Python problem
Jason Wong
jason.hcwong at gmail.com
Fri Feb 12 22:22:59 UTC 2016
Although I suspect that the reason you cannot install python2.7-dev is that
you have already installed python2.7-dev:i386 which is conflict with
python2.7-dev:amd64, you should show the error message when you are trying
to install python2.7-dev to make things clearer.
On 12 February 2016 at 22:38, punit vara <punitvara at gmail.com> wrote:
> On Fri, Feb 12, 2016 at 3:21 AM, Jason Wong <jason.hcwong at gmail.com>
> wrote:
> > I am using a docker image running Ubuntu 15.10, I have no problem
> installing
> > both "python2.7-dev" and "libpython2.7-dev".
> > According to apt-cache, "python2.7-dev" depends on "python2.7".
> > If you install "python2.7-dev", then "python2.7" should be automatically
> > installed.
> > Perhaps you should show us the message you got when you try to install
> > "python2.7-dev", and you should also report the problem to ubuntu
> community
> > as well.
> > root at c0e8f7d4cae3:/# apt-cache depends python2.7-dev
> > python2.7-dev
> > Depends: python2.7
> > Depends: libpython2.7-dev
> > Depends: libexpat1-dev
> > |Recommends: libc6-dev
> > Recommends: <libc-dev>
> > libc6-dev
> > Replaces: python2.7
> > On 11 February 2016 at 19:44, punit vara <punitvara at gmail.com> wrote:
> >> On Wed, Feb 10, 2016 at 11:45 PM, Joel Sherrill <joel at rtems.org> wrote:
> >> > We need the config.log from the subdirectory where the failure
> occurred.
> >> > This looks like one from the top directory,
> >> > Look at the build log to see what directory the build failed in and
> grab
> >> > that one.
> >> > FWIW a quick google for this issue on Ubuntu showed someone suggested:
> >> > sudo apt-get install python-dev
> >> > Have you done that?
> >> > --joel
> >> > On Wed, Feb 10, 2016 at 11:50 AM, punit vara <punitvara at gmail.com>
> >> > wrote:
> >> >> On Tue, Feb 9, 2016 at 8:21 PM, Joel Sherrill <joel at rtems.org>
> wrote:
> >> >> > On Tue, Feb 9, 2016 at 8:15 AM, punit vara <punitvara at gmail.com>
> >> >> > wrote:
> >> >> >> On Tue, Feb 9, 2016 at 6:56 PM, Aun-Ali Zaidi <admin at kodeit.net>
> >> >> >> wrote:
> >> >> >> > Hi,
> >> >> >> > I was having the same problem yesterday and managed to find a
> fix
> >> >> >> > by
> >> >> >> > installing libpython2.7-dev:
> >> >> >> > sudo apt-get install libpython2.7-dev
> >> >> >> > Aun-Ali Zaidi
> >> >> >> Thanks Aun-Ali. I have tried but again I am getting same error.
> >> >> >> Because this package would get installed when you install
> >> >> >> python2.7-dev
> >> >> > Can you look in the config.log for gdb where the failure occurred?
> Or
> >> >> > even
> >> >> > at the configure.in/ac script in its source. It is looking for a
> very
> >> >> > specific
> >> >> > file to link against and failing.
> >> >> > yum have a "provides" subcommand to search for which package
> provides
> >> >> > a specific file. Apt must have a similar capability.
> >> >> > So you can figure out the file gdb needs to link and the
> >> >> > corresponding
> >> >> > package which includes it.
> >> >> > --joel
> >> >> >> _______________________________________________
> >> >> >> devel mailing list
> >> >> >> devel at rtems.org
> >> >> >> http://lists.rtems.org/mailman/listinfo/devel
> >> >> Yes I agree with you Joel. From line 129 I found errors if you can
> >> >> help me out. Perhaps somebody can help me I am attaching config.log
> >> >> file from
> /home/punit/development/rtems/src/rtems-source-builder/rtems/build/arm-rtems4.12-gdb-7.9-x86_64-linux-gnu-1/build
> >> Yes I tried that before but same error. I am attaching log file I
> >> have sent config.log from failure subdirectory. I have provided
> >> location in previous mail which is the same as shown in this log file.
> >> If I am wrong let me.
> >> Thanks for support.
> >> devel mailing list
> >> devel at rtems.org
> > Regards,
> > Jason Wong
> root at punit-Compaq-420:~# apt-cache depends python2.7-dev
> python2.7-dev
> Depends: python2.7
> libc6-dev
> Replaces: python2.7
> Replaces: python2.7:i386
> Conflicts: python2.7-dev:i386
> Thanks Jason this is really helpful. I am attaching log file as well .
> How did you solve python missing error. I have found some linking
> error and some header file error. Please look into it. I have already
> asked to ubuntu community but not yet got any answer.
Regards,
Jason Wong
URL: <http://lists.rtems.org/pipermail/devel/attachments/20160212/0f11ba98/attachment.html>
