[PATCH 05/10] Remove Non-Volatile Memory Driver chapter
Tue Dec 20 13:45:22 UTC 2016
There exists no standard Non-Volatile Memory Driver in the RTEMS code
base.
Close #2851.
 bsp-howto/index.rst               |   1 -
 bsp-howto/non_volatile_memory.rst | 217 --------------------------------------
 2 files changed, 218 deletions(-)
 delete mode 100644 bsp-howto/non_volatile_memory.rst
diff --git a/bsp-howto/index.rst b/bsp-howto/index.rst
index f99118d..d826369 100644
--- a/bsp-howto/index.rst
+++ b/bsp-howto/index.rst
@@ -53,7 +53,6 @@ to the Community Project hosted at http://www.rtems.org.
 	real_time_clock
 	ata
 	ide_controller
-	non_volatile_memory
 	networking
 	shared_memory_support
 	frame_buffer
diff --git a/bsp-howto/non_volatile_memory.rst b/bsp-howto/non_volatile_memory.rst
deleted file mode 100644
index e23c162..0000000
--- a/bsp-howto/non_volatile_memory.rst
+++ /dev/null
@@ -1,217 +0,0 @@
-.. comment SPDX-License-Identifier: CC-BY-SA-4.0
-.. COMMENT: Written by Eric Norum
-.. COMMENT: COPYRIGHT (c) 1988-2002.
-.. COMMENT: On-Line Applications Research Corporation (OAR).
-.. COMMENT: All rights reserved.
-Non-Volatile Memory Driver
-The Non-Volatile driver is responsible for providing an interface to various
-types of non-volatile memory.  These types of memory include, but are not
-limited to, Flash, EEPROM, and battery backed RAM.  The capabilities provided
-by this class of device driver are:
-- Initialize the Non-Volatile Memory Driver
-- Optional Disable Read and Write Handlers
-- Open a Particular Memory Partition
-- Close a Particular Memory Partition
-- Read from a Particular Memory Partition
-- Write to a Particular Memory Partition
-- Erase the Non-Volatile Memory Area
-There is currently only one non-volatile device driver included in the RTEMS
-source tree.  The information provided in this chapter is based on drivers
-developed for applications using RTEMS.  It is hoped that this driver model
-information can form the basis for a standard non-volatile memory driver model
-that can be supported in future RTEMS distribution.
-Major and Minor Numbers
-The ``major`` number of a device driver is its index in the RTEMS Device
-Address Table.
-A ``minor`` number is associated with each device instance managed by a
-particular device driver.  An RTEMS minor number is an ``unsigned32`` entity.
-Convention calls dividing the bits in the minor number down into categories
-that specify an area of non-volatile memory and a partition with that area.
-This results in categories like the following:
-- ``area`` - indicates a block of non-volatile memory
-- ``partition`` - indicates a particular address range with an area
-From the above, it should be clear that a single device driver can support
-multiple types of non-volatile memory in a single system.  The minor number is
-used to distinguish the types of memory and blocks of memory used for different
-purposes.
-Non-Volatile Memory Driver Configuration
-There is not a standard non-volatile driver configuration table but some fields
-are common across different drivers.  The non-volatile memory driver
-configuration table is typically an array of structures with each structure
-containing the information for a particular area of non-volatile memory.  The
-following is a list of the type of information normally required to configure
-each area of non-volatile memory.
-``memory_type``
-    is the type of memory device in this area.  Choices are battery backed RAM,
-    EEPROM, Flash, or an optional user-supplied type.  If the user-supplied
-    type is configured, then the user is responsible for providing a set of
-    routines to program the memory.
-``memory``
-    is the base address of this memory area.
-``attributes``
-    is a pointer to a memory type specific attribute block.  Some of the fields
-    commonly contained in this memory type specific attribute structure area:
-    ``use_protection_algorithm``
-        is set to TRUE to indicate that the protection (i.e. locking) algorithm
-        should be used for this area of non-volatile memory.  A particular type
-        of non-volatile memory may not have a protection algorithm.
