[PATCH 3/3] EDF scheduler overrun handling example
Kuan-Hsun Chen c0066c at gmail.com
Wed Dec 21 16:42:41 UTC 2016
 testsuites/sptests/Makefile.am                   |   2 +-
 testsuites/sptests/configure.ac                  |   1 +
 testsuites/sptests/spedfsched04/Makefile.am      |  21 +++++
 testsuites/sptests/spedfsched04/init.c           |  70 +++++++++++++++
 testsuites/sptests/spedfsched04/spedfsched04.doc |  34 ++++++++
 testsuites/sptests/spedfsched04/spedfsched04.scn |  24 ++++++
 testsuites/sptests/spedfsched04/system.h         |  62 ++++++++++++++
 testsuites/sptests/spedfsched04/tasks.c          | 103 +++++++++++++++++++++++
 8 files changed, 316 insertions(+), 1 deletion(-)
 create mode 100644 testsuites/sptests/spedfsched04/Makefile.am
 create mode 100644 testsuites/sptests/spedfsched04/init.c
 create mode 100644 testsuites/sptests/spedfsched04/spedfsched04.doc
 create mode 100644 testsuites/sptests/spedfsched04/spedfsched04.scn
 create mode 100644 testsuites/sptests/spedfsched04/system.h
 create mode 100644 testsuites/sptests/spedfsched04/tasks.c
diff --git a/testsuites/sptests/Makefile.am b/testsuites/sptests/Makefile.am
index 4379a2b..9718139 100644
--- a/testsuites/sptests/Makefile.am
+++ b/testsuites/sptests/Makefile.am
@@ -37,7 +37,7 @@ _SUBDIRS += spfatal29
 _SUBDIRS += spmutex01
 _SUBDIRS += spextensions01
 _SUBDIRS += spsysinit01
-_SUBDIRS += sprmsched01
+_SUBDIRS += sprmsched01 spedfsched04
 if HAS_SMP
 else
 _SUBDIRS += sp29
diff --git a/testsuites/sptests/configure.ac b/testsuites/sptests/configure.ac
index 8a55aef..6713754 100644
--- a/testsuites/sptests/configure.ac
+++ b/testsuites/sptests/configure.ac
@@ -166,6 +166,7 @@ spcoverage/Makefile
 spedfsched01/Makefile
 spedfsched02/Makefile
 spedfsched03/Makefile
+spedfsched04/Makefile
 sperror01/Makefile
 sperror02/Makefile
 sperror03/Makefile
diff --git a/testsuites/sptests/spedfsched04/Makefile.am b/testsuites/sptests/spedfsched04/Makefile.am
new file mode 100644
index 0000000..21293de
--- /dev/null
+++ b/testsuites/sptests/spedfsched04/Makefile.am
@@ -0,0 +1,21 @@
+rtems_tests_PROGRAMS = spedfsched04
+spedfsched04_SOURCES = init.c tasks.c system.h
+dist_rtems_tests_DATA = spedfsched04.scn
+dist_rtems_tests_DATA += spedfsched04.doc
+include $(RTEMS_ROOT)/make/custom/@RTEMS_BSP at .cfg
+include $(top_srcdir)/../automake/compile.am
+include $(top_srcdir)/../automake/leaf.am
+AM_CPPFLAGS += -I$(top_srcdir)/../support/include
+LINK_OBJS = $(spedfsched04_OBJECTS)
+LINK_LIBS = $(spedfsched04_LDLIBS)
+spedfsched04$(EXEEXT): $(spedfsched04_OBJECTS) $(spedfsched04_DEPENDENCIES)
+	@rm -f spedfsched04$(EXEEXT)
+	$(make-exe)
+include $(top_srcdir)/../automake/local.am
diff --git a/testsuites/sptests/spedfsched04/init.c b/testsuites/sptests/spedfsched04/init.c
index 0000000..b1401e6
--- /dev/null
+++ b/testsuites/sptests/spedfsched04/init.c
@@ -0,0 +1,70 @@
+ * @file spedfsched04/init.c
+ * @brief A init task body for spedfsched04 example.
+ *  COPYRIGHT (c) 2016 Kuan-Hsun Chen.
+ *  The license and distribution terms for this file may be
+ *  found in the file LICENSE in this distribution or at
+ *  http://www.rtems.com/license/LICENSE.
