[PATCH 07/10] Add warning to Timer Driver chapter
Tue Dec 20 13:45:24 UTC 2016
Move Timer Driver chapter.
Update #2847.
 bsp-howto/index.rst | 2 +-
 bsp-howto/timer.rst | 5 +++++
 2 files changed, 6 insertions(+), 1 deletion(-)
diff --git a/bsp-howto/index.rst b/bsp-howto/index.rst
index ac0d5c0..68a9c35 100644
--- a/bsp-howto/index.rst
+++ b/bsp-howto/index.rst
@@ -49,11 +49,11 @@ to the Community Project hosted at http://www.rtems.org.
 	clock
 	i2c
 	spi
-	timer
 	real_time_clock
 	networking
 	shared_memory_support
 	frame_buffer
+	timer
 	ata
 	ide_controller
 	command
diff --git a/bsp-howto/timer.rst b/bsp-howto/timer.rst
index f0ec09b..b5e6bb6 100644
--- a/bsp-howto/timer.rst
+++ b/bsp-howto/timer.rst
@@ -7,6 +7,11 @@
 Timer Driver
+.. warning::
+   The Timer Driver is superfluous and should be replaced by the RTEMS counter
+   support.  Ask on the mailing list if you plan to write a Timer Driver.
 The timer driver is primarily used by the RTEMS Timing Tests.  This driver
 provides as accurate a benchmark timer as possible.  It typically reports its
 time in microseconds, CPU cycles, or bus cycles.  This information can be very
1.8.4.5
