[PATCH] arm: Fixed typo in file bbb-gpio.c
Joel Sherrill
joel at rtems.org
Fri Feb 19 22:14:34 UTC 2016
This should be committed now. Thanks.
On Fri, Feb 19, 2016 at 12:24 PM, punitvara <punitvara at gmail.com> wrote:
> This patch fixes typo "moode".
> Signed-off: Punit Vara <punitvara at gmail.com>
> c/src/lib/libbsp/arm/beagle/gpio/bbb-gpio.c | 2 +-
> 1 file changed, 1 insertion(+), 1 deletion(-)
> diff --git a/c/src/lib/libbsp/arm/beagle/gpio/bbb-gpio.c
> b/c/src/lib/libbsp/arm/beagle/gpio/bbb-gpio.c
> index 2a3f7e8..8532f54 100644
> --- a/c/src/lib/libbsp/arm/beagle/gpio/bbb-gpio.c
> +++ b/c/src/lib/libbsp/arm/beagle/gpio/bbb-gpio.c
> @@ -269,7 +269,7 @@ rtems_status_code rtems_gpio_bsp_set_resistor_mode(
> uint32_t pin,
> rtems_gpio_pull_mode mode
> - /* TODO: Add support for setting up resistor moode */
> + /* TODO: Add support for setting up resistor mode */
> return RTEMS_NOT_DEFINED;
> 1.9.1
> devel mailing list
> devel at rtems.org
URL: <http://lists.rtems.org/pipermail/devel/attachments/20160219/d3eb9eda/attachment.html>