+#ifdef HAVE_CONFIG_H
+#include "config.h"
+#endif
+#define CONFIGURE_INIT
+#include "system.h"
+#include <rtems/rtems/tasksimpl.h>
+#include <rtems/test.h>
+#include <rtems/status-checks.h>
+const char rtems_test_name[] = "SPEDFSCHED 4 - Overrun Test";
+/* Global variables */
+rtems_id   Task_id[ 2 ];         /* array of task ids */
+rtems_name Task_name[ 2 ];       /* array of task names */
+uint32_t tick_per_second;        /* time reference */
+int testnumber = 5;                  /* stop condition */
+rtems_task_priority Prio[ 3 ] = { 0, 2, 5 };
+rtems_task Init(
+	rtems_task_argument argument
+  uint32_t    index;
+  TEST_BEGIN();
+  rtems_status_code status;
+  tick_per_second = rtems_clock_get_ticks_per_second();
+  printf( "\nTicks per second in your system: %" PRIu32 "\n", tick_per_second );
+  Task_name[ 1 ] = rtems_build_name( 'T', 'A', '1', ' ' );
+  Task_name[ 2 ] = rtems_build_name( 'T', 'A', '2', ' ' );
+  /* Create two tasks */
+  for ( index = 1; index <= 2; index++ ){
+    status = rtems_task_create(
+      Task_name[ index ], Prio[ index ], RTEMS_MINIMUM_STACK_SIZE, RTEMS_DEFAULT_MODES,
+      RTEMS_DEFAULT_ATTRIBUTES, &Task_id[ index ]
+    directive_failed( status, "rtems_task_create loop" );
+  /* After creating the periods for tasks, start to run them sequencially. */
+    status = rtems_task_start( Task_id[ index ], Task, index);
+    directive_failed( status, "rtems_task_start loop" );
+  status = rtems_task_delete( RTEMS_SELF );
+  directive_failed( status, "rtems_task_delete of RTEMS_SELF" );
diff --git a/testsuites/sptests/spedfsched04/spedfsched04.doc b/testsuites/sptests/spedfsched04/spedfsched04.doc
index 0000000..a2e90ee
--- /dev/null
+++ b/testsuites/sptests/spedfsched04/spedfsched04.doc
@@ -0,0 +1,34 @@
+#   COPYRIGHT (c) 2016 Kuan-Hsun Chen.
+#   The license and distribution terms for this file may be
+#   found in the file LICENSE in this distribution or at
+#   http://www.rtems.com/license/LICENSE.
+This file describes the directives and concepts tested by this test set.
+The adopted scheduling here is EDF. For fixed-priority scheduling, the corresponding testing can be found in sprmsched01.
+test set name: spedfsched04
+directives:
+  - rtems_rate_monotonic_report_statistics()
+  - rtems_rate_monotonic_period()
+  - rtems_rate_monotonic_Postponed_num()
+  - _Rate_monotonic_Timeout()
+  - _Rate_monotonic_Renew_deadline()
+  - _Rate_monotonic_Release_postponedjob()
+  - _Rate_monotonic_Block_while_expired()
+concepts:
+  - Verify that watchdog deadline is renewed on time without shift via
+    _Rate_monotonic_Renew_deadline().
+  - Verify that postponed jobs are released with a correct number via
+    _Rate_monotonic_Release_postponedjob().
+  - Verify that rtems_rate_monotonic_report_statistics() reports correct number
+    of deadline misses.
+  - Verify that rtems_rate_monotonic_period() and
+    _Rate_monotonic_Block_while_expired() are operational.
diff --git a/testsuites/sptests/spedfsched04/spedfsched04.scn b/testsuites/sptests/spedfsched04/spedfsched04.scn
index 0000000..addb955
--- /dev/null
+++ b/testsuites/sptests/spedfsched04/spedfsched04.scn
@@ -0,0 +1,24 @@
+*** BEGIN OF TEST SPEDFSCHED 4 ***
+Ticks per second in your system: 1000
+Job 1 Task 1 starts at tick 14.
+                                        Job 1 Task 1 ends at tick 4023.
+Job 1 Task 2 starts at tick 4025.
+Job 2 Task 1 starts at tick 5013.
+                                        Job 2 Task 1 ends at tick 9023.
+                                        Job 1 Task 2 ends at tick 12045.
+System TIMEOUT
+Job 2 Task 2 starts at tick 12045.
+                                        Job 2 Task 2 ends at tick 16054.
+Job 3 Task 2 starts at tick 16054.
+                                        Job 3 Task 2 ends at tick 20061.
+System SUCCESSFUL
+Job 4 Task 2 starts at tick 22025.
+                                        Job 4 Task 2 ends at tick 26033.
+Job 5 Task 2 starts at tick 28025.
+                                        Job 5 Task 2 ends at tick 32033.
+Job 6 Task 2 starts at tick 34025.
+                                        Job 6 Task 2 ends at tick 38033.
+*** END OF TEST SPEDFSCHED 4 ***
diff --git a/testsuites/sptests/spedfsched04/system.h b/testsuites/sptests/spedfsched04/system.h
index 0000000..6d6f270
--- /dev/null
+++ b/testsuites/sptests/spedfsched04/system.h
@@ -0,0 +1,62 @@
+ * @file spedfsched04/system.h
+ * @brief spedfsched04 example header
+ *  COPYRIGHT (c) 1989-2007.
+ *  On-Line Applications Research Corporation (OAR).
