[PATCH] Enhancement of the RMS manager for the overrun handling.
Tue Dec 20 22:10:18 UTC 2016
On Fri, Dec 9, 2016 at 11:21 AM, Kuan-Hsun Chen <c0066c at gmail.com> wrote:
> Three additional functions:
> RM_Postponed_num, RM_Renew_deadline, and RM_Release_postponedjob.
> Four refined functions:
> RM_Activate, RM_Block_while_expired, rtems_rate_monotonic_period, RM_Timeout.
> Rate_monotonic_Control contains one counter for counting the postponed jobs and one for recording the recent deadline.
>  cpukit/rtems/include/rtems/rtems/ratemon.h     |  42 ++++++--
>  cpukit/rtems/include/rtems/rtems/ratemonimpl.h |  25 +++--
>  cpukit/rtems/src/ratemonperiod.c               | 144 +++++++++++++++++++++----
>  cpukit/rtems/src/ratemontimeout.c              |  13 ++-
>  4 files changed, 183 insertions(+), 41 deletions(-)
> diff --git a/cpukit/rtems/include/rtems/rtems/ratemon.h b/cpukit/rtems/include/rtems/rtems/ratemon.h
> index 50b8478..71a99dc 100644
> --- a/cpukit/rtems/include/rtems/rtems/ratemon.h
> +++ b/cpukit/rtems/include/rtems/rtems/ratemon.h
> @@ -22,6 +22,7 @@
>  /* COPYRIGHT (c) 1989-2009, 2016.
>   * On-Line Applications Research Corporation (OAR).
> + * COPYRIGHT (c) 2016 Kuan-Hsun Chen, TU Dortmund University (TUDo).
>   * The license and distribution terms for this file may be
>   * found in the file LICENSE in this distribution or at
> @@ -194,11 +195,6 @@ typedef struct {
>    /** This field is the object management portion of a Period instance. */
>    Objects_Control                         Object;
> -   * @brief Protects the rate monotonic period state.
> -  ISR_LOCK_MEMBER(                        Lock )
Why are these removed?
>    /** This is the timer used to provide the unblocking mechanism. */
>    Watchdog_Control                        Timer;
> @@ -206,12 +202,6 @@ typedef struct {
>    rtems_rate_monotonic_period_states      state;
> -   * @brief A priority node for use by the scheduler job release and cancel
> -   * operations.
> -  Priority_Node                           Priority;
Ditto.
>     * This field contains the length of the next period to be
>     * executed.
> @@ -240,6 +230,19 @@ typedef struct {
>     * This field contains the statistics maintained for the period.
>    Rate_monotonic_Statistics               Statistics;
> +   * This field contains the number of postponed jobs. When the watchdog timeout,
> +   * this variable will be increased immediately.
> +  uint32_t                                postponed_jobs;
> +   *  This field contains the tick of the latest deadline decided by the period
> +   *  watchdog.
> +  uint64_t                                latest_deadline;
>  }   Rate_monotonic_Control;
> @@ -386,6 +389,23 @@ void rtems_rate_monotonic_report_statistics_with_plugin(
>  void rtems_rate_monotonic_report_statistics( void );
> + * @brief RTEMS Return the number of postponed jobs
remove "RTEMS".
> + * This is a helper function to return the number of postponed jobs by this
by -> in
> + * given period. This number is only increased by the corresponding watchdog,
Is it only in a given period, or is it postponed jobs generally, i.e.
you could miss multiple periods hence jobs in multiple periods would
be counted here?
> + * and is decreased by RMS manager with the postponed job releasing.
> + * @param[in] id is the period id
> + * @retval This helper function returns the number of postponed
> + * jobs with given period_id.
> +uint32_t rtems_rate_monotonic_Postponed_num(
See coding conventions for naming rules. this is better
'rtems_rate_monotonic_postponed_jobs(). Is this function needed in the
public-facing API?
> +  rtems_id        period_id
>   * @brief RTEMS Rate Monotonic Period
>   * This routine implements the rtems_rate_monotonic_period directive. When
> diff --git a/cpukit/rtems/include/rtems/rtems/ratemonimpl.h b/cpukit/rtems/include/rtems/rtems/ratemonimpl.h
> index b6b3ffd..6cdaaeb 100644
> --- a/cpukit/rtems/include/rtems/rtems/ratemonimpl.h
> +++ b/cpukit/rtems/include/rtems/rtems/ratemonimpl.h
> @@ -9,6 +9,7 @@
>  /*  COPYRIGHT (c) 1989-2008.
>   *  Copyright (c) 2016 embedded brains GmbH.
