[PATCH 6/8] Adding pipe support
Kevin Kirspel
kevin-kirspel at idexx.com
Wed Dec 21 19:01:31 UTC 2016
freebsd/sys/kern/sys_pipe.c | 271 ++++++++++++++++++++++++++++++++++++++++++++
1 file changed, 271 insertions(+)
mode change 100644 => 100755 freebsd/sys/kern/sys_pipe.c
diff --git a/freebsd/sys/kern/sys_pipe.c b/freebsd/sys/kern/sys_pipe.c
old mode 100644
new mode 100755
index f1efd09..45d3ed1
--- a/freebsd/sys/kern/sys_pipe.c
+++ b/freebsd/sys/kern/sys_pipe.c
@@ -131,6 +131,9 @@ __FBSDID("$FreeBSD$");
#include <vm/uma.h>
/* XXX */
+#ifdef __rtems__
+static
+#endif /* __rtems__ */
int do_pipe(struct thread *td, int fildes[2], int flags);
@@ -143,6 +146,7 @@ int do_pipe(struct thread *td, int fildes[2], int flags);
* interfaces to the outside world
+#ifndef __rtems__
static fo_rdwr_t pipe_read;
static fo_rdwr_t pipe_write;
static fo_truncate_t pipe_truncate;
@@ -165,6 +169,39 @@ static struct fileops pipeops = {
.fo_chown = invfo_chown,
.fo_flags = DFLAG_PASSABLE
+#else /* __rtems__ */
+#define PIPE_NODIRECT
+#define PRIBIO (0)
+static int rtems_bsd_pipe_open(rtems_libio_t *iop, const char *path, int oflag, mode_t mode);
+static int rtems_bsd_pipe_close(rtems_libio_t *iop);
+static ssize_t rtems_bsd_pipe_read(rtems_libio_t *iop, void *buffer, size_t count);
+static ssize_t rtems_bsd_pipe_write(rtems_libio_t *iop, const void *buffer, size_t count);
+static int rtems_bsd_pipe_ioctl(rtems_libio_t *iop, ioctl_command_t request, void *buffer);
+static int rtems_bsd_pipe_stat(const rtems_filesystem_location_info_t *loc, struct stat *buf);
+static int rtems_bsd_pipe_fcntl(rtems_libio_t *iop, int cmd);
+static int rtems_bsd_pipe_poll(rtems_libio_t *iop, int events);
+int rtems_bsd_pipe_kqfilter(rtems_libio_t *iop, struct knote *kn);
+static const rtems_filesystem_file_handlers_r pipeops = {
+ .open_h = rtems_bsd_pipe_open,
+ .close_h = rtems_bsd_pipe_close,
+ .read_h = rtems_bsd_pipe_read,
+ .write_h = rtems_bsd_pipe_write,
+ .ioctl_h = rtems_bsd_pipe_ioctl,
+ .lseek_h = rtems_filesystem_default_lseek,
+ .fstat_h = rtems_bsd_pipe_stat,
+ .ftruncate_h = rtems_filesystem_default_ftruncate,
+ .fsync_h = rtems_filesystem_default_fsync_or_fdatasync,
+ .fdatasync_h = rtems_filesystem_default_fsync_or_fdatasync,
+ .fcntl_h = rtems_bsd_pipe_fcntl,
+ .poll_h = rtems_bsd_pipe_poll,
+ .kqfilter_h = rtems_bsd_pipe_kqfilter
+long maxpipekva; /* Limit on pipe KVA */
static void filt_pipedetach(struct knote *kn);
static int filt_piperead(struct knote *kn, long hint);
@@ -266,7 +303,11 @@ pipe_zone_ctor(void *mem, int size, void *arg, int flags)
rpipe = &pp->pp_rpipe;
bzero(rpipe, sizeof(*rpipe));
+#ifndef __rtems__
vfs_timestamp(&rpipe->pipe_ctime);
+ rpipe->pipe_ctime.tv_sec = time(NULL);
rpipe->pipe_atime = rpipe->pipe_mtime = rpipe->pipe_ctime;
wpipe = &pp->pp_wpipe;
@@ -336,7 +377,11 @@ kern_pipe(struct thread *td, int fildes[2])
int
+#ifndef __rtems__
struct filedesc *fdp = td->td_proc->p_fd;
+ struct filedesc *fdp = NULL;
struct file *rf, *wf;
struct pipepair *pp;
struct pipe *rpipe, *wpipe;
@@ -422,6 +467,28 @@ sys_pipe(struct thread *td, struct pipe_args *uap)
return (0);
+#ifdef __rtems__
+int
+pipe(int fildes[2])
+ struct thread *td = rtems_bsd_get_curthread_or_null();
+ int error;
+ if (td != NULL) {
+ error = sys_pipe(td, NULL);
+ } else {
+ error = ENOMEM;
+ if (error == 0) {
+ fildes[0] = td->td_retval[0];
+ fildes[1] = td->td_retval[1];
+ return error;
+ } else {
+ rtems_set_errno_and_return_minus_one(error);
* Allocate kva for pipe circular buffer, the space is pageable
@@ -448,12 +515,17 @@ retry:
size = cnt;
size = round_page(size);
+#ifndef __rtems__
buffer = (caddr_t) vm_map_min(pipe_map);
error = vm_map_find(pipe_map, NULL, 0,
(vm_offset_t *) &buffer, size, 1,
VM_PROT_ALL, VM_PROT_ALL, 0);
if (error != KERN_SUCCESS) {
+ buffer = malloc(size, M_TEMP, M_WAITOK | M_ZERO);
+ if (buffer == NULL) {
if ((cpipe->pipe_buffer.buffer == NULL) &&
(size > SMALL_PIPE_SIZE)) {
size = SMALL_PIPE_SIZE;
@@ -716,7 +788,11 @@ pipe_read(fp, uio, active_cred, flags, td)
* Handle non-blocking mode operation or
* wait for more data.
