[PATCH 7/7] Add more OR1k machine types and correct OR1k configure subdir
Fri Feb 19 13:06:30 UTC 2016
On 19/02/16 13:52, Jakob Viketoft wrote:
> ________________________________________
> From: Sebastian Huber [sebastian.huber at embedded-brains.de]
> Sent: Friday, February 19, 2016 13:36
> To: Jakob Viketoft;devel at rtems.org
> Subject: Re: [PATCH 7/7] Add more OR1k machine types and correct OR1k configure subdir
>> >On 19/02/16 10:34, Jakob Viketoft wrote:
>>> >>diff --git a/config.sub b/config.sub
>>> >>index 8b612ab..fbeac69 100755
>>> >>--- a/config.sub
>>> >>+++ b/config.sub
>>> >>@@ -296,7 +296,7 @@ case $basic_machine in
>>> >>       | nios | nios2 | nios2eb | nios2el \
>>> >>       | ns16k | ns32k \
>>> >>       | open8 \
>>> >>-     | or1k | or32 \
>>> >>+     | or1k | or32 | or1k-* \
>>> >>       | pdp10 | pdp11 | pj | pjl \
>>> >>       | powerpc | powerpc64 | powerpc64le | powerpcle \
>>> >>       | pyramid \
>> >Why do you need this change?
> We roll our own toolchain with a number of smaller changes as we need to put them in and to make that distinction clear, we have it named or1k-aac-rtems4.11-*. This is identified as the machine in RTEMS and won't map to or1k properly unless we add these extra identifiers. I pushed this in an effort to go towards more upstream, but you are right in that it's not required for the generic_or1k to build with a standard RSB toolchain.
Why can't you use the standard RSB tool chain?
Patches to config.sub should go into the config.sub upstream first. Then
we can update the complete file from it. See commit log of this file.
Phone   : +49 89 189 47 41-16
Fax     : +49 89 189 47 41-09
