Python problem
Jason Wong
jason.hcwong at gmail.com
Thu Feb 11 21:41:50 UTC 2016
I am using Ubuntu 14.04.
After removing package "libpython2.7-dev:amd64" and "python2.7-dev",
I got following error message in
"rsb-report-sparc-rtems4.12-gdb-7.9-x86_64-linux-gnu-1.txt":
checking for python... /usr/bin/python
checking for python2.7... no
configure: error: python is missing or unusable
make[1]: *** [configure-gdb] Error 1
make[1]: Leaving directory
`/data/jason/rtems/rtems-source-builder/rtems/build/sparc-rtems4.12-gdb-7.9-x86_64-linux-gnu-1/build'
make: *** [all] Error 2
shell cmd failed: /bin/sh -ex
/data/jason/rtems/rtems-source-builder/rtems/build/sparc-rtems4.12-gdb-7.9-x86_64-linux-gnu-1/doit
error: building sparc-rtems4.12-gdb-7.9-x86_64-linux-gnu-1
A more detailed config log can be found at
"build/sparc-rtems4.12-gdb-7.9-x86_64-linux-gnu-1/build/gdb/config.log".
I think it is what joel is asking for.
Error message in
"build/sparc-rtems4.12-gdb-7.9-x86_64-linux-gnu-1/build/gdb/config.log":
configure:8265: result: /usr/bin/python
configure:8403: checking for python2.7
configure:8421: /usr/bin/gcc -O2 -pipe
-I/data/jason/rtems/rtems-source-builder/rtems/build/tmp/sb-jason/4.12/rtems-sparc/data/jason/rtems/4.12/include
-o conftest -g -O2
-I/usr/include/python2.7 -I/usr/include/python2.7 -static-libstdc++
-static-libgcc
-L/data/jason/rtems/rtems-source-builder/rtems/build/tmp/sb-jason/4.12/rtems-sparc/data/jason/rtems/4.12/lib
conftest.c -ldl -lncurses -lm -ldl -lpthread -ldl -lutil -lm -lpython2.7
-Xlinker -export-dynamic -Wl,-O1 -Wl,-Bsymbolic-functions >&5
conftest.c:51:20: fatal error: Python.h: No such file or directory
#include "Python.h"
compilation terminated.
configure:8421: $? = 1
Regards,
Jason Wong
On 11 February 2016 at 19:44, punit vara <punitvara at gmail.com> wrote:
> On Wed, Feb 10, 2016 at 11:45 PM, Joel Sherrill <joel at rtems.org> wrote:
> > We need the config.log from the subdirectory where the failure occurred.
> > This looks like one from the top directory,
> > Look at the build log to see what directory the build failed in and grab
> > that one.
> > FWIW a quick google for this issue on Ubuntu showed someone suggested:
> > sudo apt-get install python-dev
> > Have you done that?
> > --joel
> > On Wed, Feb 10, 2016 at 11:50 AM, punit vara <punitvara at gmail.com>
> wrote:
> >> On Tue, Feb 9, 2016 at 8:21 PM, Joel Sherrill <joel at rtems.org> wrote:
> >> > On Tue, Feb 9, 2016 at 8:15 AM, punit vara <punitvara at gmail.com>
> wrote:
> >> >> On Tue, Feb 9, 2016 at 6:56 PM, Aun-Ali Zaidi <admin at kodeit.net>
> wrote:
> >> >> > Hi,
> >> >> > I was having the same problem yesterday and managed to find a fix
> by
> >> >> > installing libpython2.7-dev:
> >> >> > sudo apt-get install libpython2.7-dev
> >> >> > Aun-Ali Zaidi
> >> >> Thanks Aun-Ali. I have tried but again I am getting same error.
> >> >> Because this package would get installed when you install
> >> >> python2.7-dev
> >> > Can you look in the config.log for gdb where the failure occurred? Or
> >> > even
> >> > at the configure.in/ac script in its source. It is looking for a very
> >> > specific
> >> > file to link against and failing.
> >> > yum have a "provides" subcommand to search for which package provides
> >> > a specific file. Apt must have a similar capability.
> >> > So you can figure out the file gdb needs to link and the corresponding
> >> > package which includes it.
> >> > --joel
> >> >> _______________________________________________
> >> >> devel mailing list
> >> >> devel at rtems.org
> >> >> http://lists.rtems.org/mailman/listinfo/devel
> >> Yes I agree with you Joel. From line 129 I found errors if you can
> >> help me out. Perhaps somebody can help me I am attaching config.log
> >> file from
> /home/punit/development/rtems/src/rtems-source-builder/rtems/build/arm-rtems4.12-gdb-7.9-x86_64-linux-gnu-1/build
> Yes I tried that before but same error. I am attaching log file I
> have sent config.log from failure subdirectory. I have provided
> location in previous mail which is the same as shown in this log file.
> If I am wrong let me.
> Thanks for support.
> devel mailing list
> devel at rtems.org
Regards,
Jason Wong
URL: <http://lists.rtems.org/pipermail/devel/attachments/20160211/e2c9cf44/attachment.html>
