[PATCH 10/10] Add warnings to basic BSP chapters
Tue Dec 20 13:45:27 UTC 2016
Update #2852.
 bsp-howto/initilization_code.rst     | 4 ++++
 bsp-howto/linker_script.rst          | 4 ++++
 bsp-howto/makefiles.rst              | 4 ++++
 bsp-howto/miscellanous_support.rst   | 4 ++++
 bsp-howto/target_dependant_files.rst | 4 ++++
 5 files changed, 20 insertions(+)
diff --git a/bsp-howto/initilization_code.rst b/bsp-howto/initilization_code.rst
index 85bc10b..3dacaa7 100644
--- a/bsp-howto/initilization_code.rst
+++ b/bsp-howto/initilization_code.rst
@@ -7,6 +7,10 @@
 Initialization Code
+.. warning::
+   This chapter contains outdated and confusing information.
 Introduction
diff --git a/bsp-howto/linker_script.rst b/bsp-howto/linker_script.rst
index 1940ae8..c00d205 100644
--- a/bsp-howto/linker_script.rst
+++ b/bsp-howto/linker_script.rst
@@ -8,6 +8,10 @@
 Linker Script
+.. warning::
 What is a "linkcmds" file?
diff --git a/bsp-howto/makefiles.rst b/bsp-howto/makefiles.rst
index b7ca12f..cd0feaf 100644
--- a/bsp-howto/makefiles.rst
+++ b/bsp-howto/makefiles.rst
@@ -9,6 +9,10 @@
 Makefiles
+.. warning::
 This chapter discusses the Makefiles associated with a BSP.  It does not
 describe the process of configuring, building, and installing RTEMS.  This
 chapter will not provide detailed information about this process.  Nonetheless,
diff --git a/bsp-howto/miscellanous_support.rst b/bsp-howto/miscellanous_support.rst
index 1986bb6..75e5e1f 100644
--- a/bsp-howto/miscellanous_support.rst
+++ b/bsp-howto/miscellanous_support.rst
@@ -8,6 +8,10 @@
 Miscellaneous Support Files
+.. warning::
 GCC Compiler Specifications File
diff --git a/bsp-howto/target_dependant_files.rst b/bsp-howto/target_dependant_files.rst
index 2f15094..fdfe5d2 100644
--- a/bsp-howto/target_dependant_files.rst
+++ b/bsp-howto/target_dependant_files.rst
@@ -8,6 +8,10 @@
 Target Dependent Files
+.. warning::
 RTEMS has a multi-layered approach to portability. This is done to maximize the
 amount of software that can be reused. Much of the RTEMS source code can be
 reused on all RTEMS platforms. Other parts of the executive are specific to
1.8.4.5
