[PATCH 06/13] m68k: Avoid SCORE_EXTERN
Thu Feb 4 06:37:36 UTC 2016
Update #2559.
 cpukit/score/cpu/m68k/cpu.c             | 33 +++++++++++++++++++++++++++++++++
 cpukit/score/cpu/m68k/rtems/score/cpu.h | 29 +----------------------------
 2 files changed, 34 insertions(+), 28 deletions(-)
diff --git a/cpukit/score/cpu/m68k/cpu.c b/cpukit/score/cpu/m68k/cpu.c
index ad46c10..c50a63f 100644
--- a/cpukit/score/cpu/m68k/cpu.c
+++ b/cpukit/score/cpu/m68k/cpu.c
@@ -21,6 +21,39 @@
 #include <rtems/score/tls.h>
+#if ( M68K_HAS_VBR == 0 )
+ * Table of ISR handler entries that resides in RAM. The FORMAT/ID is
+ * pushed onto the stack. This is not is the same order as VBR processors.
+ * The ISR handler takes the format and uses it for dispatching the user
+ * handler.
+typedef struct {
+  uint16_t   move_a7;            /* move #FORMAT_ID,%a7 at - */
+  uint16_t   format_id;
+  uint16_t   jmp;                /* jmp  _ISR_Handlers */
+  uint32_t   isr_handler;
+} _CPU_ISR_handler_entry;
+#define M68K_MOVE_A7 0x3F3C
+#define M68K_JMP     0x4EF9
+/* points to jsr-exception-table in targets wo/ VBR register */
+static _CPU_ISR_handler_entry
+_CPU_ISR_jump_table[ CPU_INTERRUPT_NUMBER_OF_VECTORS ];
+#endif /* M68K_HAS_VBR */
+#if (M68K_HAS_FPSP_PACKAGE == 1)
+int (*_FPSP_install_raw_handler)(
+  uint32_t   vector,
+  proc_ptr new_handler,
+  proc_ptr *old_handler
+#endif
 #if defined( __mcoldfire__ ) && ( M68K_HAS_FPU == 1 )
   uint32_t _CPU_cacr_shadow;
 #endif
diff --git a/cpukit/score/cpu/m68k/rtems/score/cpu.h b/cpukit/score/cpu/m68k/rtems/score/cpu.h
index 8e0efa1..06d711a 100644
--- a/cpukit/score/cpu/m68k/rtems/score/cpu.h
+++ b/cpukit/score/cpu/m68k/rtems/score/cpu.h
@@ -313,33 +313,6 @@ typedef struct {
 extern void*                     _VBR;
-#if ( M68K_HAS_VBR == 0 )
- * Table of ISR handler entries that resides in RAM. The FORMAT/ID is
- * pushed onto the stack. This is not is the same order as VBR processors.
- * The ISR handler takes the format and uses it for dispatching the user
- * handler.
- * FIXME : should be moved to below CPU_INTERRUPT_NUMBER_OF_VECTORS
-typedef struct {
-  uint16_t   move_a7;            /* move #FORMAT_ID,%a7 at - */
-  uint16_t   format_id;
-  uint16_t   jmp;                /* jmp  _ISR_Handlers */
-  uint32_t   isr_handler;
-} _CPU_ISR_handler_entry;
-#define M68K_MOVE_A7 0x3F3C
-#define M68K_JMP     0x4EF9
-      /* points to jsr-exception-table in targets wo/ VBR register */
-SCORE_EXTERN _CPU_ISR_handler_entry _CPU_ISR_jump_table[256];
-#endif /* M68K_HAS_VBR */
 #endif /* ASM */
 /* constants */
@@ -764,7 +737,7 @@ static inline CPU_Counter_ticks _CPU_Counter_difference(
 void M68KFPSPInstallExceptionHandlers (void);
-SCORE_EXTERN int (*_FPSP_install_raw_handler)(
+extern int (*_FPSP_install_raw_handler)(
   uint32_t   vector,
1.8.4.5
