QT 5.8 Port
Kirspel, Kevin
Kevin-Kirspel at idexx.com
Wed Dec 7 19:28:52 UTC 2016
It's because it is a new file as far as the rtems-libbsd/freebsd/ git tree is concerned. I did a "git add" on the new pipe files.
Kevin Kirspel
Electrical Engineer - Sr. Staff
Idexx Roswell
235 Hembree Park Drive
Roswell GA 30076
Tel: (770)-510-4444 ext. 81642
Direct: (770)-688-1642
Fax: (770)-510-4445
From: Jennifer Averett [mailto:Jennifer.Averett at OARcorp.com]
Sent: Wednesday, December 07, 2016 1:56 PM
To: Kirspel, Kevin <Kevin-Kirspel at idexx.com>
Subject: RE: QT 5.8 Port
Just a guess but you have probably converted the file to dos format thus the entire file looks different
run dos2unix on the file then try the diff.
Jennifer Averett
On-Line Applications Research
________________________________
From: devel [devel-bounces at rtems.org] On Behalf Of Kirspel, Kevin [Kevin-Kirspel at idexx.com]
Sent: Wednesday, December 07, 2016 12:49 PM
To: devel at rtems.org<mailto:devel at rtems.org>
Subject: QT 5.8 Port
I'm porting QT 5.8 to RTEMS 4.12 and rtems-libbsd. I had to add pipe support to rtems-libbsd. I would like to submit the pipe patch but the "git diff" is long due to the fact that the diff includes the entire file contents of the modified sys_pipe.c and pipe.h files. How do you usually submit patches for review for rtems-libbsd?
Kevin Kirspel
Idexx Roswell
Roswell GA 30076
Fax: (770)-510-4445
URL: <http://lists.rtems.org/pipermail/devel/attachments/20161207/e2613657/attachment-0002.html>
