[PATCH] score: Simplify _Watchdog_Tick()
    Sebastian Huber
    Wed Feb 17 11:54:05 UTC 2016
Move thread dispatch disable check to legacy rtems_clock_tick().  Assert
that thread dispatching is disabled in _Watchdog_Tick().  This is
usually the case, since this function is called in interrupt context by
the clock tick service routine.
 cpukit/rtems/src/clocktick.c    | 5 +++++
 cpukit/score/src/watchdogtick.c | 8 ++++----
 2 files changed, 9 insertions(+), 4 deletions(-)
diff --git a/cpukit/rtems/src/clocktick.c b/cpukit/rtems/src/clocktick.c
index a6bf26d..df8012e 100644
--- a/cpukit/rtems/src/clocktick.c
+++ b/cpukit/rtems/src/clocktick.c
@@ -20,6 +20,7 @@
 #include <rtems/rtems/clock.h>
 #include <rtems/score/timecounter.h>
+#include <rtems/score/threadimpl.h>
 rtems_status_code rtems_clock_tick( void )
@@ -32,5 +33,9 @@ rtems_status_code rtems_clock_tick( void )
     &lock_context
+  if ( _Thread_Dispatch_is_enabled() ) {
+    _Thread_Dispatch();
   return RTEMS_SUCCESSFUL;
diff --git a/cpukit/score/src/watchdogtick.c b/cpukit/score/src/watchdogtick.c
index b9bc3f7..cb68ea2 100644
--- a/cpukit/score/src/watchdogtick.c
+++ b/cpukit/score/src/watchdogtick.c
@@ -12,8 +12,9 @@
  * http://www.rtems.org/license/LICENSE.
+#include <rtems/score/assert.h>
-#include <rtems/score/threadimpl.h>
+#include <rtems/score/threaddispatch.h>
@@ -23,12 +24,11 @@
 void _Watchdog_Tick( void )
+  _Assert( !_Thread_Dispatch_is_enabled() );
   _TOD_Tickle_ticks();
   _Watchdog_Tickle_ticks();
   _Scheduler_Tick();
-  if ( _Thread_Dispatch_is_enabled() )
-    _Thread_Dispatch();
1.8.4.5
