[PATCH] _ARMV7M_Is_vector_an_irq: Use ARMV7M_VECTOR_SYSTICK instead of hardcoded 16
Joel Sherrill
joel at rtems.org
Fri Feb 19 22:14:02 UTC 2016
This should be committed now. Thanks.
On Fri, Feb 19, 2016 at 8:32 AM, Martin Galvan <
martin.galvan at tallertechnologies.com> wrote:
> Also add a comment explaining why we use that value.
> cpukit/score/cpu/arm/rtems/score/armv7m.h | 3 ++-
> 1 file changed, 2 insertions(+), 1 deletion(-)
> diff --git a/cpukit/score/cpu/arm/rtems/score/armv7m.h
> b/cpukit/score/cpu/arm/rtems/score/armv7m.h
> index 251ecdc..0a69363 100644
> --- a/cpukit/score/cpu/arm/rtems/score/armv7m.h
> +++ b/cpukit/score/cpu/arm/rtems/score/armv7m.h
> @@ -386,7 +386,8 @@ typedef struct {
> static inline bool _ARMV7M_Is_vector_an_irq( int vector )
> - return vector >= 16;
> + /* External (i.e. non-system) IRQs start after the SysTick vector. */
> + return vector > ARMV7M_VECTOR_SYSTICK;
> static inline uint32_t _ARMV7M_Get_basepri(void)
> 2.7.1
> devel mailing list
> devel at rtems.org
URL: <http://lists.rtems.org/pipermail/devel/attachments/20160219/abe02abd/attachment.html>
