[PATCH] RMS scheduler overrun handling example
Tue Dec 20 21:55:51 UTC 2016
I'm not clear how to tell this test Passes vs Fails. a few more notes below.
On Fri, Dec 9, 2016 at 11:40 AM, Kuan-Hsun Chen <c0066c at gmail.com> wrote:
>  testsuites/sptests/Makefile.am                 |   2 +
>  testsuites/sptests/configure.ac                |   1 +
>  testsuites/sptests/sprmsched01/Makefile.am     |  21 +++++
>  testsuites/sptests/sprmsched01/init.c          |  69 ++++++++++++++++
>  testsuites/sptests/sprmsched01/sprmsched01.doc |  33 ++++++++
>  testsuites/sptests/sprmsched01/sprmsched01.scn |  48 ++++++++++++
>  testsuites/sptests/sprmsched01/system.h        |  64 +++++++++++++++
>  testsuites/sptests/sprmsched01/tasks.c         | 104 +++++++++++++++++++++++++
>  8 files changed, 342 insertions(+)
>  create mode 100644 testsuites/sptests/sprmsched01/Makefile.am
>  create mode 100644 testsuites/sptests/sprmsched01/init.c
>  create mode 100644 testsuites/sptests/sprmsched01/sprmsched01.doc
>  create mode 100644 testsuites/sptests/sprmsched01/sprmsched01.scn
>  create mode 100644 testsuites/sptests/sprmsched01/system.h
>  create mode 100644 testsuites/sptests/sprmsched01/tasks.c
> diff --git a/testsuites/sptests/Makefile.am b/testsuites/sptests/Makefile.am
> index 54a4de7..4281abb 100644
> --- a/testsuites/sptests/Makefile.am
> +++ b/testsuites/sptests/Makefile.am
> @@ -37,6 +37,7 @@ _SUBDIRS += spfatal29
>  _SUBDIRS += spmutex01
>  _SUBDIRS += spextensions01
>  _SUBDIRS += spsysinit01
> +_SUBDIRS += sprmsched01
>  if HAS_SMP
>  else
>  _SUBDIRS += sp29
> @@ -56,6 +57,7 @@ _SUBDIRS += sptimecounter03
>  _SUBDIRS += spatomic01
>  _SUBDIRS += spintrcritical22
>  _SUBDIRS += spsem03
> +_SUBDIRS += spresource01
>  _SUBDIRS += spmrsp01
>  _SUBDIRS += spscheduler01
>  _SUBDIRS += spprofiling01
> diff --git a/testsuites/sptests/configure.ac b/testsuites/sptests/configure.ac
> index 76d60e3..8a55aef 100644
> --- a/testsuites/sptests/configure.ac
> +++ b/testsuites/sptests/configure.ac
> @@ -255,5 +255,6 @@ sptimer_err02/Makefile
>  spcpuset01/Makefile
>  spregion_err01/Makefile
>  sppartition_err01/Makefile
> +sprmsched01/Makefile
>  AC_OUTPUT
> diff --git a/testsuites/sptests/sprmsched01/Makefile.am b/testsuites/sptests/sprmsched01/Makefile.am
> new file mode 100644
> index 0000000..f837b52
> --- /dev/null
> +++ b/testsuites/sptests/sprmsched01/Makefile.am
> @@ -0,0 +1,21 @@
> +rtems_tests_PROGRAMS = sprmsched01
> +sprmsched01_SOURCES = init.c tasks.c system.h
> +dist_rtems_tests_DATA = sprmsched01.scn
> +dist_rtems_tests_DATA += sprmsched01.doc
> +include $(RTEMS_ROOT)/make/custom/@RTEMS_BSP at .cfg
> +include $(top_srcdir)/../automake/compile.am
> +include $(top_srcdir)/../automake/leaf.am
> +AM_CPPFLAGS += -I$(top_srcdir)/../support/include
> +LINK_OBJS = $(sprmsched01_OBJECTS)
> +LINK_LIBS = $(sprmsched01_LDLIBS)
> +sprmsched01$(EXEEXT): $(sprmsched01_OBJECTS) $(sprmsched01_DEPENDENCIES)
> +       @rm -f sprmsched01$(EXEEXT)
> +       $(make-exe)
> +include $(top_srcdir)/../automake/local.am
> diff --git a/testsuites/sptests/sprmsched01/init.c b/testsuites/sptests/sprmsched01/init.c
> index 0000000..7fd3e87
> --- /dev/null
> +++ b/testsuites/sptests/sprmsched01/init.c
> @@ -0,0 +1,69 @@
> + * @file sprmsched01/init.c
> + * @brief A init task body for sprmsched01 example.
