[PATCH] arm: Fixed typo in file bbb-gpio.c
punitvara punitvara at gmail.com
Fri Feb 19 18:24:03 UTC 2016
	This patch fixes typo "moode".
	Signed-off: Punit Vara <punitvara at gmail.com>
 c/src/lib/libbsp/arm/beagle/gpio/bbb-gpio.c | 2 +-
 1 file changed, 1 insertion(+), 1 deletion(-)
diff --git a/c/src/lib/libbsp/arm/beagle/gpio/bbb-gpio.c b/c/src/lib/libbsp/arm/beagle/gpio/bbb-gpio.c
index 2a3f7e8..8532f54 100644
--- a/c/src/lib/libbsp/arm/beagle/gpio/bbb-gpio.c
+++ b/c/src/lib/libbsp/arm/beagle/gpio/bbb-gpio.c
@@ -269,7 +269,7 @@ rtems_status_code rtems_gpio_bsp_set_resistor_mode(
   uint32_t pin,
   rtems_gpio_pull_mode mode
-  /* TODO: Add support for setting up resistor moode */
+  /* TODO: Add support for setting up resistor mode */
   return RTEMS_NOT_DEFINED;
1.9.1
