled.
-.. note::
-    I/O boards.
-Reinitialize Outputs
-rewritten with the configured initial output values.
-Get Last Written Values
-entry point.  When this IOCTL function is invoked, the following information is
-returned to the caller:
-- last value written to the specified output word
-- timestamp of when the last write was performed
diff --git a/bsp-howto/index.rst b/bsp-howto/index.rst
index 31cc0fa..f99118d 100644
--- a/bsp-howto/index.rst
+++ b/bsp-howto/index.rst
@@ -57,7 +57,6 @@ to the Community Project hosted at http://www.rtems.org.
 	networking
 	shared_memory_support
 	frame_buffer
-	discrete
 	command
 *	:ref:`genindex`
1.8.4.5