> @@ -69,19 +70,19 @@ RTEMS_INLINE_ROUTINE Rate_monotonic_Control *_Rate_monotonic_Allocate( void )
>  RTEMS_INLINE_ROUTINE void _Rate_monotonic_Acquire_critical(
> -  Rate_monotonic_Control *the_period,
> -  ISR_lock_Context       *lock_context
> +  Thread_Control   *the_thread,
> +  ISR_lock_Context *lock_context
> -  _ISR_lock_Acquire( &the_period->Lock, lock_context );
> +  _Thread_Wait_acquire_default_critical( the_thread, lock_context );
At what version did you make your patch? These lock changes are weird.
>  RTEMS_INLINE_ROUTINE void _Rate_monotonic_Release(
> -  _ISR_lock_Release_and_ISR_enable( &the_period->Lock, lock_context );
> +  _Thread_Wait_release_default( the_thread, lock_context );
>  RTEMS_INLINE_ROUTINE Rate_monotonic_Control *_Rate_monotonic_Get(
> @@ -116,6 +117,18 @@ bool _Rate_monotonic_Get_status(
>    Timestamp_Control            *cpu_since_last_period
> + * @brief Renew the watchdog deadline
> + * This routine is prepared for the watchdog timeout to renew its deadline
> + * without releasing jobs.
> +void _Rate_monotonic_Renew_deadline(
> +  Rate_monotonic_Control *the_period,
> +  Thread_Control         *owner,
>  void _Rate_monotonic_Restart(
> diff --git a/cpukit/rtems/src/ratemonperiod.c b/cpukit/rtems/src/ratemonperiod.c
> index 77bd996..26cee58 100644
> --- a/cpukit/rtems/src/ratemonperiod.c
> +++ b/cpukit/rtems/src/ratemonperiod.c
> @@ -9,6 +9,7 @@
>   *  COPYRIGHT (c) 1989-2010.
> @@ -63,6 +64,24 @@ bool _Rate_monotonic_Get_status(
>    return true;
> +static void _Rate_monotonic_Release_postponedjob(
better; Release_postponed_job
> +  rtems_interval          next_length,
> +  /* This function only releases the postponed jobs. */
> +  Per_CPU_Control *cpu_self;
> +  cpu_self = _Thread_Dispatch_disable_critical( lock_context );
> +  _Rate_monotonic_Release( owner, lock_context );
> +  the_period->postponed_jobs -=1;
> +  _Scheduler_Release_job( owner, the_period->latest_deadline );
> +  _Thread_Dispatch_enable( cpu_self );
>  static void _Rate_monotonic_Release_job(
> @@ -70,29 +89,49 @@ static void _Rate_monotonic_Release_job(
> -  Per_CPU_Control      *cpu_self;
> -  Thread_queue_Context  queue_context;
> -  uint64_t              deadline;
> +  uint64_t deadline;
> +  _ISR_lock_ISR_disable( lock_context );
>    deadline = _Watchdog_Per_CPU_insert_relative(
>      &the_period->Timer,
>      cpu_self,
>      next_length
> -  _Scheduler_Release_job(
> -    owner,
> -    &the_period->Priority,
> -    deadline,
> -    &queue_context
> +  _ISR_lock_ISR_enable( lock_context );
> +  _Scheduler_Release_job( owner, deadline );
> -  _Rate_monotonic_Release( the_period, lock_context );
> -  _Thread_Priority_update( &queue_context );
> +  deadline = _Watchdog_Per_CPU_insert_relative(
> +    &the_period->Timer,
> +    cpu_self,
> +    the_period->next_length
> +  the_period->latest_deadline = deadline;
> @@ -190,6 +229,10 @@ static rtems_status_code _Rate_monotonic_Activate(
> +  /* Initialize the number of postponed job variable */
don't need this comment or the extra blank newlines around this. Just
init the variable.
> +  the_period->postponed_jobs = 0;
>    the_period->state = RATE_MONOTONIC_ACTIVE;
>    the_period->next_length = length;
>    _Rate_monotonic_Restart( the_period, executing, lock_context );
> @@ -221,7 +264,7 @@ static rtems_status_code _Rate_monotonic_Block_while_active(
>    _Thread_Wait_flags_set( executing, RATE_MONOTONIC_INTEND_TO_BLOCK );
> +  _Rate_monotonic_Release( executing, lock_context );
>    _Thread_Set_state( executing, STATES_WAITING_FOR_PERIOD );
> @@ -241,6 +284,11 @@ static rtems_status_code _Rate_monotonic_Block_while_active(
>    return RTEMS_SUCCESSFUL;
> + * There are two possible cases: one is that the previous deadline is missed,
> + * The other is that the number of postponed jobs is not 0, but the current
> + * deadline is still not expired, i.e., state = RATE_MONOTONIC_ACTIVE.
>  static rtems_status_code _Rate_monotonic_Block_while_expired(
>    rtems_interval          length,
> @@ -248,6 +296,12 @@ static rtems_status_code _Rate_monotonic_Block_while_expired(
> +   * No matter the just finished jobs in time or not,
> +   * they are actually missing their deadlines already.
