Newlib and GCC Update for RTEMS 4.12
Fri Dec 23 17:41:26 UTC 2016
Thanks Sebastian.
I have some patches to RTEMS coming which require the new newlib. I don't
plan to add autoconf logic to disable it when the old tools are in use.
I am also nibbling at removing some of the similar logic added during the
SMP work.
--joel
On Dec 23, 2016 7:54 AM, "Sebastian Huber" <
> Hello,
> I updated the RSB to use Newlib 2.5.0 with this patch
> https://sourceware.org/ml/newlib/2016/msg01190.html
> and GCC 6.3.0 (or1k GCC 4.9.3, epiphany GCC 4.9.2). All users of the RTEMS
> master should update their tool chains. This tool set is a hot candidate
> for the RTEMS 4.12 release.
> devel mailing list
> devel at rtems.org
URL: <http://lists.rtems.org/pipermail/devel/attachments/20161223/d789bcb4/attachment-0002.html>
