C11 Re: [PATCH 3/6] termios: Use C11 mutex for input/output
Tue Dec 20 22:37:34 UTC 2016
On 21/12/2016 08:20, Gedare Bloom wrote:
> I haven't fully understood the distinction. I get that C11 are
> individually (and collectively) smaller. I don't entirely get what is
> their time-space tradeoff or when they are less desirable.
There are a few advantages to self-contained resources like mutexes for
an API like C11 and POSIX.
1. All major POSIX implementations work this way. The libstdc++ code
base assumes it, see https://gcc.gnu.org/bugzilla/show_bug.cgi?id=78677.
The standard does say POSIX create calls can return an error however it
seems to be assumed this does not happen. A change in RTEMS brings us
closer to the major implementations in this regard.
2. Performance. Sebastian's work with LibBSD, which is documented in the
recent v3 SMP report highlighted the cost in the object look up in
various hot parts of the kernel. This alone is a significant piece of data.
3. Deterministic resourcing. If you can link an application and it fits
in memory the resource is allocated. There is no need to account and
adjust a configuration parameter in another area of the system. This
combines well with function section linking where we only have the
referenced code in the target executable which means only the referenced
resources are included.
4. Self-contained objects help dynamic loaded resource configuration.
You do not know what can or could be loaded dynamically and how
resources may be used or shared. A central base image configuration
leads to possible conflicts in resource allocation. The unlimited patch
back in the mid-90's was one solution to this problem, self-contains
objects is another.
> I would
> like to see a table that compares/contrasts these in a simple way to
> evaluate. I will try to look closely at these different approaches in
> a few weeks.
I hope the list above helps.