> +  the_period->state = RATE_MONOTONIC_EXPIRED;
>     *  Update statistics from the concluding period
> @@ -255,11 +309,27 @@ static rtems_status_code _Rate_monotonic_Block_while_expired(
> -  _Rate_monotonic_Release_job( the_period, executing, length, lock_context );
> +  _Rate_monotonic_Release_postponedjob( the_period, executing, length, lock_context );
>    return RTEMS_TIMEOUT;
Is this function used/needed to be used?
> +  Rate_monotonic_Control             *the_period;
> +  ISR_lock_Context                    lock_context;
> +  Thread_Control                     *owner;
> +  the_period = _Rate_monotonic_Get( period_id, &lock_context );
> +  _Assert(the_period != NULL);
> +  uint32_t jobs = the_period->postponed_jobs;
> +  owner = the_period->owner;
> +  _Rate_monotonic_Release( owner, &lock_context );
> +  return jobs;
>  rtems_status_code rtems_rate_monotonic_period(
>    rtems_id       id,
> @@ -282,22 +352,44 @@ rtems_status_code rtems_rate_monotonic_period(
>      return RTEMS_NOT_OWNER_OF_RESOURCE;
> -  _Rate_monotonic_Acquire_critical( the_period, &lock_context );
> +  _Rate_monotonic_Acquire_critical( executing, &lock_context );
>    state = the_period->state;
>    if ( length == RTEMS_PERIOD_STATUS ) {
>      status = _Rate_monotonic_Get_status_for_state( state );
> -    _Rate_monotonic_Release( the_period, &lock_context );
> +    _Rate_monotonic_Release( executing, &lock_context );
>    } else {
>      switch ( state ) {
>        case RATE_MONOTONIC_ACTIVE:
> -        status = _Rate_monotonic_Block_while_active(
> -          the_period,
> -          length,
> -          executing,
> -          &lock_context
> +        if(the_period->postponed_jobs > 0){
fix whitespace
> +           * If the number of postponed jobs is not 0, it means the
> +                  * previous postponed instance is finished without exceeding
> +                  * the current period deadline.
align asterisks.
> +           * Do nothing on the watchdog deadline assignment but release the next
> +           * remaining postponed job.
> +          status = _Rate_monotonic_Block_while_expired(
> +            the_period,
> +            length,
> +            executing,
> +            &lock_context
> +        }else{
fix ws
> +           * Normal case that no postponed jobs and no expiration, so wait for the period
> +           * and update the deadline of watchdog accordingly.
> +          status = _Rate_monotonic_Block_while_active(
> +            the_period,
> +            length,
> +            executing,
> +            &lock_context
>          break;
>        case RATE_MONOTONIC_INACTIVE:
>          status = _Rate_monotonic_Activate(
> @@ -308,6 +400,14 @@ rtems_status_code rtems_rate_monotonic_period(
>          break;
>        default:
> +         * As now this period was already TIMEOUT, there must be at least one
> +         * postponed job recorded by the watchdog. The one which exceeded
> +         * the previous deadline"s" was just finished.
remove those double-quotes.
> +         * Maybe there is more than one job postponed due to the preemption or
> +         * the previous finished job.
>          _Assert( state == RATE_MONOTONIC_EXPIRED );
>            the_period,
> diff --git a/cpukit/rtems/src/ratemontimeout.c b/cpukit/rtems/src/ratemontimeout.c
> index e514a31..be0a770 100644
> --- a/cpukit/rtems/src/ratemontimeout.c
> +++ b/cpukit/rtems/src/ratemontimeout.c
> @@ -9,6 +9,8 @@
>   *  COPYRIGHT (c) 1989-2009.
>   *  http://www.rtems.org/license/LICENSE.
> @@ -31,7 +33,7 @@ void _Rate_monotonic_Timeout( Watchdog_Control *the_watchdog )
>    _ISR_lock_ISR_disable( &lock_context );
> +  _Rate_monotonic_Acquire_critical( owner, &lock_context );
>    wait_flags = _Thread_Wait_flags_get( owner );
>    if (
> @@ -62,7 +64,14 @@ void _Rate_monotonic_Timeout( Watchdog_Control *the_watchdog )
>        _Thread_Unblock( owner );
>    } else {
> +     * If the watchdog is timeout, it means there is an additional postponed
> +     * job in the next period but it is not available to release now:
> +     * Either the current task is still executed, or it is preemptive by the
> +     * other higher priority tasks.
> +    the_period->postponed_jobs += 1;
> +    _Rate_monotonic_Renew_deadline( the_period, owner, &lock_context );
> 1.9.1
> devel mailing list
> devel at rtems.org
