POSIX compliance development
Saeed Ehteshamifar
salpha.2004 at gmail.com
Wed Dec 28 10:49:20 UTC 2016
> Do you have a list of the methods?
Yes.
https://drive.google.com/file/d/0BzwRg-R9g_6tY3dfYjBfQUppMzhIRnpXRWNzU0JQa1ZlUHZV/view?usp=sharing
and
https://drive.google.com/file/d/0BzwRg-R9g_6tRG56OFk0SmxLS3pucVRKTjd6ckpXNm1kUmFJ/view?usp=sharing
I was surprised hearing POSIX 1003-2013 has ~1300 functions! These lists
are ~350-lines long.
> Are the list of unimplemented functions in docs + rtems_face.csv up to
> date? Can I depend solely on it to remove unsupported test cases? Or it's
> better to go through RTEMS source code to check if a certain function is
> implemented?
> I think it is largely correct but some methods have been added and Gedare
> is about to commit some mmap methods.
> You can't solely go through RTEMS source code because many of the methods
> are provided by newlib.
> Also there are methods missing which should be in newlib eventually.
Right.
> Is there a middle ground of disabling them?
I think the middle ground is writing the script as I proposed. One extreme
is to completely remove unsupported functions (even those that might be
supported in the future!) from the functions list. The other extreme is to
let all in, encounter a "not-defined" compile error, and resolve it by
removing the corresponding test case (difficult).
>> --joel
>>> On Thu, Dec 15, 2016 at 9:29 AM, Saeed Ehteshamifar
>>> <salpha.2004 at gmail.com> wrote:
>>> > Hello,
>>> > For Slingshot, an RTEMS-targeted fault-injection tool for the POSIX
>>> API, I
>>> > need to remove the tests that correspond to
>>> unimplemented/unimplementable
>>> > POSIX functions/constants/etc. I can either
>>> > 1. write a script that searches for "Unimplemented" and
>>> "Unimplementable" in
>>> > the doc's source, and removes the corresponding function's test cases
>>> every
>>> > time after generating test cases or,
>>> > 2. manually delete all unimplemented/unimplementable from the
>>> Slingshot core
>>> > so that they aren't generated at all.
>>> > Now the question is: Apart from unimplementable functions, is there any
>>> > direction to implement unimplemented parts beyond the current
>>> situation?
>>> > Cause in that case, I think writing a script is a better option.
>>> > Best Regards,
>>> > Saeed
>>> > _______________________________________________
>>> > devel mailing list
>>> > devel at rtems.org
>>> > http://lists.rtems.org/mailman/listinfo/devel
>>> devel mailing list
>>> devel at rtems.org
URL: <http://lists.rtems.org/pipermail/devel/attachments/20161228/bd675e5e/attachment-0002.html>