+#ifndef __rtems__
if (fp->f_flag & FNONBLOCK) {
+ if (rtems_bsd_libio_flags_to_fflag(fp->f_io.flags) & FNONBLOCK) {
error = EAGAIN;
} else {
rpipe->pipe_state |= PIPE_WANTR;
@@ -736,7 +812,11 @@ locked_error:
/* XXX: should probably do this before getting any locks. */
if (error == 0)
+#ifndef __rtems__
vfs_timestamp(&rpipe->pipe_atime);
+ rpipe->pipe_atime.tv_sec = time(NULL);
unlocked_error:
--rpipe->pipe_busy;
@@ -762,6 +842,40 @@ unlocked_error:
PIPE_UNLOCK(rpipe);
return (error);
+#ifdef __rtems__
+static ssize_t
+rtems_bsd_pipe_read(rtems_libio_t *iop, void *buffer, size_t count)
+ struct file *fp = rtems_bsd_iop_to_fp(iop);
+ struct iovec iov = {
+ .iov_base = buffer,
+ .iov_len = count
+ struct uio auio = {
+ .uio_iov = &iov,
+ .uio_iovcnt = 1,
+ .uio_offset = 0,
+ .uio_resid = count,
+ .uio_segflg = UIO_USERSPACE,
+ .uio_rw = UIO_READ,
+ .uio_td = td
+ int error;
+ if (td != NULL) {
+ error = pipe_read(fp, &auio, NULL, 0, NULL);
+ } else {
+ error = ENOMEM;
+ if (error == 0) {
+ return (count - auio.uio_resid);
+ } else {
#ifndef PIPE_NODIRECT
@@ -1189,7 +1303,11 @@ pipe_write(fp, uio, active_cred, flags, td)
* don't block on non-blocking I/O
+#ifndef __rtems__
error = EAGAIN;
pipeunlock(wpipe);
break;
@@ -1237,7 +1355,11 @@ pipe_write(fp, uio, active_cred, flags, td)
if (error == 0)
+#ifndef __rtems__
vfs_timestamp(&wpipe->pipe_mtime);
+ wpipe->pipe_mtime.tv_sec = time(NULL);
* We have something to offer,
@@ -1250,8 +1372,43 @@ pipe_write(fp, uio, active_cred, flags, td)
PIPE_UNLOCK(rpipe);
return (error);
+#ifdef __rtems__
+static ssize_t
+rtems_bsd_pipe_write(rtems_libio_t *iop, const void *buffer, size_t count)
+ .iov_base = __DECONST(void *, buffer),
+ .iov_len = count
+ .uio_iov = &iov,
+ .uio_iovcnt = 1,
+ .uio_offset = 0,
+ .uio_rw = UIO_WRITE,
+ .uio_td = td
+ int error;
+ if (td != NULL) {
+ error = pipe_write(fp, &auio, NULL, 0, NULL);
+ } else {
+ error = ENOMEM;
+ if (error == 0) {
+ } else {
/* ARGSUSED */
+#ifndef __rtems__
static int
pipe_truncate(fp, length, active_cred, td)
struct file *fp;
@@ -1262,6 +1419,7 @@ pipe_truncate(fp, length, active_cred, td)
return (EINVAL);
* we implement a very minimal set of ioctls for compatibility with sockets.
@@ -1336,6 +1494,23 @@ pipe_ioctl(fp, cmd, data, active_cred, td)
out_unlocked:
return (error);
+#ifdef __rtems__
+static int
+rtems_bsd_pipe_ioctl(rtems_libio_t *iop, ioctl_command_t request, void *buffer)
+ int error;
+ if (td != NULL) {
+ error = pipe_ioctl(fp, request, buffer, NULL, td);
+ } else {
+ error = ENOMEM;
+ return rtems_bsd_error_to_status_and_errno(error);
static int
pipe_poll(fp, events, active_cred, td)
@@ -1400,11 +1575,29 @@ locked_error:
return (revents);
+#ifdef __rtems__
+static int
+rtems_bsd_pipe_poll(rtems_libio_t *iop, int events)
+ int error;
+ if (td != NULL) {
+ error = pipe_poll(fp, events, NULL, td);
+ } else {
+ error = ENOMEM;
+ return error;
* We shouldn't need locks here as we're doing a read and this should
* be a natural race.