+#include <inttypes.h>
+#include <rtems.h>
+#include <tmacros.h>
+/* function prototypes */
+rtems_task Init(
+rtems_task Task(
+ *  Keep the names and IDs in global variables so another task can use them.
+extern rtems_id   Task_id[ 2 ];         /* array of task ids */
+extern rtems_name Task_name[ 2 ];       /* array of task names */
+extern uint32_t tick_per_second;        /* time reference */
+extern int testnumber;                  /* stop condition */
+/* configuration information */
+#include <bsp.h> /* for device driver prototypes */
+#define CONFIGURE_SCHEDULER_EDF
+#define CONFIGURE_APPLICATION_NEEDS_CONSOLE_DRIVER
+#define CONFIGURE_APPLICATION_NEEDS_CLOCK_DRIVER
+#define CONFIGURE_MICROSECONDS_PER_TICK     1000   // NB: 10 and lower gives system failure for erc32 simulator
+#define CONFIGURE_MAXIMUM_TASKS             3
+#define CONFIGURE_MAXIMUM_PRIORITY          15
+#define CONFIGURE_EXTRA_TASK_STACKS         (20 * RTEMS_MINIMUM_STACK_SIZE)
+#define CONFIGURE_MAXIMUM_PERIODS           3
+#define CONFIGURE_RTEMS_INIT_TASKS_TABLE
+#include <rtems/confdefs.h>
+/* end of include file */
diff --git a/testsuites/sptests/spedfsched04/tasks.c b/testsuites/sptests/spedfsched04/tasks.c
index 0000000..b0c4163
--- /dev/null
+++ b/testsuites/sptests/spedfsched04/tasks.c
@@ -0,0 +1,103 @@
+ * @file sprmsched04/tasks.c
+ * @brief A heuristic example to demonstrate how the postponed jobs are handled.
+ * Given two tasks with implicit deadline under EDF policy.
+ * Task 1 has (4, 5) and task 2 has (4, 6), where (execution time, period/deadline).
+ * For the simplicity, we only execute the first task twice.
+ * In the original implementation in v4.11, no matter how many periods are
+ * expired, only one job will be released with a shifted deadline assignment.
+ * In this example, the first job of task 2 will be blocked by the second job
+ * of task 1, so that there at least one following job is postponed.
+ * Due to overhead/delay, the second following job will be postponed as well.
+ * If the overrun handling is correct, the period of task 2 changes back to
+ * normal status at time 22.
+ * Otherwise, the release time of job 3 is no longer periodic.
+#endif
+#include <rtems/score/watchdogimpl.h>
+/* CPU usage and Rate monotonic manger statistics */
+#include "rtems/cpuuse.h"
+#include "rtems/counter.h"
+uint32_t    Periods[ 3 ] = { 0, 5000, 6000 };
+uint32_t    Iterations[ 3 ] = { 0, 4000, 4000 };
+uint32_t    tsk_counter[ 3 ] = { 0, 0, 0 };
+ * @brief Task body
+rtems_task Task(
+  rtems_id    RM_period;
+  rtems_id    selfid=rtems_task_self();
+  uint32_t    start, end, index, flag = 0;
+  rtems_counter_ticks t0 = rtems_counter_nanoseconds_to_ticks( 1000000 );
+  /*create period*/
+  status = rtems_rate_monotonic_create( argument, &RM_period );
+  directive_failed( status, "rtems_rate_monotonic_create" );
+  switch ( argument ) {
+    case 1:
+    case 2:
+      while ( FOREVER ) {
+        status = rtems_rate_monotonic_period( RM_period, Periods[ argument ]);
+        if ( flag == 0 && status == RTEMS_TIMEOUT ){
+          printf( "System TIMEOUT \n" );
+          flag = 1;
+        }else if ( flag == 1 && status == RTEMS_SUCCESSFUL ){
+          printf( "System SUCCESSFUL \n" );
+          flag = 0;
+        start = rtems_clock_get_ticks_since_boot();
+        printf( "Job %d Task %d starts at tick %d.\n", tsk_counter[ argument ]+1, argument, start );
+        for( index = 0; index < Iterations[ argument ]; index++ ){
+          rtems_counter_delay_ticks( t0 );
+        end = rtems_clock_get_ticks_since_boot();
+        printf( "					Job %d Task %d ends at tick %d.\n", tsk_counter[ argument ]+1, argument, end );
+        if( argument == 2 ){
+          if( tsk_counter[ argument ] == testnumber ){
+            TEST_END();
+            status = rtems_rate_monotonic_delete( RM_period );
+            directive_failed( status, "rtems_rate_monotonic_delete" );
+            rtems_test_exit( 0 );
+        tsk_counter[ argument ]+=1;
+        if ( argument == 1 ){
+          if( tsk_counter[ argument ] == 2 ){
+            status = rtems_task_delete( selfid );
+            directive_failed( status, "rtems_task_delete" );
+      break;
1.9.1