-    ``access``
-        is an enumerated type to indicate the organization of the memory
-        devices in this memory area.  The following is a list of the access
-        types supported by the current driver implementation:
-          - simple unsigned8
-          - simple unsigned16
-          - simple unsigned32
-          - simple unsigned64
-          - single unsigned8 at offset 0 in an unsigned16
-          - single unsigned8 at offset 1 in an unsigned16
-          - single unsigned8 at offset 0 in an unsigned32
-          - single unsigned8 at offset 1 in an unsigned32
-          - single unsigned8 at offset 2 in an unsigned32
-          - single unsigned8 at offset 3 in an unsigned32
-    ``depth``
-        is the depth of the progamming FIFO on this particular chip.  Some
-        chips, particularly EEPROMs, have the same programming algorithm but
-        vary in the depth of the amount of data that can be programmed in a
-        single block.
-``number_of_partitions``
-    is the number of logical partitions within this area.
-``Partitions``
-    is the address of the table that contains an entry to describe each
-    partition in this area.  Fields within each element of this table are
-    defined as follows:
-    ``offset``
-        is the offset of this partition from the base address of this area.
-    ``length``
-        is the length of this partition.
-By dividing an area of memory into multiple partitions, it is possible to
-easily divide the non-volatile memory for different purposes.
-Initialize the Non-Volatile Memory Driver
-At system initialization, the non-volatile memory driver's initialization entry
-point will be invoked.  As part of initialization, the driver will perform
-whatever initializatin is required on each non-volatile memory area.
-The discrete I/O driver may register device names for memory partitions of
-particular interest to the system.  Normally this will be restricted to the
-device "/dev/nv_memory" to indicate the entire device driver.
-Disable Read and Write Handlers
-Depending on the target's non-volatile memory configuration, it may be possible
-to write to a status register and make the memory area completely inaccessible.
-This is target dependent and beyond the standard capabilities of any memory
-type.  The user has the optional capability to provide handlers to disable and
-enable access to a partiticular memory area.
-Open a Particular Memory Partition
-This is the driver open call.  Usually this call does nothing other than
-validate the minor number.
-With some drivers, it may be necessary to allocate memory when a particular
-device is opened.  If that is the case, then this is often the place to do this
-operation.
-Close a Particular Memory Partition
-This is the driver close call.  Usually this call does nothing.
-device is opened.  If that is the case, then this is the place where that
-memory should be deallocated.
-Read from a Particular Memory Partition
-This corresponds to the driver read call.  After validating the minor number
-and arguments, this call enables reads from the specified memory area by
-invoking the user supplied "enable reads handler" and then reads the indicated
-memory area.  When invoked the ``argument_block`` is actually a pointer to the
-following structure type:
-.. code-block:: c
-    typedef struct {
-      uint32_t  offset;
-      void     *buffer;
-      uint32_t  length;
-      uint32_t  status;
-    } Non_volatile_memory_Driver_arguments;
-The driver reads ``length`` bytes starting at ``offset`` into the partition and
-places them at ``buffer``.  The result is returned in ``status``.
-After the read operation is complete, the user supplied "disable reads handler"
-is invoked to protect the memory area again.
-Write to a Particular Memory Partition
-This corresponds to the driver write call.  After validating the minor number
-and arguments, this call enables writes to the specified memory area by
-invoking the "enable writes handler", then unprotecting the memory area, and
-finally actually writing to the indicated memory area.  When invoked the
-``argument_block`` is actually a pointer to the following structure type:
-.. code-block:: c
-    typedef struct {
-      uint32_t   offset;
-      void      *buffer;
-      uint32_t   length;
-      uint32_t   status;
-The driver writes ``length`` bytes from ``buffer`` and writes them to the
-non-volatile memory starting at ``offset`` into the partition.  The result is
-returned in ``status``.
-After the write operation is complete, the "disable writes handler" is invoked
-to protect the memory area again.
-Erase the Non-Volatile Memory Area
-This is one of the IOCTL functions supported by the I/O control device driver
-entry point.  When this IOCTL function is invoked, the specified area of
-non-volatile memory is erased.
1.8.4.5
