[PATCH 4/7] i386: relocate fatal halt to bsp layer
Mon Feb 15 19:05:41 UTC 2016
 c/src/lib/libbsp/i386/pc386/Makefile.am              |  1 +
 c/src/lib/libbsp/i386/pc386/startup/bsp_fatal_halt.c | 20 ++++++++++++++++++++
 cpukit/score/cpu/i386/rtems/score/cpu.h              | 11 ++---------
 3 files changed, 23 insertions(+), 9 deletions(-)
 create mode 100644 c/src/lib/libbsp/i386/pc386/startup/bsp_fatal_halt.c
diff --git a/c/src/lib/libbsp/i386/pc386/Makefile.am b/c/src/lib/libbsp/i386/pc386/Makefile.am
index 75a56c9..1d52cf4 100644
--- a/c/src/lib/libbsp/i386/pc386/Makefile.am
+++ b/c/src/lib/libbsp/i386/pc386/Makefile.am
@@ -147,6 +147,7 @@ libbsp_a_SOURCES += ../../i386/shared/pci/pcibios.c \
 include_HEADERS += ../../i386/shared/comm/uart.h
 # startup
 libbsp_a_SOURCES += ../../shared/bsppredriverhook.c
+libbsp_a_SOURCES += startup/bsp_fatal_halt.c
 libbsp_a_SOURCES += startup/bspgetworkarea.c
 libbsp_a_SOURCES += startup/bspidle.S
 libbsp_a_SOURCES += startup/bspstart.c
diff --git a/c/src/lib/libbsp/i386/pc386/startup/bsp_fatal_halt.c b/c/src/lib/libbsp/i386/pc386/startup/bsp_fatal_halt.c
new file mode 100644
index 0000000..c9830f6
--- /dev/null
+++ b/c/src/lib/libbsp/i386/pc386/startup/bsp_fatal_halt.c
@@ -0,0 +1,20 @@
+ *  COPYRIGHT (c) 2016.
+ *  On-Line Applications Research Corporation (OAR).
+ *  The license and distribution terms for this file may be
+ *  found in the file LICENSE in this distribution or at
+ *  http://www.rtems.org/license/LICENSE.
+#include <bsp.h>
+void _CPU_Fatal_halt(uint32_t source, uint32_t error)
+  uint32_t _error_lvalue = ( _error );
+  __asm__ volatile (
+         "cli ; movl %0,%%eax ; hlt"
+         : "=r" ((_error_lvalue))
+         : "0" ((_error_lvalue))
diff --git a/cpukit/score/cpu/i386/rtems/score/cpu.h b/cpukit/score/cpu/i386/rtems/score/cpu.h
index 2a1b95b..3513650 100644
--- a/cpukit/score/cpu/i386/rtems/score/cpu.h
+++ b/cpukit/score/cpu/i386/rtems/score/cpu.h
@@ -529,15 +529,8 @@ uint32_t   _CPU_ISR_Get_level( void );
  *    + disable interrupts and halt the CPU
-#define _CPU_Fatal_halt( _source, _error ) \
-    uint32_t _error_lvalue = ( _error ); \
-    __asm__ volatile ( "cli ; \
-                    movl %0,%%eax ; \
-                    hlt" \
-                    : "=r" ((_error_lvalue)) : "0" ((_error_lvalue)) \
+extern void _CPU_Fatal_halt(uint32_t source, uint32_t error)
+  RTEMS_NO_RETURN;
 #endif /* ASM */
1.9.1