+#ifndef __rtems__
static int
pipe_stat(fp, ub, active_cred, td)
struct file *fp;
@@ -1413,12 +1606,19 @@ pipe_stat(fp, ub, active_cred, td)
struct thread *td;
struct pipe *pipe;
+static int
+pipe_stat(struct pipe *pipe, struct stat *ub)
int new_unr;
#ifdef MAC
int error;
#endif
+#ifndef __rtems__
pipe = fp->f_data;
PIPE_LOCK(pipe);
#ifdef MAC
error = mac_pipe_check_stat(active_cred, pipe->pipe_pair);
@@ -1446,7 +1646,9 @@ pipe_stat(fp, ub, active_cred, td)
PIPE_UNLOCK(pipe);
+#ifndef __rtems__
bzero(ub, sizeof(*ub));
ub->st_mode = S_IFIFO;
ub->st_blksize = PAGE_SIZE;
if (pipe->pipe_state & PIPE_DIRECTW)
@@ -1457,15 +1659,35 @@ pipe_stat(fp, ub, active_cred, td)
ub->st_atim = pipe->pipe_atime;
ub->st_mtim = pipe->pipe_mtime;
ub->st_ctim = pipe->pipe_ctime;
+#ifndef __rtems__
ub->st_uid = fp->f_cred->cr_uid;
ub->st_gid = fp->f_cred->cr_gid;
ub->st_dev = pipedev_ino;
ub->st_ino = pipe->pipe_ino;
+ ub->st_uid = BSD_DEFAULT_UID;
+ ub->st_gid = BSD_DEFAULT_GID;
+ ub->st_dev = rtems_filesystem_make_dev_t(0xcc494cd6U, 0x1d970b4dU);
+ ub->st_ino = pipe->pipe_ino;
* Left as 0: st_nlink, st_rdev, st_flags, st_gen.
return (0);
+#ifdef __rtems__
+static int
+rtems_bsd_pipe_stat(
+ const rtems_filesystem_location_info_t *loc,
+ struct stat *buf
+ struct pipe *pipe = rtems_bsd_loc_to_f_data(loc);
+ int error = pipe_stat(pipe, buf);
/* ARGSUSED */
static int
@@ -1475,7 +1697,11 @@ pipe_close(fp, td)
struct pipe *cpipe = fp->f_data;
+#ifndef __rtems__
fp->f_ops = &badfileops;
+ fp->f_io.pathinfo.handlers = &rtems_filesystem_handlers_default;
fp->f_data = NULL;
funsetown(&cpipe->pipe_sigio);
pipeclose(cpipe);
@@ -1492,9 +1718,13 @@ pipe_free_kmem(cpipe)
if (cpipe->pipe_buffer.buffer != NULL) {
atomic_subtract_long(&amountpipekva, cpipe->pipe_buffer.size);
+#ifndef __rtems__
vm_map_remove(pipe_map,
(vm_offset_t)cpipe->pipe_buffer.buffer,
(vm_offset_t)cpipe->pipe_buffer.buffer + cpipe->pipe_buffer.size);
+ free(cpipe->pipe_buffer.buffer, M_TEMP);
cpipe->pipe_buffer.buffer = NULL;
@@ -1626,6 +1856,15 @@ pipe_kqfilter(struct file *fp, struct knote *kn)
PIPE_UNLOCK(cpipe);
return (0);
+#ifdef __rtems__
+int
+rtems_bsd_pipe_kqfilter(rtems_libio_t *iop, struct knote *kn)
+ return pipe_kqfilter(fp, kn);
static void
@@ -1687,3 +1926,35 @@ filt_pipewrite(struct knote *kn, long hint)
PIPE_UNLOCK(rpipe);
return (kn->kn_data >= PIPE_BUF);
+#ifdef __rtems__
+static int
+rtems_bsd_pipe_open(rtems_libio_t *iop, const char *path, int oflag,
+ mode_t mode)
+ return rtems_bsd_error_to_status_and_errno(ENXIO);
+static int
+rtems_bsd_pipe_close(rtems_libio_t *iop)
+ int error = pipe_close(fp, NULL);
+static int
+rtems_bsd_pipe_fcntl(rtems_libio_t *iop, int cmd)
+ int error = 0;
+ if (cmd == F_SETFL) {
+ int nbio = iop->flags & LIBIO_FLAGS_NO_DELAY;
+ error = pipe_ioctl(fp, FIONBIO, &nbio, NULL, NULL);
1.9.1