> + *  COPYRIGHT (c) 2016 Kuan-Hsun Chen, TU Dortmund University (TUDo).
> + *  The license and distribution terms for this file may be
> + *  found in the file LICENSE in this distribution or at
> + *  http://www.rtems.com/license/LICENSE.
> +#ifdef HAVE_CONFIG_H
> +#include "config.h"
> +#endif
> +#define CONFIGURE_INIT
> +#include "system.h"
> +#include <rtems/rtems/tasksimpl.h>
> +#include <rtems/test.h>
> +#include <rtems/status-checks.h>
> +const char rtems_test_name[] = "Rate Monotonic 01";
There exist other tests of RM. I prefer this should indicate it is an
overrun test.
> +/* Global variables */
> +rtems_id   Task_id[ 2 ];         /* array of task ids */
> +rtems_name Task_name[ 2 ];       /* array of task names */
> +uint32_t tick_per_second;        /* time reference */
> +int testnumber = 11;                  /* stop condition */
> +rtems_task_priority Prio[3] = {0, 2, 5};
> +rtems_task Init(
> +       rtems_task_argument argument
> +  rtems_status_code status;
> +  TEST_BEGIN();
> +  tick_per_second = rtems_clock_get_ticks_per_second();
> +  printf("\nTicks per second in your system: %" PRIu32 "\n", tick_per_second);
> +  Task_name[ 1 ] = rtems_build_name( 'T', 'A', '1', ' ' );
> +  Task_name[ 2 ] = rtems_build_name( 'T', 'A', '2', ' ' );
> +  /* Create two tasks */
> +  for ( int index = 1; index <= 2; index++){
Put all var decls at start of function scope. add consistent
whitespace. see
https://devel.rtems.org/wiki/Developer/Coding/Conventions
> +    status = rtems_task_create(
> +      Task_name[ index ], Prio[index], RTEMS_MINIMUM_STACK_SIZE, RTEMS_DEFAULT_MODES,
> +      RTEMS_DEFAULT_ATTRIBUTES, &Task_id[ index ]
> +    directive_failed( status, "rtems_task_create loop");
> +  /* After creating the periods for tasks, start to run them sequencially. */
> +    status = rtems_task_start( Task_id[ index ], Task_1, index);
> +    directive_failed( status, "rtems_task_start loop");
> +  status = rtems_task_delete( RTEMS_SELF );
> +  directive_failed( status, "rtems_task_delete of RTEMS_SELF" );
> diff --git a/testsuites/sptests/sprmsched01/sprmsched01.doc b/testsuites/sptests/sprmsched01/sprmsched01.doc
> index 0000000..7153af8
> --- /dev/null
> +++ b/testsuites/sptests/sprmsched01/sprmsched01.doc
> @@ -0,0 +1,33 @@
> +#   COPYRIGHT (c) 2016 Kuan-Hsun Chen, TU Dortmund University (TUDo).
> +#   The license and distribution terms for this file may be
> +#   found in the file LICENSE in this distribution or at
> +#   http://www.rtems.com/license/LICENSE.
> +This file describes the directives and concepts tested by this test set.
> +test set name: sprmsched01
> +directives:
> +  - rtems_rate_monotonic_report_statistics()
> +  - rtems_rate_monotonic_period()
> +  - rtems_rate_monotonic_Postponed_num()
> +  - _Rate_monotonic_Timeout()
> +  - _Rate_monotonic_Renew_deadline()
> +  - _Rate_monotonic_Release_postponedjob()
> +  - _Rate_monotonic_Block_while_expired()
> +concepts:
> +  - Verify that watchdog deadline is renewed on time without shift via
> +    _Rate_monotonic_Renew_deadline().
> +  - Verify that postponed jobs are released with a correct number via
> +    _Rate_monotonic_Release_postponedjob().
> +  - Verify that rtems_rate_monotonic_report_statistics() reports correct number
> +    of deadline misses.
> +  - Verify that rtems_rate_monotonic_period() and
> +    _Rate_monotonic_Block_while_expired() are operational.
