[PATCH] arm: Fixed typo in file bbb-gpio.c
punit vara punitvara at gmail.com
Sat Feb 20 06:29:02 UTC 2016
Your welcome Joel :-)
On Sat, Feb 20, 2016 at 3:44 AM, Joel Sherrill <joel at rtems.org> wrote:
> This should be committed now. Thanks.
> On Fri, Feb 19, 2016 at 12:24 PM, punitvara <punitvara at gmail.com> wrote:
>>         This patch fixes typo "moode".
>>         Signed-off: Punit Vara <punitvara at gmail.com>
>>  c/src/lib/libbsp/arm/beagle/gpio/bbb-gpio.c | 2 +-
>>  1 file changed, 1 insertion(+), 1 deletion(-)
>> diff --git a/c/src/lib/libbsp/arm/beagle/gpio/bbb-gpio.c
>> b/c/src/lib/libbsp/arm/beagle/gpio/bbb-gpio.c
>> index 2a3f7e8..8532f54 100644
>> --- a/c/src/lib/libbsp/arm/beagle/gpio/bbb-gpio.c
>> +++ b/c/src/lib/libbsp/arm/beagle/gpio/bbb-gpio.c
>> @@ -269,7 +269,7 @@ rtems_status_code rtems_gpio_bsp_set_resistor_mode(
>>    uint32_t pin,
>>    rtems_gpio_pull_mode mode
>> -  /* TODO: Add support for setting up resistor moode */
>> +  /* TODO: Add support for setting up resistor mode */
>>    return RTEMS_NOT_DEFINED;
>> 1.9.1
>> devel mailing list
>> devel at rtems.org