> diff --git a/testsuites/sptests/sprmsched01/sprmsched01.scn b/testsuites/sptests/sprmsched01/sprmsched01.scn
> index 0000000..3d3d2d9
> --- /dev/null
> +++ b/testsuites/sptests/sprmsched01/sprmsched01.scn
> @@ -0,0 +1,48 @@
> +*** BEGIN OF TEST Rate Monotonic 01 ***
> +Ticks per second in your system: 1000
> +Job 1 Task 1 starts at tick 13.
> +                                        Job 1 Task 1 ends at tick 6021.
> +Job 1 Task 2 starts at tick 6022.
> +                                        Job 1 Task 2 ends at tick 7024.
> +Job 2 Task 2 starts at tick 8022.
> +                                        Job 2 Task 2 ends at tick 9023.
> +Job 2 Task 1 starts at tick 10013.
> +                                        Job 2 Task 1 ends at tick 16021.
> +Job 3 Task 2 starts at tick 16023.
> +                                        Job 3 Task 2 ends at tick 17024.
> +Job 4 Task 2 starts at tick 17025.
> +                                        Job 4 Task 2 ends at tick 18026.
> +Job 5 Task 2 starts at tick 18026.
> +                                        Job 5 Task 2 ends at tick 19027.
> +Job 6 Task 2 starts at tick 19028.
> +                                        Job 6 Task 2 ends at tick 20029.
> +Job 7 Task 2 starts at tick 20029.
> +                                        Job 7 Task 2 ends at tick 21031.
> +Job 8 Task 2 starts at tick 21031.
> +                                        Job 8 Task 2 ends at tick 22033.
> +Job 9 Task 2 starts at tick 22033.
> +                                        Job 9 Task 2 ends at tick 23035.
> +Job 10 Task 2 starts at tick 24022.
> +                                        Job 10 Task 2 ends at tick 25023.
> +Job 11 Task 2 starts at tick 26022.
> +                                        Job 11 Task 2 ends at tick 27024.
> +Job 12 Task 2 starts at tick 28022.
> +                                        Job 12 Task 2 ends at tick 29024.
> +Job 13 Task 2 starts at tick 30022.
> +                                        Job 13 Task 2 ends at tick 31023.
> +Job 14 Task 2 starts at tick 32022.
> +                                        Job 14 Task 2 ends at tick 33023.
> +Job 15 Task 2 starts at tick 34022.
> +                                        Job 15 Task 2 ends at tick 35023.
> +Job 16 Task 2 starts at tick 36022.
> +                                        Job 16 Task 2 ends at tick 37023.
> +Period information by period
> +--- CPU times are in seconds ---
> +--- Wall times are in seconds ---
> +   ID     OWNER COUNT MISSED          CPU TIME                  WALL TIME
> +                                    MIN/MAX/AVG                MIN/MAX/AVG
> +0x42010002 TA2     15      6 1.001686/7.012146/2.404131 1.001698/13.013378/5.204723
> +*** END OF TEST Rate Monotonic 01 ***
> diff --git a/testsuites/sptests/sprmsched01/system.h b/testsuites/sptests/sprmsched01/system.h
> index 0000000..e4c6ade
> --- /dev/null
> +++ b/testsuites/sptests/sprmsched01/system.h
> @@ -0,0 +1,64 @@
> + * @file sprmsched01/system.h
> + * @brief sprmsched01 example header
> + *  COPYRIGHT (c) 1989-2007.
> + *  On-Line Applications Research Corporation (OAR).
> +#include <inttypes.h>
> +#include <rtems.h>
> +#include <tmacros.h>
> +/* function prototypes */
> +rtems_task Init(
> +rtems_task Task_1(
> +rtems_task Task_2(
> + *  Keep the names and IDs in global variables so another task can use them.
> +extern rtems_id   Task_id[ 2 ];         /* array of task ids */
> +extern rtems_name Task_name[ 2 ];       /* array of task names */
> +extern uint32_t tick_per_second;        /* time reference */
> +extern int testnumber;                  /* stop condition */
> +/* configuration information */
> +#include <bsp.h> /* for device driver prototypes */
> +#define CONFIGURE_APPLICATION_NEEDS_CONSOLE_DRIVER
> +#define CONFIGURE_APPLICATION_NEEDS_CLOCK_DRIVER
> +#define CONFIGURE_MICROSECONDS_PER_TICK     1000   // NB: 10 and lower gives system failure for erc32 simulator
> +#define CONFIGURE_MAXIMUM_TASKS             3
> +#define CONFIGURE_MAXIMUM_SEMAPHORES        1
> +#define CONFIGURE_MAXIMUM_PRIORITY          15
> +#define CONFIGURE_EXTRA_TASK_STACKS         (20 * RTEMS_MINIMUM_STACK_SIZE)
> +#define CONFIGURE_MAXIMUM_PERIODS           3
> +#define CONFIGURE_RTEMS_INIT_TASKS_TABLE
> +#include <rtems/confdefs.h>
> +/* end of include file */
> diff --git a/testsuites/sptests/sprmsched01/tasks.c b/testsuites/sptests/sprmsched01/tasks.c
> index 0000000..8cb06e6
> --- /dev/null
> +++ b/testsuites/sptests/sprmsched01/tasks.c
> @@ -0,0 +1,104 @@
> + * @file sprmsched01/tasks.c
> + * @brief A heuristic example to demonstrate how the postponed jobs are handled.
> + * Given two tasks with implicit deadline under fixed-priority scheudling.
> + * Task 1 has (6, 10) and task 2 has (1, 2), where (execution time, deadline/period).
> + * To force deadline misses, we reverse the rate-monotonic priority assignment
> + * and only execute the highest priority task twice.
> + * In the original implementation in v4.11, no matter how many periods are
> + * expired, RMS manager only releases a job with a shifted deadline assignment
> + * in the watchdog.
> +#endif
> +/* CPU usage and Rate monotonic manger statistics */
> +#include "rtems/cpuuse.h"
> +#include "rtems/counter.h"
> +/* Periods for the various tasks [ticks] */
> +uint32_t Periods[3] = {0, 10000, 2000};
> +uint32_t Iterations[3] = {0, 6000, 1000};
> +uint32_t tsk_counter[3] = {0, 0, 0};
> + * @brief Task 1 body
> +rtems_task Task_1(
> +  rtems_id          RM_period;
> +  rtems_id          selfid=rtems_task_self();
> +  int               start, end, flag=0;
> +  rtems_counter_ticks t0;
> +  t0 = rtems_counter_nanoseconds_to_ticks(1000000); //1ms ticks counter
> +  /*create period*/
> +  status = rtems_rate_monotonic_create( argument, &RM_period );
> +  directive_failed( status, "rtems_rate_monotonic_create" );
> +  switch ( argument ) {
> +    case 1:
> +    case 2:
> +      while ( FOREVER ) {
> +        status = rtems_rate_monotonic_period( RM_period, Periods[argument]);
> +        //directive_failed( status, "rtems_rate_monotonic_period" ); let TIMEOUT pass
> +        if(argument == 2 && flag == 0 && status == RTEMS_TIMEOUT){
> +          flag = 1;
> +          printf("RTEMS_TIMEOUT\n");
> +        }else if(flag == 1 && status == RTEMS_SUCCESSFUL){
> +          flag = 0;
> +          printf("RTEMS_SUCCESSFUL\n");
> +        start = rtems_clock_get_ticks_since_boot();
> +        if (argument == 2)
> +          printf("Job %d Task %d starts at tick %d.\n", tsk_counter[argument]+1, argument, start);
> +        else
> +          printf("Task %d starts at tick %d.\n", argument, start);
> +        for(int i=0; i<Iterations[argument]; i++){
> +          rtems_counter_delay_ticks(t0);
> +        end = rtems_clock_get_ticks_since_boot();
> +        printf("                                       Job %d Task %d ends at tick %d.\n", tsk_counter[argument]+1, argument, end);
> +        if( argument == 2 ){
> +          if(tsk_counter[ argument ] == testnumber){
> +            //rtems_rate_monotonic_report_statistics();
> +            TEST_END();
> +            status = rtems_rate_monotonic_delete(RM_period);
> +            directive_failed( status, "rtems_rate_monotonic_delete" );
> +            rtems_test_exit(0);
> +        tsk_counter[ argument ]+=1;
> +        if ( argument == 1 ){
> +          if( tsk_counter[ argument ] == 2 ){
> +            status = rtems_task_delete(selfid);
> +            directive_failed( status, "rtems_task_delete" );
> +      break;
> 1.9.1
> devel mailing list
> devel at rtems.org
